Are you able to boot off the Windows media? If you are getting that far it is more of Windows issue than a Linux issue.
If you are able to boot off the ISO but can’t get past the screen where you would select storage it means your storage controller is probably not being detected by the Windows media. First make sure you are using the latest Windows ISO. If the issue still persists you will need to download drivers from the manufacturer and load them from that screen.
If your issue is none of those things you need to explain it better. Also, what version of Windows are you trying to install?
