Hello. I have no sound on headphones. It is the same with other linux distrobutions. It is umuted.
uname -r
5.15.96.61.realtime1-1-rt-lts
pacman -Q | grep ^linux:
linux 6.2.2.arch1-1
linux-api-headers 6.1.9-1
linux-firmware 20230210.bf4115c-1
linux-firmware-whence 20230210.bf4115c-1
linux-headers 6.2.2.arch1-1
linux-rt-lts 5.15.96.61.realtime1-1
find /boot/vmli*:
find: ‘/boot/vmli*’: No such file or directory
sudo modprobe snd_hda_intel_codec:
modprobe: FATAL: Module snd_hda_intel_codec not found in directory /lib/modules/5.15.96.61.realtime1-1-rt-lts
cat /proc/asound/modules:
0 snd_hda_intel
1 snd_hda_intel
2 snd_hda_intel
pactl list sinks:
Sink #46
State: SUSPENDED
Description: Renoir Radeon High Definition Audio Controller Digital Stereo (HDMI)
Driver: PipeWire
Sample Specification: s32le 2ch 48000Hz
Channel Map: front-left,front-right
Owner Module: 4294967295
Mute: no
Volume: front-left: 48287 / 74% / -7,96 dB, front-right: 48287 / 74% / -7,96 dB
balance 0,00
Base Volume: 65536 / 100% / 0,00 dB
Monitor Source: alsa_output.pci-0000_08_00.1.hdmi-stereo.monitor
Latency: 0 usec, configured 0 usec
Flags: HARDWARE DECIBEL_VOLUME LATENCY SET_FORMATS
Properties:
object.path = "alsa:pcm:1:hdmi:1:playback"
api.alsa.path = "hdmi:1"
api.alsa.pcm.card = "1"
api.alsa.pcm.stream = "playback"
audio.channels = "2"
audio.position = "FL,FR"
device.routes = "1"
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "C49RG9x"
alsa.id = "HDMI 0"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "3"
alsa.card = "1"
alsa.card_name = "HD-Audio Generic"
alsa.long_card_name = "HD-Audio Generic at 0xfc588000 irq 75"
alsa.driver_name = "snd_hda_intel"
device.profile.name = "hdmi-stereo"
device.profile.description = "Digital Stereo (HDMI)"
card.profile.device = "2"
device.id = "44"
factory.name = "api.alsa.pcm.sink"
priority.driver = "632"
priority.session = "632"
media.class = "Audio/Sink"
node.nick = "HD-Audio Generic"
node.name = "alsa_output.pci-0000_08_00.1.hdmi-stereo"
device.description = "Renoir Radeon High Definition Audio Controller"
device.icon_name = "audio-card-hdmi"
device.bus = "pci"
device.bus_path = "pci-0000:08:00.1"
node.pause-on-idle = "false"
factory.id = "18"
clock.quantum-limit = "8192"
client.id = "37"
node.driver = "true"
factory.mode = "merge"
audio.adapt.follower = ""
library.name = "audioconvert/libspa-audioconvert"
object.id = "46"
object.serial = "46"
node.max-latency = "16384/48000"
api.alsa.period-size = "1024"
api.alsa.period-num = "32"
api.alsa.headroom = "0"
device.enum.api = "udev"
api.alsa.card = "1"
api.alsa.card.name = "HD-Audio Generic"
api.alsa.card.longname = "HD-Audio Generic at 0xfc588000 irq 75"
device.plugged.usec = "5631952"
sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:08:00.1/sound/card1"
device.subsystem = "sound"
device.vendor.id = "0x1002"
device.vendor.name = "Advanced Micro Devices, Inc. [AMD/ATI]"
device.product.id = "0x1637"
device.product.name = "Renoir Radeon High Definition Audio Controller"
device.name = "alsa_card.pci-0000_08_00.1"
device.nick = "HD-Audio Generic"
api.alsa.use-acp = "true"
api.acp.auto-profile = "false"
api.acp.auto-port = "false"
api.dbus.ReserveDevice1 = "Audio1"
device.string = "1"
Ports:
hdmi-output-0: HDMI / DisplayPort (type: HDMI, priority: 5900, availability group: Legacy 1, available)
Active Port: hdmi-output-0
Formats:
pcm
Sink #47
State: SUSPENDED
Description: Family 17h/19h HD Audio Controller Digital Stereo (IEC958)
Driver: PipeWire
Mute: no
balance 0,00
Monitor Source: alsa_output.pci-0000_08_00.6.iec958-stereo.monitor
Flags: HARDWARE HW_MUTE_CTRL DECIBEL_VOLUME LATENCY SET_FORMATS
Properties:
object.path = "alsa:pcm:2:iec958:2:playback"
api.alsa.path = "iec958:2"
api.alsa.pcm.card = "2"
device.routes = "1"
device.api = "alsa"
alsa.name = "ALCS1200A Digital"
alsa.id = "ALCS1200A Digital"
alsa.device = "1"
alsa.card = "2"
alsa.long_card_name = "HD-Audio Generic at 0xfc580000 irq 76"
device.profile.name = "iec958-stereo"
device.profile.description = "Digital Stereo (IEC958)"
card.profile.device = "11"
device.id = "45"
priority.driver = "608"
priority.session = "608"
node.name = "alsa_output.pci-0000_08_00.6.iec958-stereo"
device.description = "Family 17h/19h HD Audio Controller"
device.icon_name = "audio-card-iec958"
device.bus = "pci"
device.bus_path = "pci-0000:08:00.6"
factory.id = "18"
client.id = "37"
object.id = "47"
object.serial = "47"
api.alsa.card = "2"
api.alsa.card.longname = "HD-Audio Generic at 0xfc580000 irq 76"
device.plugged.usec = "5680263"
sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:08:00.6/sound/card2"
device.vendor.id = "0x1022"
device.vendor.name = "Advanced Micro Devices, Inc. [AMD]"
device.product.id = "0x15e3"
device.product.name = "Family 17h/19h HD Audio Controller"
device.name = "alsa_card.pci-0000_08_00.6"
api.dbus.ReserveDevice1 = "Audio2"
device.string = "2"
Ports:
iec958-stereo-output: Digital Output (S/PDIF) (type: SPDIF, priority: 0, availability unknown)
Active Port: iec958-stereo-output
Formats:
pcm
inxi -Axxx:
Device-1: NVIDIA GA106 High Definition Audio vendor: ZOTAC
driver: snd_hda_intel v: kernel pcie: speed: 8 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:228e class-ID: 0403
Device-2: AMD Renoir Radeon High Definition Audio vendor: ASUSTeK
bus-ID: 08:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-3: AMD Family 17h/19h HD Audio vendor: ASUSTeK
bus-ID: 08:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound API: ALSA v: k5.15.96.61.realtime1-1-rt-lts running: yes
Sound Server-2: PipeWire v: 0.3.66 running: yes
aplay -l:
*** List of PLAYBACK Hardware Devices ****
card 0: NVidia [HDA NVidia], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: NVidia [HDA NVidia], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 0: NVidia [HDA NVidia], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 0: NVidia [HDA NVidia], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 0: NVidia [HDA NVidia], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
card 0: NVidia [HDA NVidia], device 11: HDMI 5 [HDMI 5]
Subdevices: 1/1
card 0: NVidia [HDA NVidia], device 12: HDMI 6 [HDMI 6]
Subdevices: 1/1
card 1: Generic [HD-Audio Generic], device 3: HDMI 0 [C49RG9x]
Subdevices: 1/1
card 1: Generic [HD-Audio Generic], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 2: Generic_1 [HD-Audio Generic], device 0: ALCS1200A Analog [ALCS1200A Analog]
Subdevices: 1/1
card 2: Generic_1 [HD-Audio Generic], device 1: ALCS1200A Digital [ALCS1200A Digital]
Subdevices: 1/1
journalctl -k | grep -Ei "ALSA|HDA|sof[-]|HDMI|snd[_-]|sound|hda.codec|hda.intel":
mars 10 13:13:38 Daniel-PC kernel: ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
mars 10 13:13:40 Daniel-PC kernel: snd_hda_intel 0000:01:00.1: enabling device (0000 -> 0002)
mars 10 13:13:40 Daniel-PC kernel: snd_hda_intel 0000:01:00.1: Disabling MSI
mars 10 13:13:40 Daniel-PC kernel: snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
mars 10 13:13:40 Daniel-PC kernel: snd_hda_intel 0000:08:00.1: enabling device (0000 -> 0002)
mars 10 13:13:40 Daniel-PC kernel: snd_hda_intel 0000:08:00.1: Handle vga_switcheroo audio client
mars 10 13:13:40 Daniel-PC kernel: snd_hda_intel 0000:08:00.6: enabling device (0000 -> 0002)
mars 10 13:13:40 Daniel-PC kernel: input: HD-Audio Generic HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:08.1/0000:08:00.1/sound/card1/input5
mars 10 13:13:40 Daniel-PC kernel: input: HD-Audio Generic HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:08.1/0000:08:00.1/sound/card1/input6
mars 10 13:13:40 Daniel-PC kernel: input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input7
mars 10 13:13:40 Daniel-PC kernel: input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input8
mars 10 13:13:40 Daniel-PC kernel: input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input9
mars 10 13:13:40 Daniel-PC kernel: input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input10
mars 10 13:13:40 Daniel-PC kernel: input: HDA NVidia HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input11
mars 10 13:13:40 Daniel-PC kernel: input: HDA NVidia HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input12
mars 10 13:13:40 Daniel-PC kernel: input: HDA NVidia HDMI/DP,pcm=12 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input13
mars 10 13:13:40 Daniel-PC kernel: snd_hda_codec_realtek hdaudioC2D0: ALCS1200A: SKU not ready 0x00000000
mars 10 13:13:40 Daniel-PC kernel: snd_hda_codec_realtek hdaudioC2D0: autoconfig for ALCS1200A: line_outs=3 (0x14/0x15/0x16/0x0/0x0) type:line
mars 10 13:13:40 Daniel-PC kernel: snd_hda_codec_realtek hdaudioC2D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
mars 10 13:13:40 Daniel-PC kernel: snd_hda_codec_realtek hdaudioC2D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
mars 10 13:13:40 Daniel-PC kernel: snd_hda_codec_realtek hdaudioC2D0: mono: mono_out=0x0
mars 10 13:13:40 Daniel-PC kernel: snd_hda_codec_realtek hdaudioC2D0: dig-out=0x1e/0x0
mars 10 13:13:40 Daniel-PC kernel: snd_hda_codec_realtek hdaudioC2D0: inputs:
mars 10 13:13:40 Daniel-PC kernel: snd_hda_codec_realtek hdaudioC2D0: Front Mic=0x19
mars 10 13:13:40 Daniel-PC kernel: snd_hda_codec_realtek hdaudioC2D0: Rear Mic=0x18
mars 10 13:13:40 Daniel-PC kernel: snd_hda_codec_realtek hdaudioC2D0: Line=0x1a
mars 10 13:13:40 Daniel-PC kernel: input: HD-Audio Generic Front Mic as /devices/pci0000:00/0000:00:08.1/0000:08:00.6/sound/card2/input15
mars 10 13:13:40 Daniel-PC kernel: input: HD-Audio Generic Rear Mic as /devices/pci0000:00/0000:00:08.1/0000:08:00.6/sound/card2/input16
mars 10 13:13:40 Daniel-PC kernel: input: HD-Audio Generic Line as /devices/pci0000:00/0000:00:08.1/0000:08:00.6/sound/card2/input17
mars 10 13:13:40 Daniel-PC kernel: input: HD-Audio Generic Line Out Front as /devices/pci0000:00/0000:00:08.1/0000:08:00.6/sound/card2/input18
mars 10 13:13:40 Daniel-PC kernel: input: HD-Audio Generic Line Out Surround as /devices/pci0000:00/0000:00:08.1/0000:08:00.6/sound/card2/input19
mars 10 13:13:40 Daniel-PC kernel: input: HD-Audio Generic Line Out CLFE as /devices/pci0000:00/0000:00:08.1/0000:08:00.6/sound/card2/input20
mars 10 13:13:40 Daniel-PC kernel: input: HD-Audio Generic Front Headphone as /devices/pci0000:00/0000:00:08.1/0000:08:00.6/sound/card2/input21
mars 10 13:13:41 Daniel-PC kernel: snd_hda_intel 0000:08:00.1: bound 0000:08:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
