No Audio over HDMI output - How to set kernel parameter correctly?
Hi all,
I have some issues regarding my Audio setup. I found a bunch of threads covering that, but I didnt find anything thats really matching to my case.
Hardware:
  • Dell Precision with Intel iGPU and Nvidia discrete GPU
  • USB C to HDMI cable and USB C to USB-A/HDMI Dongle
  • Dell WD19 DP Dock
  • inxi sendlog http://ix.io/4MqD
The internal speakers work just fine, what does not work is audio if connected over HDMI to the laptop. Neither with the direct USB-C to HDMI cable, nor with the Multi-Use dongle.
I did some searching around and it seems like, that the WD19 brings its own Realtek Audio Chipset with it. In that case, if connected to the dock, I can use the output of the dock without any issues.
aplay -l with HDMI cable, the LEN P24q-20 would be the needed output device here:
[daniel@fs0ciety ~]$ aplay -l
**** Liste der Hardware-Geräte (PLAYBACK) ****
Karte 0: PCH [HDA Intel PCH], Gerät 0: ALC289 Analog [ALC289 Analog]
  Sub-Geräte: 1/1
  Sub-Gerät #0: subdevice #0
Karte 0: PCH [HDA Intel PCH], Gerät 3: HDMI 0 [LEN P24q-20]
  Sub-Geräte: 1/1
Karte 0: PCH [HDA Intel PCH], Gerät 7: HDMI 1 [HDMI 1]
  Sub-Geräte: 1/1
Karte 0: PCH [HDA Intel PCH], Gerät 8: HDMI 2 [HDMI 2]
  Sub-Geräte: 1/1
Karte 0: PCH [HDA Intel PCH], Gerät 9: HDMI 3 [HDMI 3]
  Sub-Geräte: 1/1
aplay -l Connected to the dock:
  Sub-Geräte: 1/1
Karte 0: PCH [HDA Intel PCH], Gerät 3: HDMI 0 [Mi Monitor]
  Sub-Geräte: 1/1
  Sub-Geräte: 1/1
  Sub-Geräte: 1/1
  Sub-Geräte: 1/1
Karte 1: Dock [WD19 Dock], Gerät 0: USB Audio [USB Audio]
  Sub-Geräte: 1/1
Karte 1: Dock [WD19 Dock], Gerät 1: USB Audio [USB Audio #1]
  Sub-Geräte: 1/1
inxi -Aa connected to HDMI
[daniel@fs0ciety ~]$ inxi -Aa
  Device-1: Intel Tiger Lake-H HD Audio vendor: Dell driver: snd_hda_intel
    v: kernel alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3
    chip-ID: 8086:43c8 class-ID: 0403
  API: ALSA v: k6.6.2-arch1-1 status: kernel-api
  Server-1: PipeWire v: 0.3.85 status: active with: 1: pipewire-pulse
inxi -Aa connected to the Dock
  Device-2: HP HyperX SoloCast driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4.3.2.3.1:36
    chip-ID: 03f0:078b class-ID: 0300
  Device-3: Realtek USB Audio driver: snd-usb-audio type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4.3.4:28 chip-ID: 0bda:402e
    class-ID: 0102 serial: 200901010001
Im not sure right now if the issue is maybe caused by the Optimus setup, help would be great in this case :slight_smile:
Welchen Dell Precision hast du denn? Offensichtlich einen neueren, aber welchen?
Precision 5560
I noticed also that, if I change the profile in the XFCE PulseAudio Module to the connected HDMI (not connected in the Screenshot), it should choose the HDMI as output if I understand it correctly, but I get no audio at all then. No HDMI Audio and no internal Audio. If I change back to internal, I have internal Audio again.
Ich hab den Precision 5550, also mit den Unterschieden bei GPU, PCIe Anbindung und Thunderbolt. Sonst sollte das das gleiche sein. Mein Dock ist das TB19S, also ohne Analog Audio Ausgang.
Muss den allerdings erst noch einrichten, ist neu. Ich schreibe danach, wie das Audio sich bei mir verhält.
Am Dock ist das bei mir kein Thema, da wird der eigene Audio-Chipsatz erkannt und funktioniert auch.Nur wenn der interne DAC einen externen Ausgang ansprechen soll wirds schwierig
Bist du sicher, dass diese Kabel-Hardware überhaupt Audio unterstützt? Ich würde das mal mit einem USB-C Smartphone probieren.
Hardware itself is working, just confirmed with Windows 11 on the second SSD. USB-C to HDMI cable, and the TV shows up as its own audio device.
Right now I would suspect some driver issues when running Endeavour? As the device is listed as HD Audio Driver for Display Audio and not the Realtek Audio Driver which is used for the internal speakers.
Edit:
Though it does show up in inxi -aA
[daniel@fs0ciety ~]$ inxi -aA
Output of alsa-info can be found here: http://alsa-project.org/db/?f=9605f657202d8d984751ca56af021f9b24536327
Little bump, I did some additional digging around and I think I found the underlying issue. Or at least I hope so. Seems to be related to the sof-firmware https://thesofproject.github.io/latest/getting_started/intel_debug/introduction.html#pci-devices-introduced-after-2016
mistake
I now tried to add the module options snd-intel-dspcfg dsp_driver=1 in \etc\modprobe.d\alsa-base.conf but the output of journalctl shows me, that the module could not be loaded.
Output with options:
Nov 29 10:50:41 fs0ciety modprobe[436]: libkmod: kmod_config_parse: /etc/modprobe.d/alsa-base.conf line 1: ignoring bad line starting with 'options'
Output without options:
Nov 29 10:50:41 fs0ciety modprobe[436]: libkmod: kmod_config_parse: /etc/modprobe.d/alsa-base.conf line 1: ignoring bad line starting with 'snd_intel_dspcfg.dsp_driver=1'
I also tried to set the parameter live
[daniel@fs0ciety ~]$ modprobe snd_intel_dspcfg.dsp_driver=1
modprobe: FATAL: Module snd_intel_dspcfg.dsp_driver=1 not found in directory /lib/modules/6.6.2-arch1-1
Is there any way I can set the module correctly in the current kernel? I am using systemd as bootloader
Edit:
Im an idiot, I had a typo issue in the line. Now it looks like this:
snd-intel-dspcfg.dsp_driver=0
Now the HDMI output is automatically chosen as Audio output when connected, internal speakers when disconnected. And it also works just like it should and gives audio output :slight_smile:
