Well, I managed to scp the files off my other PC and then ran: sudo pacman -U file:///var/cache/pacman/pkg/libnma-common-1.8.40-1-x86_64.pkg.tar.zst file://var/cache/pacman/pkg/libnma-1.8.40-1-x86_64.pkg.tar.zst which solved the issue!
I learnt quite a bit from this.
Thanks to all you friendly people for making my first post such a happy experience =D
so fast
Not sure if heftig was not already into it before reporting it…
But i think it is a good idea to help by reporting BUGs. A lot of these issues never get reported and if the maintainer may do not get the issue it takes longer to get the fix in these cases.
