I switched over to Endeavour from Manjaro about a week ago and I’m having a lot of graphical issues weren’t present on Manjaro. My screen spazzing out whenever I close certain fullscreen games (Quaver and osu! both did it), and the main issue of my monitor’s refresh rate not working at all. I have a 165hz monitor and a 60hz one, and nothing was working in 165hz despite my settings being right, mangohud saying games were running at 165fps, xrandr showing it was 165hz, and so on.
The reason I say it’s a Kwin issue is that every issue immediately stopped when I disabled Kwin. Everything is much less pretty now but everything is SO much smoother than it looked before and it seems I don’t have the weird issues that the rhythm games were causing before.
I don’t mind keeping my pc this way but I did like the effects that Kwin had, made my pc feel a lot more personalised and stuff. Has anyone had an issue like this? I’d like to be able to reenable it but I can’t live with the issues I was having with it.
Welcome to forums @Noelle!!
It would be great to have your system information and logs as per this article:
Are you running x11 or wayland. What kernel are you running? What about your Graphics hardware/driver situation. These are the things that effect the things you’ve mentioned.
Welcome @Noelle
As @sradjoker has suggested please provide some logs such as your hardware. All of the information on how to do this is provided in the Wiki.
Here is one you can use to upload your hardware info and post the link.
inxi -Faz | eos-sendlog
I am sure you probably mean the Compositor, since you can’t have a desktop without its Window Manager .
You may try altering the Render engine setting (or similar name…) in Compositor settings, instead of disabling (e.g. use Xrender).
Thank you for all the welcomes!
System info:
Kernel: 5.18.3-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
Desktop: KDE Plasma v: 5.24.90 tk: Qt v: 5.15.4 wm: kwin_x11 dm: SDDM
Type: Desktop System: Dell product: OptiPlex 7010 v: 01
serial: <superuser required> Chassis: type: 15 serial: <superuser required>
Mobo: Dell model: 0GXM1W v: A02 serial: <superuser required> UEFI: Dell
v: A29 date: 06/28/2018
Info: quad core model: Intel Core i5-3470 bits: 64 type: MCP
arch: Ivy Bridge rev: 9 cache: L1: 256 KiB L2: 1024 KiB L3: 6 MiB
Speed (MHz): avg: 1977 high: 2049 min/max: 1600/3600 cores: 1: 2007
2: 2000 3: 1855 4: 2049 bogomips: 25554
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Device-1: NVIDIA GP108 [GeForce GT 1030] vendor: Micro-Star MSI
driver: nvidia v: 515.48.07 arch: Pascal pcie: speed: 8 GT/s lanes: 4
ports: active: none off: DP-1,HDMI-A-1 empty: none bus-ID: 01:00.0
chip-ID: 10de:1d01
Device-2: WaveRider USB 2.0 Camera type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-1.5:7 chip-ID: 0c46:636b
Display: x11 server: X.Org v: 21.1.3 with: Xwayland v: 22.1.2
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1325 s-dpi: 91
Monitor-1: DP-1 mapped: DP-0 note: disabled pos: primary,top-left
model: VG248 res: 1920x1080 dpi: 92 diag: 609mm (24")
Monitor-2: HDMI-A-1 mapped: HDMI-0 note: disabled pos: bottom-r
model: Samsung SMBX2450L res: 1920x1080 dpi: 94 diag: 598mm (23.5")
OpenGL: renderer: NVIDIA GeForce GT 1030/PCIe/SSE2
v: 4.6.0 NVIDIA 515.48.07 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Dell
driver: snd_hda_intel bus-ID: 1-1.2:4 v: kernel chip-ID: 0d8c:0005
bus-ID: 00:1b.0 chip-ID: 8086:1e20
Device-2: NVIDIA GP108 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel pcie: speed: 8 GT/s lanes: 4
bus-ID: 01:00.1 chip-ID: 10de:0fb8
Device-3: C-Media Blue Snowball type: USB
driver: hid-generic,snd-usb-audio,usbhid
Device-4: Logitech G433 Gaming Headset type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-1.4:6 chip-ID: 046d:0a6d
Device-5: WaveRider USB 2.0 Camera type: USB
Sound Server-1: ALSA v: k5.18.3-arch1-1 running: yes
Sound Server-2: PulseAudio v: 16.0 running: no
Sound Server-3: PipeWire v: 0.3.52 running: yes
Device-1: Intel 82579LM Gigabit Network vendor: Dell driver: e1000e
v: kernel port: f040 bus-ID: 00:19.0 chip-ID: 8086:1502
IF: eno1 state: down mac: <filter>
vendor: TP-LINK TG-3468 driver: r8169 v: kernel pcie: speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168
IF: enp3s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Bluetooth:
Device-1: Dynex Bluetooth 4.0 Adapter [Broadcom 1.12 BCM20702A0] type: USB
driver: btusb v: 0.8 bus-ID: 3-4:4 chip-ID: 19ff:0239
Report: rfkill ID: hci0 rfk-id: 0 state: up address: see --recommends
Local Storage: total: 2.28 TiB used: 1.77 TiB (77.5%)
ID-1: /dev/sda vendor: Western Digital model: WDBNCE5000PNC
size: 465.76 GiB speed: 6.0 Gb/s serial: <filter>
ID-2: /dev/sdb vendor: Toshiba model: MQ04ABF100 size: 931.51 GiB
ID-3: /dev/sdc type: USB vendor: Generic model: Flash Disk size: 3.92 GiB
serial: <filter>
ID-4: /dev/sdd type: USB vendor: Seagate model: ST31000528AS
size: 931.51 GiB serial: <filter>
ID-1: / size: 399.59 GiB used: 243.08 GiB (60.8%) fs: ext4 dev: /dev/sda5
ID-2: /boot/efi size: 96 MiB used: 27.3 MiB (28.4%) fs: vfat
dev: /dev/sda1
ID-1: swap-1 type: file size: 3 GiB used: 1.92 GiB (64.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 55.0 C mobo: 27.8 C gpu: nvidia temp: 46 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 100%
Processes: 256 Uptime: 18h 26m Memory: 7.72 GiB used: 4.36 GiB (56.5%)
Init: systemd v: 251 default: graphical Compilers: gcc: 12.1.0
Packages: 1305 pacman: 1296 flatpak: 9 Shell: Zsh v: 5.9
running-in: konsole inxi: 3.3.17
What I did was disable the “enable on startup” option in the Compositor settings. and I don’t seem to be able to find any other options like what you mentioned.
Some logs would be great. Can you provide a boot log with compositor on? We might find something that’s wrong
journalctl -b -0 | eos-sendlog
It seems they have removed this setting. You may try altering the other settings and test for better results.
Use “Only when cheap” for Tearing Prevention.
Also try “Balanced” in Latency.
Try other settings until you find your HW/SW good combination.
Just some extra information I thought might be useful.
I made sure to set the RefreshRate and MaxFPS in kwinrc, no difference.
I used testufo.com to make sure I wasn’t just seeing things and sure enough, as I enable and disable the compositor it’s night and day. Looks like the only part of my refresh rate that’s actually working is my mouse cursor, since I mainly test refresh rate by circling my cursor and there doesn’t seem to be any difference. Apart from that though, looks like pretty much every program seems to be displaying in 60fps.
These logs do not contain any significant display/kwin error (although there are several issues that would need corrective actions).
What was the behavior, in relation to your issues?
Do you have some reason you don’t try, as suggested, to alter compositor settings?
We need something to compare, when reviewing lengthy logs. We are neither kde nor nvidia, nor Xorg developers, if you thought so .
Help us help you
@Noelle
I don’t see where you ever did answer @sradjoker whether you were using Wayland? Also you haven’t provided any boot logs as he requested
And as @petsam has said.
I think these are the logs
To be fair those were provided, but did not try anything else.
Sorry I’m honestly not quite sure what I’m being asked right now lol. I tried modifying the settings that @petsam suggested (tearing and latency) but those didn’t seem to change anything at all.
All I know is that when I startup EOS with the compositor enabled then I get full screen glitches upon closing certain games, and that the compositor seems to lock my framerate despite everything saying it’s unlocked. I realize I have no way to prove that the framerate is off but I swear it’s extremely noticable. Disabling it fixes all the problems I get. I went back and forth with qdbus org.kde.KWin /Compositor suspend
and qdbus org.kde.KWin /Compositor resume
and it’s very clear.
Games are interfering with the system in a bad uncontrollable way.
If your system behaves properly in all other system activity, the issue does not exist (at least for myself).
Maybe others might be able to help.
I personally don’t want to waste my time to help Linux users play games, no offense.
1stW issues…
Looks like switching to Wayland is the only thing that would solve the fps issue at least, it’s immediately noticable and the kwin fps actually goes above 60 to my refresh rate. Unfortunately it’s Wayland so it’s really unstable and glitchy for me and I’d rather just have the compositor off completely.
I feel like I should probably just do a reinstall at this point. It’s gotta be something specific to my system since nobody was able to say they had the same problems. We’ll see how things pan out, either it fixes, or I at least get a nice fresh system. Thanks for all the help guys
