DISCLAIMER: user is new to Linux
Hello
I do have a RTX 2070 Super card and a Philipps 3275 4k monitor, which is able to show 10-bit color depth. In W11 that setting can be easily applied, works across all apps and looks pretty nice.
To achieve something similar in EOS, I edited the DefaultDepth to 30 in xorg.conf, although in nvidia-settings the max color depth is only 8-bit. However, the driver showed me Color Depth 30 in the nvidia-settings and the desktop looked even better (KDE).
But my Latte panels got a big black solid stripe in the background and Brave also got framed with a thick black stripe. It seems, that not all apps get along with the 10-bit setting and I’m not sure, why I can manually change it, but nvidia-settings doesn’t offer it.
Is this something, that’s just is as it is (the stripe thing) or is there something one has to additionally install, when using 10-bit color depth?
Thank you
