Basically what the title says
An hour ago or so I just updated and restarted my PC and now my LAN network connection refuses to work whatsoever
Yes, my home network still works
Welcome @ @classic !
Please, read this post first, before posting an issue without any more specific information than you gave us about your problem, so we can help you start trouble-shooting:
Thank you.
I was able to TEMP fix it with the help of endeavourOS Telegram members
If you suffer too, do the following:
inxi -Na
Check which driver is active. For example: “driver: r8169”
Then:
sudo modprobe
Temporarily fixed it for me!
This has to be done on every restart though!
See if the following will work for you:
https://discovery.endeavouros.com/network/r8168-workaround/2021/03/
So just install a different package and uninstall the other one…
Can try tomorrow. I can use my phone for tethering.
Is r8169 the one working for you? If positive, uninstall 8168 and reboot.
Also for getting a module to load on boot:
https://wiki.archlinux.org/title/Kernel_module#Using_files_in_/etc/modprobe.d/
r1869 is set as driver right now. It does NOT work unless i do the modprobe command
Have a look at the link in my previous post.
Yes will give it a try tomorrow thank you:)
this worked
