Obs studio glitch recording
Hi guys,
I’m having a problem whit OBS. I’ve searched but haven’t found any solution.. Basically, when I start a screen recording everything goes fine but when I finish, and I’m going to open the file, it’s full of glitches/artifacts.
My hardware:
My hardware
Type: Desktop System: ASUS
Mobo: ASUSTeK model: TUF GAMING B850-PLUS WIFI v: Rev 1.xx
UEFI: American Megatrends v: 1028 date: 04/29/2025
Info: 8-core model: AMD Ryzen 7 9700X bits: 64 type: MT MCP smt: enabled
arch: Zen 5 rev: 0 cache: L1: 640 KiB L2: 8 MiB L3: 32 MiB
Speed (MHz): avg: 2326 min/max: 605/5582 boost: enabled cores: 1: 2326
2: 2326 3: 2326 4: 2326 5: 2326 6: 2326 7: 2326 8: 2326 9: 2326 10: 2326
11: 2326 12: 2326 13: 2326 14: 2326 15: 2326 16: 2326 bogomips: 121604
Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a
ssse3 svm
Device-1: NVIDIA GB203 [GeForce RTX 5070 Ti] vendor: Micro-Star MSI
driver: nvidia v: 580.105.08 arch: Lovelace pcie: speed: 2.5 GT/s lanes: 16
ports: active: DP-2 empty: DP-3,DP-4,HDMI-A-2
Device-2: Advanced Micro Devices [AMD/ATI] Granite Ridge [Radeon Graphics]
vendor: ASUSTeK driver: amdgpu v: kernel: RDNA-2 pcie: speed: 16 GT/s
lanes: 16 ports: active: none empty: DP-1,HDMI-A-1,Writeback-1
Display: wayland server: Xwayland v: 24.1.9 compositor: gnome-shell
driver: gpu: nv_platform,nvidia,nvidia-nvswitch display-ID: 0
Monitor-1: DP-2 model: MSI MAG274Q QD E2 serial: res: 2560x1440
dpi: 108 size: 597x336mm (23.5x13.23") diag: 685mm (27") modes:
max: 2560x1440 min: 640x480
API: EGL Message: EGL data requires eglinfo. Check --recommends.
Info: Tools: gpu: nvidia-settings,nvidia-smi x11: xprop,xrandr
Device-1: NVIDIA GB203 High Definition Audio driver: snd_hda_intel v: kernel
Device-2: Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio
[Rembrandt/Strix] vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
speed: 16 GT/s lanes: 16
Device-3: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio
vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: speed: 16 GT/s
lanes: 16
API: ALSA v: k6.17.8-arch1-1 status: kernel-api
Server-1: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin
Device-1: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
pcie: speed: 5 GT/s lanes: 1 port: e000
Image about OBS rec
I hope someone can help me, thanks….
Make a short recording, then in the OBS menu Help → Show log files. Upload the latest log of that recording session here: https://obsproject.com/tools/analyzer#logFile
Do you have an example clip?
