I just installed EndeavourOS 22.8. I think i have an nvidia issue. I am not really sure what it is
I’m adding some screen captures here:
I can not use nvidia-smi or nvidia-setting os nvidia x server settings either.
and prime-run inxi -Ga
What is the full hardware output?
inxi -Faz | eos-sendlog
Does it not boot to the desktop?
Edit: Is this a laptop? It is currently rendering on Intel Gpu
Edit2: Your post doesn’t really explain what your issue is?
First of all looking at the output it shows no driver for Nvidia loaded. You probably need to add ibt=off to the default grub command line in /etc/default/grub Then you have to update grub with sudo grub-mkconfig -o /boot/grub/grub.cfg
Edit: Then reboot & run again
inxi -Ga
is prime-run a command? Because I get command not found outtput.
Yes it is laptop. I boots desktop normally but can not switch between modes with optimus-manager.
Kernel: 5.19.9-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-linux
root=UUID=c47bba48-37a1-42cc-a4d3-82b997bd212a rw loglevel=3 nowatchdog
nvme_load=YES nvidia-drm.modeset=1
Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.6 wm: kwin_x11 vt: 1
dm: SDDM Distro: EndeavourOS base: Arch Linux
Type: Laptop System: MONSTER product: ABRA A5 V17.2 v: N/A
Mobo: MONSTER model: ABRA A5 V17.2 serial: <superuser required>
UEFI: INSYDE v: 1.07.09TFB18 date: 11/19/2021
Battery:
ID-1: BAT0 charge: 44.4 Wh (100.0%) condition: 44.4/47.2 Wh (94.1%)
volts: 16.5 min: 14.4 model: Notebook BAT type: Li-ion serial: <filter>
status: full
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M525
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
Info: model: 11th Gen Intel Core i5-11400H bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 built: 2020 process: Intel 10nm
family: 6 model-id: 0x8D (141) stepping: 1 microcode: 0x40
Topology: cpus: 1x cores: 6 tpc: 2 threads: 12 smt: enabled cache:
L1: 480 KiB desc: d-6x48 KiB; i-6x32 KiB L2: 7.5 MiB desc: 6x1.2 MiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1758 high: 3978 min/max: 800/4500 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 2700 3: 935
4: 800 5: 800 6: 2700 7: 1153 8: 1247 9: 1479 10: 1806 11: 3978 12: 2700
bogomips: 64536
Vulnerabilities:
prctl
sanitization
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: CLEVO/KAPOK
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:9a68
class-ID: 0300
Device-2: NVIDIA GA107M [GeForce RTX 3050 Ti Mobile] vendor: CLEVO/KAPOK
driver: N/A alternate: nouveau, nvidia_drm, nvidia non-free: 515.xx+
status: current (as of 2022-08) arch: Ampere code: GAxxx process: TSMC n7
(7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 8 link-max:
lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:25a0 class-ID: 0300
Device-3: Chicony USB2.0 Camera type: USB driver: uvcvideo bus-ID: 1-8:3
chip-ID: 04f2:b729 class-ID: fe01 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: intel unloaded: modesetting alternate: fbdev,vesa gpu: i915
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.00x11.22")
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP1 model: ChiMei InnoLux 0x1521 built: 2020
res: 1920x1080 hz: 144 dpi: 143 gamma: 1.2 size: 340x190mm (13.39x7.48")
diag: 394mm (15.5") ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics (TGL GT1) v: 4.6 Mesa 22.1.7
direct render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: CLEVO/KAPOK
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:43c8 class-ID: 0403
Device-2: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:2291 class-ID: 0403
Sound Server-1: ALSA v: k5.19.9-arch1-1 running: yes
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.58 running: yes
Device-1: Intel Tiger Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:43f0 class-ID: 0280
vendor: CLEVO/KAPOK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp3s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Bluetooth:
Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-14:4 chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: disabled
Local Storage: total: 952.89 GiB used: 36.04 GiB (3.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SanDisk
model: SSDPR-PX500-512-80 size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter>
rev: U0806A0 temp: 39.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: KIOXIA model: EXCERIA SATA SSD
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 18.3 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Kingston
model: DataTraveler 3.0 size: 28.82 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> scheme: MBR
SMART Message: Unknown USB bridge. Flash drive/Unsupported enclosure?
ID-1: / raw-size: 176.83 GiB size: 172.99 GiB (97.83%) used: 28.1 GiB
(16.2%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 27.3 MiB
(28.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
I added “ibt=off to” the GRUB_CMDLINE_LINUX_DEFAULT and rebooted:
class-ID: 0300
chip-ID: 04f2:b729 class-ID: fe01 serial: 200901010001
direct render: Yes
It doesn’t look like you ran the grub update command?
Edit: You have to add this permanently using a text editor and save the file and then update grub with the command given.
sudo nano /etc/default/grub
add this to the default grub command line
ibt=off
use ctrl + o then enter to save the file
use ctrl + x to exit nano
Then run
Then reboot
Driver should show nvidia!
Oh, my bad. Think this absolutely solved my problem. Thank you so much.
class-ID: 0300
driver: nvidia v: 515.65.01 alternate: nouveau,nvidia_drm non-free: 515.xx+
lanes: 16 ports: active: none empty: DP-1 bus-ID: 01:00.0
loaded: modesetting,nvidia gpu: i915 display-ID: :0 screens: 1
Monitor-1: eDP-1 model: ChiMei InnoLux 0x1521 built: 2020 res: 1920x1080
hz: 144 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
direct render: Yes
Now that solves the one problem. So you just have to learn how your hardware can switch between graphics using one of the methods available.
I think you mean bb, optimus-manager, optimus-switch etc. (?) I installed optimus-manager and using it for now.
Excellent!
