Offline installation with calamares failing
Offline installer fails. Stuck at the unpacking iso step forever.
installer log from live session:
Hardware information:
Boot log:
Is there a reason you’re not doing a online install?
Mainly that I wanted the installation done faster.
@mOCHU035
There are 10 newer Bios updates for this laptop. I would suggest you update it. It may not be the exact reason for your issue but the updates are significant.
