Haven’t touched anything, no updates, no nothing. But no more sound from my speakers. When I boot into a live environment of EOS the speakers work fine. I have no clue what is wrong. Re-installing the distro is currently not an option.
pactl list sinks
pactl list sinks
Sink #46
State: SUSPENDED
Name: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_5__sink
Description: Cannon Lake PCH cAVS HDMI / DisplayPort 3 Output
Driver: PipeWire
Sample Specification: s24-32le 2ch 48000Hz
Channel Map: front-left,front-right
Owner Module: 4294967295
Mute: no
Volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB
balance 0.00
Base Volume: 65536 / 100% / 0.00 dB
Monitor Source: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_5__sink.monitor
Latency: 0 usec, configured 0 usec
Flags: HARDWARE DECIBEL_VOLUME LATENCY
Properties:
object.path = "alsa:pcm:0:hw:sofhdadsp,5:playback"
api.alsa.path = "hw:sofhdadsp,5"
api.alsa.open.ucm = "true"
api.alsa.pcm.card = "0"
api.alsa.pcm.stream = "playback"
audio.channels = "2"
audio.position = "FL,FR"
device.routes = "1"
alsa.mixer_device = "_ucm0001.hw:sofhdadsp"
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = ""
alsa.id = "HDMI3 (*)"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "5"
alsa.card = "0"
alsa.card_name = "sof-hda-dsp"
alsa.long_card_name = "LENOVO-81NX-LenovoYogaS740_15IRH-LNVNB161216"
alsa.driver_name = "snd_soc_skl_hda_dsp"
device.profile.name = "HiFi: hw:sofhdadsp,5: sink"
device.profile.description = "HDMI / DisplayPort 3 Output"
card.profile.device = "0"
device.id = "43"
factory.name = "api.alsa.pcm.sink"
priority.driver = "664"
priority.session = "664"
media.class = "Audio/Sink"
node.nick = "sof-hda-dsp"
node.name = "alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_5__sink"
device.description = "Cannon Lake PCH cAVS"
device.icon_name = "audio-card"
device.bus = "pci"
device.bus_path = "pci-0000:00:1f.3-platform-skl_hda_dsp_generic"
node.pause-on-idle = "false"
factory.id = "18"
clock.quantum-limit = "8192"
client.id = "33"
node.driver = "true"
factory.mode = "merge"
audio.adapt.follower = ""
library.name = "audioconvert/libspa-audioconvert"
object.id = "46"
object.serial = "46"
device.enum.api = "udev"
api.alsa.card = "0"
api.alsa.card.name = "sof-hda-dsp"
api.alsa.card.longname = "LENOVO-81NX-LenovoYogaS740_15IRH-LNVNB161216"
device.plugged.usec = "8170419"
sysfs.path = "/devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0"
device.subsystem = "sound"
device.vendor.id = "0x8086"
device.vendor.name = "Intel Corporation"
device.product.id = "0xa348"
device.product.name = "Cannon Lake PCH cAVS"
device.name = "alsa_card.pci-0000_00_1f.3-platform-skl_hda_dsp_generic"
device.nick = "sof-hda-dsp"
api.alsa.use-acp = "true"
api.acp.auto-profile = "false"
api.acp.auto-port = "false"
api.dbus.ReserveDevice1 = "Audio0"
device.string = "0"
Ports:
[Out] HDMI3: HDMI / DisplayPort 3 Output (type: HDMI, priority: 700, availability group: HDMI/DP,pcm=5, not available)
Active Port: [Out] HDMI3
Formats:
pcm
Sink #47
State: SUSPENDED
Name: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_4__sink
Description: Cannon Lake PCH cAVS HDMI / DisplayPort 2 Output
Driver: PipeWire
Mute: no
balance 0.00
Monitor Source: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_4__sink.monitor
Properties:
object.path = "alsa:pcm:0:hw:sofhdadsp,4:playback"
api.alsa.path = "hw:sofhdadsp,4"
device.routes = "1"
device.api = "alsa"
alsa.name = ""
alsa.id = "HDMI2 (*)"
alsa.device = "4"
alsa.card = "0"
device.profile.name = "HiFi: hw:sofhdadsp,4: sink"
device.profile.description = "HDMI / DisplayPort 2 Output"
card.profile.device = "1"
device.id = "43"
priority.driver = "680"
priority.session = "680"
node.name = "alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_4__sink"
device.bus = "pci"
factory.id = "18"
client.id = "33"
object.id = "47"
object.serial = "47"
api.alsa.card = "0"
device.string = "0"
Ports:
[Out] HDMI2: HDMI / DisplayPort 2 Output (type: HDMI, priority: 600, availability group: HDMI/DP,pcm=4, not available)
Active Port: [Out] HDMI2
Formats:
pcm
Sink #48
State: SUSPENDED
Name: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_3__sink
Description: Cannon Lake PCH cAVS HDMI / DisplayPort 1 Output
Driver: PipeWire
Mute: no
balance 0.00
Monitor Source: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_3__sink.monitor
Properties:
object.path = "alsa:pcm:0:hw:sofhdadsp,3:playback"
api.alsa.path = "hw:sofhdadsp,3"
device.routes = "1"
device.api = "alsa"
alsa.name = ""
alsa.id = "HDMI1 (*)"
alsa.device = "3"
alsa.card = "0"
device.profile.name = "HiFi: hw:sofhdadsp,3: sink"
device.profile.description = "HDMI / DisplayPort 1 Output"
card.profile.device = "2"
device.id = "43"
priority.driver = "696"
priority.session = "696"
node.name = "alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_3__sink"
device.bus = "pci"
factory.id = "18"
client.id = "33"
object.id = "48"
object.serial = "48"
api.alsa.card = "0"
device.string = "0"
Ports:
[Out] HDMI1: HDMI / DisplayPort 1 Output (type: HDMI, priority: 500, availability group: HDMI/DP,pcm=3, not available)
Active Port: [Out] HDMI1
Formats:
pcm
Sink #49
State: SUSPENDED
Name: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp__sink
Description: Cannon Lake PCH cAVS Speaker + Headphones
Driver: PipeWire
Sample Specification: s32le 2ch 48000Hz
Mute: no
Volume: front-left: 39322 / 60% / -13.31 dB, front-right: 39322 / 60% / -13.31 dB
balance 0.00
Monitor Source: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp__sink.monitor
Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
Properties:
object.path = "alsa:pcm:0:hw:sofhdadsp:playback"
api.alsa.path = "hw:sofhdadsp"
device.routes = "2"
device.api = "alsa"
alsa.name = ""
alsa.id = "HDA Analog (*)"
alsa.device = "0"
alsa.card = "0"
device.profile.name = "HiFi: hw:sofhdadsp: sink"
device.profile.description = "Speaker + Headphones"
card.profile.device = "3"
device.id = "43"
priority.driver = "744"
priority.session = "744"
node.name = "alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp__sink"
device.bus = "pci"
factory.id = "18"
client.id = "33"
object.id = "49"
object.serial = "49"
node.max-latency = "4096/48000"
api.alsa.period-size = "1024"
api.alsa.period-num = "8"
api.alsa.headroom = "0"
api.alsa.card = "0"
device.string = "0"
Ports:
[Out] Speaker: Speaker (type: Speaker, priority: 100, availability unknown)
[Out] Headphones: Headphones (type: Headphones, priority: 200, availability group: Headphone, not available)
Active Port: [Out] Speaker
Formats:
pcm
pacman -Q | grep pipewire
gst-plugin-pipewire 1:0.3.80-1
kpipewire 5.27.8-1
libpipewire 1:0.3.80-1
pipewire 1:0.3.80-1
pipewire-alsa 1:0.3.80-1
pipewire-audio 1:0.3.80-1
pipewire-jack 1:0.3.80-1
pipewire-media-session 1:0.4.2-2
pipewire-pulse 1:0.3.80-1
systemctl status pipewire
● pipewire.service - PipeWire Multimedia Service
Loaded: loaded (/usr/lib/systemd/user/pipewire.service; disabled; preset: enabled)
Active: active (running) since Fri 2023-09-15 20:45:46 CEST; 9min ago
TriggeredBy: ● pipewire.socket
Main PID: 1608 (pipewire)
Tasks: 3 (limit: 38146)
Memory: 7.8M
CPU: 1.688s
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire.service
└─1608 /usr/bin/pipewire
Sep 15 20:45:46 mastermind systemd[1234]: Started PipeWire Multimedia Service.
inxi -Faz
Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo
driver: sof-audio-pci-intel-cnl alternate: snd_hda_intel, snd_soc_skl,
snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0401
API: ALSA v: k6.5.3-arch1-1 status: kernel-api
Server-1: PipeWire v: 0.3.80 status: active with: 1: pipewire-pulse
status: active 2: pipewire-media-session status: active 3: pipewire-alsa
type: plugin 4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli
journalctl -b | grep PipeWire
Sep 15 20:45:35 user systemd[1159]: Listening on PipeWire PulseAudio.
Sep 15 20:45:35 user systemd[1159]: Listening on PipeWire Multimedia System Socket.
Sep 15 20:45:44 user systemd[1234]: Listening on PipeWire PulseAudio.
Sep 15 20:45:44 user systemd[1234]: Listening on PipeWire Multimedia System Socket.
Sep 15 20:45:46 user systemd[1234]: Started PipeWire Multimedia Service.
Sep 15 20:45:46 user systemd[1234]: Started PipeWire Media Session Manager.
Sep 15 20:45:47 user systemd[1234]: Started PipeWire PulseAudio.
Sep 15 20:45:54 user systemd[1159]: Closed PipeWire PulseAudio.
Sep 15 20:45:54 user systemd[1159]: Closed PipeWire Multimedia System Socket.
Pastebin of the full journalctl output
To me everything looks fine. Bluetooth headphones work. Speakers are working in live environment. I don’t understand the inner workings of the audio services etc. I just find it strange that Pipewire PulseAudio is closing after it started.
I also tried switching away from pipewire to pulseaudio, but that does nothing. I tried deleting configurations, restarting daemons etc. Audio has always been an issue for my laptop since I started using Linux. I find it strange that all of the sudden it stops working.
Anyone that can help me troubleshoot it a bit further?
