Hello,
I have ASUS CROSSHAIR X670E HERO mainboard and there is no sound going out of the green jack (on EndeavourOS Neo, on Windows it works).
I can see in the mixer that audio is played through the correct device (the volume bar is moving) but there is no sound.
Found this:
journalctl --user -u pipewire -u wireplumber -u pipewire-pulse:
pipewire[2565]: pw.node: (alsa_output.pci-0000_01_00.1.pro-output-3-52) graph xrun not-triggered (0 suppressed)
pipewire[2565]: pw.node: (alsa_output.pci-0000_01_00.1.pro-output-3-52) xrun state:0x72a053586008 pending:1/3 s:0 a:0 f:0 waiting:0 process:0 status:triggered
pipewire[2565]: spa.alsa: Broken configuration: no configurations available: Nepřípustný argument
...skipping...
pipewire[2745]: spa.alsa: Broken configuration for playback: no configurations available: Nepřípustný argument
pipewire[2745]: spa.alsa: Broken configuration: no configurations available: Nepřípustný argument
pipewire[2745]: pw.node: (alsa_output.usb-Generic_USB_Audio-00.pro-output-2-55) graph xrun not-triggered (0 suppressed)
pipewire[2745]: pw.node: (alsa_output.usb-Generic_USB_Audio-00.pro-output-2-55) xrun state:0x7bca15848008 pending:2/3 s:192589695685 a:192589704562 f:192589708298 waiting:8877 process:3736 status:triggered
pipewire[2745]: pw.link: 0x581f8b518ad0: one of the nodes is in error out:running in:error
pipewire[2745]: pw.link: 0x581f8973fbb0: one of the nodes is in error out:running in:error
pipewire[2745]: pw.node: (alsa_output.usb-Generic_USB_Audio-00.pro-output-3-54) suspended -> error ((null))
pipewire[2745]: pw.node: (alsa_output.usb-Generic_USB_Audio-00.pro-output-0-57) graph xrun not-triggered (0 suppressed)
pipewire[2745]: pw.node: (alsa_output.usb-Generic_USB_Audio-00.pro-output-0-57) xrun state:0x7bca1584a008 pending:1/3 s:205492324795 a:205492334333 f:205492338590 waiting:9538 process:4257 status:triggered
pipewire[2745]: pw.node: (alsa_output.usb-Generic_USB_Audio-00.pro-output-1-56) graph xrun not-triggered (0 suppressed)
pipewire[2745]: pw.node: (alsa_output.usb-Generic_USB_Audio-00.pro-output-1-56) xrun state:0x7bca15849008 pending:1/2 s:209324611531 a:209324618564 f:209324621660 waiting:7033 process:3096 status:triggered
pipewire[2745]: pw.node: (alsa_output.usb-Generic_USB_Audio-00.pro-output-2-55) xrun state:0x7bca15848008 pending:1/2 s:209325283434 a:209325291359 f:209325294455 waiting:7925 process:3096 status:triggered
pipewire[2745]: pw.node: (alsa_input.usb-Generic_USB_Audio-00.pro-input-0-53) graph xrun not-triggered (2 suppressed)
pipewire[2745]: pw.node: (alsa_input.usb-Generic_USB_Audio-00.pro-input-0-53) xrun state:0x7bca14561008 pending:1/2 s:209326527614 a:209326533034 f:209326533585 waiting:5420 process:551 status:triggered
pipewire[2745]: pw.node: (alsa_output.usb-Generic_USB_Audio-00.pro-output-0-57) xrun state:0x7bca1584a008 pending:2/3 s:209326971922 a:209326985567 f:209326991218 waiting:13645 process:5651 status:triggered
pipewire[2745]: pw.node: (alsa_input.usb-Generic_USB_Audio-00.pro-input-2-68) graph xrun not-triggered (1 suppressed)
pipewire[2745]: pw.node: (alsa_input.usb-Generic_USB_Audio-00.pro-input-2-68) xrun state:0x7bca14554008 pending:1/2 s:209328223886 a:209328235227 f:209328235938 waiting:11341 process:711 status:triggered
pipewire[2745]: pw.node: (alsa_input.usb-Generic_USB_Audio-00.pro-input-1-67) graph xrun not-triggered (1 suppressed)
pipewire[2745]: pw.node: (alsa_input.usb-Generic_USB_Audio-00.pro-input-1-67) xrun state:0x7bca14555008 pending:1/1 s:209329220834 a:209329228649 f:209329229230 waiting:7815 process:581 status:triggered
pipewire[2745]: pw.node: (alsa_output.usb-Generic_USB_Audio-00.pro-output-3-54) idle -> error ((null))
aplay -l:
**** List of PLAYBACK Hardware Devices ****
card 0: HDMI [HDA ATI HDMI], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: HDMI [HDA ATI HDMI], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 0: HDMI [HDA ATI HDMI], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 0: HDMI [HDA ATI HDMI], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 0: HDMI [HDA ATI HDMI], device 10: HDMI 4 [U32E2WG6]
Subdevices: 1/1
card 0: HDMI [HDA ATI HDMI], device 11: HDMI 5 [HDMI 5]
Subdevices: 1/1
card 1: Generic [HD-Audio Generic], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 1: Generic [HD-Audio Generic], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 1: Generic [HD-Audio Generic], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 2: Audio [USB Audio], device 0: USB Audio [USB Audio]
Subdevices: 1/1
card 2: Audio [USB Audio], device 1: USB Audio [USB Audio #1]
Subdevices: 1/1
card 2: Audio [USB Audio], device 2: USB Audio [USB Audio #2]
Subdevices: 1/1
card 2: Audio [USB Audio], device 3: USB Audio [USB Audio #3]
Subdevices: 1/1
aplay -L:
null
Discard all samples (playback) or generate zero samples (capture)
lavrate
Rate Converter Plugin Using Libav/FFmpeg Library
samplerate
Rate Converter Plugin Using Samplerate Library
speexrate
Rate Converter Plugin Using Speex Resampler
jack
JACK Audio Connection Kit
oss
Open Sound System
pipewire
PipeWire Sound Server
pulse
PulseAudio Sound Server
speex
Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
upmix
Plugin for channel upmix (4,6,8)
vdownmix
Plugin for channel downmix (stereo) with a simple spacialization
default
Default ALSA Output (currently PipeWire Media Server)
hdmi:CARD=HDMI,DEV=0
HDA ATI HDMI, HDMI 0
HDMI Audio Output
hdmi:CARD=HDMI,DEV=1
HDA ATI HDMI, HDMI 1
HDMI Audio Output
hdmi:CARD=HDMI,DEV=2
HDA ATI HDMI, HDMI 2
HDMI Audio Output
hdmi:CARD=HDMI,DEV=3
HDA ATI HDMI, HDMI 3
HDMI Audio Output
hdmi:CARD=HDMI,DEV=4
HDA ATI HDMI, U32E2WG6
HDMI Audio Output
hdmi:CARD=HDMI,DEV=5
HDA ATI HDMI, HDMI 5
HDMI Audio Output
usbstream:CARD=HDMI
HDA ATI HDMI
USB Stream Output
hdmi:CARD=Generic,DEV=0
HD-Audio Generic, HDMI 0
HDMI Audio Output
hdmi:CARD=Generic,DEV=1
HD-Audio Generic, HDMI 1
HDMI Audio Output
hdmi:CARD=Generic,DEV=2
HD-Audio Generic, HDMI 2
HDMI Audio Output
usbstream:CARD=Generic
HD-Audio Generic
USB Stream Output
sysdefault:CARD=Audio
USB Audio, USB Audio
Default Audio Device
front:CARD=Audio,DEV=0
Front output / input
surround21:CARD=Audio,DEV=0
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=Audio,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=Audio,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=Audio,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=Audio,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=Audio,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=Audio,DEV=0
IEC958 (S/PDIF) Digital Audio Output
iec958:CARD=Audio,DEV=1
USB Audio, USB Audio #1
usbstream:CARD=Audio
USB Audio
USB Stream Output
Ideas?
