I am dealing with a NULL pointer dereference after updating from sof-firmware 2024.06-1 to sof-firmware 2024.09-1 on EndeavourOS (ArchLinux). The sound doesn’t work at all. I tried it on 6.11.3.arch1-1 and there were no problems there (I just can’t adjust the volume, but I had this problem before too).
I tried: As write there https://thesofproject.github.io/latest/getting_started/intel_debug/introduction.html#pci-devices-introduced-after-2016 I used options snd-intel-dspcfg dsp_driver=1 and the sound worked.
System
Kernel: 6.6.56-1-lts arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
Desktop: KDE Plasma v: 6.2.0 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Laptop System: LENOVO product: 83E2 v: Yoga Pro 7 14IMH9
serial: <superuser required> Chassis: type: 10 v: Yoga Pro 7 14IMH9
Mobo: LENOVO model: LNVNB161216 v: No DPK serial: <superuser required>
part-nu: LENOVO_MT_83E2_BU_idea_FM_Yoga Pro 7 14IMH9 UEFI: LENOVO
v: N9CN25WW date: 02/26/2024
Battery:
ID-1: BAT0 charge: 73.0 Wh (99.1%) condition: 73.7/73.0 Wh (100.9%)
volts: 17.4 min: 15.5 model: Sunwoda L22D4PF4 serial: <filter>
status: charging
Info: 16-core (6-mt/10-st) model: Intel Core Ultra 9 185H bits: 64
type: MST AMCP arch: Meteor Lake rev: 4 cache: 24 MiB note: check
Speed (MHz): avg: 4734 min/max: 400/4700:5000:3800:2500 cores: 1: 4734
2: 4734 3: 4734 4: 4734 5: 4734 6: 4734 7: 4734 8: 4734 9: 4734 10: 4734
11: 4734 12: 4734 13: 4734 14: 4734 15: 4734 16: 4734 17: 4734 18: 4734
19: 4734 20: 4734 21: 4734 22: 4734 bogomips: 135212
Device-1: Intel Meteor Lake-P [Intel Arc Graphics] vendor: Lenovo
driver: i915 v: kernel arch: Gen-13 ports: active: eDP-1 empty: DP-1, DP-2,
DP-3, DP-4, HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:7d55
Device-2: Luxvisions Innotech Integrated RGB Camera driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 bus-ID: 3-9:2 chip-ID: 30c9:00c2
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.2
compositor: kwin_wayland driver: X: loaded: modesetting
alternate: fbdev,intel,vesa dri: iris gpu: i915 display-ID: 0
Monitor-1: eDP-1 res: 1536x960 size: N/A
API: EGL v: 1.5 platforms: device: 0 drv: iris device: 1 drv: swrast gbm:
drv: iris surfaceless: drv: iris wayland: drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.2.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Arc Graphics (MTL)
device-ID: 8086:7d55 display-ID: :1.0
API: Vulkan v: 1.3.295 surfaces: xcb,xlib,wayland device: 0
type: integrated-gpu driver: mesa intel device-ID: 8086:7d55
Device-1: Intel Meteor Lake-P HD Audio vendor: Lenovo
driver: sof-audio-pci-intel-mtl bus-ID: 00:1f.3 chip-ID: 8086:7e28
API: ALSA v: k6.6.56-1-lts status: kernel-api
Server-1: PipeWire v: 1.2.5 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin
Device-1: Intel Meteor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:7e40
IF-ID-1: docker0 state: down mac: <filter>
Bluetooth:
Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 bus-ID: 3-10:3 chip-ID: 8087:0033
Report: btmgmt ID: hci0 rfk-id: 5 state: down bt-service: enabled,running
rfk-block: hardware: no software: no address: <filter> bt-v: 5.3 lmp-v: 12
Local Storage: total: 953.87 GiB used: 303.87 GiB (31.9%)
ID-1: /dev/nvme0n1 vendor: SK Hynix model: HFS001TEJ9X115N
size: 953.87 GiB speed: 63.2 Gb/s lanes: 4 serial: <filter> temp: 38.9 C
ID-1: / size: 892.87 GiB used: 303.09 GiB (33.9%) fs: ext4
dev: /dev/nvme0n1p3
ID-2: /boot/efi size: 511 MiB used: 8.3 MiB (1.6%) fs: vfat
dev: /dev/nvme0n1p1
ID-1: swap-1 type: partition size: 45.17 GiB used: 788.3 MiB (1.7%)
priority: -2 dev: /dev/nvme0n1p2
Src: /sys System Temperatures: cpu: 55.0 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 32 GiB note: est. available: 30.96 GiB used: 11.3 GiB (36.5%)
Processes: 470 Power: uptime: 16h 9m wakeups: 1 Init: systemd v: 256
default: graphical
Packages: 1324 pm: pacman pkgs: 1300 pm: flatpak pkgs: 24 Compilers:
gcc: 14.2.1 Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.36
Here the dmesg boot log
[ 7.481237] i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
[ 7.519932] sof-audio-pci-intel-mtl 0000:00:1f.3: use msi interrupt mode
[ 7.556017] sof-audio-pci-intel-mtl 0000:00:1f.3: hda codecs found, mask 5
[ 7.556020] sof-audio-pci-intel-mtl 0000:00:1f.3: using HDA machine driver skl_hda_dsp_generic now
[ 7.556040] sof-audio-pci-intel-mtl 0000:00:1f.3: DMICs detected in NHLT tables: 4
[ 7.558672] sof-audio-pci-intel-mtl 0000:00:1f.3: Loaded firmware library: ADSPFW, version: 2.11.1.1
[ 7.676258] sof-audio-pci-intel-mtl 0000:00:1f.3: Booted firmware version: 2.11.1.1
[ 7.692580] sof-audio-pci-intel-mtl 0000:00:1f.3: Topology: ABI 3:29:1 Kernel ABI 3:23:0
[ 7.692897] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: Parent card not yet available, widget card binding deferred
[ 7.692923] BUG: kernel NULL pointer dereference, address: 0000000000000000
[ 7.692953] #PF: supervisor write access in kernel mode
[ 7.692973] #PF: error_code(0x0002) - not-present page
[ 7.692993] PGD 0 P4D 0
[ 7.693006] Oops: 0002 [#1] PREEMPT SMP NOPTI
[ 7.693024] CPU: 2 PID: 620 Comm: (udev-worker) Tainted: P U W OE 6.6.56-1-lts #1 1400000003000000474e5500ae7da552b296012d
[ 7.693068] Hardware name: LENOVO 83E2/LNVNB161216, BIOS N9CN25WW 02/26/2024
[ 7.693094] RIP: 0010:sof_ipc4_widget_update_kcontrol_module_id+0x3f/0x60 [snd_sof]
[ 7.693152] Code: 8b 91 c8 03 00 00 48 81 c1 c8 03 00 00 48 8d 42 98 48 39 d1 74 23 0f 1f 44 00 00 8b 77 08 39 70 10 75 09 48 8b 50 48 41 8b 30 <09> 32 48 8b 50 68 48 8d 42 98 48 39 d1 75 e2 c3 cc cc cc cc 66 66
[ 7.693218] RSP: 0018:ffffc9000792f5f0 EFLAGS: 00010246
[ 7.693238] RAX: ffff888104b955c0 RBX: ffff88811c9678c0 RCX: ffff888103a29bf0
[ 7.693265] RDX: 0000000000000000 RSI: 0000000000000019 RDI: ffff88811c881100
[ 7.693292] RBP: ffff88811c881100 R08: ffff8881259e4f00 R09: ffff8881018a0a00
[ 7.693317] R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000000
[ 7.693343] R13: 0000000000000078 R14: ffff88810dd58380 R15: ffff88811c880800
[ 7.693369] FS: 00007209ff7c6880(0000) GS:ffff88885f480000(0000) knlGS:0000000000000000
[ 7.693399] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 7.693421] CR2: 0000000000000000 CR3: 00000001158ac005 CR4: 0000000000f70ee0
[ 7.693448] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 7.693475] DR3: 0000000000000000 DR6: 00000000ffff07f0 DR7: 0000000000000400
[ 7.694319] PKRU: 55555554
[ 7.695083] Call Trace:
[ 7.695808] <TASK>
[ 7.696670] ? __die+0x23/0x70
[ 7.697555] ? page_fault_oops+0x174/0x530
[ 7.698357] ? xas_find+0x153/0x1a0
[ 7.699097] ? xas_load+0xe/0x50
[ 7.699776] ? exc_page_fault+0x7f/0x180
[ 7.700424] ? asm_exc_page_fault+0x26/0x30
[ 7.701067] ? sof_ipc4_widget_update_kcontrol_module_id+0x3f/0x60 [snd_sof 1400000003000000474e5500b848599ada760e54]
[ 7.701744] sof_ipc4_widget_setup_comp_process+0x12e/0x1b0 [snd_sof 1400000003000000474e5500b848599ada760e54]
[ 7.702434] sof_complete+0x25e/0x390 [snd_sof 1400000003000000474e5500b848599ada760e54]
[ 7.703130] ? __pfx_soc_tplg_dapm_graph_elems_load+0x10/0x10 [snd_soc_core 1400000003000000474e550019f3d5f3d0388d77]
[ 7.703853] snd_soc_tplg_component_load+0x29a/0x3a0 [snd_soc_core 1400000003000000474e550019f3d5f3d0388d77]
[ 7.704579] snd_sof_load_topology+0x6c/0x150 [snd_sof 1400000003000000474e5500b848599ada760e54]
[ 7.705316] sof_pcm_probe+0x72/0x100 [snd_sof 1400000003000000474e5500b848599ada760e54]
[ 7.706060] snd_soc_component_probe+0x1f/0x60 [snd_soc_core 1400000003000000474e550019f3d5f3d0388d77]
[ 7.706820] soc_probe_component+0x1b3/0x340 [snd_soc_core 1400000003000000474e550019f3d5f3d0388d77]
[ 7.707604] snd_soc_bind_card+0x598/0xd80 [snd_soc_core 1400000003000000474e550019f3d5f3d0388d77]
[ 7.708386] ? __pfx_devm_card_release+0x10/0x10 [snd_soc_core 1400000003000000474e550019f3d5f3d0388d77]
[ 7.709175] devm_snd_soc_register_card+0x47/0x90 [snd_soc_core 1400000003000000474e550019f3d5f3d0388d77]
[ 7.709981] skl_hda_audio_probe+0x1d0/0x370 [snd_soc_skl_hda_dsp 1400000003000000474e55009da6d76b1bd43107]
[ 7.710780] platform_probe+0x41/0xa0
[ 7.711574] really_probe+0x19b/0x3e0
[ 7.712368] ? __pfx___driver_attach+0x10/0x10
[ 7.713166] __driver_probe_device+0x78/0x160
[ 7.713961] driver_probe_device+0x1f/0xa0
[ 7.714757] __driver_attach+0xba/0x1c0
[ 7.715544] bus_for_each_dev+0x8c/0xe0
[ 7.716322] bus_add_driver+0x112/0x240
[ 7.717101] driver_register+0x5c/0x100
[ 7.717870] ? __pfx_skl_hda_audio_init+0x10/0x10 [snd_soc_skl_hda_dsp 1400000003000000474e55009da6d76b1bd43107]
[ 7.718676] do_one_initcall+0x5a/0x320
[ 7.719486] do_init_module+0x60/0x240
[ 7.720234] init_module_from_file+0x89/0xe0
[ 7.720983] idempotent_init_module+0x121/0x320
[ 7.721733] __x64_sys_finit_module+0x5e/0xb0
[ 7.722476] do_syscall_64+0x5a/0x80
[ 7.723226] ? folio_wait_bit_common+0x20b/0x350
[ 7.723960] ? xas_load+0x41/0x50
[ 7.724676] ? filemap_get_read_batch+0x139/0x260
[ 7.725401] ? filemap_get_pages+0xa7/0x650
[ 7.726131] ? _copy_to_iter+0x5e/0x4a0
[ 7.726853] ? do_syscall_64+0x66/0x80
[ 7.727565] ? exit_to_user_mode_prepare+0x132/0x1f0
[ 7.728260] ? atime_needs_update+0x61/0x120
[ 7.728947] ? touch_atime+0x1e/0x120
[ 7.729615] ? filemap_read+0x326/0x350
[ 7.730251] ? __seccomp_filter+0x301/0x510
[ 7.730881] ? ksys_lseek+0x69/0xb0
[ 7.731504] ? syscall_exit_to_user_mode+0x22/0x40
[ 7.732126] ? do_syscall_64+0x66/0x80
[ 7.732753] ? exit_to_user_mode_prepare+0x132/0x1f0
[ 7.733377] ? syscall_exit_to_user_mode+0x22/0x40
[ 7.733994] ? do_syscall_64+0x66/0x80
[ 7.734595] entry_SYSCALL_64_after_hwframe+0x78/0xe2
[ 7.735204] RIP: 0033:0x7209fff261fd
[ 7.735855] Code: ff c3 66 2e 0f 1f 84 00 00 00 00 00 90 f3 0f 1e fa 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d e3 fa 0c 00 f7 d8 64 89 01 48
[ 7.737151] RSP: 002b:00007ffc6a451518 EFLAGS: 00000246 ORIG_RAX: 0000000000000139
[ 7.737804] RAX: ffffffffffffffda RBX: 00005d1829080740 RCX: 00007209fff261fd
[ 7.738460] RDX: 0000000000000004 RSI: 00007209ff7c005d RDI: 000000000000004e
[ 7.739124] RBP: 00007ffc6a4515d0 R08: 0000000000000002 R09: 00007ffc6a451560
[ 7.739799] R10: 0000000000000007 R11: 0000000000000246 R12: 00007209ff7c005d
[ 7.740468] R13: 0000000000020000 R14: 00005d182905f570 R15: 00005d1829058820
[ 7.741138] </TASK>
[ 7.741805] Modules linked in: snd_soc_skl_hda_dsp(+) snd_soc_intel_hda_dsp_common snd_soc_hdac_hdmi snd_sof_probes snd_hda_codec_hdmi cmac overlay snd_hda_codec_realtek snd_hda_codec_generic algif_hash ledtrig_audio algif_skcipher af_alg nft_fib_inet nft_fib_ipv4 nft_fib_ipv6 nft_fib nft_reject_inet nf_reject_ipv4 nf_reject_ipv6 nft_reject nft_ct nft_chain_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 nf_tables libcrc32c bnep snd_soc_dmic snd_sof_pci_intel_mtl snd_sof_intel_hda_common soundwire_intel snd_sof_intel_hda_mlink soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils intel_uncore_frequency snd_soc_hdac_hda intel_uncore_frequency_common snd_hda_ext_core btusb x86_pkg_temp_thermal snd_soc_acpi_intel_match btrtl intel_powerclamp uvcvideo snd_soc_acpi btintel soundwire_generic_allocation videobuf2_vmalloc btbcm coretemp soundwire_bus uvc btmtk videobuf2_memops vfat fat videobuf2_v4l2 bluetooth snd_soc_core kvm_intel videodev videobuf2_common ecdh_generic mc
[ 7.741829] snd_compress ac97_bus snd_pcm_dmaengine kvm iwlmvm snd_hda_intel snd_intel_dspcfg snd_intel_sdw_acpi iTCO_wdt irqbypass i915 spi_nor intel_pmc_bxt snd_hda_codec mei_gsc_proxy iTCO_vendor_support mtd pmt_telemetry mac80211 intel_rapl_msr pmt_class snd_hda_core rapl drm_buddy snd_hwdep processor_thermal_device_pci i2c_algo_bit processor_thermal_device intel_cstate snd_pcm libarc4 processor_thermal_rfim ttm snd_timer processor_thermal_mbox intel_uncore processor_thermal_rapl pcspkr wmi_bmof drm_display_helper snd mei_me spi_intel_pci intel_rapl_common i2c_i801 thunderbolt int3403_thermal cec intel_vpu iwlwifi mei spi_intel soundcore intel_gtt int340x_thermal_zone i2c_smbus intel_vsec ideapad_laptop platform_profile intel_hid int3400_thermal joydev acpi_tad acpi_pad sparse_keymap acpi_thermal_rel mousedev mac_hid loop dm_mod fuse nfnetlink ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 hid_sensor_custom hid_sensor_hub intel_ishtp_hid wl(POE) crct10dif_pclmul crc32_pclmul crc32c_intel
[ 7.746541] polyval_clmulni polyval_generic serio_raw gf128mul atkbd ghash_clmulni_intel hid_multitouch libps2 sha512_ssse3 cfg80211 sha256_ssse3 vivaldi_fmap nvme sha1_ssse3 ucsi_acpi aesni_intel typec_ucsi nvme_core crypto_simd i2c_hid_acpi roles cryptd intel_ish_ipc rfkill nvme_common xhci_pci intel_lpss_pci i2c_hid intel_ishtp typec intel_lpss video xhci_pci_renesas idma64 i8042 wmi serio vboxnetflt(OE) vboxnetadp(OE) vboxdrv(OE) pkcs8_key_parser i2c_dev crypto_user
[ 7.754969] CR2: 0000000000000000
[ 7.755956] ---[ end trace 0000000000000000 ]---
[ 7.757025] RIP: 0010:sof_ipc4_widget_update_kcontrol_module_id+0x3f/0x60 [snd_sof]
[ 7.758114] Code: 8b 91 c8 03 00 00 48 81 c1 c8 03 00 00 48 8d 42 98 48 39 d1 74 23 0f 1f 44 00 00 8b 77 08 39 70 10 75 09 48 8b 50 48 41 8b 30 <09> 32 48 8b 50 68 48 8d 42 98 48 39 d1 75 e2 c3 cc cc cc cc 66 66
[ 7.760367] RSP: 0018:ffffc9000792f5f0 EFLAGS: 00010246
[ 7.761492] RAX: ffff888104b955c0 RBX: ffff88811c9678c0 RCX: ffff888103a29bf0
[ 7.762629] RDX: 0000000000000000 RSI: 0000000000000019 RDI: ffff88811c881100
[ 7.763778] RBP: ffff88811c881100 R08: ffff8881259e4f00 R09: ffff8881018a0a00
[ 7.764924] R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000000
[ 7.766066] R13: 0000000000000078 R14: ffff88810dd58380 R15: ffff88811c880800
[ 7.767192] FS: 00007209ff7c6880(0000) GS:ffff88885f480000(0000) knlGS:0000000000000000
[ 7.768366] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 7.769577] CR2: 0000000000000000 CR3: 00000001158ac005 CR4: 0000000000f70ee0
[ 7.770808] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 7.772021] DR3: 0000000000000000 DR6: 00000000ffff07f0 DR7: 0000000000000400
[ 7.773253] PKRU: 55555554
[ 7.774463] note: (udev-worker)[620] exited with irqs disabled
[ 7.952524] input: ydotoold virtual device as /devices/virtual/input/input18
[ 8.035984] tun: Universal TUN/TAP device driver, 1.6
[ 9.245839] overlayfs: failed to set xattr on upper
[ 9.245844] overlayfs: ...falling back to redirect_dir=nofollow.
[ 9.245846] overlayfs: ...falling back to metacopy=off.
[ 9.245846] overlayfs: ...falling back to index=off.
[ 9.245847] overlayfs: ...falling back to uuid=null.
[ 9.245848] overlayfs: ...falling back to xino=off.
[ 9.245849] overlayfs: try mounting with 'userxattr' option
[ 9.287015] overlayfs: upper fs does not support file handles, falling back to index=off.
