Hi,
I’ve been facing this issue for quite a while. I dropped EndeavourOS and tried a few other OSs and the issue pertains. Now I’ve come back and finally decided to make forum post instead of IRC.
I reinstalled it fresh today with 6.0.7 Kernel still can not see any output devices except the dummy output.
Audio doesn’t work with laptop speakers or earphones but works in bluetooth.
Alsa info
http://alsa-project.org/db/?f=353610dadbfeee6deb37e9dce6540eae5338c27e
Please assist with this! Thanks a lot.
inxi -A
Device-1: Intel Ice Lake-LP Smart Sound Audio driver: snd_hda_intel
Sound API: ALSA v: k6.0.7-arch1-1 running: yes
Sound Server-1: PipeWire v: 0.3.59 running: yes
ainz
November 10, 2022, 1:13pm
2
Welcome to the forum!
Try installing sof-firmware
sudo pacman -S sof-firmware
Then reboot.
You could try the following kernel parameter in /etc/default/grub
and then update grub with sudo grub-mkconfig -o /boot/grub/grub.cfg
add
snd-intel-dspcfg.dsp_driver=1
Edit: Or you could also create the option in
/etc/modprobe.d/inteldsp.conf
add
snd-intel-dspcfg dsp_driver=1
Hi,
Tried this. Have not seen any result. I have tried it before as well. Still showing no output devices.
eso
November 11, 2022, 11:11pm
5
Hello,what is the output of this line?
hwinfo | grep -i Sound | wc -l
for me 192 / Lenovo S145 81w8
It says only “157” nothing else.
eso
November 12, 2022, 10:19am
7
I have a HyperX headphone. If I subtract those lines than 118 with me.
a working config
eso
November 12, 2022, 11:19am
8
With Meld you can see the differences between our alsa-info files. /not found the reason/
In command window run
alsamixer
Check master volume if card is present
No it is not present. When I press F6. You can see intel HDA PCH But no card.
eso
November 21, 2022, 10:59pm
10
Hi, In the output of your
‘!!ALSA Information Script’ I see the same PipeWire ‘pseudo?’ card as in mine. From terminal my alsamixer shows this:
Sorry, I am not an expert.
If I boot an EOS live USB system (XFCE) the mixer works without any changes in config.
Same. But sound doesn’t work with live CD either. It works with Bluetooth though.
