Network Controller Issue
Oh, I thought it was harder. The command failed Error occurred, no packages were upgraded.
Maybe update first.
sudo pacman -Syu
Edit: It is always a good idea when installing any package to update first.
I just read the errors and noticed they happened because the laptop is not connected to the internet.
Yes, give me some minutes
That would do it.
Edit: Can you connect to ethernet?
Sorry for the wait had to setup wifi on my desktop, I run
said yes to a bunch of thing and know it’s installing 800mb and apparently this pc ethernet is pretty slow, so it will take a couple of hours
Okay. Get it up to date first and see if anything changes after rebooting again. Then try installing the akm package and install the lts kernel and reboot and see. That’s all i can suggest at this point because those ralink chips either work or they don’t.
Ok, thank you very much.
