Nnn Help - Regarding preview file
Hi,
I configured nnn with global file preview plugin/setting. But when I activate with it open in a new separate window. I want to open in another new terminal window. In tmux it works fine. It opens in the right pane. What settings should I need to change?
I need like this
It’s stated in the documentation:
The previews will be shown in a tmux split. If that isn’t possible, it will try to use a kitty terminal split. And as a final fallback, a different terminal window will be used ($NNN_TERMINAL).
In other words, you have to set the NNN_TERMINAL environment variable to the terminal emulator you want to use.
Go to /etc/environment:
NNN_TERMINAL=konsole
Save the file. Log out and log back in for changes to take effect.
Sources:
I set NNN_TERMNIAL=bash but when I activate the preview it changes/shows in the same terminal window but I want in a separate new terminal window.
while adding konsole it gave an error. So I changed it to bash
bash is shell, not a terminal emulator. You need to set the variable to a terminal emulator like konsole, alacritty, or whatever.
Dude. You made a typo. It shouldn’t be capital K. It’s konsole not Konsole
For the post here i typed konsole but in the variable file I gave Konsole only …
2023-08-30-14-45-15
You typed “Konsole” with a capital “K”. Like I mentioned already, it needs to be “konsole” with a small “k”.
Oopsy … I read it wrong sorry … 1min lemme change it
Thanks @anthony93 :v: :v: :v: Got it now …
