Hello, maybe I’m wrong, @Bryanpwo wrote that the issue is in Xorg based DE’s, but in the EndeavourOS Nvidia Installer entry in Discovery there is the issue about wayland DE’s.
I have an amd and nvidia card in my desktop with optimus installed. The only two files I have in /etc/X11/xorg.conf.d are: 00-keyboard.conf and 10-optimus-manager.conf
I do not see what exactly is the issue as the post on reddit does not give any details on that.
And the conf it writes should not do much anyways said from using nologo option what is not needed since a long time
From my reading the issue seems to be when you have both an active integrated gpu and an nvidia dedicated gpu on a desktop. That being said, I don’t currently have available hardware to test that.
That being said, this seems to be impacting a pretty small subset of users so perhaps we should unpin it?
I’m not totally sold on the fact that this is the underlying issue. We have no way of knowing exactly how those systems are set up & were configured. There have been a number of users who have had their systems working and others have struggles with getting them to work. Removing this file doesn’t seem to affect anything or having it for me. It is possible on some of these hybrid setups that they need some other xorg settings and this maybe conflicts with it? I don’t have any hybrid hardware and I’m no expert either.
This was my bet also… so more a BUG on something else… as it should not conflict if you have display plugged in to Nvidia pcie Card while the CPU have an unplugged igpu?
I see some reports from users with Optimus where it is a problem to have the nvidia config when it boots with intel enabled… and i am not sure if nvidia-installer-dkms pulls the file if you do not install bumblebee and only run it installing Nvidia drivers?
I have a hybrid graphics nvidia laptop. I just installed nvidia and nvidia-dkms using pacman and had no issues at all. Optimus works. Using Cinnamon by the way.
