For the past few days, I’ve had the occasional issue where I would lose sound. When I investigated it at the time, I couldn’t find much online or on my system to explain what was happening, other than all 3 services (Wireplumber, Pipewire and PipewirePulse) were sleeping. I would assume they should be awake as I’m attempting to play sounds.
Anyways, this happened again and after a reboot. Wireplumber and PipWire aren’t starting. I’m not sure how to start them manually, systemctl says they service is not found.
Here’s the Audio section from inxi:
Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0c:00.1 chip-ID: 1002:ab38
class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0e:00.3
chip-ID: 1022:1457 class-ID: 0403
API: ALSA v: k6.7.0-arch3-1 status: kernel-api
Server-1: sndiod v: N/A status: off tools: aucat,midicat,sndioctl
Server-2: PipeWire v: 1.0.1 status: off with: 1: pipewire-pulse
status: active 2: wireplumber status: off 3: pipewire-alsa type: plugin
I’m adding this in case it is relevant, connection refused if I attempt to run pactl:
$ ps ax | rg wire ; pactl info
919 ? S<sl 0:00 /usr/bin/pipewire-pulse
3199 pts/0 S+ 0:00 rg wire
Connection failure: Connection refused
