There is an issue with nvidia drivers installing and setting up correctly sometimes. I’m not sure if that is your issue as I see you used Rufus to create the live usb also. Did you install using the non free driver entry in the menu of the live usb. If you can log in and post the out put of
Same issue with me! I just created an account here just to say the same thing. The error persist in offline and online instalation. I tried three times, btrfs installation online, btrfs installation offline and XFS instalation online. All the three times using the non free mode on boot for installation. The funny thing is that I already have used this ISO in the same pen-drive last Friday with no issues. After distro hopping I was returning to endeavour but that issue occurred. I tried the tips here on the forum about black screen, but nothing worked. Even pacman wasn’t working with that mirror tip, returning URL error. Tomorrow I will try the installation again and I will return here to say if worked or not
Welcome @Cacique
On Friday there is a new ISO coming that you will be able to download that should resolve these issues. If you are going to try another install then i would recommend you add nvidia-dkms as a package in the following file on the live installer before you start the install.
user_pkglist.txt
Use sudo xed and then open /liveuser/user_pkglist.txt and add
nvidia-dkms
Save the file and then start the installer and run through the install process.
Here the problem persisted. I reinstalled and continued on black screen with just the terminal. I started SDDM as spoken here and it worked. Just like the user up there, the internet wasn’t working, I started too and everything seems to be working as it should now. The installation did not have any errors, however, this happened. Now everything is working as expected. Thank you all for your attention!
