NVIDIA GM108M [GeForce MX130] driver issue
hello guys im new here… (sorry for bad english)
i have an issue with nvidiadriver and im not smart enough to figured it out myself.
I encountered the following problem when installing Endeavour OS using the GRUB option:
$ nvidia-inst
After installation, I checked if the driver was installed correctly, but it was not available:
$ inxi -G
  Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] driver: i915 v: kernel
  Device-2: NVIDIA GM108M [GeForce MX130] driver: N/A
  Device-3: Chicony HD User Facing driver: uvcvideo type: USB
  Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.2
    compositor: kwin_wayland driver: X: loaded: modesetting dri: iris gpu: i915
    resolution: 1920x1080
  API: EGL v: 1.5 drivers: iris,swrast
    platforms: gbm,wayland,x11,surfaceless,device
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: Intel Mesa v: 24.2.3-arch1.1
    renderer: Mesa Intel UHD Graphics 620 (WHL GT2)
$spci | grep -i vga
00:02.0 VGA compatible controller: Intel Corporation WhiskeyLake-U GT2 [UHD Graphics 620]
$ nvidia-smi
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
Additionally, I encountered this problem when I tried to install Endeavour OS using systemd during boot:
pcieport 0000:02:00.0: can't change power state from D3cold to D0
I tried using Bumblebee and Optimus Manager. I also disabled power management on boot and added some kernel parameters to see if that would resolve the issue, but the problem persists.
I don’t know what I’m doing, so I just copied and pasted the error messages into ChatGPT and followed every step. I’ve tried multiple times and messed up the system several times before writing this thread.
I had this problem before with Linux Lite as well, but it works fine with Windows, so I guess the GPU is not defective.
Please show the output of:
lspci -vnn | grep -P 'VGA|Display|3D'
lsmod | grep nvidia
pacman -Qs nvidia
Just to check, did you reboot after running nvidia-inst?
Also, try envycontrol if optimus manager fails.
Yes, I rebooted the system after installing the driver using the nvidia-inst CLI
$ lspci -vnn | grep -P 'VGA|Display|3D'
lsmod | grep nvidia
pacman -Qs nvidia
00:02.0 VGA compatible controller [0300]: Intel Corporation WhiskeyLake-U GT2 [UHD Graphics 620] [8086:3ea0] (prog-if 00 [VGA controller])
02:00.0 3D controller [0302]: NVIDIA Corporation GM108M [GeForce MX130] [10de:174d] (rev a2)
local/egl-gbm 1.1.2-1
    The GBM EGL external platform library
local/egl-wayland 4:1.1.16-1
    EGLStream-based Wayland external platform
local/libvdpau 1.5-3
    Nvidia VDPAU library
local/libxnvctrl 560.35.03-1
    NVIDIA NV-CONTROL X extension
local/nvidia-dkms 560.35.03-3
    NVIDIA drivers - module sources
local/nvidia-hook 1.5.1-1
    pacman hook for nvidia
local/nvidia-inst 24-1
    Script to setup nvidia drivers (dkms version) in EndeavourOS
local/nvidia-settings 560.35.03-1
    Tool for configuring the NVIDIA graphics driver
local/nvidia-utils 560.35.03-3
    NVIDIA drivers utilities
this cli didn’t return anything
lsmod | grep nvidia
The nvidia module is not loaded for some reason.
One more output is needed:
pacman -Qs headers linux
Did you solve the problem? Im struggling the same issue right now…
This is an old thread and lots of software changes has happened in nearly 2 years.
So I’d suggest starting a new thread, and start it with showing some basic information:
lsmod | grep nvidia
pacman -Qs nvidia
pacman -Qs linux headers
Welcome to the EndeavourOS forum. :handshake: I hope you enjoy your time here.
Pudge
