No sound and pavucontrol doesn't detect sound cards
Hi, since today I don’t have sound and pavucontrol doesn’t detect sound cards. I suspected it was the update of alsa-sound-cards who was the culprit but reverting to an older version did not help.
I also tried to reinstall the kernel but it did not help.
Kernel: 5.11.8-arch1-1
here’s an inxi output
┌─[xavierp@xavier-20l5cto1ww] - [~] - [Wed Mar 24, 09:35]
└─[$] <> inxi -F
System:    Host: xavier-20l5cto1ww Kernel: 5.11.8-arch1-1 x86_64 bits: 64 Desktop: KDE Plasma 5.21.3 Distro: EndeavourOS
Machine:   Type: Laptop System: LENOVO product: 20L5CTO1WW v: ThinkPad T480 serial: <superuser required>
           Mobo: LENOVO model: 20L5CTO1WW v: SDK0J40709 WIN serial: <superuser required> UEFI: LENOVO v: N24ET61W (1.36 )
           date: 10/13/2020
Battery:   ID-1: BAT0 charge: 19.3 Wh condition: 20.3/23.9 Wh (85%)
           ID-2: BAT1 charge: 57.5 Wh condition: 59.3/71.1 Wh (83%)
CPU:       Info: Quad Core model: Intel Core i7-8550U bits: 64 type: MT MCP L2 cache: 8 MiB
           Speed: 1900 MHz min/max: 400/4000 MHz Core speeds (MHz): 1: 1900 2: 1900 3: 1900 4: 1900 5: 1900 6: 1900 7: 1900
           8: 1900
Graphics:  Device-1: Intel UHD Graphics 620 driver: i915 v: kernel
           Device-2: NVIDIA GP108M [GeForce MX150] driver: nvidia v: 460.67
           Device-3: Acer Integrated IR Camera type: USB driver: uvcvideo
           Device-4: Acer SunplusIT Integrated Camera type: USB driver: uvcvideo
           Display: x11 server: X.Org 1.20.10 driver: loaded: intel,nvidia unloaded: fbdev,modesetting,vesa resolution:
           1: 2560x1440~60Hz 2: 1440x2560~60Hz
Audio:     Device-1: Intel Sunrise Point-LP HD Audio driver: snd_hda_intel
           Device-2: Logitech HD Pro Webcam C920 type: USB driver: snd-usb-audio,uvcvideo
           Device-3: Blue Microphones Yeti Stereo Microphone type: USB driver: snd-usb-audio
           Device-4: Lenovo ThinkPad Thunderbolt 3 Dock USB Audio type: USB driver: hid-generic,snd-usb-audio,usbhid
           Sound Server: ALSA v: k5.11.8-arch1-1
Network:   Device-1: Intel Ethernet I219-V driver: e1000e
           IF: enp0s31f6 state: down mac: 98:fa:9b:28:26:16
           Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi
           IF: wlan0 state: up mac: 84:fd:d1:1e:71:7f
           Device-3: Lenovo ThinkPad TBT 3 Dock type: USB driver: r8152
           IF: enp9s0u2u1u2 state: down mac: 3c:e1:a1:c3:ae:e2
           IF-ID-1: docker0 state: down mac: 02:42:7a:99:63:c5
Bluetooth: Device-1: Intel Bluetooth wireless interface type: USB driver: btusb
           Message: Required tool hciconfig not installed. Check --recommends
Drives:    Local Storage: total: 931.51 GiB used: 159.15 GiB (17.1%)
           ID-1: /dev/sda vendor: Samsung model: SSD 860 EVO 1TB size: 931.51 GiB
Partition: ID-1: / size: 915.6 GiB used: 159.15 GiB (17.4%) fs: ext4 dev: /dev/dm-0
           ID-2: /boot/efi size: 299.4 MiB used: 2.6 MiB (0.9%) fs: vfat dev: /dev/sda1
Swap:      Alert: No Swap data was found.
Sensors:   System Temperatures: cpu: 49.0 C mobo: 44.0 C
           Fan Speeds (RPM): cpu: 2863
Info:      Processes: 302 Uptime: 2m Memory: 31.25 GiB used: 3.37 GiB (10.8%) Shell: Zsh inxi: 3.3.01
┌─[xavierp@xavier-20l5cto1ww] - [~] - [Wed Mar 24, 09:36]
Have you uninstalled something recently?
A longshot, but a few things over the years have removed the pulseaudio package for me because it was a dependency for the thing I removed for some stupid reason.
Check if the package pulseaudio is installed.
No not that I remember, there was a big update yesterday.
I’m using pipewire not pulse.
Ok so I solved it here are the step:
  1. Realise that last update might have broken something
  2. Look at pacman’s logs by using a random ide
vim /var/log/pacman.log
  1. Hunt down anything related to audio that were updated yesterday
[2021-03-23T21:16:28+0100] [ALPM] upgraded alsa-card-profiles
[2021-03-23T21:16:41+0100] [ALPM] upgraded pipewire (1:0.3.23-1 -> 1:0.3.24-1)
[2021-03-23T21:16:41+0100] [ALPM] warning: /etc/pipewire/media-session.d/media-session.conf installed as /etc/pipewire/media-session.d/media-session.conf.pacnew
[2021-03-23T21:16:41+0100] [ALPM] upgraded pipewire-media-session (1:0.3.23-1 -> 1:0.3.24-1)
[2021-03-23T21:16:41+0100] [ALPM] upgraded pipewire-pulse (1:0.3.23-1 -> 1:0.3.24-1)
  1. Realise that somehow the pipewire or alsa update broke something
  2. Fix it by downgrading to the previous version using package downgrade
└─[$] <> sudo downgrade pipewire
└─[$] <> sudo downgrade pipewire-media-session
└─[$] <> sudo downgrade pipewire-pulse
└─[$] <> sudo downgrade alsa-card-profiles
  1. Reboot
  2. Pray
I have removed the different prompt you have to go through but you get the idea.
I am running Xfce and switched to Pipewire today just because. Worked fine, but then 1. Xfce as I said, 2. The update in itself might be an issue, I installed the version fresh.
The real issue is you did not deal with the pacnew file. If you don’t deal with it next time you update it will break again.
The welcome application has a button just for this purpose.
Maybe another sticky note about pipewire?
I think I need to make a couple. One for pacnew files and another for xf86-video-intel needing to be removed.
So I did what you were talking about but now should I upgrade or not ?
You have to deal with the .pacnew, like here or here.
@csteinforth has given you a few good links. This thread also has a lot of information on how to deal with pacnew files. Sorry for the late reply I was driving home from work.
Or you can use the welcome app like so:
OT: first timeshift and now welcome in dark and red :wink:
Thanks will try tomorrow !
I still don’t understand these pacnew files and what i’m supposed to do with them. I see pacnew all the time but have never done anything? :thinking: I run pacdiff and it shows nothing.
