this is the website i would like to run it through hypnotix
i found through sniffing the web page a reference to
https://qvmstream.tulix.tv/720p/720p/playlist.m3u8
but im not sure how to get that to work
i managed to get the file to sorta play in vlc but it looks a biut like max headroom.
running it in vlc terminal it spits out these endless errors as it plays
[h264 @ 0x7f2ca86281c0] No start code is found.
[h264 @ 0x7f2ca86281c0] Error splitting the input into NAL units.
[h264 @ 0x7f2ca863a780] No start code is found.
[h264 @ 0x7f2ca863a780] Error splitting the input into NAL units.
[h264 @ 0x7f2ca808ce00] No start code is found.
[h264 @ 0x7f2ca808ce00] Error splitting the input into NAL units.
[h264 @ 0x7f2ca8640980] No start code is found.
[h264 @ 0x7f2ca8640980] Error splitting the input into NAL units.
[h264 @ 0x7f2ca8642d00] No start code is found.
[h264 @ 0x7f2ca8642d00] Error splitting the input into NAL units.
[h264 @ 0x7f2ca8098b40] No start code is found.
[h264 @ 0x7f2ca8098b40] Error splitting the input into NAL units.
weird i can run it from a terminal flawlessly
mpv https://qvmstream.tulix.tv/720p/720p/playlist.m3u8
I’m not sure if the functionality for multiple providers is actually implemented yet, but a workaround is to edit $HOME/.hypnotix/providers/freeiptv and add this at the top (but below #EXTM3U):
#EXTINF:-1 tvg-name=Quo Vadis tvg-id=quovadisministry.org tvg-logo=http://logos.zattic.com/images/channels/logos/2a2a4aee64bbd6f7f817/black/84x48.png group-title="Quo Vadis",Quo Vadis
(I’m sure you can find a better logo file/URL…)
It will need to be re-added if the freeiptv provider list is updated, but at this stage of of the application’s development that’s probably OK.
i don’t sctually have a subdirectory for freeiptv but i do have a bunch of files named freeiptv
ok i see it now ty!
TY that works PURRRRRRRRRfecly
Hello, Very new to linux and Hypnotix
I am trying to edit the provider list and I do not see the provider file you refer to in the post
I also do not see a file named freeiptv. Any guidance would be greatly appreicated
@MrT It is not a good idea to “piggyback” on a post that has been marked solved. If you want more people to look at your problem, create a new post.
Finally, right click the freeiptv file and open it using a text editor. That should hold the links to the IPTV channels.
thank you, I will make sure I do not do that going forward.
I do not see a file called freeiptv, that’s my problem.
