Nvidia problems again!
The latest NVIDIA package 565.77-11 broke my system! It wouldn’t even make it to the log in screen! Just kept freezing before getting there. I managed to fix it by arch-chroot into the system, using the endeavoros live USB image and downgrading the NVIDIA 565.77-11 package. I was trying to use eos-shifttime in the arch-chroot environment but, it wouldn’t work. kept getting an error that wouldn’t let it run. If anybody knows how to run eos-shifttime in the arch-chroot environment, please tell me how its done. Fortunately I remembered that nvidia was one of the last four packages that were updated, and figured it was probably the problem! Is there a command that show what the last updated packages were? I was glad that the downgrade command worked!
you can check in /var/log/pacman
can you provide part mothertboard /cpu / gpu
inxi -Fza
Can you show your command and the full output in detail?
Yes, it is package pahis that probably is not installed by default so you need to install it first. Also other similar packages exist. For example:
pahis --upgraded
Alternatively you can look at file /var/log/pacman.log which contains the same info.
BTW, I’m using nvidia 565.77-11 without issues.
Kernel: 6.12.8-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
clocksource: tsc avail: hpet,acpi_pm
parameters: BOOT_IMAGE=/boot/vmlinuz-linux
root=UUID=2d474b2c-b235-4cf4-92a0-796532552719 rw nowatchdog
nvme_load=YES resume=UUID=a212dc32-5e69-4966-be95-3a85317d0b9d
nvidia_drm.modeset=1 nvidia_drm.fbdev=1 loglevel=3
Desktop: KDE Plasma v: 6.2.5 tk: Qt v: N/A info: frameworks v: 6.10.0
wm: kwin_wayland vt: 1 dm: SDDM Distro: EndeavourOS base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: X79-DELUXE v: Rev 1.xx
serial: part-nu: SKU uuid:
UEFI: American Megatrends v: 4805 date: 02/02/2016
Info: model: Intel Core i7-3930K bits: 64 type: MT MCP arch: Sandy Bridge
gen: core 3 level: v2 built: 2010-12 process: Intel 32nm family: 6
model-id: 0x2D (45) stepping: 7 microcode: 0x71A
Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 threads: 12 tpc: 2
smt: enabled cache: L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB
desc: 6x256 KiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1200 min/max: 1200/3800 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 1200 2: 1200 3: 1200 4: 1200 5: 1200 6: 1200
7: 1200 8: 1200 9: 1200 10: 1200 11: 1200 12: 1200 bogomips: 76882
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Vulnerabilities:
Type: gather_data_sampling status: Not affected
Type: itlb_multihit status: KVM: Split huge pages
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT
vulnerable
Type: mmio_stale_data status: Unknown: No mitigations
Type: reg_file_data_sampling status: Not affected
Type: spec_rstack_overflow status: Not affected
prctl
sanitization
Type: spectre_v2 mitigation: Retpolines; IBPB: conditional; IBRS_FW;
STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
affected
Device-1: NVIDIA TU106 [GeForce RTX 2060 Rev. A] vendor: eVga.com.
driver: nvidia v: 565.77 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-09; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 3 speed: 8 GT/s
lanes: 16 ports: active: none off: DP-1 empty: DP-2,DVI-D-1,HDMI-A-1
bus-ID: 01:00.0 chip-ID: 10de:1f08 class-ID: 0300
Display: wayland server: X.org v: 1.21.1.15 with: Xwayland v: 24.1.4
compositor: kwin_wayland driver: X: loaded: nvidia unloaded: modesetting
alternate: fbdev,nouveau,nv,vesa gpu: nvidia display-ID: 0
Monitor-1: DP-1 res: 1920x1080 size: N/A modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia gbm:
drv: nvidia surfaceless: drv: nvidia wayland: drv: nvidia x11: drv: nvidia
API: OpenGL v: 4.6.0 vendor: nvidia v: 565.77 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce RTX 2060/PCIe/SSE2
memory: 5.86 GiB display-ID: :1.0
API: Vulkan v: 1.4.303 layers: 1 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 2060 driver: N/A device-ID: 10de:1f08
surfaces: xcb,xlib,wayland
Device-1: Intel C600/X79 series High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1d20
class-ID: 0403
Device-2: NVIDIA TU106 High Definition Audio vendor: eVga.com.
driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
API: ALSA v: k6.12.8-arch1-1 status: kernel-api
Server-1: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
Device-1: Intel 82579V Gigabit Network vendor: ASUSTeK P8P67 Deluxe
driver: e1000e v: kernel port: f040 bus-ID: 00:19.0 chip-ID: 8086:1503
class-ID: 0200
IF: eno1 state: up speed: 1000 Mbps duplex: full mac:
Device-2: Broadcom BCM4352 802.11ac Dual Band Wireless Network Adapter
vendor: ASUSTeK driver: wl v: kernel modules: bcma pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 16:00.0 chip-ID: 14e4:43b1 class-ID: 0280
IF: wlan0 state: dormant mac:
Device-3: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
vendor: ASUSTeK AM1I-A driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: b000 bus-ID: 18:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp24s0 state: down mac:
Device-4: Realtek RTL8814AU 802.11a/b/g/n/ac Wireless Adapter
driver: rtl8814au type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 5-1.2:3 chip-ID: 0bda:8813 class-ID: 0000 serial:
IF: wlan1 state: dormant mac:
Info: services: NetworkManager, smbd, sshd, systemd-timesyncd,
wpa_supplicant
Bluetooth:
Device-1: ASUSTek BCM20702A0 driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 4-1.5:4 chip-ID: 0b05:17cf
class-ID: fe01 serial:
Report: btmgmt ID: hci0 rfk-id: 1 state: down bt-service: disabled
Local Storage: total: 3.3 TiB used: 21.16 GiB (0.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 2TB
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: fw-rev: 4B2QJXD7 temp: 27.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: fw-rev: 2B6Q scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD1001FALS-00Y6A0 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s tech: N/A serial: fw-rev: 1D05
scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 840 PRO Series
size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: SSD serial: fw-rev: 6B0Q scheme: GPT
ID-1: / raw-size: 109.44 GiB size: 107.16 GiB (97.92%)
used: 21.16 GiB (19.7%) fs: ext4 dev: /dev/sdc2 maj-min: 8:34
ID-2: /boot/efi raw-size: 1024 MiB size: 1022 MiB (99.80%)
used: 296 KiB (0.0%) fs: vfat dev: /dev/sdc1 maj-min: 8:33
Kernel: swappiness: 60 (default) cache-pressure: 100 (default) zswap: no
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdc3 maj-min: 8:35
System Temperatures: cpu: 28.0 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 32 GiB available: 31.28 GiB used: 2.44 GiB (7.8%)
Processes: 319 Power: uptime: 9m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 0 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 12.46 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 257 default: graphical
tool: systemctl
Packages: 1178 pm: pacman pkgs: 1164 libs: 287 tools: yay pm: flatpak
pkgs: 14 Compilers: gcc: 14.2.1 Shell: Bash v: 5.2.37 running-in: konsole
inxi: 3.3.36
could not find pahis in the arch repo. or the aur? Did you spell it correctly?
[ricklinux@rick-ms7c37 ~]$ yay -S pahis
Sync Explicit (1): pahis-24-1
resolving dependencies...
Package (1)        New Version  Net Change  Download Size
endeavouros/pahis  24-1           0.01 MiB       0.01 MiB
Total Download Size:   0.01 MiB
Total Installed Size:  0.01 MiB
:: Proceed with installation? [Y/n]
Tried to update the linux kernel and linux-headers to 6.12.9, and it did the same thing to me. Had to do the same thing to downgrade those packages to get back into my system. I edited the pacman.conf file to ignore nvidia linux and linux-headers for now.
I have no issues on nvidia either with Wayland using GTX 1060.
Ok, I got the pahis package and used pahis --upgraded. I was a little confused at first because I was looking at the bottom of the list instead of the top and was not seeing the latest installed packages. But, I understand how its organized now. Thanks!
