pulse audio ain’t pulsing
i ran the command
systemctl --user status pulseaudio.{socket,service}
and the output was
Unit pulseaudio.socket could not be found.
Unit pulseaudio.service could not be found.
i ran the command
and the output was
Same here.
But then again, I’m not using pulseaudio but pipewire…
[thomas@roamer ~]$ systemctl --user status pipewire.{socket,service}
● pipewire.socket - PipeWire Multimedia System Sockets
Loaded: loaded (/usr/lib/systemd/user/pipewire.socket; enabled; preset: enabled)
Active: active (running) since Sat 2024-08-24 07:37:24 CEST; 6h ago
Invocation: 5f83b212e879472a99ee7a55206754c7
Triggers: ● pipewire.service
Listen: /run/user/1000/pipewire-0 (Stream)
/run/user/1000/pipewire-0-manager (Stream)
CGroup: /user.slice/user-1000.slice/user@1000.service/app.slice/pipewire.socket
Aug 24 07:37:24 roamer systemd[1479]: Listening on PipeWire Multimedia System Sockets.
● pipewire.service - PipeWire Multimedia Service
Loaded: loaded (/usr/lib/systemd/user/pipewire.service; disabled; preset: enabled)
Active: active (running) since Sat 2024-08-24 07:37:25 CEST; 6h ago
Invocation: 9b1cc6e7f8c04334bcaef71762571ab2
TriggeredBy: ● pipewire.socket
Main PID: 1577 (pipewire)
Tasks: 3 (limit: 18826)
Memory: 10.7M (peak: 14.1M)
CPU: 16.976s
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire.service
└─1577 /usr/bin/pipewire
Aug 24 07:37:25 roamer systemd[1479]: Started PipeWire Multimedia Service.
[thomas@roamer ~]$
EOS is using pipewire.
[ricklinux@asus-tuff ~]$ inxi -Aa
Device-1: Intel 200 Series PCH HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3
chip-ID: 8086:a2f0 class-ID: 0403
Device-2: NVIDIA GP104 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 4
link-max: lanes: 16 bus-ID: 02:00.1 chip-ID: 10de:10f0 class-ID: 0403
API: ALSA v: k6.10.6-arch1-1 status: kernel-api
Server-1: PipeWire v: 1.2.2 status: active with: 1: pipewire-pulse
