Hi Team,
The newtork icon is not showing in the system tray.
Desktop - XFCE
libappindicator-gtk3 is installed
Also tried running /usr/bin/nm-applet but still not showing. Kindly help.
Hi Team,
Desktop - XFCE
Hi, @Vicky
How about this (in terminal)?
yay -S network-manager-applet
Log out and log in.
IDK what happened.
Edit @Vicky
Start type Session
Session and Startup > Application Autostart
and check Network (Manage your network conn.) is checked.
did you try “add new elements” by pressing the right mouse button on tray
So you have it displayed correctly. One connected and one not connected.
// moderation edit: moved to xfce section //
A little gallery says more… ![]()
on xfce4 you can reach all with your mouse… and you have human readable configs created in your users path in a logical order:
Thanks @joekamprad ,
The icon is showing now.
@Vicky mark the post that solved your problem as the solution. Which will help others and also close the thread automatically in two days.
