Odroid N2 and Pinebook Pro have a problem with Pacman 7.0 when using the EnOS kernel linux-eos-arm.
With pacman 7.0, Archlinux has added the ability to use a sandbox with a new user and new group they added named alpm. I think this is supposed to restrict filesystem access to user alpm when doing updates.
When updating on Odroid N2 or Pinebook Pro with pacman or yay, the following error occurs.
error: restricting filesystem access failed because landlock is not supported by the kernel
I have edited the config file that the EnOS linux-eos-arm PKGBUILD uses from
# CONFIG_SECURITY_LANDLOCK is not set
to
CONFIG_SECURITY_LANDLOCK=y
The kernel re-compile did not fix the problem. It must need something else enabled besides LANDLOCK.
Archlinux ARM has already fixed the LANDLOCK problem on RPi 4b, and RPi 5 kernels.
So they are not affected. Archlinux ARM has also fixed the LANLOCK problem on it’s linux-aarch64 kernel.
So currently, the Odroid N2 and Pinebook Pro users have two choices.
- Use Archlinux ARM kernel linux-aarch64 instead of EnOS ARM kernel linux-eos-arm
- Use EnOS kernel linux-eos-arm and edit /etc/pacman.conf to uncomment the following line.
#DisableSandbox
and operate with the sand box disabled like Archlinux was before pacman 7.0
In the mean time, I will continue to look into getting kernel linux-eos-arm installed with
LANDLOCK enabled.
If there are any kernel GURUs out there that have any suggestions, please feel free to contact me in this Endeavour.
I do not know how much this pacman sandbox addition means security wise for the average home user. Maybe @dalto can clarify this.
Pudge
