Headphone connected through bluthooth and jack work but not the speakers
inxi -Aaz
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: ASUSTeK
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
chip-ID: 8086:51c8 class-ID: 0401
Sound API: ALSA v: k6.1.1-arch1-1 running: yes
Sound Interface: sndio v: N/A running: no
Sound Server-2: PipeWire v: 0.3.63 running: yes
Tried alsamixer but it show the device
Kernel: 6.1.1-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: initrd=\e50a4ec2e367489b958c0e970f60f09c\6.1.1-arch1-1\initrd
nvme_load=YES rw root=UUID=b7e5a354-e0e2-4d56-bca9-eb74c403fc8e
systemd.machine_id=e50a4ec2e367489b958c0e970f60f09c
Desktop: sway v: 1.7 info: waybar dm: SDDM Distro: EndeavourOS
base: Arch Linux
Type: Convertible System: ASUSTeK product: Zenbook UP6502ZD_UP6502ZD v: 1.0
serial: N6N0CV11M90125A
Mobo: ASUSTeK model: UP6502ZD v: 1.0 serial: N624NBCV00K10UMB
UEFI: American Megatrends LLC. v: UP6502ZD.303 date: 05/16/2022
Battery:
ID-1: BAT0 charge: 92.9 Wh (100.0%) condition: 92.9/96.0 Wh (96.8%)
volts: 13.1 min: 11.7 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: full cycles: 14
Device-1: hid-0018:04F3:2F09.0006-battery model: ELAN9008:00 04F3:2F09
serial: N/A charge: N/A status: N/A
Info: model: 12th Gen Intel Core i7-12700H socket: U3E1 bits: 64
type: MST AMCP arch: Alder Lake gen: core 12 level: v3 note: check
built: 2021+ process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154)
stepping: 3 microcode: 0x424
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 2538 high: 4293 min/max: 400/4600:4700:3500
base/boost: 2277/4700 scaling: driver: intel_pstate governor: powersave
volts: 0.9 V ext-clock: 100 MHz cores: 1: 2700 2: 2700 3: 838 4: 2700
5: 1723 6: 2700 7: 4293 8: 2700 9: 2700 10: 2700 11: 1555 12: 2700
13: 2700 14: 1866 15: 2700 16: 2700 17: 2700 18: 2700 19: 2700 20: 2700
bogomips: 107560
Vulnerabilities:
prctl
sanitization
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel Alder Lake-P Integrated Graphics vendor: ASUSTeK
driver: i915 v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+
ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2
bus-ID: 0000:00:02.0 chip-ID: 8086:46a6 class-ID: 0300
Device-2: Intel DG2 [Arc A370M] vendor: ASUSTeK driver: i915 v: kernel
arch: Gen-12.7 code: Alchemist process: TSMC n6 (7nm) built: 2022+ ports:
active: none empty: DP-3, DP-4, DP-5, DP-6, HDMI-A-3, HDMI-A-4, HDMI-A-5,
HDMI-A-6, HDMI-A-7 bus-ID: 0000:04:00.0 chip-ID: 8086:5693 class-ID: 0380
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 3-9:3 chip-ID: 13d3:5497 class-ID: fe01 serial: 200901010001
Display: server: X.org v: 1.21.1.6 with: Xwayland v: 22.1.7
compositor: sway v: 1.7 driver: X: loaded: N/A unloaded: intel,modesetting
alternate: fbdev,vesa dri: i965 gpu: i915 note: X driver n/a
display-ID: :1
Monitor-1: eDP-1 model: Samsung 0x416e built: 2021 res: 2880x1620 dpi: 213
gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
modes: 2880x1620
API: OpenGL Message: GL data unavailable for root.
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
modules: wl bus-ID: 0000:00:14.3 chip-ID: 8086:51f0 class-ID: 0280
IF: wlan0 state: up mac: f0:b6:1e:3a:86:49
Bluetooth:
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 3-10:4
chip-ID: 8087:0033 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 0 state: down bt-service: disabled
RAID:
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 953.87 GiB used: 9.58 GiB (1.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFM001TD3JX013N
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: FYA9N044711409T2A rev: 41000C20 temp: 40.9 C
scheme: GPT
SMART: yes health: PASSED on: 95d 16h cycles: 213
read-units: 6,833,284 [3.49 TB] written-units: 11,983,197 [6.13 TB]
ID-1: / raw-size: 952.89 GiB size: 936.85 GiB (98.32%) used: 9.49 GiB (1.0%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 49.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2900
Processes: 336 Uptime: 18m wakeups: 2562 Memory: 15.32 GiB
used: 2.41 GiB (15.7%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 993
libs: 241 tools: yay Shell: Bash (sudo) v: 5.1.16 running-in: xfce4-terminal
inxi: 3.3.24
