Odd ldconfig logs in yay output
Recently I started getting these in the output of yay:
ldconfig: File /usr/lib/libmlt++-7.so.7 is empty, not checked.
ldconfig: File /usr/lib/libpoppler-qt6.so.3 is empty, not checked.
ldconfig: File /usr/lib/libmlt-7.so is empty, not checked.
ldconfig: File /usr/lib/libpoppler-qt6.so.3.11.0 is empty, not checked.
ldconfig: File /usr/lib/libhandle.so is empty, not checked.
ldconfig: File /usr/lib/libhandle.so.1.0.3 is empty, not checked.
ldconfig: File /usr/lib/libhandle.so.1 is empty, not checked.
ldconfig: File /usr/lib/libpoppler-qt6.so is empty, not checked.
ldconfig: File /usr/lib/libmlt++-7.so.7.32.0 is empty, not checked.
ldconfig: File /usr/lib/libmlt-7.so.7 is empty, not checked.
ldconfig: File /usr/lib/libmlt-7.so.7.32.0 is empty, not checked.
ldconfig: File /usr/lib/libmlt++-7.so is empty, not checked.
Should I be worried about them?
Yes, that usually indicates some type of file corruption.
It is telling you that your libraries are 0 bytes.
Any easy way to find and fix/reinstall those libs?
Sure, you can reinstall those packages. However, you need to wonder what other files are corrupted besides just those.
I am at work and can’t get you the exact command but there is a command that will validate all your package files.
Great to hear that, want to see if i have any corrupted files.
Check this link
From the link:
$ sudo LANG=C pacman -Qk | grep -v " 0 missing files"
is really helpful, but be careful with
$ sudo LANG=C pacman -Qkk | grep -v " 0 altered files"
It does a more thorough check, but also shows some files that have legit changes. These are mostly configuration files that have changed since the original install. So look closely.
Thanks @keescase for the pointer!
Seems to have been related to: System breaks after updating to dracut 108
Solution marked in that topic.
