Hi all,
A fresh install here. I’m having this issue with thumbnails in Nemo:
This is supposed to be an old problem, based on what I’ve read on the internet, but I can’t found how to solve it.
That fix button in the screenshot seems to do nothing. I’ve also tried sudo nemo --fix-cache
with no result.
If I delete the thumbnails folder inside cache folder, the message dissapear…just for a while. It always comes back.
Do you have any tips on how to permanent fix this?
Thanks in advance!!
If the prompt is saying that you need sudo rights to alter files in your $HOME
directory then it’s possible your file permissions are incorrect.
To reset all permissions so all files and directories are owned by your user, run:
sudo chown -R $USER $HOME
If that doesn’t help, make sure the dependencies required for thumbnail generation are installed:
$ pacman -Si nemo
Optional Deps : cinnamon-translations: i18n
ffmpegthumbnailer: support for video thumbnails
catdoc: search helpers support for legacy MS Office files
ghostscript: search helpers support for PostScript files
libgsf: search helpers support for MS Office files
libreoffice: search helpers support for legacy MS Office powerpoint files
odt2txt: search helpers support for LibreOffice files
poppler: search helpers support for PDF
I’m sorry to say, but nor of that worked. I think it’s not a problem about writting permissions because if I delete thumbnails folders, it will be created again and also its content. I think it could be about the files that I have, but I’m not sure and I don’t know how to debug this or where to look.
I’m just thinking out loud:
I’ve been looking again to de ownership of the files and I think it’s something weird, because in fact I can’t change that ownership.
If I open Nemo with sudo so I can change permissions in a gui, every time a try to change the user, it automatically comes back to root:
No matter which user I select here, root always remain. It happens the same if I try to change the ownership from console.
Do you think that is normal?
Are these files owned by root to begin with, or is something running as root altering those permissions after the files are created?
Where are these files located on your system? For example, are they on an NTFS partition?
They are in /home…and yes, I’ve mounted /home on an NTFS partition (I know it is not the best…). Do you think it is related to be a NTFS partition?
What mount options do you have for the NTFS partition in /etc/fstab
This:
I haven’t change any of this from the default installation.
Well, I had some urgency, so finally I’ve done another fresh install, this time formatting everything to ext4. The problem is gone.
So I can’t say that this problem was solved, but…it isn’t a problem for me anymore.
Just a guess, but based on your fstab, all the files/directories on /home
would be owned by root. Since this is a constraint of your mounting options, chmod
wouldn’t actually change the permissions. In case anyone else runs into this issue, I believe adding the mount options uid
and gid
would fix the issue.
Relevant information from man mount
Mount options for ntfs
uid=value, gid=value and umask=value
Set the file permission on the filesystem. The umask value is given
in octal. By default, the files are owned by root and not readable
by somebody else.
