I tried arandr and i get all the resolutions but my refresh rate for all resolutions says only 50.00Hz
I get this with arandr also
[christopher@EndeavourOS ~]$ arandr
(arandr:4431): Gdk-CRITICAL **: 10:34:18.640: gdk_atom_intern: assertion 'atom_name != NULL' failed
Gdk-Message: 10:35:24.747: Window 0x619955e42040 is a temporary window without parent, application will not be able to position it on screen.
(arandr:4431): Gdk-CRITICAL **: 10:35:24.749: gdk_wayland_window_handle_configure_popup: assertion 'impl->transient_for' failed
Ok i figured it out, I went & installed Windows 11(I know I know lol.)
Same thing 3440x1440 @50Hz, so i did more digging and it turns out I need HDMI 2.0 or better to get a high refresh rate(My motherboard isn’t that old lol.).
I thought, wait i have a practically brand new hardly used Sapphire Radeon RX570 4Gig. I shutdown installed it and Windows 11 recognized it i updated installed new drivers rebooted and boom 165Hz
So later this week I’ll be re-installing EOS Gnome, sound works on Windows 11 but i don’t have my 5.1 like i do with Arch
What HDMI cable spec was the current cable 1.4? Cable spec and quality makes a huge difference. Certified cables are the best because they are guaranteed to meet the spec they are designed for.
