Newer Kernel versions (>7.2.9?) seem to break the UMC204HD Audio Interface
Hey! After upgrading to a newer Kernel version, 7.2.11-arch-1-1, my Behringer UMC204HD audio interface started “looping” between trying to connect and then failing after 5 seconds with:
kernel: usb 1-10: failed to read device descriptor: -110
kernel: snd-usb-audio 1-10:1.0: probe with driver snd-usb-audio failed with error -110
The 7.2.9 kernel seems to work fine, so somewhere between that and the 7.2.11 one it probably broke.
I also tried the newest CachyOS Kernels but the same happened there:
7.2.9.arch-1-1 and 7.9.2-2-cachyos; in both it still work
7.2.11-arch-1-1 and 7.3.0-3-cachyos (and 7.3.0-4-cachyos); broken
I also made sure that the interface itself wasn’t broken. And neither is the cable or the USB port.
Here’s a journalctl log with some (hopefully useful) stuff from the Interface looping:
11:55:17 kernel: Linux version 7.2.11-arch1-1 (linux@archlinux) (gcc (GCC) 16.2.1 20260810, GNU ld (GNU Binutils) 2.47) #1 SMP PREEMPT_DYNAMIC Fri, 16 Oct 2026 00:28:58 +0000
11:55:17 kernel: Command line: initrd=\f73eff6db7e44187ab866a4d1d28f0d4\7.2.11-arch1-1\initrd nvme_load=YES nowatchdog rw rootflags=subvol=/@ root=UUID=00ffbda2-6d2a-4077-adec-2b47121ccc42 systemd.machine_id=f73eff6db7e44187ab866a4d1d28f0d4
11:55:18 kernel: usb 1-10: new high-speed USB device number 8 using xhci_hcd
11:55:19 kernel: usb 1-10: New USB device found, idVendor=1397, idProduct=0508, bcdDevice= 1.35
11:55:19 kernel: usb 1-10: New USB device strings: Mfr=1, Product=2, SerialNumber=0
11:55:19 kernel: usb 1-10: Product: UMC204HD 192k
11:55:19 kernel: usb 1-10: Manufacturer: BEHRINGER
11:55:22 kernel: usb 1-10: USB disconnect, device number 8
11:55:27 kernel: usb 1-10: failed to read device descriptor: -110
11:55:27 kernel: snd-usb-audio 1-10:1.0: probe with driver snd-usb-audio failed with error -110
11:55:27 kernel: usb 1-10: failed to read device descriptor: -19
11:55:27 kernel: usbcore: registered new interface driver snd-usb-audio
11:55:28 kernel: usb 1-10: new high-speed USB device number 9 using xhci_hcd
11:55:28 kernel: usb 1-10: New USB device found, idVendor=1397, idProduct=0508, bcdDevice= 1.35
11:55:28 kernel: usb 1-10: New USB device strings: Mfr=1, Product=2, SerialNumber=0
11:55:28 kernel: usb 1-10: Product: UMC204HD 192k
11:55:28 kernel: usb 1-10: Manufacturer: BEHRINGER
11:55:33 kernel: usb 1-10: failed to read device descriptor: -110
11:55:33 kernel: snd-usb-audio 1-10:1.0: probe with driver snd-usb-audio failed with error -110
11:55:38 kernel: usb 1-10: failed to read device descriptor: -110
11:55:38 kernel: snd-usb-audio 1-10:1.3: probe with driver snd-usb-audio failed with error -110
11:55:43 kernel: usb 1-10: failed to read device descriptor: -110
11:55:43 kernel: snd-usb-audio 1-10:1.4: probe with driver snd-usb-audio failed with error -110
11:55:43 kernel: usb 1-10: USB disconnect, device number 9
11:55:44 kernel: usb 1-10: new high-speed USB device number 10 using xhci_hcd
11:55:44 kernel: usb 1-10: New USB device found, idVendor=1397, idProduct=0508, bcdDevice= 1.35
11:55:44 kernel: usb 1-10: New USB device strings: Mfr=1, Product=2, SerialNumber=0
11:55:44 kernel: usb 1-10: Product: UMC204HD 192k
11:55:44 kernel: usb 1-10: Manufacturer: BEHRINGER
11:55:49 kernel: usb 1-10: failed to read device descriptor: -110
11:55:49 kernel: snd-usb-audio 1-10:1.0: probe with driver snd-usb-audio failed with error -110
11:55:49 kernel: usb 1-10: failed to read device descriptor: -71
11:55:49 kernel: snd-usb-audio 1-10:1.3: probe with driver snd-usb-audio failed with error -71
11:55:49 kernel: snd-usb-audio 1-10:1.4: probe with driver snd-usb-audio failed with error -71
11:55:49 kernel: usb 1-10: USB disconnect, device number 10
11:55:49 kernel: usb 1-10: new high-speed USB device number 11 using xhci_hcd
11:55:49 kernel: usb 1-10: New USB device found, idVendor=1397, idProduct=0508, bcdDevice= 1.35
11:55:49 kernel: usb 1-10: New USB device strings: Mfr=1, Product=2, SerialNumber=0
11:55:49 kernel: usb 1-10: Product: UMC204HD 192k
11:55:49 kernel: usb 1-10: Manufacturer: BEHRINGER
11:55:54 kernel: usb 1-10: failed to read device descriptor: -110
11:55:54 kernel: snd-usb-audio 1-10:1.0: probe with driver snd-usb-audio failed with error -110
11:55:54 kernel: usb 1-10: failed to read device descriptor: -71
11:55:54 kernel: snd-usb-audio 1-10:1.3: probe with driver snd-usb-audio failed with error -71
11:55:54 kernel: snd-usb-audio 1-10:1.4: probe with driver snd-usb-audio failed with error -71
11:55:54 kernel: usb 1-10: USB disconnect, device number 11
11:55:54 kernel: usb 1-10: new high-speed USB device number 12 using xhci_hcd
11:55:55 kernel: usb 1-10: New USB device found, idVendor=1397, idProduct=0508, bcdDevice= 1.35
11:55:55 kernel: usb 1-10: New USB device strings: Mfr=1, Product=2, SerialNumber=0
11:55:55 kernel: usb 1-10: Product: UMC204HD 192k
11:55:55 kernel: usb 1-10: Manufacturer: BEHRINGER
11:56:00 kernel: usb 1-10: failed to read device descriptor: -110
11:56:00 kernel: snd-usb-audio 1-10:1.0: probe with driver snd-usb-audio failed with error -110
11:56:05 kernel: usb 1-10: failed to read device descriptor: -110
11:56:05 kernel: snd-usb-audio 1-10:1.3: probe with driver snd-usb-audio failed with error -110
11:56:10 kernel: usb 1-10: failed to read device descriptor: -110
11:56:10 kernel: snd-usb-audio 1-10:1.4: probe with driver snd-usb-audio failed with error -110
11:56:10 kernel: usb 1-10: USB disconnect, device number 12
11:56:10 kernel: usb 1-10: new high-speed USB device number 13 using xhci_hcd
11:56:10 kernel: usb 1-10: New USB device found, idVendor=1397, idProduct=0508, bcdDevice= 1.35
11:56:10 kernel: usb 1-10: New USB device strings: Mfr=1, Product=2, SerialNumber=0
11:56:10 kernel: usb 1-10: Product: UMC204HD 192k
11:56:10 kernel: usb 1-10: Manufacturer: BEHRINGER
11:56:16 kernel: usb 1-10: failed to read device descriptor: -110
11:56:16 kernel: snd-usb-audio 1-10:1.0: probe with driver snd-usb-audio failed with error -110
11:56:21 kernel: usb 1-10: failed to read device descriptor: -110
11:56:21 kernel: snd-usb-audio 1-10:1.3: probe with driver snd-usb-audio failed with error -110
11:56:26 kernel: usb 1-10: failed to read device descriptor: -110
11:56:26 kernel: snd-usb-audio 1-10:1.4: probe with driver snd-usb-audio failed with error -110
11:56:26 kernel: usb 1-10: USB disconnect, device number 13
Forum hygiene … For the readability :wink:
Copy txt from terminal → Control-E → Paste the txt
What a lot of users still doing a lot:
Paste txt → txt is selected → press code icon
For a onliner this is fine
To analise output this is very help full :robot:
Sorry to interrupt. I cannot help you with the issue.
Thanks for letting me know :​)
Seems to be a known issue:
https://linux-regtracking.leemhuis.info/regzbot/regression/lore/45162613-2802-401c-84c9-742f9c8c68e6@app.fastmail.com/
That’s good to know! I tried searching a bit but didn’t really know where to look and couldn’t find anything.
Thanks for the reply :>
The fix has been posted.
