Please help, no sound card detected.
stefano@stefano-tobefilledbyoem ~]$ inxi -F
System: Host: stefano-tobefilledbyoem Kernel: 5.8.14-arch1-1 x86_64 bits: 64 Desktop: Cinnamon 4.6.7 Distro: EndeavourOS
Machine: Type: Desktop Mobo: ASRock model: FM2A58M-DG3+ serial: <superuser/root required> BIOS: American Megatrends v: P2.00
date: 05/11/2015
CPU: Info: Dual Core model: AMD A4-6300 APU with Radeon HD Graphics bits: 64 type: MCP L2 cache: 1024 KiB
Speed: 1795 MHz min/max: 1800/3700 MHz Core speeds (MHz): 1: 2726 2: 3057
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Richland [Radeon HD 8370D] driver: radeon v: kernel
Display: x11 server: X.Org 1.20.9 driver: ati,radeon unloaded: fbdev,modesetting,vesa resolution: 1440x900~75Hz
Audio: Device-1: Advanced Micro Devices [AMD/ATI] Trinity HDMI Audio driver: snd_hda_intel
Device-2: Advanced Micro Devices [AMD] FCH Azalia driver: snd_hda_intel
Sound Server: ALSA v: k5.8.14-arch1-1
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8168
IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: d0:50:99:8a:82:a3
Device-2: Qualcomm Atheros AR9485 Wireless Network Adapter driver: ath9k
IF: wlan0 state: down mac: 7e:02:dd:d5:b9:10
Drives: Local Storage: total: 931.51 GiB used: 12.43 GiB (1.3%)
ID-1: /dev/sda vendor: Toshiba model: DT01ACA100 size: 931.51 GiB
Partition: ID-1: / size: 698.72 GiB used: 12.43 GiB (1.8%) fs: ext4 dev: /dev/sda3
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 15.0 C mobo: N/A gpu: radeon temp: 3.0 C
Fan Speeds (RPM): N/A
Info: Processes: 163 Uptime: 15m Memory: 6.73 GiB used: 2.21 GiB (32.9%) Shell: Bash inxi: 3.1.07
[stefano@stefano-tobefilledbyoem ~]$
ringo
October 11, 2020, 8:26am
2
do you use the hdmi part of sound or plug… could be not setup properly in pavucontrol.
in the last tab…
That is not correct according to your post.
Did you install pavucontrol
and try to set up your audio settings?
Edit : Again too slow
Well i reboot it with endeavour usb live and sound works great.
Now i’m reinstalling base system os.
Perhaps kde and cinnamon desktops env gets wrong.
Trying to replace partition.
I’ll let you know later.
Thanks
ringo
October 11, 2020, 8:52am
5
To check some issu3s is good with patience as with sound is importand. Reinstalling wont fix always. Random occcurance does not learn. But at the end we come to a solution
You’re right but i had other issues apart sound card.
Hope everything goes well after reinstall.
Still waiting end of it.
Thank you.
Ok now sound card works fine.
Have another problem: ethernet card does not.
1st install worked fine, new install it does’nt.
Get crazy
ringo
October 11, 2020, 11:13am
8
ok what is output of pacman -Qs r8168 ?
the 8169 is standard in the kernel but mayby is after install removed somehow …check if r8168 is installed…
ringo
October 11, 2020, 11:16am
9
sometimes you need 8168 and other time 8169 for other cases are
but not for everyone, i think you need r8168 driver n you have to confirm with pacman -Qs r8168 .
Ok i need to try but now i’m connected with other distro.
Let u know later, thanks.
Well no wired internet connection but wifi 20 kbi/s, impossible to receive data in time.
I must leave endeavour os on my amd desktop pc but i’m testing it on my laptop lenovo Intel Core i5-8300H as it’s working perfectly with kde plasma.
Thank you anyway, see you soon.
by the way : no response asking pacman -Qs r8168.
ringo
October 11, 2020, 4:38pm
12
lspci you see mostly what kinda chipset you use and on that inxi command you post… was on the asrock , i cannot tell basicly but some cards need straight 8168… while other need 8169 and thats in the kernel basicly.
@stefano57
Please post this command.
lspci -v
