Nvida GPU not taking costume edid
i was trying to add virtual monitor by faking a edid file base on this topic
the fake second monitor appears in system-settings but i cant change the resolution
/proc/cmdline also shows that is taking my parameters i added
when checking the edid file for my nvidia card returs nothing
cat /sys/class/drm/card1-DP-2/edid
when i check my real monitor plugged in HDMI-A-1 it returns the content of the file
cat /sys/class/drm/card1-HDMI-A-1/edid
could this be related to my problem?
fixed!!!
turns out the edid i used was broken.
The easiest way to get a working edid is to make a costume one using AW EDID Editor, is windows only but works perfectly on wine
