So, the problem is basically as the title says. I’ve got EndeavourOS installed on an ASUS ExpertCenter, and while i can get sound out of the port on the back panel, no sound comes through the front panel.
alsamixer could help or pavucontrol
usually, output will detect plugged jack and it should enable the plugged jack output…
alsamixer in terminal and press F6 to choose the card:
The problem seems to be that the sound device defaults to pipewire device. How do i set the default to the actual sound card, or can i uninstall pipewire all together?
pipewire is not a device… it is the default Soundsystem that manages audio devices on the software level…
It is connected with devices and other software like also or apps using pulseaudio…
But i would first try to check what exactly is the reason of the muted front audio…
I know that p.e. on a lot systems what you would call “front output” is called “headphone”
And what Jonathon mentioned to get enabled a hardware jack must be plugged with a connector to be enabled hardware sided… in case you have multiple output connectors plugged it have to default to one and the other will in most case muted… also it is plugged in…
So if you have something plugged in to “back audio output jack” the “front audio jack” is not active … if you plug in a plug into both only one will be unmuted…
you can set all other output devices to “off” with pacvucontrol GUI:
This is what opens when I run alsamixer on startup
And when it’s like that, I only get sound from the port on the back panel.
I only get all the other controls when I press F6 to switch the card:
And then I receive sound out of the front jack, and even bluetooth where before I wasn’t getting any sound at all.
I’m not sure what you mean by multiple output connectors, but if you’re referring to the sound card, then I only have the one device. The PC itself isn’t a custom build, it’s an off-the-shelf PC, so yes, the front and back jacks are connected internally. This is what my pavucontrol looks like:
can be multiple cards or also headphone Front and Line out from the same card what are 3 output connectors …
alsa mixer is only to check it is not to be used to setup devices and state of connectors… you could use alsa as it is an underlying mechanism to set up audio… but in normal circumstances, it does not need to do that.
but that pavucontrol only shows Build-in Audio could link to an issue … not sure why … it does that and do not show a “real” device name…
it is listed as detected here:
also not a good sign…
your pavucontrol shows this build-in audio as Off is this the state or did you put it off on testing?
I would like to see the detailed hardware info from: inxi -Aa
and pactl list | eos-sendlog
% Total % Received % Xferd Average Speed Time Time Time Current
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
curl: (60) SSL certificate problem: certificate has expired
More details here: https://curl.se/docs/sslcerts.html
curl failed to verify the legitimacy of the server and therefore could not
establish a secure connection to it. To learn more about this situation and
how to fix it, please visit the web page mentioned above.
I didn’t change anything pavucontrol, didn’t even use pavucontrol until your made mention of it
Also the output device in pavucontrol and in cinnamon sound settings shows up as ‘Dummy output’. Is that normal?
Tried and the device still shows up as dummy output.
Couldn’t upload the txt file from pactl list > ~/pactl-list.txt so i use 0x0.st instead. Here it is: output
