Neues Paket linux-firmware-amdgpu 20260910-1 macht Probleme
Hallo,
mit dem heutigen Update kamen wieder neue Linux-Firmware-Pakete. Nach dem Installieren und Neustarten ruckelte meine ganze grafische Oberfläche XFCE.
Journalctl zeigte mir folgende Fehler:
Sep 12 17:29:24 mmeos kernel: amdgpu 0000:e5:00.0: [drm] *ERROR* Error queueing DMUB command: status=2
Sep 12 17:29:24 mmeos kernel: amdgpu 0000:e5:00.0: [drm] *ERROR* dc_dmub_srv_log_diagnostic_data: DMCUB error - collecting diagnostic data
Sep 12 17:29:29 mmeos kernel: amdgpu 0000:e5:00.0: [drm] *ERROR* Error queueing DMUB command: status=2
Sep 12 17:29:29 mmeos kernel: amdgpu 0000:e5:00.0: [drm] *ERROR* dc_dmub_srv_log_diagnostic_data: DMCUB error - collecting diagnostic data
Sep 12 17:29:31 mmeos wpa_supplicant[721]: ap0: nl80211: kernel reports: multicast RX registrations are not supported
Sep 12 17:29:31 mmeos wpa_supplicant[721]: Could not set interface ap0 flags (UP): Device or resource busy
Sep 12 17:29:31 mmeos wpa_supplicant[721]: nl80211: Could not set interface 'ap0' UP
Sep 12 17:29:31 mmeos wpa_supplicant[721]: ap0: Failed to initialize driver interface
Sep 12 17:29:31 mmeos NetworkManager[635]: <error> [1789226971.2642] device (ap0): Couldn't initialize supplicant interface: GDBus.Error:fi.w1.wpa_supplicant1.UnknownError: wpa_supplicant couldn't grab this interface.
Sep 12 17:29:34 mmeos kernel: amdgpu 0000:e5:00.0: [drm] *ERROR* Error queueing DMUB command: status=2
Sep 12 17:29:34 mmeos kernel: amdgpu 0000:e5:00.0: [drm] *ERROR* dc_dmub_srv_log_diagnostic_data: DMCUB error - collecting diagnostic data
Sep 12 17:29:35 mmeos kernel: amdgpu 0000:e5:00.0: [drm] *ERROR* Error queueing DMUB command: status=2
Sep 12 17:29:35 mmeos kernel: amdgpu 0000:e5:00.0: [drm] *ERROR* dc_dmub_srv_log_diagnostic_data: DMCUB error - collecting diagnostic data
Sep 12 17:29:40 mmeos kernel: amdgpu 0000:e5:00.0: [drm] *ERROR* Error queueing DMUB command: status=2
Sep 12 17:29:40 mmeos kernel: amdgpu 0000:e5:00.0: [drm] *ERROR* dc_dmub_srv_log_diagnostic_data: DMCUB error - collecting diagnostic data
Sep 12 17:29:40 mmeos bluetoothd[638]: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Host is down
Sep 12 17:29:42 mmeos wpa_supplicant[721]: ap0: nl80211: kernel reports: multicast RX registrations are not supported
Sep 12 17:29:42 mmeos wpa_supplicant[721]: Could not set interface ap0 flags (UP): Device or resource busy
Sep 12 17:29:42 mmeos wpa_supplicant[721]: nl80211: Could not set interface 'ap0' UP
Sep 12 17:29:42 mmeos wpa_supplicant[721]: ap0: Failed to initialize driver interface
Sep 12 17:29:42 mmeos NetworkManager[635]: <error> [1789226982.2687] device (ap0): Couldn't initialize supplicant interface: GDBus.Error:fi.w1.wpa_supplicant1.UnknownError: wpa_supplicant couldn't grab this interface.
Sep 12 17:29:45 mmeos kernel: amdgpu 0000:e5:00.0: [drm] *ERROR* Error queueing DMUB command: status=2
Sep 12 17:29:45 mmeos kernel: amdgpu 0000:e5:00.0: [drm] *ERROR* dc_dmub_srv_log_diagnostic_data: DMCUB error - collecting diagnostic data
Sep 12 17:29:50 mmeos kernel: amdgpu 0000:e5:00.0: [drm] *ERROR* Error queueing DMUB command: status=2
Sep 12 17:29:50 mmeos kernel: amdgpu 0000:e5:00.0: [drm] *ERROR* dc_dmub_srv_log_diagnostic_data: DMCUB error - collecting diagnostic data
Sep 12 17:29:53 mmeos wpa_supplicant[721]: ap0: nl80211: kernel reports: multicast RX registrations are not supported
Sep 12 17:29:53 mmeos wpa_supplicant[721]: Could not set interface ap0 flags (UP): Device or resource busy
Sep 12 17:29:53 mmeos wpa_supplicant[721]: nl80211: Could not set interface 'ap0' UP
Sep 12 17:29:53 mmeos wpa_supplicant[721]: ap0: Failed to initialize driver interface
Sep 12 17:29:53 mmeos NetworkManager[635]: <error> [1789226993.2705] device (ap0): Couldn't initialize supplicant interface: GDBus.Error:fi.w1.wpa_supplicant1.UnknownError: wpa_supplicant couldn't grab this interface.
Sep 12 17:29:55 mmeos kernel: amdgpu 0000:e5:00.0: [drm] *ERROR* Error queueing DMUB command: status=2
Sep 12 17:29:55 mmeos kernel: amdgpu 0000:e5:00.0: [drm] *ERROR* dc_dmub_srv_log_diagnostic_data: DMCUB error - collecting diagnostic data
Sep 12 17:30:00 mmeos kernel: amdgpu 0000:e5:00.0: [drm] *ERROR* Error queueing DMUB command: status=2
Sep 12 17:30:00 mmeos kernel: amdgpu 0000:e5:00.0: [drm] *ERROR* dc_dmub_srv_log_diagnostic_data: DMCUB error - collecting diagnostic data
Sep 12 17:30:01 mmeos kernel: amdgpu 0000:e5:00.0: [drm] *ERROR* Error queueing DMUB command: status=2
Sep 12 17:30:01 mmeos kernel: amdgpu 0000:e5:00.0: [drm] *ERROR* dc_dmub_srv_log_diagnostic_data: DMCUB error - collecting diagnostic data
Die AI schrieb:
Die von dir beschriebenen Ruckler werden höchstwahrscheinlich durch einen Fehler im AMD-Grafiktreiber (amdgpu) verursacht, der nach einem Update aufgetreten ist. Die Fehlermeldungen im Journal zeigen, dass die Display Microcontroller Unit (DMUB) des Grafikprozessors nicht mehr korrekt kommuniziert. Das ist ein bekanntes Problem, das nach Kernel- oder Firmware-Updates auftreten kann.
und weiter:
Vorgehen:
Du musst das Paket linux-firmware-amdgpu auf eine ältere Version downgraden. Da du EndeavourOS (Arch-basiert) verwendest, kannst du dies mitpacmantun.
Das habe ich gemacht und siehe da: es läuft wieder.
Unter Gitlab/Workitems ist das Problem beschrieben und bekannt.
Falls jemand mit AMDGPU arbeitet, bitte mit dem Update warten.
bye
nabashi
Ich habe heute auch auf den neuen Kernel 7.2.4 und auf die neue Linux-Firmware aktualisiert. Danach stürzt mein Rechner nach dem Login direkt ab und bootet neu. Zuerst dachte ich, dass es am Linux-Kernel liegt, und habe von ZEN zu LTS gewechselt, denn den habe ich parallel installiert. Aber auch hier stürzt der Rechner direkt nach dem Login ab und startet neu.
Vor dem Update wurde ein BTRFS-Snapshot erstellt, den ich wiederhergestellt habe. Aktuell habe ich keine Probleme mehr. Die Updates stehen aber nun aus.
Es scheint hier tatsächlich ein Problem mit der Linux-Firmware vom 10.09. zu geben. :confused:
EDIT: Auch im Arch-Forum wird dazu etwas geschrieben:
[SOLVED] System freezes during boot with most recent firmware (AMD) / Kernel & Hardware / Arch Linux Forums
KDE Plasma crash after global update / Applications & Desktop Environments / Arch Linux Forums
❯ pacman -Q linux-firmware-amdgpu
Heute Morgen upgedated und absolut keine Probleme.
War ja auch mesa update noch die letzten Tage
❯ inxi -Gaz
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 23 [Radeon RX 6600/6600
    XT/6600M] vendor: Gigabyte driver: amdgpu v: kernel arch: RDNA-2
    code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: DP-2 empty: DP-1, HDMI-A-1,
    HDMI-A-2, Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:73ff class-ID: 0300
  Display: wayland server: X.org v: 1.21.1.24 with: Xwayland v: 24.1.13
    gpu: amdgpu display-ID: 0
  Monitor-1: DP-2 model: LG (GoldStar) ULTRAGEAR serial: <filter>
    built: 2024 res: mode: 2560x1440 hz: 180 scale: 100% (1) dpi: 109 gamma: 1.2
    size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9 modes:
    max: 2560x1440 min: 640x350
  API: EGL v: 1.5 hw: drv: amd radeonsi platforms: device: 0 drv: radeonsi
    device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi wayland:
    drv: radeonsi x11: drv: radeonsi
  API: OpenGL v: 4.6 vendor: amd mesa v: 26.2.2-arch1.1 glx-v: 1.4
    direct-render: yes renderer: AMD Radeon RX 6600 (radeonsi navi23 ACO DRM
    3.64 7.2.4-zen2-1-zen) device-ID: 1002:73ff memory: 7.81 GiB unified: no
    display-ID: :1.0
  API: Vulkan v: 1.4.357 layers: 6 device: 0 type: discrete-gpu name: AMD
    Radeon RX 6600 (RADV NAVI23) driver: mesa radv v: 26.2.2-arch1.1
    device-ID: 1002:73ff surfaces: N/A
    de: kscreen-console,kscreen-doctor gpu: corectrl, lact, radeontop
Ich nutze eine RX 9700 XT. Ich habe gerade linux-firmware* über die pacman.conf ausgeschlossen. Mal schauen, was passiert …
Vielleicht liegt es auch der einen oder anderen Grafikkarte. Ich wollte nur mitteilen, dass mit meiner Konfiguration keine Probleme bestehen
Lass uns teilhaben was raus geklommen ist
Keine Problem mit einer 9060 XT und der neuen Firmware hier.
Ich konnte jedoch komplette Neustarts nach dem Login mit diesem bekannten, bestehenden Bug erleben dürfen.
Also, das Ausschließen der linux-firmware Pakete half nicht! Danach stürzte der Rechner zwar nicht immer, aber immer mal wieder nach dem Login ab.
Ich musste zusätzlich auch noch das Paket amd-ucode ausschließen. Nun kann ich den Rechner neustarten und habe keine Abstürze mehr nach dem Login. Habe mehrere Neustarts probiert.
  Kernel: 7.2.4-zen2-1-zen arch: x86_64 bits: 64
  Desktop: KDE Plasma v: 6.7.5 Distro: EndeavourOS
  Type: Desktop Mobo: Micro-Star model: MAG X570 TOMAHAWK WIFI (MS-7C84)
    v: 1.0 serial: <superuser required> Firmware: UEFI vendor: American
    Megatrends LLC. v: 1.K4 date: 08/14/2026
  Info: 12-core model: AMD Ryzen 9 3900X bits: 64 type: MT MCP cache:
    L2: 6 MiB
  Speed (MHz): avg: 3624 min/max: 563/4674 cores: 1: 3624 2: 3624 3: 3624
    4: 3624 5: 3624 6: 3624 7: 3624 8: 3624 9: 3624 10: 3624 11: 3624 12: 3624
    13: 3624 14: 3624 15: 3624 16: 3624 17: 3624 18: 3624 19: 3624 20: 3624
    21: 3624 22: 3624 23: 3624 24: 3624
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 [Radeon RX 9070/9070
    XT/9070 GRE] driver: amdgpu v: kernel
  Device-2: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
    type: USB
    compositor: kwin_wayland driver: gpu: amdgpu resolution: 3440x1440~144Hz
  API: EGL v: 1.5 drivers: radeonsi,swrast
    platforms: gbm,wayland,x11,surfaceless,device
  API: OpenGL v: 4.6 vendor: amd mesa v: 26.2.2-arch1.1 renderer: AMD
    Radeon RX 9070 XT (radeonsi gfx1201 ACO DRM 3.64 7.2.4-zen2-1-zen)
  API: Vulkan v: 1.4.357 drivers: radv surfaces: N/A
    de: kscreen-console,kscreen-doctor wl: wayland-info
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 HDMI/DP Audio
    driver: snd_hda_intel
  Device-2: Advanced Micro Devices [AMD] Starship/Matisse HD Audio
  Device-3: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
    type: USB
  API: ALSA v: k7.2.4-zen2-1-zen status: kernel-api
  Server-1: PipeWire v: 1.6.8 status: active
  Device-1: Realtek RTL8125 2.5GbE driver: r8169
  IF: enp38s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Bluetooth:
  Device-1: Intel AX200 Bluetooth driver: btusb type: USB
  Report: btmgmt ID: hci0 rfk-id: 0 state: down bt-service: disabled
  Local Storage: total: 8.19 TiB used: 3.31 TiB (40.5%)
  ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO 1TB size: 931.51 GiB
  ID-2: /dev/nvme1n1 vendor: Samsung model: SSD 970 EVO Plus 2TB
  ID-3: /dev/sda vendor: Samsung model: SSD 850 EVO 1TB size: 931.51 GiB
  ID-4: /dev/sdb vendor: Western Digital model: WD20EZBX-00AYRA0
  ID-5: /dev/sdc vendor: Western Digital model: WD20EZBX-00AYRA0
  ID-6: /dev/sdd vendor: Samsung model: PSSD T7 size: 931.51 GiB type: USB
  ID-1: / size: 920.71 GiB used: 49.69 GiB (5.4%) fs: btrfs
    dev: /dev/nvme0n1p2
  ID-2: /boot/efi size: 2 GiB used: 664 KiB (0.0%) fs: vfat
    dev: /dev/nvme0n1p1
  ID-3: /home size: 920.71 GiB used: 49.69 GiB (5.4%) fs: btrfs
    dev: /dev/nvme0n1p2
  ID-4: /var/log size: 920.71 GiB used: 49.69 GiB (5.4%) fs: btrfs
    dev: /dev/nvme0n1p2
  ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%)
    dev: /dev/nvme0n1p3
  System Temperatures: cpu: 39.6 C mobo: N/A gpu: amdgpu temp: 35.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 10
  Memory: total: 32 GiB available: 31.25 GiB used: 3.21 GiB (10.3%)
  Processes: 562 Uptime: 5m Shell: Bash inxi: 3.3.41
Nur als info:
Ich hatte die Probleme, die du beschrieben hast, überhaupt nicht. Alle Updates in letzer Zeit lieferten keine negativen Ergebnisse. Mein Cinnamon läuft einwandfrei.
OT ein
Scheint wohl wieder mal ein KDE Ding zu sein. Obwohl Wayland -immer noch nicht- sauber läuft, kann man keine X11 Sitzung mehr starten. Da könnte man manche Fehler besser eingrenzen.
OT aus
Das heutige Update könnte das Problem lösen.
Hallo,
bei mir brachte das heutige Update die Lösung.
Ich warte noch auf weitere Rückmeldungen, bevor ich diesen Thread als gelöst markiere.
bye
nabashi
Wenn es für dich gelöst ist, kannst du auch das Thema schließen. Du hast es ja auch gestartet :wink:
na dann…
Ich habe seit gestern auch die Linux-Firmware in Version 20260910-2 installiert und keinerlei Abstürze mehr.
Seit heute ist die Version 20260916-1 im Testing. Gibt wohl noch ein paar Probleme mit AMD-Grafikkarten, die bestimmt nach und nach gefixt werden.
this topic should be in english
many users from rembrandt or using bad linux-firmware 20260910-1 should update for
20260910-2 or more
See also:
title do not shows that version firmware amdgpu 2060910-1 is bad
Moderatoren Hinweis: Bitte haltet dieses Thema in der deutschen Sprache. Alles andere ist sehr unhöflich. Falls nötig, mach doch einfach ein neues Thema im englischen Bereich auf mit einem Hinweis auf hier
Moderators Note: Please keep this thread in German. Anything else is very rude. If necessary, just start a new thread in the English section and link to this one.
Soeben wurde mir die Firmware in Version 20260916-1 angeboten. Auch danach habe ich keinerlei Probleme. :slight_smile:
Ich hatte gestern Abend auch auf linux-firmware-amdgpu 20260916-1 upgedatet. Alles läuft wie es soll
Dito
