no sound when using audio jacks only sound via hdmi and display port is working also in alsamixer when pressing f6 only HDA NVidia shows up.
sound was working fine in windows
clean install of endeavour os with Budgie
output of inxi -Fxxxz
Kernel: 5.14.8-arch1-1 x86_64 bits: 64 compiler: gcc v: 11.1.0
Desktop: Budgie 10.5.3 info: budgie-panel wm: budgie-wm dm: LightDM 1.30.0
Type: Desktop System: Dell product: XPS 8940 v: N/A serial:
Chassis: type: 3 serial:
Mobo: Dell model: 0427JK v: A00 serial: UEFI: Dell v: 2.1.3
date: 07/23/2021
Info: 8-Core model: 11th Gen Intel Core i7-11700 bits: 64 type: MT MCP
arch: Rocket Lake rev: 1 cache: L2: 16 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
bogomips: 79888
Speed: 1835 MHz min/max: 800/4800 MHz Core speeds (MHz): 1: 1835 2: 800
3: 800 4: 801 5: 800 6: 800 7: 800 8: 800 9: 801 10: 800 11: 800 12: 800
13: 801 14: 800 15: 800 16: 800
Device-1: Intel RocketLake-S GT1 [UHD Graphics 750] vendor: Dell
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:4c8a class-ID: 0300
Device-2: NVIDIA GA104 [GeForce RTX 3060 Ti] vendor: Dell driver: nvidia
v: 470.74 bus-ID: 02:00.0 chip-ID: 10de:2486 class-ID: 0300
Display: x11 server: X.org 1.20.13 compositor: budgie-wm driver:
loaded: intel,nvidia unloaded: fbdev,modesetting,vesa
alternate: nouveau,nv resolution: <missing: xdpyinfo>
Device-1: Intel vendor: Dell driver: snd_hda_intel v: kernel
bus-ID: 00:1f.3 chip-ID: 8086:f1c8 class-ID: 0403
Device-2: NVIDIA GA104 High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 02:00.1 chip-ID: 10de:228b
class-ID: 0403
Sound Server-1: ALSA v: k5.14.8-arch1-1 running: yes
Sound Server-2: JACK v: 1.9.19 running: no
Sound Server-3: PulseAudio v: 15.0 running: yes
Sound Server-4: PipeWire v: 0.3.38 running: no
Device-1: Intel Comet Lake PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel port: 5000 bus-ID: 00:14.3 chip-ID: 8086:06f0
class-ID: 0280
IF: wlan0 state: up mac:
Device-2: Realtek vendor: Rivet Networks driver: r8169 v: kernel
port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:2600 class-ID: 0200
IF: enp4s0 state: down mac:
Bluetooth:
Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-14:6 chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: disabled
Local Storage: total: 1.4 TiB used: 7.08 GiB (0.5%)
ID-1: /dev/nvme0n1 vendor: Samsung model: PM991a NVMe 512GB
size: 476.94 GiB speed: 31.6 Gb/s lanes: 4 rotation: SSD serial:
rev: 26302039 scheme: GPT
ID-2: /dev/sda vendor: Seagate model: ST1000DM010-2EP102 size: 931.51 GiB
speed: 6.0 Gb/s rotation: 7200 rpm serial: rev: 1001 scheme: GPT
ID-3: /dev/sdb type: USB vendor: SanDisk model: USB 3.2Gen1
size: 28.65 GiB serial: rev: 1.00 scheme: MBR
ID-1: / size: 143.72 GiB used: 7.01 GiB (4.9%) fs: ext4 dev: /dev/sda3
ID-2: /boot/efi size: 146 MiB used: 75 MiB (51.4%) fs: vfat
dev: /dev/nvme0n1p1
System Temperatures: cpu: 48.0 C mobo: N/A
Fan Speeds (RPM): cpu: 801 fan-2: 993
Processes: 368 Uptime: 4m wakeups: 0 Memory: 15.31 GiB
used: 1.4 GiB (9.2%) Init: systemd v: 249 Compilers: gcc: 11.1.0 Packages:
pacman: 846 Shell: Bash v: 5.1.8 running-in: gnome-terminal inxi: 3.3.05
