Hmmm…I ran relector-simple
after updating endeavouros-mirrorlist
and don’t have any pacnew
TTY3
sudo pacman -Syy
sudo pacman -Syu
systemctl reboot
Same here.
Right, that must be it, thanks for bringing it up. I just didn’t think that of course I had changed the file during testing.
So for most people no need to do any extra stuff, which is great.
Ouch…only 5 hours of sleep?
Why, that’s my normal sleeping time. (Just kidding )
Actually couldn’t sleep for some reason… and just came back here.
But now it is so late here that a good sleep is the only sensible option.
On KDE i updated with pacman and i saw the new mirror list file so i copied it as instructed. I didn’t try discover but i have been using it frequently without issue.
I got a pacnew when i updated using pacman and i have updated my mirrors many times using the welcome screen.
The button on the welcome app updates only Arch mirrors (for now).
I did a fresh install last night. Do i have to do this procedure?
Probably not. You can check if you have that /etc/pacman.d/endeavouros-mirrorlist.pacnew file. If not, all should be fine.
No pacnew file, but every time I update I get this:
$ sudo pacman -Syu
core is up to date
extra is up to date
community is up to date
multilib is up to date
endeavouros 11.6 KiB 246 KiB/s 00:00 [###############################] 100%
there is nothing to do
endeavouros is never up to date and reloads. Anyone else getting this result?
Interesting. Seems like it is a github thing. Now that the github repo changed to another place in github, it strangely started giving this behavior. With the old github place it doesn’t.
As a guess, it might be caused by some kind of redirection at github?
I updated my system and got the pacnew file and i copied it over as instructed but i had made the change prior for testing. So i’m not sure if this is different again but it did create pacnew and i copied it over.
I get this when i run the update command also.
[rick@plasma-pc ~]$ sudo pacman -Syu
[sudo] password for rick:
core is up to date
extra is up to date
endeavouros 11.6 KiB 1653 KiB/s 00:00 [-------------------------------] 100%
[rick@plasma-pc ~]$
I also have that behavior. This has changed from previous output of sudo pacman -Syu
But as all seems to work like before, I’m not that worried (famous last words… )
To get rid of that unnecessary endeavouros reload, you may want to modify the github mirror order at file /etc/pacman.d/endeavouros-mirrorlist to:
## Github Server = https://github.com/endeavouros-team/mirrors/releases/download/mirror1/ Server = https://github.com/endeavouros-team/repo/raw/master/$repo/$arch
Both of those mirror addresses will be supported at least for a few months from now, so the change should be a safe thing to do.
And if EndeavourOS mirrors for some reason happen to change, we’ll update the
endeavouros-mirrorlist package for you in order to keep things working as expected.
@manuel
I don’t know if this will help any, but here is an observation on my part.
You probably don’t remember a topic where I was having trouble getting the keyring and mirrorlist.
What I ended up doing is getting what the latest version IS from
“https://github.com/endeavouros-team/repo/TREE/master/endeavouros/x86_64”
Then downloading the actual file from
https://github.com/endeavouros-team/repo/RAW/master/endeavouros/x86_64/
I put the difference between the two in capitals letters to stand out, being TREE and RAW
Following this process, here is what I got yesterday after running the install script again
pacman -Q | grep mirrorlist
endeavouros-mirrolist 1.4-1 (no .pacnew)
pacman-mirrorlist 20200207-1
It seems to work fine. Just for my edification, what is the .pacnew part doing?
Pudge
Edited the file as suggested, then ran pacman -Syyu
. Another pacman -Syu
did not reload the endeavouros repo.
The longish explanation is available with command: man pacman
, under HANDLING CONFIG FILES
So, if you get a .pacnew file (e.g. endeavouros-mirrorlist.pacnew), you should
- always check what the changes are (e.g. compared to endeavouros-mirrorlist), and
- manually merge (meaning: carefully copy only the useful parts) stuff from the .pacnew file to the original file
Depending on what the file is, you’ll probably end up mergeing
- nothing (e.g. /etc/passwd) because you most likely want to login in the future too
- fully (e.g. application’s config file that you have not modified)
- partially (e.g. a mirrorlist that you have modified, but want to include new mirrors)
As you can see, .pacnew files need careful and special case by case handling.
And this is one of the reasons pacman is a great package manager: it shows when user actions may be needed while updating the system, as it warns about .pacnew and some other files.
Update.
I am going to assume that I didn’t notice or I update more slowly than most. I checked again and had:
But only the endeavouros repo never showing an up to date output. I never had a .pacnew just an updated /etc/pacman.d/mirrorlist
Applied this:
sudo pacman -Syyu
Clean sudo pacman -Syu
Thank you @sothis6881
I had a problem with updating the mirrorlist as well.
in stead of copying it it got deleted.
Tried to create it but I have it wrong I guess.
I did:
sudo reflector -a4 -phttps -c Netherlands -f 10 --save /etc/
pacman.d/mirrorlist
then:
sudo pacman -Syyu
Which output:
: Pakket-databases synchroniseren...
fout:kan het bestand 'endeavouros.db' niet ophalen van mirror.fra10.de.leaseweb.net : The
requested URL returned error: 404
fout:kan het bestand 'endeavouros.db' niet ophalen van mirror.wtnet.de : The requested URL
returned error: 404
fout:kan het bestand 'endeavouros.db' niet ophalen van ger.mirror.pkgbuild.com : The reque
fout:kan het bestand 'endeavouros.db' niet ophalen van mirror.orbit-os.com : The requested
fout:kan het bestand 'endeavouros.db' niet ophalen van mirrors.n-ix.net : The requested UR
fout:kan het bestand 'endeavouros.db' niet ophalen van mirror.chaoticum.net : The requeste
fout:kan het bestand 'endeavouros.db' niet ophalen van mirror.metalgamer.eu : The requeste
fout:kan het bestand 'endeavouros.db' niet ophalen van arch.jensgutermuth.de : The request
fout:kan het bestand 'endeavouros.db' niet ophalen van mirror.netcologne.de : The requeste
fout:kan het bestand 'endeavouros.db' niet ophalen van mirror.mikrogravitation.org : The r
fout:fout bij het updaten endeavouros (kon niet alle bestanden ophalen)
core 136,0 KiB 4,43 MiB/s 00:00 [############################] 100%
extra 1651,4 KiB 6,20 MiB/s 00:00 [############################] 100%
community 4,9 MiB 5,14 MiB/s 00:01 [############################] 100%
multilib 159,1 KiB 12,0 MiB/s 00:00 [############################] 100%
fout:fout bij het synchroniseren van alle databases
They seem German mirrors iso Dutch(Netherlands)
Anyone an idea how to repair?
