After trying (and loving) EndeavourOS on virtualbox, I decided to install on bare metal. All seemed to go smoothly, except Kalu gave a message about not accessing a web site, but it seemed to start quicker that the wifi. I followed advice from the forum to put a 10 sec. delay on starting Kalu. Since then (and its been several hours) both Kalu and running pacman -Syu from terminal said nothing to do. When running on VB, it seems there were more frequent updates. I expected more messages or updates. Is it possible I’ve accidentally disabled a source mirror?
Here is my mirrorlist, endeveavouros-mirrorlist files
mirrorlist:
################# Arch Linux mirrorlist generated by Reflector #################
# With: reflector -c US -p https -a2 -phttps -f10 --sort age --save /tmp/t
mp.VNqaXecrGh
# When: 2019-10-04 23:29:39 UTC
# From: https://www.archlinux.org/mirrors/status/json/
# Retrieved: 2019-10-04 23:29:22 UTC
# Last Check: 2019-10-04 23:12:06 UTC
Server = https://arch.mirror.constant.com/$repo/os/$arch
Server = https://mirror.lty.me/archlinux/$repo/os/$arch
Server = https://mirrors.lug.mtu.edu/archlinux/$repo/os/$arch
Server = https://iad.mirrors.misaka.one/archlinux/$repo/os/$arch
Server = https://mirrors.rit.edu/archlinux/$repo/os/$arch
Server = https://mirror.dal10.us.leaseweb.net/archlinux/$repo/os/$arch
Server = https://arch.mirror.square-r00t.net/$repo/os/$arch
Server = https://mirror.stephen304.com/archlinux/$repo/os/$arch
Server = https://mirror.mia11.us.leaseweb.net/archlinux/$repo/os/$arch
Server = https://mirror.kaminski.io/archlinux/$repo/os/$arch
endeavouros-mirrorlist:
# EndeavourOS Repository Mirrorlist #
#[endeavouros]
#SigLevel = PackageRequired
#Include = /etc/pacman.d/endeavouros-mirrorlist
# Github
Server = https://github.com/endeavouros-team/mirrors/releases/download/mirror1/
Server = https://github.com/endeavouros-team/mirrors/releases/download/mirror2/
There is also mirrorlist.bak and mirrorlist.pacnew files. Just not sure what to look for to make sure everything that should be there, is there.
Any help/education would be appreciated.
Thanks!
ps
Here is my system specs:
System: Host: home Kernel: 5.3.1-arch1-1-ARCH x86_64 bits: 64 Desktop: Xfce 4.14.1 Distro: EndeavourOS
Machine: Type: Laptop System: Dell product: Latitude E6430 v: 01 serial: <root required>
Mobo: Dell model: N/A serial: <root required> BIOS: Dell v: A12 date: 05/20/2013
Battery: ID-1: BAT0 charge: 53.9 Wh condition: 53.9/62.2 Wh (87%)
CPU: Topology: Dual Core model: Intel Core i5-3340M bits: 64 type: MT MCP L2 cache: 3072 KiB
Speed: 1196 MHz min/max: 1200/3400 MHz Core speeds (MHz): 1: 1196 2: 1196 3: 1196 4: 1196
Graphics: Device-1: NVIDIA GF108GLM [NVS 5200M] driver: nouveau v: kernel
Display: x11 server: X.Org 1.20.5 driver: modesetting unloaded: fbdev,vesa tty: N/A
Audio: Device-1: Intel 7 Series/C216 Family High Definition Audio driver: snd_hda_intel
Device-2: NVIDIA GF108 High Definition Audio driver: snd_hda_intel
Sound Server: ALSA v: k5.3.1-arch1-1-ARCH
Network: Device-1: Intel 82579LM Gigabit Network driver: e1000e
IF: eno1 state: down mac: f0:1f:af:1b:c2:dd
Device-2: Intel Centrino Advanced-N 6205 [Taylor Peak] driver: iwlwifi
IF: wlp3s0 state: up mac: 6c:88:14:7d:ae:fc
Drives: Local Storage: total: 232.89 GiB used: 14.77 GiB (6.3%)
ID-1: /dev/sda vendor: SK Hynix model: HFS250G32TND-N1A2A size: 232.89 GiB
Partition: ID-1: / size: 211.32 GiB used: 14.77 GiB (7.0%) fs: ext4 dev: /dev/sda1
ID-2: swap-1 size: 17.18 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda2
Sensors: System Temperatures: cpu: 62.0 C mobo: 48.0 C sodimm: 42.0 C gpu: nouveau temp: 57 C
Fan Speeds (RPM): cpu: 2925
Info: Processes: 166 Uptime: 1h 56m Memory: 15.59 GiB used: 1.13 GiB (7.2%) Shell: bash inxi: 3.0.36
