gaming123@gaming-machine ~ cat /lib/udev/rules.d/61-gdm.rules
# identify virtio graphics cards to find passthrough setups
SUBSYSTEM!="virtio", GOTO="gdm_virtio_device_end"
ACTION!="add", GOTO="gdm_virtio_device_end"
ATTR{vendor}=="0x1af4", ATTR{device}=="0x0010", RUN+="/usr/bin/touch /run/udev/gdm-machine-has-virtual-gpu", ENV{GDM_MACHINE_HAS_VIRTUAL_GPU}="1", GOTO="gdm_virtio_device_end"
LABEL="gdm_virtio_device_end"
SUBSYSTEM!="pci", GOTO="gdm_pci_device_end"
ACTION!="bind", GOTO="gdm_pci_device_end"
# cirrus
ATTR{vendor}=="0x1013", ATTR{device}=="0x00b8", ATTR{subsystem_vendor}=="0x1af4", ATTR{subsystem_device}=="0x1100", RUN+="/usr/bin/touch /run/udev/gdm-machine-has-virtual-gpu", ENV{GDM_MACHINE_HAS_VIRTUAL_GPU}="1", GOTO="gdm_pci_device_end"
# vga
ATTR{vendor}=="0x1b36", ATTR{device}=="0x0100", RUN+="/usr/bin/touch /run/udev/gdm-machine-has-virtual-gpu", ENV{GDM_MACHINE_HAS_VIRTUAL_GPU}="1", GOTO="gdm_pci_device_end"
# qxl
ATTR{vendor}=="0x1234", ATTR{device}=="0x1111", RUN+="/usr/bin/touch /run/udev/gdm-machine-has-virtual-gpu", ENV{GDM_MACHINE_HAS_VIRTUAL_GPU}="1", GOTO="gdm_pci_device_end"
# disable Wayland on Hi1710 chipsets
ATTR{vendor}=="0x19e5", ATTR{device}=="0x1711", GOTO="gdm_disable_wayland"
# disable Wayland on Matrox chipsets
ATTR{vendor}=="0x102b", ATTR{device}=="0x0522", GOTO="gdm_disable_wayland"
ATTR{vendor}=="0x102b", ATTR{device}=="0x0524", GOTO="gdm_disable_wayland"
ATTR{vendor}=="0x102b", ATTR{device}=="0x0530", GOTO="gdm_disable_wayland"
ATTR{vendor}=="0x102b", ATTR{device}=="0x0532", GOTO="gdm_disable_wayland"
ATTR{vendor}=="0x102b", ATTR{device}=="0x0533", GOTO="gdm_disable_wayland"
ATTR{vendor}=="0x102b", ATTR{device}=="0x0534", GOTO="gdm_disable_wayland"
ATTR{vendor}=="0x102b", ATTR{device}=="0x0536", GOTO="gdm_disable_wayland"
ATTR{vendor}=="0x102b", ATTR{device}=="0x0538", GOTO="gdm_disable_wayland"
# disable Wayland on aspeed chipsets
ATTR{vendor}=="0x1a03", ATTR{device}=="0x2010", GOTO="gdm_disable_wayland"
ATTR{vendor}=="0x1a03", ATTR{device}=="0x2000", GOTO="gdm_disable_wayland"
LABEL="gdm_pci_device_end"
# disable Wayland if modesetting is disabled
KERNEL!="card[0-9]*", GOTO="gdm_nomodeset_end"
SUBSYSTEM!="drm", GOTO="gdm_nomodeset_end"
IMPORT{parent}="GDM_MACHINE_HAS_VIRTUAL_GPU"
ENV{GDM_MACHINE_HAS_VIRTUAL_GPU}!="1", RUN+="/usr/bin/touch /run/udev/gdm-machine-has-hardware-gpu"
# but keep it enabled for simple framebuffer drivers
DRIVERS=="simple-framebuffer", GOTO="gdm_nomodeset_end"
IMPORT{cmdline}="nomodeset", GOTO="gdm_disable_wayland"
LABEL="gdm_nomodeset_end"
# The vendor nvidia driver has multiple modules that need to be loaded before GDM can make an
# informed choice on which way to proceed, so force GDM to wait until NVidia's modules are
# loaded before starting up.
KERNEL!="nvidia", GOTO="gdm_nvidia_end"
SUBSYSTEM!="module", GOTO="gdm_nvidia_end"
ACTION!="add", GOTO="gdm_nvidia_end"
RUN+="/usr/bin/touch /run/udev/gdm-machine-has-vendor-nvidia-driver"
# Check if suspend/resume services necessary for working wayland support is available
TEST{0711}!="/usr/bin/nvidia-sleep.sh", GOTO="gdm_disable_wayland"
TEST{0711}!="/usr/lib/systemd/system-sleep/nvidia", GOTO="gdm_disable_wayland"
IMPORT{program}="/bin/sh -c \"sed -e 's/: /=/g' -e 's/\([^[:upper:]]\)\([[:upper:]]\)/\1_\2/g' -e 's/[[:lower:]]/\U&/g' -e 's/^/NVIDIA_/' /proc/driver/nvidia/params\""
ENV{NVIDIA_PRESERVE_VIDEO_MEMORY_ALLOCATIONS}!="1", GOTO="gdm_disable_wayland"
IMPORT{program}="/bin/sh -c 'echo NVIDIA_HIBERNATE=`systemctl is-enabled nvidia-hibernate`'"
ENV{NVIDIA_HIBERNATE}!="enabled", GOTO="gdm_disable_wayland"
IMPORT{program}="/bin/sh -c 'echo NVIDIA_RESUME=`systemctl is-enabled nvidia-resume`'"
ENV{NVIDIA_RESUME}!="enabled", GOTO="gdm_disable_wayland"
IMPORT{program}="/bin/sh -c 'echo NVIDIA_SUSPEND=`systemctl is-enabled nvidia-suspend`'"
ENV{NVIDIA_SUSPEND}!="enabled", GOTO="gdm_disable_wayland"
LABEL="gdm_nvidia_end"
# If this machine has an internal panel, take note, since it's probably a laptop
# FIXME: It could be "ghost connectors" make this pop positive for some workstations
# in the wild. If so, we may have to fallback to looking at the chassis type from
# dmi data or acpi
KERNEL!="card[0-9]-eDP-*", GOTO="gdm_laptop_check_end"
SUBSYSTEM!="drm", GOTO="gdm_laptop_check_end"
ACTION!="add", GOTO="gdm_laptop_check_end"
RUN+="/usr/bin/touch /run/udev/gdm-machine-is-laptop"
GOTO="gdm_hybrid_nvidia_laptop_check"
LABEL="gdm_laptop_check_end"
# If this is a hybrid graphics setup, take note
KERNEL!="card[1-9]*", GOTO="gdm_hybrid_graphics_check_end"
KERNEL=="card[1-9]-*", GOTO="gdm_hybrid_graphics_check_end"
SUBSYSTEM!="drm", GOTO="gdm_hybrid_graphics_check_end"
ACTION!="add", GOTO="gdm_hybrid_graphics_check_end"
RUN+="/usr/bin/touch /run/udev/gdm-machine-has-hybrid-graphics"
LABEL="gdm_hybrid_graphics_check_end"
# If this is a hybrid graphics laptop with vendor nvidia driver, disable wayland
LABEL="gdm_hybrid_nvidia_laptop_check"
TEST!="/run/udev/gdm-machine-is-laptop", GOTO="gdm_hybrid_nvidia_laptop_check_end"
TEST!="/run/udev/gdm-machine-has-hybrid-graphics", GOTO="gdm_hybrid_nvidia_laptop_check_end"
TEST!="/run/udev/gdm-machine-has-vendor-nvidia-driver", GOTO="gdm_hybrid_nvidia_laptop_check_end"
LABEL="gdm_hybrid_nvidia_laptop_check_end"
# Disable wayland in situation where we're in a guest with a virtual gpu and host passthrough gpu
LABEL="gdm_virt_passthrough_check"
TEST!="/run/udev/gdm-machine-has-hybrid-graphics", GOTO="gdm_virt_passthrough_check_end"
TEST!="/run/udev/gdm-machine-has-virtual-gpu", GOTO="gdm_virt_passthrough_check_end"
TEST!="/run/udev/gdm-machine-has-hardware-gpu", GOTO="gdm_virt_passthrough_check_end"
LABEL="gdm_virt_passthrough_check_end"
# Disable wayland when there are multiple virtual gpus
LABEL="gdm_virt_multi_gpu_check"
TEST!="/run/udev/gdm-machine-has-hybrid-graphics", GOTO="gdm_virt_multi_gpu_check_end"
TEST!="/run/udev/gdm-machine-has-virtual-gpu", GOTO="gdm_virt_multi_gpu_check_end"
TEST=="/run/udev/gdm-machine-has-hardware-gpu", GOTO="gdm_virt_multi_gpu_check_end"
LABEL="gdm_virt_multi_gpu_check_end"
# Disable wayland when nvidia modeset is disabled or when drivers are a lower
# version than 470,
# For versions above 470 but lower than 510 prefer Xorg,
# Above 510, prefer Wayland.
KERNEL!="nvidia_drm", GOTO="gdm_nvidia_drm_end"
SUBSYSTEM!="module", GOTO="gdm_nvidia_drm_end"
ACTION!="add", GOTO="gdm_nvidia_drm_end"
# disable wayland if nvidia-drm modeset is not enabled
ATTR{parameters/modeset}!="Y", GOTO="gdm_disable_wayland"
# disable wayland for nvidia drivers versions lower than 470
ATTR{version}=="4[0-6][0-9].*|[0-3][0-9][0-9].*|[0-9][0-9].*|[0-9].*", GOTO="gdm_disable_wayland"
# For nvidia drivers versions Above 510, keep Wayland by default
ATTR{version}=="[5-9][1-9][0-9].*", GOTO="gdm_end"
# For nvidia drivers versions 470-495, prefer Xorg by default
GOTO="gdm_prefer_xorg"
LABEL="gdm_nvidia_drm_end"
GOTO="gdm_end"
LABEL="gdm_prefer_xorg"
RUN+="/usr/lib/gdm-runtime-config set daemon PreferredDisplayServer xorg"
GOTO="gdm_end"
LABEL="gdm_disable_wayland"
RUN+="/usr/lib/gdm-runtime-config set daemon WaylandEnable false"
GOTO="gdm_end"
LABEL="gdm_end"
You have hybrid graphics:
Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q]
vendor: Hewlett-Packard driver: nvidia v: 520.56.06 arch: Ampere pcie:
speed: 5 GT/s lanes: 8 ports: active: none empty: DP-1,HDMI-A-1
bus-ID: 01:00.0 chip-ID: 10de:2520
Device-2: AMD Cezanne vendor: Hewlett-Packard driver: amdgpu v: kernel
arch: GCN-5.1 pcie: speed: 8 GT/s lanes: 16 ports: active: eDP-1
empty: DP-2 bus-ID: 07:00.0 chip-ID: 1002:1638 temp: 46.0 C
Device-3: Chicony HP Wide Vision HD Camera type: USB driver: uvcvideo
bus-ID: 1-3:2 chip-ID: 04f2:b735
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.4
compositor: gnome-shell driver: X: loaded: amdgpu,nvidia dri: radeonsi
gpu: amdgpu display-ID: :1 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96
Monitor-1: eDP-1 mapped: eDP-1-0 model: BOE Display 0x09f2 res: 1920x1080
dpi: 137 diag: 407mm (16")
OpenGL: renderer: NVIDIA GeForce RTX 3060 Laptop GPU/PCIe/SSE2 v: 4.6.0
NVIDIA 520.56.06 direct render: Yes
So if I am reading the /lib/udev/rules.d/61-gdm.rules correctly, it says:
So it looks like Wayland is disabled by default with proprietary nvidia driver.
Again, I don’t have experience with hybrid graphics.
You might need a “special” setup to make this work.
Please wait for forum members with experience on running GNOME-Wayland on hybrid graphics with Nvidia to come to assist.
I would check the arch wiki
https://wiki.archlinux.org/title/GDM#Wayland_and_the_proprietary_NVIDIA_driver
Seems it should default to Wayland as of 510 Nvidia driver. There are also some tips about how to enable it
And OP has:
NVIDIA 520.56.06
Maybe conflict with plasma… this post has been cryptic to begin with. Could be any other settings user changed or not.
I can agree with that post
Who hasn’t … ![]()
Have you ever tried eos with gnome installation only? Did you then run Wayland? Or is this your first eos install and selected both plasma/gnome.
Any other system changes like config files edits?
Something I would try for the sake of testing is to install plasma-wayland-session as suggested further up in the thread and check if that would give an option to log into a Wayland session on Plasma.
You could try sddm instead of gdm as well
