No hardware acceleration with integrated intel gpu
This is my first time trying out endevouros. Everything seems to be working except hardware acceleration when playing movies. For instance, in smplayer, I have vaapi set as the video driver. However, I notice higher the usual cpu usage when playing videos. It turns out that I’m not having any hardware decoding. I was able to confirm that using intel_gpu_tool. I don’t know much about endevouros. So, I hope someone can help. Hardware acceleration using the intel gpu used to work when I was on manjaro. The only drivers I installed are via nvidia-inst -p --32 .
~ ❯ inxi -G
  Device-1: Intel Coffee Lake-S GT2 [UHD Graphics P630] driver: i915
    v: kernel
  Device-2: NVIDIA GP107GLM [Quadro P2000 Mobile] driver: nvidia
    v: 545.29.06
  Device-3: Chicony Integrated Camera (1280x720@30) driver: uvcvideo
    type: USB
  Display: x11 server: X.Org v: 21.1.9 driver: X:
    loaded: modesetting,nvidia dri: iris gpu: i915
    resolution: 1920x1080~60Hz
  API: EGL v: 1.5 drivers: iris,nvidia,swrast
    platforms: gbm,x11,surfaceless,device
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa
    v: 23.2.1-arch1.2 renderer: Mesa Intel UHD Graphics P630 (CFL GT2)
  API: Vulkan v: 1.3.269 drivers: nvidia surfaces: xcb,xlib
~ ❯ vainfo
Trying display: wayland
Trying display: x11
vaInitialize failed with error code -1 (unknown libva error),exit
Do you have libva-intel-driver installed? If not, install that. It provides VAAPI support for Coffee Lake CPUs
That fixed it. Thanks.
This is where you can find the install documentation to enable video acceleration:
https://wiki.archlinux.org/title/Hardware_video_acceleration
