My theme is arc-dark and my icon pack is papirus-dark. Github pages for both clearly state that they support GTK2 and GTK3, yet for some reason neofetch shows that I have 2 themes and 2 icon packs applied:
I’ve only installed papirus icon pack through pacman from arch repository and applied both icons and theme in “Appearance” settings section.
Is this a neofetch bug or maybe I indeed somehow managed to apply 2 themes at once? What would be the best way to check it?
Visually I haven’t noticed any glitches or inconsistency…
As always big thanks in advance for any suggestions!
You may have some leftovers in file ~/.config/gtk-3.0/settings.ini.
If you look the the source code of /usr/bin/neofetch, around lines 3060-3071, you’ll see it takes and later shows more stuff, even if you don’t have that installed.
Neofetch has a bug, it still detect the Xfce theme as GTK2, not GTK3. If Neofetch was not buggy, the GTK3 theme would be right.
If gtk2 is installed on your system, install lxappearance package and launch it every time you change a theme, choose the theme and apply, you won’t need to edit the config file.
What puzzles me though is since, from my understanding, active theme is read from settings.ini and this file clearly has the wrong entries - why I’m still able to use without any issues currently selected Arc-Dark?
I mean if not mentioned neofetch bug I wouldn’t even notice that something might be wrong.
