I’m trying to yay -Syu protonvpn but I get this error:
==> Starting build()...
File "/home/me/.cache/yay/python-proton-client/src/proton-python-client-0.7.1/setup.py", line 4, in <module>
from proton.constants import VERSION
File "/home/me/.cache/yay/python-proton-client/src/proton-python-client-0.7.1/proton/__init__.py", line 1, in <module>
from .api import Session # noqa
File "/home/me/.cache/yay/python-proton-client/src/proton-python-client-0.7.1/proton/api.py", line 5, in <module>
import gnupg
ModuleNotFoundError: No module named 'gnupg'
==> ERROR: A failure occurred in build().
Aborting...
-> error making: python-proton-client
However, I have both gnupg and python-gnupg installed. If it helps, my python --version is 3.10.7.
What should I do? Searching online, apparently no one has ever had this issue before.
Are you certain about the python version? Mine was upgraded to 3.10.8 back in October. Maybe just run yay and let it upgrade everything, then try again. The package python-gunpg contains the module that proton is complaining about, so that shouldn’t be an issue. Querying the AUR does not show a build dependency on python-gnupg, either.
Now I see what happened. My system was up-to-date. sudo pacman -Syu and yay -Syu told me there were no updates to install. Yet, as you point out, my Python was oudated.
I’m using asdf-vm to install and manage user Python versions. My ~/.tool-versions file said this:
