Logging back in fixed it thankfully.
That said, before I re-logged I attempted to run “sudo pacman - Syu” and got a segmentation fault.
After re-logging it threw a different error. Attempted updating mirrors, changed nothing.
Remove /var/lib/pacman/db.lck
delete the db.lck file manually
Take a look at your disk and filesystem status.
You may have a failing disk.
Honestly, before doing anything else. I would boot off an ISO and backup any important data.
Boot disc came back as healthy last time I checked but this is definitely making me think whatever check I used before might have been full of shit.
Worth noting I was also dealing with some apparent RAM issues leading into this thread, but I don’t think that’s what’s going on right now.
Booting into my live USB rn.
smartctl 7.5 2025-04-30 r5714 [x86_64-linux-6.17.8-arch1-1] (local build)
Copyright (C) 2002-25, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: WD Blue / Red / Green SSDs
Device Model: WDC WDS100T2B0A-00SM50
Serial Number: 21332C803078
LU WWN Device Id: 5 001b44 8bc9445a3
Firmware Version: 415020WD
User Capacity: 1,000,204,886,016 bytes [1.00 TB]
Sector Size: 512 bytes logical/physical
Rotation Rate: Solid State Device
Form Factor: 2.5 inches
TRIM Command: Available, deterministic, zeroed
Device is: In smartctl database 7.5/5706
ATA Version is: ACS-4 T13/BSR INCITS 529 revision 5
SATA Version is: SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Sat Dec 20 20:40:22 2025 EST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 0) seconds.
capabilities: (0x11) SMART execute Offline immediate.
No Auto Offline data collection support.
Suspend Offline collection upon new
command.
No Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
No Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 10) minutes.
SMART Attributes Data Structure revision number: 4
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
5 Reallocated_Sector_Ct 0x0032 100 100 --- Old_age Always - 0
9 Power_On_Hours 0x0032 100 100 --- Old_age Always - 34126
12 Power_Cycle_Count 0x0032 100 100 --- Old_age Always - 209
165 Block_Erase_Count 0x0032 100 100 --- Old_age Always - 3548423596606
166 Minimum_PE_Cycles_TLC 0x0032 100 100 --- Old_age Always - 85
167 Max_Bad_Blocks_per_Die 0x0032 100 100 --- Old_age Always - 181
168 Maximum_PE_Cycles_TLC 0x0032 100 100 --- Old_age Always - 158
169 Total_Bad_Blocks 0x0032 100 100 --- Old_age Always - 673
170 Grown_Bad_Blocks 0x0032 100 100 --- Old_age Always - 0
171 Program_Fail_Count 0x0032 100 100 --- Old_age Always - 0
172 Erase_Fail_Count 0x0032 100 100 --- Old_age Always - 0
173 Average_PE_Cycles_TLC 0x0032 100 100 --- Old_age Always - 117
174 Unexpected_Power_Loss 0x0032 100 100 --- Old_age Always - 101
184 End-to-End_Error 0x0032 100 100 --- Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 --- Old_age Always - 0
188 Command_Timeout 0x0032 100 100 --- Old_age Always - 0
194 Temperature_Celsius 0x0022 072 054 --- Old_age Always - 28 (Min/Max 16/54)
199 UDMA_CRC_Error_Count 0x0032 100 100 --- Old_age Always - 0
230 Media_Wearout_Indicator 0x0032 021 021 --- Old_age Always - 0x153e0b46153e
232 Available_Reservd_Space 0x0033 100 100 004 Pre-fail Always - 100
233 NAND_GB_Written_TLC 0x0032 100 100 --- Old_age Always - 119050
234 NAND_GB_Written_SLC 0x0032 100 100 --- Old_age Always - 160769
241 Host_Writes_GiB 0x0030 253 253 --- Old_age Offline - 114352
242 Host_Reads_GiB 0x0030 253 253 --- Old_age Offline - 198697
244 Temp_Throttle_Status 0x0032 000 100 --- Old_age Always - 0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Ran a new short test, it says it passed. Gonna go ahead and run a long one.
Edit: Gotta wait 10 minutes for results on the long test, but just want to note the cruel irony of potentially having both an SSD and RAM fail exactly when the prices of both have suddenly skyrocketed due to corpo greed and the desire to profit off the AI slop bubble.
While smart tests will sometimes reveal issues with a failing SSD, they won’t always.
You should also make sure the partition isn’t close to full.
Either way, I would prioritize a backup over anything else.
The only minorly important data on the drive I’m actually particularly worried about is password data because I had to update a bunch recently due to someone gaining access to an account presumably due to leaked data and using one of my cards.
But I use a set of passwords based off a system rather than unique ones for every single account/site, so it won’t really be an issue to get back into accounts without that data saved.
There’s also some cross stitch patterns, but I exported those yesterday so I could work on them at work so all I’d be losing is the editable copies of them which is whatever.
Also, I just checked and both the EFI and EndeavorOS partitions have 75% space remaining.
Came back fine again I think?
sudo smartctl -a /dev/sda |less output:
Local Time is: Sat Dec 20 21:07:37 2025 EST
was never started.
been run.
command.
power-saving mode.
194 Temperature_Celsius 0x0022 073 054 --- Old_age Always - 27 (Min/Max 16/54)
No Errors Logged
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Extended offline Completed without error 00% 34126 -
sudo smartctl -x /dev/sdaoutput:
[liveuser@eos-2025.11.24 ~]$ sudo smartctl -x /dev/sda
Local Time is: Sat Dec 20 21:09:38 2025 EST
AAM feature is: Unavailable
APM level is: 128 (minimum power consumption without standby)
Rd look-ahead is: Enabled
Write cache is: Enabled
DSN feature is: Unavailable
ATA Security is: Disabled, frozen [SEC2]
was never started.
been run.
command.
power-saving mode.
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
5 Reallocated_Sector_Ct -O–CK 100 100 — - 0
9 Power_On_Hours -O–CK 100 100 — - 34126
12 Power_Cycle_Count -O–CK 100 100 — - 209
165 Block_Erase_Count -O–CK 100 100 — - 3548423596606
166 Minimum_PE_Cycles_TLC -O–CK 100 100 — - 85
167 Max_Bad_Blocks_per_Die -O–CK 100 100 — - 181
168 Maximum_PE_Cycles_TLC -O–CK 100 100 — - 158
169 Total_Bad_Blocks -O–CK 100 100 — - 673
170 Grown_Bad_Blocks -O–CK 100 100 — - 0
171 Program_Fail_Count -O–CK 100 100 — - 0
172 Erase_Fail_Count -O–CK 100 100 — - 0
173 Average_PE_Cycles_TLC -O–CK 100 100 — - 117
174 Unexpected_Power_Loss -O–CK 100 100 — - 101
184 End-to-End_Error -O–CK 100 100 — - 0
187 Reported_Uncorrect -O–CK 100 100 — - 0
188 Command_Timeout -O–CK 100 100 — - 0
194 Temperature_Celsius -O—K 074 054 — - 26 (Min/Max 16/54)
199 UDMA_CRC_Error_Count -O–CK 100 100 — - 0
230 Media_Wearout_Indicator -O–CK 021 021 — - 0x153e0b46153e
232 Available_Reservd_Space PO–CK 100 100 004 - 100
233 NAND_GB_Written_TLC -O–CK 100 100 — - 119050
234 NAND_GB_Written_SLC -O–CK 100 100 — - 160769
241 Host_Writes_GiB ----CK 253 253 — - 114352
242 Host_Reads_GiB ----CK 253 253 — - 198697
244 Temp_Throttle_Status -O–CK 000 100 — - 0
||||||_ K auto-keep
|||||__ C event count
||||__ R error rate
|||__ S speed/performance
||__ O updated online
|______ P prefailure warning
General Purpose Log Directory Version 1
SMART Log Directory Version 1 [multi-sector log support]
Address Access R/W Size Description
0x00 GPL,SL R/O 1 Log Directory
0x01 SL R/O 1 Summary SMART error log
0x02 SL R/O 2 Comprehensive SMART error log
0x03 GPL R/O 1 Ext. Comprehensive SMART error log
0x04 GPL,SL R/O 8 Device Statistics log
0x06 SL R/O 1 SMART self-test log
0x07 GPL R/O 1 Extended self-test log
0x10 GPL R/O 1 NCQ Command Error log
0x11 GPL R/O 1 SATA Phy Event Counters log
0x24 GPL R/O 1957 Current Device Internal Status Data log
0x25 GPL R/O 1957 Saved Device Internal Status Data log
0x30 GPL,SL R/O 9 IDENTIFY DEVICE data log
0x80-0x9f GPL,SL R/W 16 Host vendor specific log
0xde GPL VS 8 Device vendor specific log
SMART Extended Comprehensive Error Log Version: 1 (1 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
2 Short offline Completed without error 00% 34126 -
Selective Self-tests/Logging not supported
SCT Commands not supported
Device Statistics (GP Log 0x04)
Page Offset Size Value Flags Description
0x01 ===== = = === == General Statistics (rev 1) ==
0x01 0x008 4 209 — Lifetime Power-On Resets
0x01 0x010 4 34126 — Power-on Hours
0x01 0x018 6 239814199225 — Logical Sectors Written
0x01 0x020 6 1158338331 — Number of Write Commands
0x01 0x028 6 416698549643 — Logical Sectors Read
0x01 0x030 6 312050674748 — Number of Read Commands
0x07 ===== = = === == Solid State Device Statistics (rev 1) ==
0x07 0x008 1 11 N-- Percentage Used Endurance Indicator
|||_ C monitored condition met
||__ D supports DSN
|___ N normalized value
Pending Defects log (GP Log 0x0c) not supported
SATA Phy Event Counters (GP Log 0x11)
ID Size Value Description
0x0001 4 0 Command failed due to ICRC error
0x0002 4 0 R_ERR response for data FIS
0x0005 4 0 R_ERR response for non-data FIS
0x000a 4 10 Device-to-host register FISes sent due to a COMRESET
I would run fsck on your filesystems and see if any of them have new errors.
Came back clean, so what now?
[liveuser@eos-2025.11.24 ~]$ sudo fsck /dev/sda2
fsck from util-linux 2.41.2
e2fsck 1.47.3 (8-Jul-2025)
/dev/sda2 is mounted.
e2fsck: Cannot continue, aborting.
[liveuser@eos-2025.11.24 ~]$ sudo umount /dev/sda2
endeavouros: clean, 841860/60923904 files, 70745623/243665837 blocks
systemctl --failedoutput:
[liveuser@eos-2025.11.24 ~]$ systemctl --failed
UNIT LOAD ACTIVE SUB DESCRIPTION
● intel.service loaded failed failed detect intel legacy gpu and install xf86-video-intel
Full journalctl -b logs: (Broken up into multiple messages due to character limit)
[liveuser@eos-2025.11.24 ~]$ sudo journalctl -b
Dec 20 20:35:02 EndeavourOS kernel: Linux version 6.17.8-arch1-1 (linux@archlinux) (gcc (GCC) 15.2.1 20251112>
Dec 20 20:35:02 EndeavourOS kernel: Command line: initrd=\arch\boot\x86_64\initramfs-linux.img initrd=\arch\b>
Dec 20 20:35:02 EndeavourOS kernel: x86/CPU: Running old microcode
Dec 20 20:35:02 EndeavourOS kernel: BIOS-provided physical RAM map:
Dec 20 20:35:02 EndeavourOS kernel: BIOS-e820: [mem 0x0000000000000000-0x0000000000057fff] usable
Dec 20 20:35:02 EndeavourOS kernel: BIOS-e820: [mem 0x0000000000058000-0x0000000000058fff] reserved
Dec 20 20:35:02 EndeavourOS kernel: BIOS-e820: [mem 0x0000000000059000-0x000000000009dfff] usable
Dec 20 20:35:02 EndeavourOS kernel: BIOS-e820: [mem 0x000000000009e000-0x00000000000fffff] reserved
Dec 20 20:35:02 EndeavourOS kernel: BIOS-e820: [mem 0x0000000000100000-0x000000003fffffff] usable
Dec 20 20:35:02 EndeavourOS kernel: BIOS-e820: [mem 0x0000000040000000-0x00000000403fffff] reserved
Dec 20 20:35:02 EndeavourOS kernel: BIOS-e820: [mem 0x0000000040400000-0x000000007a6abfff] usable
Dec 20 20:35:02 EndeavourOS kernel: BIOS-e820: [mem 0x000000007a6ac000-0x000000007a6acfff] ACPI NVS
Dec 20 20:35:02 EndeavourOS kernel: BIOS-e820: [mem 0x000000007a6ad000-0x000000007a6adfff] reserved
Dec 20 20:35:02 EndeavourOS kernel: BIOS-e820: [mem 0x000000007a6ae000-0x000000008d982fff] usable
Dec 20 20:35:02 EndeavourOS kernel: BIOS-e820: [mem 0x000000008d983000-0x000000008de58fff] reserved
Dec 20 20:35:02 EndeavourOS kernel: BIOS-e820: [mem 0x000000008de59000-0x000000008dec8fff] ACPI data
Dec 20 20:35:02 EndeavourOS kernel: BIOS-e820: [mem 0x000000008dec9000-0x000000008e32dfff] ACPI NVS
Dec 20 20:35:02 EndeavourOS kernel: BIOS-e820: [mem 0x000000008e32e000-0x000000008f7fdfff] reserved
Dec 20 20:35:02 EndeavourOS kernel: BIOS-e820: [mem 0x000000008f7fe000-0x000000008f7fefff] usable
Dec 20 20:35:02 EndeavourOS kernel: BIOS-e820: [mem 0x000000008f7ff000-0x000000008fffffff] reserved
Dec 20 20:35:02 EndeavourOS kernel: BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
Dec 20 20:35:02 EndeavourOS kernel: BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
Dec 20 20:35:02 EndeavourOS kernel: BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
Dec 20 20:35:02 EndeavourOS kernel: BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
Dec 20 20:35:02 EndeavourOS kernel: BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
Dec 20 20:35:02 EndeavourOS kernel: BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
Dec 20 20:35:02 EndeavourOS kernel: BIOS-e820: [mem 0x0000000100000000-0x000000086effffff] usable
Dec 20 20:35:02 EndeavourOS kernel: NX (Execute Disable) protection: active
Dec 20 20:35:02 EndeavourOS kernel: APIC: Static calls initialized
Dec 20 20:35:02 EndeavourOS kernel: efi: EFI v2.7 by American Megatrends
Dec 20 20:35:02 EndeavourOS kernel: efi: TPMFinalLog=0x8e2fd000 ACPI 2.0=0x8e277000 ACPI=0x8e277000 SMBIOS=0x>
Dec 20 20:35:02 EndeavourOS kernel: random: crng init done
Dec 20 20:35:02 EndeavourOS kernel: efi: Remove mem51: MMIO range=[0xe0000000-0xefffffff] (256MB) from e820 m>
Dec 20 20:35:02 EndeavourOS kernel: e820: remove [mem 0xe0000000-0xefffffff] reserved
Dec 20 20:35:02 EndeavourOS kernel: efi: Not removing mem52: MMIO range=[0xfe000000-0xfe010fff] (68KB) from e>
Dec 20 20:35:02 EndeavourOS kernel: efi: Not removing mem53: MMIO range=[0xfec00000-0xfec00fff] (4KB) from e8>
Dec 20 20:35:02 EndeavourOS kernel: efi: Not removing mem54: MMIO range=[0xfed00000-0xfed00fff] (4KB) from e8>
Dec 20 20:35:02 EndeavourOS kernel: efi: Not removing mem55: MMIO range=[0xfee00000-0xfee00fff] (4KB) from e8>
Dec 20 20:35:02 EndeavourOS kernel: efi: Remove mem56: MMIO range=[0xff000000-0xffffffff] (16MB) from e820 map
Dec 20 20:35:02 EndeavourOS kernel: e820: remove [mem 0xff000000-0xffffffff] reserved
Dec 20 20:35:02 EndeavourOS kernel: SMBIOS 2.8 present.
Dec 20 20:35:02 EndeavourOS kernel: DMI: Micro-Star International Co., Ltd. MS-7B48/Z370-A PRO (MS-7B48), BIO>
Dec 20 20:35:02 EndeavourOS kernel: DMI: Memory slots populated: 2/4
Dec 20 20:35:02 EndeavourOS kernel: tsc: Detected 3700.000 MHz processor
Dec 20 20:35:02 EndeavourOS kernel: tsc: Detected 3699.850 MHz TSC
Dec 20 20:35:02 EndeavourOS kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
Dec 20 20:35:02 EndeavourOS kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
Dec 20 20:35:02 EndeavourOS kernel: last_pfn = 0x86f000 max_arch_pfn = 0x400000000
Dec 20 20:35:02 EndeavourOS kernel: MTRR map: 4 entries (3 fixed + 1 variable; max 23), built from 10 variabl>
Dec 20 20:35:02 EndeavourOS kernel: x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
Dec 20 20:35:02 EndeavourOS kernel: last_pfn = 0x8f7ff max_arch_pfn = 0x400000000
Dec 20 20:35:02 EndeavourOS kernel: esrt: Reserving ESRT space from 0x000000008a973718 to 0x000000008a973750.
Dec 20 20:35:02 EndeavourOS kernel: e820: update [mem 0x8a973000-0x8a973fff] usable ==> reserved
Dec 20 20:35:02 EndeavourOS kernel: Using GB pages for direct mapping
Dec 20 20:35:02 EndeavourOS kernel: Secure boot disabled
Dec 20 20:35:02 EndeavourOS kernel: RAMDISK: [mem 0x5c6fe000-0x6a7cdfff]
Dec 20 20:35:02 EndeavourOS kernel: ACPI: Early table checksum verification disabled
Dec 20 20:35:02 EndeavourOS kernel: ACPI: RSDP 0x000000008E277000 000024 (v02 ALASKA)
Dec 20 20:35:02 EndeavourOS kernel: ACPI: XSDT 0x000000008E2770B0 0000E4 (v01 ALASKA A M I 01072009 AMI 0>
Dec 20 20:35:02 EndeavourOS kernel: ACPI: FACP 0x000000008E2A5AE8 000114 (v06 ALASKA A M I 01072009 AMI 0>
Dec 20 20:35:02 EndeavourOS kernel: ACPI: DSDT 0x000000008E277230 02E8B8 (v02 ALASKA A M I 01072009 INTL 2>
Dec 20 20:35:02 EndeavourOS kernel: ACPI: FACS 0x000000008E32DF80 000040
Dec 20 20:35:02 EndeavourOS kernel: ACPI: APIC 0x000000008E2A5C00 0000F4 (v03 ALASKA A M I 01072009 AMI 0>
Dec 20 20:35:02 EndeavourOS kernel: ACPI: FPDT 0x000000008E2A5CF8 000044 (v01 ALASKA A M I 01072009 AMI 0>
Dec 20 20:35:02 EndeavourOS kernel: ACPI: FIDT 0x000000008E2A5D40 00009C (v01 ALASKA A M I 01072009 AMI 0>
Dec 20 20:35:02 EndeavourOS kernel: ACPI: MCFG 0x000000008E2A5DE0 00003C (v01 ALASKA A M I 01072009 MSFT 0>
Dec 20 20:35:02 EndeavourOS kernel: ACPI: SSDT 0x000000008E2A5E20 0003A3 (v01 SataRe SataTabl 00001000 INTL 2>
Dec 20 20:35:02 EndeavourOS kernel: ACPI: MSDM 0x000000008E2A61C8 000055 (v03 ALASKA A M I 01072009 AMI 0>
Dec 20 20:35:02 EndeavourOS kernel: ACPI: SSDT 0x000000008E2A6220 003165 (v02 SaSsdt SaSsdt 00003000 INTL 2>
Dec 20 20:35:02 EndeavourOS kernel: ACPI: SSDT 0x000000008E2A9388 002743 (v02 PegSsd PegSsdt 00001000 INTL 2>
Dec 20 20:35:02 EndeavourOS kernel: ACPI: HPET 0x000000008E2ABAD0 000038 (v01 INTEL KBL 00000001 MSFT 0>
Dec 20 20:35:02 EndeavourOS kernel: ACPI: SSDT 0x000000008E2ABB08 0011AA (v02 INTEL Ther_Rvp 00001000 INTL 2>
Dec 20 20:35:02 EndeavourOS kernel: ACPI: SSDT 0x000000008E2ACCB8 000A2C (v02 INTEL xh_rvp08 00000000 INTL 2>
Dec 20 20:35:02 EndeavourOS kernel: ACPI: SSDT 0x000000008E2AD6E8 0017AE (v02 CpuRef CpuSsdt 00003000 INTL 2>
Dec 20 20:35:02 EndeavourOS kernel: ACPI: LPIT 0x000000008E2AEE98 000094 (v01 INTEL KBL 00000000 MSFT 0>
Dec 20 20:35:02 EndeavourOS kernel: ACPI: SSDT 0x000000008E2AEF30 000141 (v02 INTEL HdaDsp 00000000 INTL 2>
Dec 20 20:35:02 EndeavourOS kernel: ACPI: SSDT 0x000000008E2AF078 00029F (v02 INTEL sensrhub 00000000 INTL 2>
Dec 20 20:35:02 EndeavourOS kernel: ACPI: SSDT 0x000000008E2AF318 003002 (v02 INTEL PtidDevc 00001000 INTL 2>
Dec 20 20:35:02 EndeavourOS kernel: ACPI: SSDT 0x000000008E2B2320 000517 (v02 INTEL TbtTypeC 00000000 INTL 2>
Dec 20 20:35:02 EndeavourOS kernel: ACPI: SSDT 0x000000008E2B2838 000306 (v02 INTEL Wwan 00000001 INTL 2>
Dec 20 20:35:02 EndeavourOS kernel: ACPI: DBGP 0x000000008E2B2B40 000034 (v01 INTEL 00000002 MSFT 0>
Dec 20 20:35:02 EndeavourOS kernel: ACPI: DBG2 0x000000008E2B2B78 000054 (v00 INTEL 00000002 MSFT 0>
Dec 20 20:35:02 EndeavourOS kernel: ACPI: TPM2 0x000000008E2B2BD0 000034 (v04 ALASKA A M I 00000001 AMI 0>
Dec 20 20:35:02 EndeavourOS kernel: ACPI: BGRT 0x000000008E2B2C08 000038 (v01 ALASKA A M I 01072009 AMI 0>
Dec 20 20:35:02 EndeavourOS kernel: ACPI: WSMT 0x000000008E2B2C40 000028 (v01 ALASKA A M I 01072009 AMI 0>
Dec 20 20:35:02 EndeavourOS kernel: ACPI: Reserving FACP table memory at [mem 0x8e2a5ae8-0x8e2a5bfb]
Dec 20 20:35:02 EndeavourOS kernel: ACPI: Reserving DSDT table memory at [mem 0x8e277230-0x8e2a5ae7]
Dec 20 20:35:02 EndeavourOS kernel: ACPI: Reserving FACS table memory at [mem 0x8e32df80-0x8e32dfbf]
Dec 20 20:35:02 EndeavourOS kernel: ACPI: Reserving APIC table memory at [mem 0x8e2a5c00-0x8e2a5cf3]
Dec 20 20:35:02 EndeavourOS kernel: ACPI: Reserving FPDT table memory at [mem 0x8e2a5cf8-0x8e2a5d3b]
Dec 20 20:35:02 EndeavourOS kernel: ACPI: Reserving FIDT table memory at [mem 0x8e2a5d40-0x8e2a5ddb]
Dec 20 20:35:02 EndeavourOS kernel: ACPI: Reserving MCFG table memory at [mem 0x8e2a5de0-0x8e2a5e1b]
Dec 20 20:35:02 EndeavourOS kernel: ACPI: Reserving SSDT table memory at [mem 0x8e2a5e20-0x8e2a61c2]
Dec 20 20:35:02 EndeavourOS kernel: ACPI: Reserving MSDM table memory at [mem 0x8e2a61c8-0x8e2a621c]
Dec 20 20:35:02 EndeavourOS kernel: ACPI: Reserving SSDT table memory at [mem 0x8e2a6220-0x8e2a9384]
Dec 20 20:35:02 EndeavourOS kernel: ACPI: Reserving SSDT table memory at [mem 0x8e2a9388-0x8e2abaca]
Dec 20 20:35:02 EndeavourOS kernel: ACPI: Reserving HPET table memory at [mem 0x8e2abad0-0x8e2abb07]
Dec 20 20:35:02 EndeavourOS kernel: ACPI: Reserving SSDT table memory at [mem 0x8e2abb08-0x8e2accb1]
Dec 20 20:35:02 EndeavourOS kernel: ACPI: Reserving SSDT table memory at [mem 0x8e2accb8-0x8e2ad6e3]
Dec 20 20:35:02 EndeavourOS kernel: ACPI: Reserving SSDT table memory at [mem 0x8e2ad6e8-0x8e2aee95]
Dec 20 20:35:02 EndeavourOS kernel: ACPI: Reserving LPIT table memory at [mem 0x8e2aee98-0x8e2aef2b]
Dec 20 20:35:02 EndeavourOS kernel: ACPI: Reserving SSDT table memory at [mem 0x8e2aef30-0x8e2af070]
Dec 20 20:35:02 EndeavourOS kernel: ACPI: Reserving SSDT table memory at [mem 0x8e2af078-0x8e2af316]
Dec 20 20:35:02 EndeavourOS kernel: ACPI: Reserving SSDT table memory at [mem 0x8e2af318-0x8e2b2319]
Dec 20 20:35:02 EndeavourOS kernel: ACPI: Reserving SSDT table memory at [mem 0x8e2b2320-0x8e2b2836]
Dec 20 20:35:02 EndeavourOS kernel: ACPI: Reserving SSDT table memory at [mem 0x8e2b2838-0x8e2b2b3d]
Dec 20 20:35:02 EndeavourOS kernel: ACPI: Reserving DBGP table memory at [mem 0x8e2b2b40-0x8e2b2b73]
Dec 20 20:35:02 EndeavourOS kernel: ACPI: Reserving DBG2 table memory at [mem 0x8e2b2b78-0x8e2b2bcb]
Dec 20 20:35:02 EndeavourOS kernel: ACPI: Reserving TPM2 table memory at [mem 0x8e2b2bd0-0x8e2b2c03]
Dec 20 20:35:02 EndeavourOS kernel: ACPI: Reserving BGRT table memory at [mem 0x8e2b2c08-0x8e2b2c3f]
Dec 20 20:35:02 EndeavourOS kernel: ACPI: Reserving WSMT table memory at [mem 0x8e2b2c40-0x8e2b2c67]
Dec 20 20:35:02 EndeavourOS kernel: No NUMA configuration found
Dec 20 20:35:02 EndeavourOS kernel: Faking a node at [mem 0x0000000000000000-0x000000086effffff]
Dec 20 20:35:02 EndeavourOS kernel: NODE_DATA(0) allocated [mem 0x86efd52c0-0x86effffff]
Dec 20 20:35:02 EndeavourOS kernel: Zone ranges:
Dec 20 20:35:02 EndeavourOS kernel: DMA [mem 0x0000000000001000-0x0000000000ffffff]
Dec 20 20:35:02 EndeavourOS kernel: DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
Dec 20 20:35:02 EndeavourOS kernel: Normal [mem 0x0000000100000000-0x000000086effffff]
Dec 20 20:35:02 EndeavourOS kernel: Device empty
Dec 20 20:35:02 EndeavourOS kernel: Movable zone start for each node
Dec 20 20:35:02 EndeavourOS kernel: Early memory node ranges
Dec 20 20:35:02 EndeavourOS kernel: node 0: [mem 0x0000000000001000-0x0000000000057fff]
Dec 20 20:35:02 EndeavourOS kernel: node 0: [mem 0x0000000000059000-0x000000000009dfff]
Dec 20 20:35:02 EndeavourOS kernel: node 0: [mem 0x0000000000100000-0x000000003fffffff]
Dec 20 20:35:02 EndeavourOS kernel: node 0: [mem 0x0000000040400000-0x000000007a6abfff]
Dec 20 20:35:02 EndeavourOS kernel: node 0: [mem 0x000000007a6ae000-0x000000008d982fff]
Dec 20 20:35:02 EndeavourOS kernel: node 0: [mem 0x000000008f7fe000-0x000000008f7fefff]
Dec 20 20:35:02 EndeavourOS kernel: node 0: [mem 0x0000000100000000-0x000000086effffff]
Dec 20 20:35:02 EndeavourOS kernel: Initmem setup node 0 [mem 0x0000000000001000-0x000000086effffff]
Dec 20 20:35:02 EndeavourOS kernel: On node 0, zone DMA: 1 pages in unavailable ranges
Dec 20 20:35:02 EndeavourOS kernel: On node 0, zone DMA: 98 pages in unavailable ranges
Dec 20 20:35:02 EndeavourOS kernel: On node 0, zone DMA32: 1024 pages in unavailable ranges
Dec 20 20:35:02 EndeavourOS kernel: On node 0, zone DMA32: 2 pages in unavailable ranges
Dec 20 20:35:02 EndeavourOS kernel: On node 0, zone DMA32: 7803 pages in unavailable ranges
Dec 20 20:35:02 EndeavourOS kernel: On node 0, zone Normal: 2049 pages in unavailable ranges
Dec 20 20:35:02 EndeavourOS kernel: On node 0, zone Normal: 4096 pages in unavailable ranges
Dec 20 20:35:02 EndeavourOS kernel: ACPI: PM-Timer IO Port: 0x1808
Dec 20 20:35:02 EndeavourOS kernel: ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
Dec 20 20:35:02 EndeavourOS kernel: ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
Dec 20 20:35:02 EndeavourOS kernel: ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
Dec 20 20:35:02 EndeavourOS kernel: ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
Dec 20 20:35:02 EndeavourOS kernel: ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
Dec 20 20:35:02 EndeavourOS kernel: ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
Dec 20 20:35:02 EndeavourOS kernel: ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
Dec 20 20:35:02 EndeavourOS kernel: ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
Dec 20 20:35:02 EndeavourOS kernel: ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
Dec 20 20:35:02 EndeavourOS kernel: ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
Dec 20 20:35:02 EndeavourOS kernel: ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
Dec 20 20:35:02 EndeavourOS kernel: ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
Dec 20 20:35:02 EndeavourOS kernel: IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
Dec 20 20:35:02 EndeavourOS kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
Dec 20 20:35:02 EndeavourOS kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
Dec 20 20:35:02 EndeavourOS kernel: ACPI: Using ACPI (MADT) for SMP configuration information
Dec 20 20:35:02 EndeavourOS kernel: ACPI: HPET id: 0x8086a201 base: 0xfed00000
Dec 20 20:35:02 EndeavourOS kernel: e820: update [mem 0x89ca6000-0x89ce7fff] usable ==> reserved
Dec 20 20:35:02 EndeavourOS kernel: TSC deadline timer available
Dec 20 20:35:02 EndeavourOS kernel: CPU topo: Max. logical packages: 1
Dec 20 20:35:02 EndeavourOS kernel: CPU topo: Max. logical dies: 1
Dec 20 20:35:02 EndeavourOS kernel: CPU topo: Max. dies per package: 1
Dec 20 20:35:02 EndeavourOS kernel: CPU topo: Max. threads per core: 2
Dec 20 20:35:02 EndeavourOS kernel: CPU topo: Num. cores per package: 6
Dec 20 20:35:02 EndeavourOS kernel: CPU topo: Num. threads per package: 12
Dec 20 20:35:02 EndeavourOS kernel: CPU topo: Allowing 12 present CPUs plus 0 hotplug CPUs
Dec 20 20:35:02 EndeavourOS kernel: PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
Dec 20 20:35:02 EndeavourOS kernel: PM: hibernation: Registered nosave memory: [mem 0x00058000-0x00058fff]
Dec 20 20:35:02 EndeavourOS kernel: PM: hibernation: Registered nosave memory: [mem 0x0009e000-0x000fffff]
Dec 20 20:35:02 EndeavourOS kernel: PM: hibernation: Registered nosave memory: [mem 0x40000000-0x403fffff]
Dec 20 20:35:02 EndeavourOS kernel: PM: hibernation: Registered nosave memory: [mem 0x7a6ac000-0x7a6adfff]
Dec 20 20:35:02 EndeavourOS kernel: PM: hibernation: Registered nosave memory: [mem 0x89ca6000-0x89ce7fff]
Dec 20 20:35:02 EndeavourOS kernel: PM: hibernation: Registered nosave memory: [mem 0x8a973000-0x8a973fff]
Dec 20 20:35:02 EndeavourOS kernel: PM: hibernation: Registered nosave memory: [mem 0x8d983000-0x8f7fdfff]
Dec 20 20:35:02 EndeavourOS kernel: PM: hibernation: Registered nosave memory: [mem 0x8f7ff000-0xffffffff]
Dec 20 20:35:02 EndeavourOS kernel: [mem 0x90000000-0xfdffffff] available for PCI devices
Dec 20 20:35:02 EndeavourOS kernel: Booting paravirtualized kernel on bare hardware
Dec 20 20:35:02 EndeavourOS kernel: clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma>
Dec 20 20:35:02 EndeavourOS kernel: setup_percpu: NR_CPUS:8192 nr_cpumask_bits:12 nr_cpu_ids:12 nr_node_ids:1
Dec 20 20:35:02 EndeavourOS kernel: percpu: Embedded 62 pages/cpu s217088 r8192 d28672 u262144
Dec 20 20:35:02 EndeavourOS kernel: pcpu-alloc: s217088 r8192 d28672 u262144 alloc=1*2097152
Dec 20 20:35:02 EndeavourOS kernel: pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 -- -- -- --
Dec 20 20:35:02 EndeavourOS kernel: Kernel command line: initrd=\arch\boot\x86_64\initramfs-linux.img initrd=>
Dec 20 20:35:02 EndeavourOS kernel: Unknown kernel command line parameters "archisobasedir=arch archisosearch>
Dec 20 20:35:02 EndeavourOS kernel: printk: log buffer data + meta data: 131072 + 458752 = 589824 bytes
Dec 20 20:35:02 EndeavourOS kernel: Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, line>
Dec 20 20:35:02 EndeavourOS kernel: Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linea>
Dec 20 20:35:02 EndeavourOS kernel: software IO TLB: area num 16.
Dec 20 20:35:02 EndeavourOS kernel: Fallback order for Node 0: 0
Dec 20 20:35:02 EndeavourOS kernel: Built 1 zonelists, mobility grouping on. Total pages: 8373534
Dec 20 20:35:02 EndeavourOS kernel: Policy zone: Normal
Dec 20 20:35:02 EndeavourOS kernel: mem auto-init: stack:all(zero), heap alloc:on, heap free:off
Dec 20 20:35:02 EndeavourOS kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=12, Nodes=1
Dec 20 20:35:02 EndeavourOS kernel: Kernel/User page tables isolation: enabled
Dec 20 20:35:02 EndeavourOS kernel: ftrace: allocating 56535 entries in 224 pages
Dec 20 20:35:02 EndeavourOS kernel: ftrace: allocated 224 pages with 3 groups
Dec 20 20:35:02 EndeavourOS kernel: Dynamic Preempt: full
Dec 20 20:35:02 EndeavourOS kernel: rcu: Preemptible hierarchical RCU implementation.
Dec 20 20:35:02 EndeavourOS kernel: rcu: RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=12.
Dec 20 20:35:02 EndeavourOS kernel: rcu: RCU priority boosting: priority 1 delay 500 ms.
Dec 20 20:35:02 EndeavourOS kernel: Trampoline variant of Tasks RCU enabled.
Dec 20 20:35:02 EndeavourOS kernel: Rude variant of Tasks RCU enabled.
Dec 20 20:35:02 EndeavourOS kernel: Tracing variant of Tasks RCU enabled.
Dec 20 20:35:02 EndeavourOS kernel: rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies.
Dec 20 20:35:02 EndeavourOS kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=12
Dec 20 20:35:02 EndeavourOS kernel: RCU Tasks: Setting shift to 4 and lim to 1 rcu_task_cb_adjust=1 rcu_task_>
Dec 20 20:35:02 EndeavourOS kernel: RCU Tasks Rude: Setting shift to 4 and lim to 1 rcu_task_cb_adjust=1 rcu_>
Dec 20 20:35:02 EndeavourOS kernel: RCU Tasks Trace: Setting shift to 4 and lim to 1 rcu_task_cb_adjust=1 rcu>
Dec 20 20:35:02 EndeavourOS kernel: NR_IRQS: 524544, nr_irqs: 2152, preallocated irqs: 16
Dec 20 20:35:02 EndeavourOS kernel: rcu: srcu_init: Setting srcu_struct sizes based on contention.
Dec 20 20:35:02 EndeavourOS kernel: kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrva>
Dec 20 20:35:02 EndeavourOS kernel: Console: colour dummy device 80x25
Dec 20 20:35:02 EndeavourOS kernel: printk: legacy console [tty0] enabled
Dec 20 20:35:02 EndeavourOS kernel: ACPI: Core revision 20250404
Dec 20 20:35:02 EndeavourOS kernel: clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: >
Dec 20 20:35:02 EndeavourOS kernel: APIC: Switch to symmetric I/O mode setup
Dec 20 20:35:02 EndeavourOS kernel: x2apic: IRQ remapping doesn't support X2APIC mode
Dec 20 20:35:02 EndeavourOS kernel: ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
Dec 20 20:35:02 EndeavourOS kernel: clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x6aa99074b1>
Dec 20 20:35:02 EndeavourOS kernel: Calibrating delay loop (skipped), value calculated using timer frequency.>
Dec 20 20:35:02 EndeavourOS kernel: x86/cpu: SGX disabled or unsupported by BIOS.
Dec 20 20:35:02 EndeavourOS kernel: CPU0: Thermal monitoring enabled (TM1)
Dec 20 20:35:02 EndeavourOS kernel: Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
Dec 20 20:35:02 EndeavourOS kernel: Last level dTLB entries: 4KB 64, 2MB 32, 4MB 32, 1GB 4
Dec 20 20:35:02 EndeavourOS kernel: process: using mwait in idle threads
Dec 20 20:35:02 EndeavourOS kernel: mitigations: Enabled attack vectors: user_kernel, user_user, guest_host, >
Dec 20 20:35:02 EndeavourOS kernel: Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled v>
Dec 20 20:35:02 EndeavourOS kernel: SRBDS: Mitigation: Microcode
Dec 20 20:35:02 EndeavourOS kernel: Spectre V2 : Mitigation: IBRS
Dec 20 20:35:02 EndeavourOS kernel: RETBleed: Mitigation: IBRS
Dec 20 20:35:02 EndeavourOS kernel: Spectre V2 : User space: Mitigation: STIBP via prctl
Dec 20 20:35:02 EndeavourOS kernel: MDS: Mitigation: Clear CPU buffers
Dec 20 20:35:02 EndeavourOS kernel: MMIO Stale Data: Mitigation: Clear CPU buffers
Dec 20 20:35:02 EndeavourOS kernel: VMSCAPE: Mitigation: IBPB before exit to userspace
Dec 20 20:35:02 EndeavourOS kernel: Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sani>
Dec 20 20:35:02 EndeavourOS kernel: Spectre V2 : Spectre v2 / SpectreRSB: Filling RSB on context switch and V>
Dec 20 20:35:02 EndeavourOS kernel: Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction >
Dec 20 20:35:02 EndeavourOS kernel: GDS: Vulnerable: No microcode
Dec 20 20:35:02 EndeavourOS kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
Dec 20 20:35:02 EndeavourOS kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
Dec 20 20:35:02 EndeavourOS kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
Dec 20 20:35:02 EndeavourOS kernel: x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
Dec 20 20:35:02 EndeavourOS kernel: x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
Dec 20 20:35:02 EndeavourOS kernel: x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
Dec 20 20:35:02 EndeavourOS kernel: x86/fpu: xstate_offset[3]: 832, xstate_sizes[3]: 64
Dec 20 20:35:02 EndeavourOS kernel: x86/fpu: xstate_offset[4]: 896, xstate_sizes[4]: 64
Dec 20 20:35:02 EndeavourOS kernel: x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using '>
Dec 20 20:35:02 EndeavourOS kernel: Freeing SMP alternatives memory: 56K
Dec 20 20:35:02 EndeavourOS kernel: pid_max: default: 32768 minimum: 301
Dec 20 20:35:02 EndeavourOS kernel: LSM: initializing lsm=capability,landlock,lockdown,yama,bpf
Dec 20 20:35:02 EndeavourOS kernel: landlock: Up and running.
Dec 20 20:35:02 EndeavourOS kernel: Yama: becoming mindful.
Dec 20 20:35:02 EndeavourOS kernel: LSM support for eBPF active
Dec 20 20:35:02 EndeavourOS kernel: Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
Dec 20 20:35:02 EndeavourOS kernel: Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linea>
Dec 20 20:35:02 EndeavourOS kernel: smpboot: CPU0: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz (family: 0x6, mod>
Dec 20 20:35:02 EndeavourOS kernel: Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width c>
Dec 20 20:35:02 EndeavourOS kernel: ... version: 4
Dec 20 20:35:02 EndeavourOS kernel: ... bit width: 48
Dec 20 20:35:02 EndeavourOS kernel: ... generic registers: 4
Dec 20 20:35:02 EndeavourOS kernel: ... value mask: 0000ffffffffffff
Dec 20 20:35:02 EndeavourOS kernel: ... max period: 00007fffffffffff
Dec 20 20:35:02 EndeavourOS kernel: ... fixed-purpose events: 3
Dec 20 20:35:02 EndeavourOS kernel: ... event mask: 000000070000000f
Dec 20 20:35:02 EndeavourOS kernel: signal: max sigframe size: 2032
Dec 20 20:35:02 EndeavourOS kernel: Estimated ratio of average max frequency by base frequency (times 1024): >
Dec 20 20:35:02 EndeavourOS kernel: rcu: Hierarchical SRCU implementation.
Dec 20 20:35:02 EndeavourOS kernel: rcu: Max phase no-delay instances is 400.
Dec 20 20:35:02 EndeavourOS kernel: Timer migration: 2 hierarchy levels; 8 children per group; 2 crossnode le>
Dec 20 20:35:02 EndeavourOS kernel: NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
Dec 20 20:35:02 EndeavourOS kernel: smp: Bringing up secondary CPUs ...
Dec 20 20:35:02 EndeavourOS kernel: smpboot: x86: Booting SMP configuration:
Dec 20 20:35:02 EndeavourOS kernel: .... node #0, CPUs: #1 #2 #3 #4 #5 #6 #7 #8 #9 #10 #11
Dec 20 20:35:02 EndeavourOS kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kerne>
Dec 20 20:35:02 EndeavourOS kernel: MMIO Stale Data CPU bug present and SMT on, data leak possible. See https>
Dec 20 20:35:02 EndeavourOS kernel: VMSCAPE: SMT on, STIBP is required for full protection. See https://www.k>
Dec 20 20:35:02 EndeavourOS kernel: smp: Brought up 1 node, 12 CPUs
Dec 20 20:35:02 EndeavourOS kernel: smpboot: Total of 12 processors activated (88796.40 BogoMIPS)
Dec 20 20:35:02 EndeavourOS kernel: Memory: 32542456K/33494136K available (20065K kernel code, 2946K rwdata, >
Dec 20 20:35:02 EndeavourOS kernel: devtmpfs: initialized
Dec 20 20:35:02 EndeavourOS kernel: x86/mm: Memory block size: 128MB
Dec 20 20:35:02 EndeavourOS kernel: ACPI: PM: Registering ACPI NVS region [mem 0x7a6ac000-0x7a6acfff] (4096 b>
Dec 20 20:35:02 EndeavourOS kernel: ACPI: PM: Registering ACPI NVS region [mem 0x8dec9000-0x8e32dfff] (460800>
Dec 20 20:35:02 EndeavourOS kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_n>
Dec 20 20:35:02 EndeavourOS kernel: posixtimers hash table entries: 8192 (order: 5, 131072 bytes, linear)
Dec 20 20:35:02 EndeavourOS kernel: futex hash table entries: 4096 (262144 bytes on 1 NUMA nodes, total 256 K>
Dec 20 20:35:02 EndeavourOS kernel: pinctrl core: initialized pinctrl subsystem
Dec 20 20:35:02 EndeavourOS kernel: PM: RTC time: 01:34:55, date: 2025-12-21
Dec 20 20:35:02 EndeavourOS kernel: NET: Registered PF_NETLINK/PF_ROUTE protocol family
Dec 20 20:35:02 EndeavourOS kernel: DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
Dec 20 20:35:02 EndeavourOS kernel: DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
Dec 20 20:35:02 EndeavourOS kernel: DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocatio>
Dec 20 20:35:02 EndeavourOS kernel: audit: initializing netlink subsys (disabled)
Dec 20 20:35:02 EndeavourOS kernel: audit: type=2000 audit(1766280895.052:1): state=initialized audit_enabled>
Dec 20 20:35:02 EndeavourOS kernel: thermal_sys: Registered thermal governor 'fair_share'
Dec 20 20:35:02 EndeavourOS kernel: thermal_sys: Registered thermal governor 'bang_bang'
Dec 20 20:35:02 EndeavourOS kernel: thermal_sys: Registered thermal governor 'step_wise'
Dec 20 20:35:02 EndeavourOS kernel: thermal_sys: Registered thermal governor 'user_space'
Dec 20 20:35:02 EndeavourOS kernel: thermal_sys: Registered thermal governor 'power_allocator'
Dec 20 20:35:02 EndeavourOS kernel: cpuidle: using governor ladder
Dec 20 20:35:02 EndeavourOS kernel: cpuidle: using governor menu
Dec 20 20:35:02 EndeavourOS kernel: ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
Dec 20 20:35:02 EndeavourOS kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
Dec 20 20:35:02 EndeavourOS kernel: PCI: ECAM [mem 0xe0000000-0xefffffff] (base 0xe0000000) for domain 0000 [>
Dec 20 20:35:02 EndeavourOS kernel: PCI: Using configuration type 1 for base access
Dec 20 20:35:02 EndeavourOS kernel: kprobes: kprobe jump-optimization is enabled. All kprobes are optimized i>
Dec 20 20:35:02 EndeavourOS kernel: HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
Dec 20 20:35:02 EndeavourOS kernel: HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
Dec 20 20:35:02 EndeavourOS kernel: HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
Dec 20 20:35:02 EndeavourOS kernel: HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
Dec 20 20:35:02 EndeavourOS kernel: raid6: skipped pq benchmark and selected avx2x4
Dec 20 20:35:02 EndeavourOS kernel: raid6: using avx2x2 recovery algorithm
Dec 20 20:35:02 EndeavourOS kernel: fbcon: Taking over console
Dec 20 20:35:02 EndeavourOS kernel: ACPI: Added _OSI(Module Device)
Dec 20 20:35:02 EndeavourOS kernel: ACPI: Added _OSI(Processor Device)
Dec 20 20:35:02 EndeavourOS kernel: ACPI: Added _OSI(Processor Aggregator Device)
Dec 20 20:35:02 EndeavourOS kernel: ACPI: 12 ACPI AML tables successfully acquired and loaded
Dec 20 20:35:02 EndeavourOS kernel: ACPI: Dynamic OEM Table Load:
Dec 20 20:35:02 EndeavourOS kernel: ACPI: SSDT 0xFFFF8C3D40E81800 0003FF (v02 PmRef Cpu0Cst 00003001 INTL 2>
Dec 20 20:35:02 EndeavourOS kernel: ACPI: SSDT 0xFFFF8C3D40E79800 00077A (v02 PmRef Cpu0Ist 00003000 INTL 2>
Dec 20 20:35:02 EndeavourOS kernel: ACPI: SSDT 0xFFFF8C3D40E8F000 000D14 (v02 PmRef ApIst 00003000 INTL 2>
Dec 20 20:35:02 EndeavourOS kernel: ACPI: SSDT 0xFFFF8C3D40E81400 000317 (v02 PmRef ApHwp 00003000 INTL 2>
Dec 20 20:35:02 EndeavourOS kernel: ACPI: SSDT 0xFFFF8C3D40E83800 00030A (v02 PmRef ApCst 00003000 INTL 2>
Dec 20 20:35:02 EndeavourOS kernel: ACPI: Interpreter enabled
Dec 20 20:35:02 EndeavourOS kernel: ACPI: PM: (supports S0 S3 S4 S5)
Dec 20 20:35:02 EndeavourOS kernel: ACPI: Using IOAPIC for interrupt routing
Dec 20 20:35:02 EndeavourOS kernel: PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" a>
Dec 20 20:35:02 EndeavourOS kernel: PCI: Ignoring E820 reservations for host bridge windows
Dec 20 20:35:02 EndeavourOS kernel: ACPI: Enabled 8 GPEs in block 00 to 7F
Dec 20 20:35:02 EndeavourOS kernel: ACPI: \_SB_.PCI0.PEG0.PG00: New power resource
Dec 20 20:35:02 EndeavourOS kernel: ACPI: \_SB_.PCI0.PEG1.PG01: New power resource
Dec 20 20:35:02 EndeavourOS kernel: ACPI: \_SB_.PCI0.PEG2.PG02: New power resource
Dec 20 20:35:02 EndeavourOS kernel: ACPI: \_TZ_.FN00: New power resource
Dec 20 20:35:02 EndeavourOS kernel: ACPI: \_TZ_.FN01: New power resource
Dec 20 20:35:02 EndeavourOS kernel: ACPI: \_TZ_.FN02: New power resource
Dec 20 20:35:02 EndeavourOS kernel: ACPI: \_TZ_.FN03: New power resource
Dec 20 20:35:02 EndeavourOS kernel: ACPI: \_TZ_.FN04: New power resource
Dec 20 20:35:02 EndeavourOS kernel: ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
Dec 20 20:35:02 EndeavourOS kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments >
Dec 20 20:35:02 EndeavourOS kernel: acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug SHPCHotplug>
Dec 20 20:35:02 EndeavourOS kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeCapability LTR DPC]
Dec 20 20:35:02 EndeavourOS kernel: acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configura>
Dec 20 20:35:02 EndeavourOS kernel: PCI host bridge to bus 0000:00
Dec 20 20:35:02 EndeavourOS kernel: pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
Dec 20 20:35:02 EndeavourOS kernel: pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
Dec 20 20:35:02 EndeavourOS kernel: pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000fffff window]
Dec 20 20:35:02 EndeavourOS kernel: pci_bus 0000:00: root bus resource [mem 0x90000000-0xdfffffff window]
Dec 20 20:35:02 EndeavourOS kernel: pci_bus 0000:00: root bus resource [mem 0xfd000000-0xfe7fffff window]
Dec 20 20:35:02 EndeavourOS kernel: pci_bus 0000:00: root bus resource [bus 00-fe]
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:00:00.0: [8086:3ec2] type 00 class 0x060000 conventional PCI end>
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:00:01.0: [8086:1901] type 01 class 0x060400 PCIe Root Port
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:00:01.0: PCI bridge to [bus 01]
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:00:01.0: bridge window [io 0xe000-0xefff]
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:00:01.0: bridge window [mem 0xde000000-0xdf0fffff]
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:00:01.0: bridge window [mem 0xc0000000-0xd1ffffff 64bit pref]
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:00:08.0: [8086:1911] type 00 class 0x088000 conventional PCI end>
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:00:08.0: BAR 0 [mem 0xdf32f000-0xdf32ffff 64bit]
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:00:14.0: [8086:a2af] type 00 class 0x0c0330 conventional PCI end>
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:00:14.0: BAR 0 [mem 0xdf310000-0xdf31ffff 64bit]
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:00:14.0: PME# supported from D3hot D3cold
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:00:14.2: [8086:a2b1] type 00 class 0x118000 conventional PCI end>
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:00:14.2: BAR 0 [mem 0xdf32e000-0xdf32efff 64bit]
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:00:16.0: [8086:a2ba] type 00 class 0x078000 conventional PCI end>
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:00:16.0: BAR 0 [mem 0xdf32d000-0xdf32dfff 64bit]
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:00:16.0: PME# supported from D3hot
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:00:17.0: [8086:a282] type 00 class 0x010601 conventional PCI end>
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:00:17.0: BAR 0 [mem 0xdf328000-0xdf329fff]
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:00:17.0: BAR 1 [mem 0xdf32c000-0xdf32c0ff]
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:00:17.0: BAR 2 [io 0xf050-0xf057]
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:00:17.0: BAR 3 [io 0xf040-0xf043]
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:00:17.0: BAR 4 [io 0xf020-0xf03f]
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:00:17.0: BAR 5 [mem 0xdf32b000-0xdf32b7ff]
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:00:17.0: PME# supported from D3hot
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:00:1c.0: [8086:a290] type 01 class 0x060400 PCIe Root Port
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:00:1c.0: PCI bridge to [bus 02]
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:00:1c.3: [8086:a293] type 01 class 0x060400 PCIe Root Port
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:00:1c.3: PCI bridge to [bus 03]
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:00:1c.3: bridge window [io 0xd000-0xdfff]
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:00:1c.3: bridge window [mem 0xdf200000-0xdf2fffff]
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:00:1d.0: [8086:a298] type 01 class 0x060400 PCIe Root Port
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:00:1d.0: PCI bridge to [bus 04]
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:00:1d.0: bridge window [mem 0xdf100000-0xdf1fffff]
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:00:1f.0: [8086:a2c9] type 00 class 0x060100 conventional PCI end>
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:00:1f.2: [8086:a2a1] type 00 class 0x058000 conventional PCI end>
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:00:1f.2: BAR 0 [mem 0xdf324000-0xdf327fff]
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:00:1f.3: [8086:a2f0] type 00 class 0x040300 conventional PCI end>
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:00:1f.3: BAR 0 [mem 0xdf320000-0xdf323fff 64bit]
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:00:1f.3: BAR 4 [mem 0xdf300000-0xdf30ffff 64bit]
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:00:1f.3: PME# supported from D3hot D3cold
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:00:1f.4: [8086:a2a3] type 00 class 0x0c0500 conventional PCI end>
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:00:1f.4: BAR 0 [mem 0xdf32a000-0xdf32a0ff 64bit]
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:00:1f.4: BAR 4 [io 0xf000-0xf01f]
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:01:00.0: [10de:1b80] type 00 class 0x030000 PCIe Legacy Endpoint
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:01:00.0: BAR 0 [mem 0xde000000-0xdeffffff]
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:01:00.0: BAR 1 [mem 0xc0000000-0xcfffffff 64bit pref]
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:01:00.0: BAR 3 [mem 0xd0000000-0xd1ffffff 64bit pref]
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:01:00.0: BAR 5 [io 0xe000-0xe07f]
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:01:00.0: ROM [mem 0xdf000000-0xdf07ffff pref]
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:01:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000>
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:01:00.0: 32.000 Gb/s available PCIe bandwidth, limited by 2.5 GT>
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:01:00.1: [10de:10f0] type 00 class 0x040300 PCIe Endpoint
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:01:00.1: BAR 0 [mem 0xdf080000-0xdf083fff]
Dec 20 20:35:02 EndeavourOS kernel: acpiphp: Slot [1] registered
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:03:00.0: [10ec:8168] type 00 class 0x020000 PCIe Endpoint
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:03:00.0: BAR 0 [io 0xd000-0xd0ff]
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:03:00.0: BAR 2 [mem 0xdf204000-0xdf204fff 64bit]
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:03:00.0: BAR 4 [mem 0xdf200000-0xdf203fff 64bit]
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:03:00.0: supports D1 D2
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:04:00.0: [15b7:5030] type 00 class 0x010802 PCIe Endpoint
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:04:00.0: BAR 0 [mem 0xdf100000-0xdf103fff 64bit]
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:04:00.0: 31.504 Gb/s available PCIe bandwidth, limited by 8.0 GT>
Dec 20 20:35:02 EndeavourOS kernel: ACPI: PCI: Interrupt link LNKA configured for IRQ 11
Dec 20 20:35:02 EndeavourOS kernel: ACPI: PCI: Interrupt link LNKB configured for IRQ 10
Dec 20 20:35:02 EndeavourOS kernel: ACPI: PCI: Interrupt link LNKC configured for IRQ 11
Dec 20 20:35:02 EndeavourOS kernel: ACPI: PCI: Interrupt link LNKD configured for IRQ 11
Dec 20 20:35:02 EndeavourOS kernel: ACPI: PCI: Interrupt link LNKE configured for IRQ 11
Dec 20 20:35:02 EndeavourOS kernel: ACPI: PCI: Interrupt link LNKF configured for IRQ 11
Dec 20 20:35:02 EndeavourOS kernel: ACPI: PCI: Interrupt link LNKG configured for IRQ 11
Dec 20 20:35:02 EndeavourOS kernel: ACPI: PCI: Interrupt link LNKH configured for IRQ 11
Dec 20 20:35:02 EndeavourOS kernel: iommu: Default domain type: Translated
Dec 20 20:35:02 EndeavourOS kernel: iommu: DMA domain TLB invalidation policy: lazy mode
Dec 20 20:35:02 EndeavourOS kernel: SCSI subsystem initialized
Dec 20 20:35:02 EndeavourOS kernel: libata version 3.00 loaded.
Dec 20 20:35:02 EndeavourOS kernel: ACPI: bus type USB registered
Dec 20 20:35:02 EndeavourOS kernel: usbcore: registered new interface driver usbfs
Dec 20 20:35:02 EndeavourOS kernel: usbcore: registered new interface driver hub
Dec 20 20:35:02 EndeavourOS kernel: usbcore: registered new device driver usb
Dec 20 20:35:02 EndeavourOS kernel: EDAC MC: Ver: 3.0.0
Dec 20 20:35:02 EndeavourOS kernel: efivars: Registered efivars operations
Dec 20 20:35:02 EndeavourOS kernel: NetLabel: Initializing
Dec 20 20:35:02 EndeavourOS kernel: NetLabel: domain hash size = 128
Dec 20 20:35:02 EndeavourOS kernel: NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
Dec 20 20:35:02 EndeavourOS kernel: NetLabel: unlabeled traffic allowed by default
Dec 20 20:35:02 EndeavourOS kernel: mctp: management component transport protocol core
Dec 20 20:35:02 EndeavourOS kernel: NET: Registered PF_MCTP protocol family
Dec 20 20:35:02 EndeavourOS kernel: PCI: Using ACPI for IRQ routing
Dec 20 20:35:02 EndeavourOS kernel: PCI: pci_cache_line_size set to 64 bytes
Dec 20 20:35:02 EndeavourOS kernel: e820: reserve RAM buffer [mem 0x00058000-0x0005ffff]
Dec 20 20:35:02 EndeavourOS kernel: e820: reserve RAM buffer [mem 0x0009e000-0x0009ffff]
Dec 20 20:35:02 EndeavourOS kernel: e820: reserve RAM buffer [mem 0x7a6ac000-0x7bffffff]
Dec 20 20:35:02 EndeavourOS kernel: e820: reserve RAM buffer [mem 0x89ca6000-0x8bffffff]
Dec 20 20:35:02 EndeavourOS kernel: e820: reserve RAM buffer [mem 0x8a973000-0x8bffffff]
Dec 20 20:35:02 EndeavourOS kernel: e820: reserve RAM buffer [mem 0x8d983000-0x8fffffff]
Dec 20 20:35:02 EndeavourOS kernel: e820: reserve RAM buffer [mem 0x8f7ff000-0x8fffffff]
Dec 20 20:35:02 EndeavourOS kernel: e820: reserve RAM buffer [mem 0x86f000000-0x86fffffff]
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:01:00.0: vgaarb: setting as boot VGA device
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:01:00.0: vgaarb: bridge control possible
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,lo>
Dec 20 20:35:02 EndeavourOS kernel: vgaarb: loaded
Dec 20 20:35:02 EndeavourOS kernel: hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
Dec 20 20:35:02 EndeavourOS kernel: hpet0: 8 comparators, 64-bit 24.000000 MHz counter
Dec 20 20:35:02 EndeavourOS kernel: clocksource: Switched to clocksource tsc-early
Dec 20 20:35:02 EndeavourOS kernel: VFS: Disk quotas dquot_6.6.0
Dec 20 20:35:02 EndeavourOS kernel: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Dec 20 20:35:02 EndeavourOS kernel: pnp: PnP ACPI init
Dec 20 20:35:02 EndeavourOS kernel: system 00:00: [mem 0x40000000-0x403fffff] has been reserved
Dec 20 20:35:02 EndeavourOS kernel: system 00:01: [io 0x0a00-0x0a0f] has been reserved
Dec 20 20:35:02 EndeavourOS kernel: system 00:01: [io 0x0a10-0x0a1f] has been reserved
Dec 20 20:35:02 EndeavourOS kernel: system 00:01: [io 0x0a20-0x0a2f] has been reserved
Dec 20 20:35:02 EndeavourOS kernel: system 00:01: [io 0x0a30-0x0a3f] has been reserved
Dec 20 20:35:02 EndeavourOS kernel: pnp 00:02: [dma 0 disabled]
Dec 20 20:35:02 EndeavourOS kernel: pnp 00:04: [dma 0 disabled]
Dec 20 20:35:02 EndeavourOS kernel: system 00:05: [io 0x0680-0x069f] has been reserved
Dec 20 20:35:02 EndeavourOS kernel: system 00:05: [io 0xffff] has been reserved
Dec 20 20:35:02 EndeavourOS kernel: system 00:05: [io 0x1800-0x18fe] could not be reserved
Dec 20 20:35:02 EndeavourOS kernel: system 00:05: [io 0x164e-0x164f] has been reserved
Dec 20 20:35:02 EndeavourOS kernel: system 00:06: [io 0x0800-0x087f] has been reserved
Dec 20 20:35:02 EndeavourOS kernel: system 00:07: [mem 0xfed10000-0xfed17fff] has been reserved
Dec 20 20:35:02 EndeavourOS kernel: system 00:07: [mem 0xfed18000-0xfed18fff] has been reserved
Dec 20 20:35:02 EndeavourOS kernel: system 00:07: [mem 0xfed19000-0xfed19fff] has been reserved
Dec 20 20:35:02 EndeavourOS kernel: system 00:07: [mem 0xe0000000-0xefffffff] has been reserved
Dec 20 20:35:02 EndeavourOS kernel: system 00:07: [mem 0xfed20000-0xfed3ffff] has been reserved
Dec 20 20:35:02 EndeavourOS kernel: system 00:07: [mem 0xfed90000-0xfed93fff] has been reserved
Dec 20 20:35:02 EndeavourOS kernel: system 00:07: [mem 0xfed45000-0xfed8ffff] has been reserved
Dec 20 20:35:02 EndeavourOS kernel: system 00:07: [mem 0xff000000-0xffffffff] has been reserved
Dec 20 20:35:02 EndeavourOS kernel: system 00:07: [mem 0xfee00000-0xfeefffff] could not be reserved
Dec 20 20:35:02 EndeavourOS kernel: system 00:07: [mem 0xdffc0000-0xdffdffff] has been reserved
Dec 20 20:35:02 EndeavourOS kernel: system 00:08: [mem 0xfd000000-0xfdabffff] has been reserved
Dec 20 20:35:02 EndeavourOS kernel: system 00:08: [mem 0xfdad0000-0xfdadffff] has been reserved
Dec 20 20:35:02 EndeavourOS kernel: system 00:08: [mem 0xfdb00000-0xfdffffff] has been reserved
Dec 20 20:35:02 EndeavourOS kernel: system 00:08: [mem 0xfe000000-0xfe01ffff] could not be reserved
Dec 20 20:35:02 EndeavourOS kernel: system 00:08: [mem 0xfe036000-0xfe03bfff] has been reserved
Dec 20 20:35:02 EndeavourOS kernel: system 00:08: [mem 0xfe03d000-0xfe3fffff] has been reserved
Dec 20 20:35:02 EndeavourOS kernel: system 00:09: [io 0xff00-0xfffe] has been reserved
Dec 20 20:35:02 EndeavourOS kernel: system 00:0a: [mem 0xfdaf0000-0xfdafffff] has been reserved
Dec 20 20:35:02 EndeavourOS kernel: system 00:0a: [mem 0xfdae0000-0xfdaeffff] has been reserved
Dec 20 20:35:02 EndeavourOS kernel: system 00:0a: [mem 0xfdac0000-0xfdacffff] has been reserved
Dec 20 20:35:02 EndeavourOS kernel: pnp: PnP ACPI: found 11 devices
Dec 20 20:35:02 EndeavourOS kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2>
Dec 20 20:35:02 EndeavourOS kernel: NET: Registered PF_INET protocol family
Dec 20 20:35:02 EndeavourOS kernel: IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
Dec 20 20:35:02 EndeavourOS kernel: tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 byte>
Dec 20 20:35:02 EndeavourOS kernel: Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
Dec 20 20:35:02 EndeavourOS kernel: TCP established hash table entries: 262144 (order: 9, 2097152 bytes, line>
Dec 20 20:35:02 EndeavourOS kernel: TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
Dec 20 20:35:02 EndeavourOS kernel: TCP: Hash tables configured (established 262144 bind 65536)
Dec 20 20:35:02 EndeavourOS kernel: MPTCP token hash table entries: 32768 (order: 7, 786432 bytes, linear)
Dec 20 20:35:02 EndeavourOS kernel: UDP hash table entries: 16384 (order: 8, 1048576 bytes, linear)
Dec 20 20:35:02 EndeavourOS kernel: UDP-Lite hash table entries: 16384 (order: 8, 1048576 bytes, linear)
Dec 20 20:35:02 EndeavourOS kernel: NET: Registered PF_UNIX/PF_LOCAL protocol family
Dec 20 20:35:02 EndeavourOS kernel: NET: Registered PF_XDP protocol family
Dec 20 20:35:02 EndeavourOS kernel: pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
Dec 20 20:35:02 EndeavourOS kernel: pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
Dec 20 20:35:02 EndeavourOS kernel: pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000fffff window]
Dec 20 20:35:02 EndeavourOS kernel: pci_bus 0000:00: resource 7 [mem 0x90000000-0xdfffffff window]
Dec 20 20:35:02 EndeavourOS kernel: pci_bus 0000:00: resource 8 [mem 0xfd000000-0xfe7fffff window]
Dec 20 20:35:02 EndeavourOS kernel: pci_bus 0000:01: resource 0 [io 0xe000-0xefff]
Dec 20 20:35:02 EndeavourOS kernel: pci_bus 0000:01: resource 1 [mem 0xde000000-0xdf0fffff]
Dec 20 20:35:02 EndeavourOS kernel: pci_bus 0000:01: resource 2 [mem 0xc0000000-0xd1ffffff 64bit pref]
Dec 20 20:35:02 EndeavourOS kernel: pci_bus 0000:03: resource 0 [io 0xd000-0xdfff]
Dec 20 20:35:02 EndeavourOS kernel: pci_bus 0000:03: resource 1 [mem 0xdf200000-0xdf2fffff]
Dec 20 20:35:02 EndeavourOS kernel: pci_bus 0000:04: resource 1 [mem 0xdf100000-0xdf1fffff]
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:01:00.1: extending delay after power-on from D3hot to 20 msec
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
Dec 20 20:35:02 EndeavourOS kernel: PCI: CLS 64 bytes, default 64
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:00:1f.1: [8086:a2a0] type 00 class 0x058000 conventional PCI end>
Dec 20 20:35:02 EndeavourOS kernel: pci 0000:00:1f.1: BAR 0 [mem 0xfd000000-0xfdffffff 64bit]
Dec 20 20:35:02 EndeavourOS kernel: PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
Dec 20 20:35:02 EndeavourOS kernel: software IO TLB: mapped [mem 0x0000000085ca6000-0x0000000089ca6000] (64MB)
Dec 20 20:35:02 EndeavourOS kernel: Trying to unpack rootfs image as initramfs...
Dec 20 20:35:02 EndeavourOS kernel: platform rtc_cmos: registered platform RTC device (no PNP device found)
Dec 20 20:35:02 EndeavourOS kernel: Initialise system trusted keyrings
Dec 20 20:35:02 EndeavourOS kernel: Key type blacklist registered
Dec 20 20:35:02 EndeavourOS kernel: workingset: timestamp_bits=36 max_order=23 bucket_order=0
Dec 20 20:35:02 EndeavourOS kernel: fuse: init (API version 7.44)
Dec 20 20:35:02 EndeavourOS kernel: integrity: Platform Keyring initialized
Dec 20 20:35:02 EndeavourOS kernel: integrity: Machine keyring initialized
Dec 20 20:35:02 EndeavourOS kernel: xor: automatically using best checksumming function avx
Dec 20 20:35:02 EndeavourOS kernel: Key type asymmetric registered
Dec 20 20:35:02 EndeavourOS kernel: Asymmetric key parser 'x509' registered
Dec 20 20:35:02 EndeavourOS kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
Dec 20 20:35:02 EndeavourOS kernel: io scheduler mq-deadline registered
Dec 20 20:35:02 EndeavourOS kernel: io scheduler kyber registered
Dec 20 20:35:02 EndeavourOS kernel: io scheduler bfq registered
Dec 20 20:35:02 EndeavourOS kernel: ledtrig-cpu: registered to indicate activity on CPUs
Dec 20 20:35:02 EndeavourOS kernel: input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/>
Dec 20 20:35:02 EndeavourOS kernel: ACPI: button: Sleep Button [SLPB]
Dec 20 20:35:02 EndeavourOS kernel: input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/>
Dec 20 20:35:02 EndeavourOS kernel: ACPI: button: Power Button [PWRB]
Dec 20 20:35:02 EndeavourOS kernel: input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
Dec 20 20:35:02 EndeavourOS kernel: ACPI: button: Power Button [PWRF]
Dec 20 20:35:02 EndeavourOS kernel: thermal LNXTHERM:00: registered as thermal_zone0
Dec 20 20:35:02 EndeavourOS kernel: ACPI: thermal: Thermal Zone [TZ00] (28 C)
Dec 20 20:35:02 EndeavourOS kernel: thermal LNXTHERM:01: registered as thermal_zone1
Dec 20 20:35:02 EndeavourOS kernel: ACPI: thermal: Thermal Zone [TZ01] (30 C)
Dec 20 20:35:02 EndeavourOS kernel: Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
Dec 20 20:35:02 EndeavourOS kernel: 00:04: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
Dec 20 20:35:02 EndeavourOS kernel: serial8250: ttyS1 at I/O 0x2f8 (irq = 3, base_baud = 115200) is a 16550A
Dec 20 20:35:02 EndeavourOS kernel: Non-volatile memory driver v1.3
Dec 20 20:35:02 EndeavourOS kernel: Linux agpgart interface v0.103
Dec 20 20:35:02 EndeavourOS kernel: ACPI: bus type drm_connector registered
Dec 20 20:35:02 EndeavourOS kernel: ahci 0000:00:17.0: AHCI vers 0001.0301, 32 command slots, 6 Gbps, SATA mo>
Dec 20 20:35:02 EndeavourOS kernel: ahci 0000:00:17.0: 6/6 ports implemented (port mask 0x3f)
Dec 20 20:35:02 EndeavourOS kernel: ahci 0000:00:17.0: flags: 64bit ncq sntf led clo only pio slum part ems d>
Dec 20 20:35:02 EndeavourOS kernel: scsi host0: ahci
Dec 20 20:35:02 EndeavourOS kernel: scsi host1: ahci
Dec 20 20:35:02 EndeavourOS kernel: scsi host2: ahci
Dec 20 20:35:02 EndeavourOS kernel: scsi host3: ahci
Dec 20 20:35:02 EndeavourOS kernel: scsi host4: ahci
Dec 20 20:35:02 EndeavourOS kernel: scsi host5: ahci
Dec 20 20:35:02 EndeavourOS kernel: ata1: SATA max UDMA/133 abar m2048@0xdf32b000 port 0xdf32b100 irq 124 lpm>
Dec 20 20:35:02 EndeavourOS kernel: ata2: SATA max UDMA/133 abar m2048@0xdf32b000 port 0xdf32b180 irq 124 lpm>
Dec 20 20:35:02 EndeavourOS kernel: ata3: SATA max UDMA/133 abar m2048@0xdf32b000 port 0xdf32b200 irq 124 lpm>
Dec 20 20:35:02 EndeavourOS kernel: ata4: SATA max UDMA/133 abar m2048@0xdf32b000 port 0xdf32b280 irq 124 lpm>
Dec 20 20:35:02 EndeavourOS kernel: ata5: SATA max UDMA/133 abar m2048@0xdf32b000 port 0xdf32b300 irq 124 lpm>
Dec 20 20:35:02 EndeavourOS kernel: ata6: SATA max UDMA/133 abar m2048@0xdf32b000 port 0xdf32b380 irq 124 lpm>
Dec 20 20:35:02 EndeavourOS kernel: xhci_hcd 0000:00:14.0: xHCI Host Controller
Dec 20 20:35:02 EndeavourOS kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
Dec 20 20:35:02 EndeavourOS kernel: xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x0>
Dec 20 20:35:02 EndeavourOS kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
Dec 20 20:35:02 EndeavourOS kernel: xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
Dec 20 20:35:02 EndeavourOS kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice=>
Dec 20 20:35:02 EndeavourOS kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec 20 20:35:02 EndeavourOS kernel: usb usb1: Product: xHCI Host Controller
Dec 20 20:35:02 EndeavourOS kernel: usb usb1: Manufacturer: Linux 6.17.8-arch1-1 xhci-hcd
Dec 20 20:35:02 EndeavourOS kernel: usb usb1: SerialNumber: 0000:00:14.0
Dec 20 20:35:02 EndeavourOS kernel: hub 1-0:1.0: USB hub found
Dec 20 20:35:02 EndeavourOS kernel: hub 1-0:1.0: 16 ports detected
Dec 20 20:35:02 EndeavourOS kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice=>
Dec 20 20:35:02 EndeavourOS kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec 20 20:35:02 EndeavourOS kernel: usb usb2: Product: xHCI Host Controller
Dec 20 20:35:02 EndeavourOS kernel: usb usb2: Manufacturer: Linux 6.17.8-arch1-1 xhci-hcd
Dec 20 20:35:02 EndeavourOS kernel: usb usb2: SerialNumber: 0000:00:14.0
Dec 20 20:35:02 EndeavourOS kernel: hub 2-0:1.0: USB hub found
Dec 20 20:35:02 EndeavourOS kernel: hub 2-0:1.0: 10 ports detected
Dec 20 20:35:02 EndeavourOS kernel: usbcore: registered new interface driver usbserial_generic
Dec 20 20:35:02 EndeavourOS kernel: usbserial: USB Serial support registered for generic
Dec 20 20:35:02 EndeavourOS kernel: i8042: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
Dec 20 20:35:02 EndeavourOS kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect >
Dec 20 20:35:02 EndeavourOS kernel: serio: i8042 KBD port at 0x60,0x64 irq 1
Dec 20 20:35:02 EndeavourOS kernel: rtc_cmos rtc_cmos: RTC can wake from S4
Dec 20 20:35:02 EndeavourOS kernel: rtc_cmos rtc_cmos: registered as rtc0
Dec 20 20:35:02 EndeavourOS kernel: rtc_cmos rtc_cmos: setting system clock to 2025-12-21T01:34:55 UTC (17662>
Dec 20 20:35:02 EndeavourOS kernel: rtc_cmos rtc_cmos: alarms up to one month, y3k, 114 bytes nvram
Dec 20 20:35:02 EndeavourOS kernel: intel_pstate: Intel P-state driver initializing
Dec 20 20:35:02 EndeavourOS kernel: intel_pstate: Disabling energy efficiency optimization
Dec 20 20:35:02 EndeavourOS kernel: intel_pstate: HWP enabled
Dec 20 20:35:02 EndeavourOS kernel: simple-framebuffer simple-framebuffer.0: [drm] Registered 1 planes with d>
Dec 20 20:35:02 EndeavourOS kernel: [drm] Initialized simpledrm 1.0.0 for simple-framebuffer.0 on minor 0
Dec 20 20:35:02 EndeavourOS kernel: Console: switching to colour frame buffer device 128x48
Dec 20 20:35:02 EndeavourOS kernel: simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame >
Dec 20 20:35:02 EndeavourOS kernel: hid: raw HID events driver (C) Jiri Kosina
Dec 20 20:35:02 EndeavourOS kernel: usbcore: registered new interface driver usbhid
Dec 20 20:35:02 EndeavourOS kernel: usbhid: USB HID core driver
Dec 20 20:35:02 EndeavourOS kernel: drop_monitor: Initializing network drop monitor service
Dec 20 20:35:02 EndeavourOS kernel: NET: Registered PF_INET6 protocol family
Dec 20 20:35:02 EndeavourOS kernel: Segment Routing with IPv6
Dec 20 20:35:02 EndeavourOS kernel: RPL Segment Routing with IPv6
Dec 20 20:35:02 EndeavourOS kernel: In-situ OAM (IOAM) with IPv6
Dec 20 20:35:02 EndeavourOS kernel: NET: Registered PF_PACKET protocol family
Dec 20 20:35:02 EndeavourOS kernel: microcode: Current revision: 0x000000ea
Dec 20 20:35:02 EndeavourOS kernel: IPI shorthand broadcast: enabled
Dec 20 20:35:02 EndeavourOS kernel: sched_clock: Marking stable (518002093, 3418664)->(526141494, -4720737)
Dec 20 20:35:02 EndeavourOS kernel: registered taskstats version 1
Dec 20 20:35:02 EndeavourOS kernel: Loading compiled-in X.509 certificates
Dec 20 20:35:02 EndeavourOS kernel: Freeing initrd memory: 230208K
Dec 20 20:35:02 EndeavourOS kernel: Loaded X.509 cert 'Build time autogenerated kernel key: c03c1fe1402d6c6e4>
Dec 20 20:35:02 EndeavourOS kernel: zswap: loaded using pool zstd/zsmalloc
Dec 20 20:35:02 EndeavourOS kernel: Demotion targets for Node 0: null
Dec 20 20:35:02 EndeavourOS kernel: Key type .fscrypt registered
Dec 20 20:35:02 EndeavourOS kernel: Key type fscrypt-provisioning registered
Dec 20 20:35:02 EndeavourOS kernel: Btrfs loaded, zoned=yes, fsverity=yes
Dec 20 20:35:02 EndeavourOS kernel: Key type big_key registered
Dec 20 20:35:02 EndeavourOS kernel: PM: Magic number: 5:747:559
Dec 20 20:35:02 EndeavourOS kernel: tty ttyS31: hash matches
Dec 20 20:35:02 EndeavourOS kernel: port serial8250:0.30: hash matches
Dec 20 20:35:02 EndeavourOS kernel: RAS: Correctable Errors collector initialized.
Dec 20 20:35:02 EndeavourOS kernel: clk: Disabling unused clocks
Dec 20 20:35:02 EndeavourOS kernel: PM: genpd: Disabling unused power domains
Dec 20 20:35:02 EndeavourOS kernel: usb 1-3: new high-speed USB device number 2 using xhci_hcd
Dec 20 20:35:02 EndeavourOS kernel: ata4: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Dec 20 20:35:02 EndeavourOS kernel: ata2: SATA link down (SStatus 4 SControl 300)
Dec 20 20:35:02 EndeavourOS kernel: ata5: SATA link down (SStatus 4 SControl 300)
Dec 20 20:35:02 EndeavourOS kernel: ata1: SATA link down (SStatus 4 SControl 300)
Dec 20 20:35:02 EndeavourOS kernel: ata6: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Dec 20 20:35:02 EndeavourOS kernel: ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Dec 20 20:35:02 EndeavourOS kernel: ata4.00: ACPI cmd f5/00:00:00:00:00:00(SECURITY FREEZE LOCK) filtered out
Dec 20 20:35:02 EndeavourOS kernel: ata4.00: ACPI cmd b1/c1:00:00:00:00:00(DEVICE CONFIGURATION OVERLAY) filt>
Dec 20 20:35:02 EndeavourOS kernel: ata3.00: ACPI cmd f5/00:00:00:00:00:00(SECURITY FREEZE LOCK) filtered out
Dec 20 20:35:02 EndeavourOS kernel: ata3.00: ACPI cmd b1/c1:00:00:00:00:00(DEVICE CONFIGURATION OVERLAY) filt>
Dec 20 20:35:02 EndeavourOS kernel: ata4.00: ATA-10: WDC WD10EZEX-08WN4A0, 02.01A02, max UDMA/100
Dec 20 20:35:02 EndeavourOS kernel: ata3.00: ATA-11: WDC WDS100T2B0A-00SM50, 415020WD, max UDMA/133
Dec 20 20:35:02 EndeavourOS kernel: ata3.00: 1953525168 sectors, multi 1: LBA48 NCQ (depth 32), AA
Dec 20 20:35:02 EndeavourOS kernel: ata6.00: ACPI cmd f5/00:00:00:00:00:00(SECURITY FREEZE LOCK) filtered out
Dec 20 20:35:02 EndeavourOS kernel: ata6.00: ACPI cmd b1/c1:00:00:00:00:00(DEVICE CONFIGURATION OVERLAY) filt>
Dec 20 20:35:02 EndeavourOS kernel: ata4.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 32), AA
Dec 20 20:35:02 EndeavourOS kernel: ata4.00: Features: DIPM NCQ-prio
Dec 20 20:35:02 EndeavourOS kernel: ata3.00: Features: Dev-Sleep DIPM
Dec 20 20:35:02 EndeavourOS kernel: ata4.00: configured for UDMA/100
Dec 20 20:35:02 EndeavourOS kernel: ata6.00: ATA-9: SanDisk SDSSDA120G, Z32070RL, max UDMA/133
Dec 20 20:35:02 EndeavourOS kernel: ata6.00: 234441648 sectors, multi 1: LBA48 NCQ (depth 32), AA
Dec 20 20:35:02 EndeavourOS kernel: ata3.00: configured for UDMA/133
Dec 20 20:35:02 EndeavourOS kernel: ahci 0000:00:17.0: port does not support device sleep
Dec 20 20:35:02 EndeavourOS kernel: scsi 2:0:0:0: Direct-Access ATA WDC WDS100T2B0A 20WD PQ: 0 ANSI>
Dec 20 20:35:02 EndeavourOS kernel: sd 2:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
Dec 20 20:35:02 EndeavourOS kernel: sd 2:0:0:0: [sda] Write Protect is off
Dec 20 20:35:02 EndeavourOS kernel: sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
Dec 20 20:35:02 EndeavourOS kernel: sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't supp>
Dec 20 20:35:02 EndeavourOS kernel: scsi 3:0:0:0: Direct-Access ATA WDC WD10EZEX-08W 1A02 PQ: 0 ANSI>
Dec 20 20:35:02 EndeavourOS kernel: sd 2:0:0:0: [sda] Preferred minimum I/O size 512 bytes
Dec 20 20:35:02 EndeavourOS kernel: sd 3:0:0:0: [sdb] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
Dec 20 20:35:02 EndeavourOS kernel: sd 3:0:0:0: [sdb] 4096-byte physical blocks
Dec 20 20:35:02 EndeavourOS kernel: sd 3:0:0:0: [sdb] Write Protect is off
Dec 20 20:35:02 EndeavourOS kernel: sd 3:0:0:0: [sdb] Mode Sense: 00 3a 00 00
Dec 20 20:35:02 EndeavourOS kernel: sd 3:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't supp>
Dec 20 20:35:02 EndeavourOS kernel: sd 3:0:0:0: [sdb] Preferred minimum I/O size 4096 bytes
Dec 20 20:35:02 EndeavourOS kernel: ata6.00: Features: Dev-Sleep DIPM
Dec 20 20:35:02 EndeavourOS kernel: sda: sda1 sda2
Dec 20 20:35:02 EndeavourOS kernel: sd 2:0:0:0: [sda] Attached SCSI disk
Dec 20 20:35:02 EndeavourOS kernel: sdb: sdb1
Dec 20 20:35:02 EndeavourOS kernel: sd 3:0:0:0: [sdb] Attached SCSI disk
Dec 20 20:35:02 EndeavourOS kernel: ata6.00: configured for UDMA/133
Dec 20 20:35:02 EndeavourOS kernel: usb 1-3: New USB device found, idVendor=0781, idProduct=5575, bcdDevice= >
Dec 20 20:35:02 EndeavourOS kernel: usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Dec 20 20:35:02 EndeavourOS kernel: usb 1-3: Product: Cruzer Glide
Dec 20 20:35:02 EndeavourOS kernel: usb 1-3: Manufacturer: SanDisk
Dec 20 20:35:02 EndeavourOS kernel: usb 1-3: SerialNumber: 20042204920C67D02EA1
Dec 20 20:35:02 EndeavourOS kernel: scsi 5:0:0:0: Direct-Access ATA SanDisk SDSSDA12 70RL PQ: 0 ANSI>
Dec 20 20:35:02 EndeavourOS kernel: sd 5:0:0:0: [sdc] 234441648 512-byte logical blocks: (120 GB/112 GiB)
Dec 20 20:35:02 EndeavourOS kernel: sd 5:0:0:0: [sdc] Write Protect is off
Dec 20 20:35:02 EndeavourOS kernel: sd 5:0:0:0: [sdc] Mode Sense: 00 3a 00 00
Dec 20 20:35:02 EndeavourOS kernel: sd 5:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't supp>
Dec 20 20:35:02 EndeavourOS kernel: sd 5:0:0:0: [sdc] Preferred minimum I/O size 512 bytes
Dec 20 20:35:02 EndeavourOS kernel: sdc: sdc1 sdc2 sdc3 sdc4
Dec 20 20:35:02 EndeavourOS kernel: sd 5:0:0:0: [sdc] Attached SCSI disk
Dec 20 20:35:02 EndeavourOS kernel: Freeing unused decrypted memory: 2028K
Dec 20 20:35:02 EndeavourOS kernel: Freeing unused kernel image (initmem) memory: 4688K
Dec 20 20:35:02 EndeavourOS kernel: Write protecting the kernel read-only data: 36864k
Dec 20 20:35:02 EndeavourOS kernel: Freeing unused kernel image (text/rodata gap) memory: 412K
Dec 20 20:35:02 EndeavourOS kernel: Freeing unused kernel image (rodata/data gap) memory: 180K
Dec 20 20:35:02 EndeavourOS kernel: x86/mm: Checked W+X mappings: passed, no W+X pages found.
Dec 20 20:35:02 EndeavourOS kernel: rodata_test: all tests were successful
Dec 20 20:35:02 EndeavourOS kernel: x86/mm: Checking user space page tables
Dec 20 20:35:02 EndeavourOS kernel: usb 1-7: new full-speed USB device number 3 using xhci_hcd
Dec 20 20:35:02 EndeavourOS kernel: Run /init as init process
Dec 20 20:35:02 EndeavourOS kernel: with arguments:
Dec 20 20:35:02 EndeavourOS kernel: /init
Dec 20 20:35:02 EndeavourOS kernel: with environment:
Dec 20 20:35:02 EndeavourOS kernel: HOME=/
Dec 20 20:35:02 EndeavourOS kernel: TERM=linux
Dec 20 20:35:02 EndeavourOS kernel: archisobasedir=arch
Dec 20 20:35:02 EndeavourOS kernel: archisosearchuuid=2025-11-24-21-31-18-00
Dec 20 20:35:02 EndeavourOS kernel: cow_spacesize=10G
Dec 20 20:35:02 EndeavourOS kernel: copytoram=n
Dec 20 20:35:02 EndeavourOS kernel: nvme_load=yes
Dec 20 20:35:02 EndeavourOS kernel: Key type psk registered
Dec 20 20:35:02 EndeavourOS kernel: r8169 0000:03:00.0: can't disable ASPM; OS doesn't have ASPM control
Dec 20 20:35:02 EndeavourOS kernel: nvme nvme0: pci function 0000:04:00.0
Dec 20 20:35:02 EndeavourOS kernel: usb 1-7: New USB device found, idVendor=1038, idProduct=12aa, bcdDevice= >
Dec 20 20:35:02 EndeavourOS kernel: usb 1-7: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Dec 20 20:35:02 EndeavourOS kernel: usb 1-7: Product: SteelSeries Arctis 5
Dec 20 20:35:02 EndeavourOS kernel: usb 1-7: Manufacturer: SteelSeries
Dec 20 20:35:02 EndeavourOS kernel: usb 1-7: SerialNumber: 00000000
Dec 20 20:35:02 EndeavourOS kernel: r8169 0000:03:00.0 eth0: RTL8168h/8111h, 30:9c:23:9d:99:d8, XID 541, IRQ >
Dec 20 20:35:02 EndeavourOS kernel: r8169 0000:03:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumm>
Dec 20 20:35:02 EndeavourOS kernel: tsc: Refined TSC clocksource calibration: 3695.999 MHz
Dec 20 20:35:02 EndeavourOS kernel: clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x6a8d2284b57, max>
Dec 20 20:35:02 EndeavourOS kernel: nvme nvme0: 12/0/0 default/read/poll queues
Dec 20 20:35:02 EndeavourOS kernel: nvme0n1: p1
Dec 20 20:35:02 EndeavourOS kernel: input: SteelSeries SteelSeries Arctis 5 as /devices/pci0000:00/0000:00:14>
Dec 20 20:35:02 EndeavourOS kernel: hid-generic 0003:1038:12AA.0001: input,hidraw0: USB HID v1.11 Device [Ste>
Dec 20 20:35:02 EndeavourOS kernel: usb 1-8: new full-speed USB device number 4 using xhci_hcd
Dec 20 20:35:02 EndeavourOS kernel: usb 1-8: New USB device found, idVendor=1b1c, idProduct=1b8b, bcdDevice= >
Dec 20 20:35:02 EndeavourOS kernel: usb 1-8: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Dec 20 20:35:02 EndeavourOS kernel: usb 1-8: Product: CORSAIR SCIMITAR RGB ELITE Gaming Mouse
Dec 20 20:35:02 EndeavourOS kernel: usb 1-8: Manufacturer: Corsair
Dec 20 20:35:02 EndeavourOS kernel: usb 1-8: SerialNumber: 1401F03BAF7D21015FB3CE66F5001C04
Dec 20 20:35:02 EndeavourOS kernel: input: Corsair CORSAIR SCIMITAR RGB ELITE Gaming Mouse as /devices/pci000>
Dec 20 20:35:02 EndeavourOS kernel: input: Corsair CORSAIR SCIMITAR RGB ELITE Gaming Mouse Consumer Control a>
Dec 20 20:35:02 EndeavourOS kernel: input: Corsair CORSAIR SCIMITAR RGB ELITE Gaming Mouse Keyboard as /devic>
Dec 20 20:35:02 EndeavourOS kernel: hid-generic 0003:1B1C:1B8B.0002: input,hiddev96,hidraw1: USB HID v1.11 Mo>
Dec 20 20:35:02 EndeavourOS kernel: hid-generic 0003:1B1C:1B8B.0003: hiddev97,hidraw2: USB HID v1.11 Device [>
Dec 20 20:35:02 EndeavourOS kernel: usb 1-9: new low-speed USB device number 5 using xhci_hcd
Dec 20 20:35:02 EndeavourOS kernel: usb 1-9: New USB device found, idVendor=04d9, idProduct=1503, bcdDevice= >
Dec 20 20:35:02 EndeavourOS kernel: usb 1-9: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Dec 20 20:35:02 EndeavourOS kernel: usb 1-9: Product: USB Keyboard
Dec 20 20:35:02 EndeavourOS kernel: usb 1-9: Manufacturer:
Dec 20 20:35:02 EndeavourOS kernel: input: USB Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.>
Dec 20 20:35:02 EndeavourOS kernel: hid-generic 0003:04D9:1503.0004: input,hidraw3: USB HID v1.10 Keyboard [ >
Dec 20 20:35:02 EndeavourOS kernel: input: USB Keyboard System Control as /devices/pci0000:00/0000:00:14.0/>
Dec 20 20:35:02 EndeavourOS kernel: input: USB Keyboard Consumer Control as /devices/pci0000:00/0000:00:14.>
Dec 20 20:35:02 EndeavourOS kernel: hid-generic 0003:04D9:1503.0005: input,hidraw4: USB HID v1.10 Device [ U>
Dec 20 20:35:02 EndeavourOS kernel: usb 1-11: new full-speed USB device number 6 using xhci_hcd
Dec 20 20:35:02 EndeavourOS kernel: usb 1-11: New USB device found, idVendor=0c76, idProduct=161e, bcdDevice=>
Dec 20 20:35:02 EndeavourOS kernel: usb 1-11: New USB device strings: Mfr=0, Product=1, SerialNumber=0
Dec 20 20:35:02 EndeavourOS kernel: usb 1-11: Product: USB PnP Audio Device
Dec 20 20:35:02 EndeavourOS kernel: input: USB PnP Audio Device as /devices/pci0000:00/0000:00:14.0/usb1/1-11>
Dec 20 20:35:02 EndeavourOS kernel: hid-generic 0003:0C76:161E.0006: input,hidraw5: USB HID v1.00 Device [USB>
Dec 20 20:35:02 EndeavourOS kernel: usb-storage 1-3:1.0: USB Mass Storage device detected
Dec 20 20:35:02 EndeavourOS kernel: scsi host6: usb-storage 1-3:1.0
Dec 20 20:35:02 EndeavourOS kernel: usbcore: registered new interface driver usb-storage
Dec 20 20:35:02 EndeavourOS kernel: usbcore: registered new interface driver uas
Dec 20 20:35:02 EndeavourOS kernel: scsi 6:0:0:0: Direct-Access SanDisk Cruzer Glide 2.01 PQ: 0 ANSI>
Dec 20 20:35:02 EndeavourOS kernel: sd 6:0:0:0: [sdd] 62530624 512-byte logical blocks: (32.0 GB/29.8 GiB)
Dec 20 20:35:02 EndeavourOS kernel: sd 6:0:0:0: [sdd] Write Protect is off
Dec 20 20:35:02 EndeavourOS kernel: sd 6:0:0:0: [sdd] Mode Sense: 43 00 00 00
Dec 20 20:35:02 EndeavourOS kernel: sd 6:0:0:0: [sdd] Write cache: disabled, read cache: enabled, doesn't sup>
Dec 20 20:35:02 EndeavourOS kernel: sdd: sdd1 sdd2
Dec 20 20:35:02 EndeavourOS kernel: sd 6:0:0:0: [sdd] Attached SCSI disk
Dec 20 20:35:02 EndeavourOS kernel: ISO 9660 Extensions: Microsoft Joliet Level 3
Dec 20 20:35:02 EndeavourOS kernel: ISO 9660 Extensions: RRIP_1991A
Dec 20 20:35:02 EndeavourOS kernel: loop: module loaded
Dec 20 20:35:02 EndeavourOS kernel: loop0: detected capacity change from 0 to 5814704
Dec 20 20:35:02 EndeavourOS kernel: squashfs: version 4.0 (2009/01/31) Phillip Lougher
Dec 20 20:35:02 EndeavourOS kernel: overlayfs: "xino" feature enabled using 2 upper inode bits.
Dec 20 20:35:02 EndeavourOS systemd[1]: systemd 258.2-2-arch running in system mode (+PAM +AUDIT -SELINUX +AP>
Dec 20 20:35:02 EndeavourOS systemd[1]: Detected architecture x86-64.
Dec 20 20:35:02 EndeavourOS systemd[1]: Detected first boot.
Dec 20 20:35:02 EndeavourOS systemd[1]: Initializing machine ID from random generator.
Dec 20 20:35:02 EndeavourOS systemd[1]: Hostname set to <EndeavourOS>.
Dec 20 20:35:02 EndeavourOS systemd[1]: bpf-restrict-fs: LSM BPF program attached
Dec 20 20:35:02 EndeavourOS systemd-gpt-auto-generator[518]: EFI loader partition unknown, not processing /.
Dec 20 20:35:02 EndeavourOS systemd-gpt-auto-generator[518]: (The boot loader did not set EFI variable Loader>
Dec 20 20:35:02 EndeavourOS systemd[1]: Applying preset policy.
Dec 20 20:35:02 EndeavourOS systemd[1]: Created symlink '/etc/systemd/system/multi-user.target.wants/machines>
Dec 20 20:35:02 EndeavourOS systemd[1]: Created symlink '/etc/systemd/system/ctrl-alt-del.target' → '/usr/lib>
Dec 20 20:35:02 EndeavourOS systemd[1]: Created symlink '/etc/systemd/system/multi-user.target.wants/remote-c>
Dec 20 20:35:02 EndeavourOS systemd[1]: Created symlink '/etc/systemd/system/multi-user.target.wants/remote-i>
Dec 20 20:35:02 EndeavourOS systemd[1]: Created symlink '/etc/systemd/system/multi-user.target.wants/remote-v>
Dec 20 20:35:02 EndeavourOS systemd[1]: Created symlink '/etc/systemd/system/sysinit.target.wants/systemd-boo>
Dec 20 20:35:02 EndeavourOS systemd[1]: Created symlink '/etc/systemd/system/sysinit.target.wants/systemd-con>
Dec 20 20:35:02 EndeavourOS systemd[1]: Created symlink '/etc/systemd/system/systemd-homed.service.wants/syst>
Dec 20 20:35:02 EndeavourOS systemd[1]: Created symlink '/etc/systemd/system/dbus-org.freedesktop.home1.servi>
Dec 20 20:35:02 EndeavourOS systemd[1]: Created symlink '/etc/systemd/system/multi-user.target.wants/systemd->
Dec 20 20:35:02 EndeavourOS systemd[1]: Created symlink '/etc/systemd/system/sockets.target.wants/systemd-jou>
Dec 20 20:35:02 EndeavourOS systemd[1]: Created symlink '/etc/systemd/system/systemd-journald.service.wants/s>
Dec 20 20:35:02 EndeavourOS systemd[1]: Created symlink '/etc/systemd/system/sockets.target.wants/systemd-mou>
Dec 20 20:35:02 EndeavourOS systemd[1]: Created symlink '/etc/systemd/system/sysinit.target.wants/systemd-net>
Dec 20 20:35:02 EndeavourOS systemd[1]: Created symlink '/etc/systemd/system/network-online.target.wants/syst>
Dec 20 20:35:02 EndeavourOS systemd[1]: Created symlink '/etc/systemd/system/dbus-org.freedesktop.network1.se>
Dec 20 20:35:02 EndeavourOS systemd[1]: Created symlink '/etc/systemd/system/sockets.target.wants/systemd-net>
Dec 20 20:35:02 EndeavourOS systemd[1]: Created symlink '/etc/systemd/system/sockets.target.wants/systemd-nsr>
Dec 20 20:35:02 EndeavourOS systemd[1]: Created symlink '/etc/systemd/system/sysinit.target.wants/systemd-pst>
Dec 20 20:35:02 EndeavourOS systemd[1]: Created symlink '/etc/systemd/system/dbus-org.freedesktop.resolve1.se>
Dec 20 20:35:02 EndeavourOS systemd[1]: Created symlink '/etc/systemd/system/sysinit.target.wants/systemd-res>
Dec 20 20:35:02 EndeavourOS systemd[1]: Created symlink '/etc/systemd/system/sockets.target.wants/systemd-res>
Dec 20 20:35:02 EndeavourOS systemd[1]: Created symlink '/etc/systemd/system/sysinit.target.wants/systemd-sys>
Dec 20 20:35:02 EndeavourOS systemd[1]: Created symlink '/etc/systemd/system/dbus-org.freedesktop.timesync1.s>
Dec 20 20:35:02 EndeavourOS systemd[1]: Created symlink '/etc/systemd/system/sysinit.target.wants/systemd-tim>
Dec 20 20:35:02 EndeavourOS systemd[1]: Created symlink '/etc/systemd/system/factory-reset.target.wants/syste>
Dec 20 20:35:02 EndeavourOS systemd[1]: Populated /etc with preset unit settings.
Dec 20 20:35:02 EndeavourOS systemd[1]: Queued start job for default target Multi-User System.
Dec 20 20:35:02 EndeavourOS systemd[1]: Created slice Slice /system/dirmngr.
Dec 20 20:35:02 EndeavourOS systemd[1]: Created slice Slice /system/getty.
Dec 20 20:35:02 EndeavourOS systemd[1]: Created slice Slice /system/gpg-agent.
Dec 20 20:35:02 EndeavourOS systemd[1]: Created slice Slice /system/gpg-agent-browser.
Dec 20 20:35:02 EndeavourOS systemd[1]: Created slice Slice /system/gpg-agent-extra.
Dec 20 20:35:02 EndeavourOS systemd[1]: Created slice Slice /system/gpg-agent-ssh.
Dec 20 20:35:02 EndeavourOS systemd[1]: Created slice Slice /system/keyboxd.
Dec 20 20:35:02 EndeavourOS systemd[1]: Created slice Slice /system/modprobe.
Dec 20 20:35:02 EndeavourOS systemd[1]: Created slice User and Session Slice.
Dec 20 20:35:02 EndeavourOS systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
Dec 20 20:35:02 EndeavourOS systemd[1]: Started Forward Password Requests to Wall Directory Watch.
Dec 20 20:35:02 EndeavourOS systemd[1]: Set up automount Arbitrary Executable File Formats File System Automo>
Dec 20 20:35:02 EndeavourOS systemd[1]: Reached target Local Encrypted Volumes.
Dec 20 20:35:02 EndeavourOS systemd[1]: Reached target Image Downloads.
Dec 20 20:35:02 EndeavourOS systemd[1]: Reached target Local Integrity Protected Volumes.
Dec 20 20:35:02 EndeavourOS systemd[1]: Reached target Path Units.
Dec 20 20:35:02 EndeavourOS systemd[1]: Reached target Remote Encrypted Volumes.
Dec 20 20:35:02 EndeavourOS systemd[1]: Reached target Remote File Systems.
Dec 20 20:35:02 EndeavourOS systemd[1]: Reached target Remote Integrity Protected Volumes.
Dec 20 20:35:02 EndeavourOS systemd[1]: Reached target Remote Verity Protected Volumes.
Dec 20 20:35:02 EndeavourOS systemd[1]: Reached target Slice Units.
Dec 20 20:35:02 EndeavourOS systemd[1]: Reached target Swaps.
Dec 20 20:35:02 EndeavourOS systemd[1]: Reached target Local Verity Protected Volumes.
Dec 20 20:35:02 EndeavourOS systemd[1]: Listening on Device-mapper event daemon FIFOs.
Dec 20 20:35:02 EndeavourOS systemd[1]: Listening on LVM2 poll daemon socket.
Dec 20 20:35:02 EndeavourOS systemd[1]: Listening on Query the User Interactively for a Password.
Dec 20 20:35:02 EndeavourOS systemd[1]: Listening on Process Core Dump Socket.
Dec 20 20:35:02 EndeavourOS systemd[1]: Listening on Credential Encryption/Decryption.
Dec 20 20:35:02 EndeavourOS systemd[1]: Listening on Factory Reset Management.
Dec 20 20:35:02 EndeavourOS systemd[1]: Listening on Journal Audit Socket.
Dec 20 20:35:02 EndeavourOS systemd[1]: Listening on Journal Socket (/dev/log).
Dec 20 20:35:02 EndeavourOS systemd[1]: Listening on Journal Sockets.
Dec 20 20:35:02 EndeavourOS systemd[1]: Listening on DDI File System Mounter Socket.
Dec 20 20:35:02 EndeavourOS systemd[1]: Listening on Network Service Varlink Socket.
Dec 20 20:35:02 EndeavourOS systemd[1]: Listening on Network Service Netlink Socket.
Dec 20 20:35:02 EndeavourOS systemd[1]: Listening on Namespace Resource Manager Socket.
Dec 20 20:35:02 EndeavourOS systemd[1]: TPM PCR Measurements was skipped because of an unmet condition check >
Dec 20 20:35:02 EndeavourOS systemd[1]: Make TPM PCR Policy was skipped because of an unmet condition check (>
Dec 20 20:35:02 EndeavourOS systemd[1]: Listening on Resolve Monitor Varlink Socket.
Dec 20 20:35:02 EndeavourOS systemd[1]: Listening on Resolve Service Varlink Socket.
Dec 20 20:35:02 EndeavourOS systemd[1]: Listening on udev Control Socket.
Dec 20 20:35:02 EndeavourOS systemd[1]: Listening on udev Kernel Socket.
Dec 20 20:35:02 EndeavourOS systemd[1]: Listening on udev Varlink Socket.
Dec 20 20:35:02 EndeavourOS systemd[1]: Listening on User Database Manager Socket.
Dec 20 20:35:02 EndeavourOS systemd[1]: Mounting Huge Pages File System...
Dec 20 20:35:02 EndeavourOS systemd[1]: Mounting POSIX Message Queue File System...
Dec 20 20:35:02 EndeavourOS systemd[1]: Mounting Kernel Debug File System...
Dec 20 20:35:02 EndeavourOS systemd[1]: Mounting Kernel Trace File System...
Dec 20 20:35:02 EndeavourOS systemd[1]: Mounting Temporary Directory /tmp...
Dec 20 20:35:02 EndeavourOS systemd[1]: Starting Create List of Static Device Nodes...
Dec 20 20:35:02 EndeavourOS systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or>
Dec 20 20:35:02 EndeavourOS systemd[1]: Load Kernel Module configfs was skipped because of an unmet condition>
Dec 20 20:35:02 EndeavourOS systemd[1]: Mounting Kernel Configuration File System...
Dec 20 20:35:02 EndeavourOS systemd[1]: Starting Load Kernel Module dm_mod...
Dec 20 20:35:02 EndeavourOS systemd[1]: Load Kernel Module drm was skipped because of an unmet condition chec>
Dec 20 20:35:02 EndeavourOS systemd[1]: Load Kernel Module efi_pstore was skipped because of an unmet conditi>
Dec 20 20:35:02 EndeavourOS systemd[1]: Load Kernel Module fuse was skipped because of an unmet condition che>
Dec 20 20:35:02 EndeavourOS systemd[1]: Mounting FUSE Control File System...
Dec 20 20:35:02 EndeavourOS systemd[1]: Load Kernel Module loop was skipped because of an unmet condition che>
Dec 20 20:35:02 EndeavourOS systemd[1]: Clear SysFail Entry If The Boot Is Successful was skipped because of >
Dec 20 20:35:02 EndeavourOS systemd[1]: Clear Stale Hibernate Storage Info was skipped because of an unmet co>
Dec 20 20:35:02 EndeavourOS systemd[1]: Starting Journal Service...
Dec 20 20:35:02 EndeavourOS systemd[1]: Starting Load Kernel Modules...
Dec 20 20:35:02 EndeavourOS systemd[1]: Starting Generate Network Units from Kernel Command Line...
Dec 20 20:35:02 EndeavourOS systemd[1]: TPM PCR Machine ID Measurement was skipped because of an unmet condit>
Dec 20 20:35:02 EndeavourOS systemd[1]: Starting Remount Root and Kernel File Systems...
Dec 20 20:35:02 EndeavourOS systemd[1]: Early TPM SRK Setup was skipped because of an unmet condition check (>
Dec 20 20:35:02 EndeavourOS systemd[1]: Starting Load udev Rules from Credentials...
Dec 20 20:35:02 EndeavourOS systemd[1]: Starting Coldplug All udev Devices...
Dec 20 20:35:02 EndeavourOS systemd[1]: Mounted Huge Pages File System.
Dec 20 20:35:02 EndeavourOS systemd[1]: Mounted POSIX Message Queue File System.
Dec 20 20:35:02 EndeavourOS systemd[1]: Mounted Kernel Debug File System.
Dec 20 20:35:02 EndeavourOS systemd[1]: Mounted Kernel Trace File System.
Dec 20 20:35:02 EndeavourOS systemd[1]: Mounted Temporary Directory /tmp.
Dec 20 20:35:02 EndeavourOS systemd[1]: Finished Create List of Static Device Nodes.
Dec 20 20:35:02 EndeavourOS systemd[1]: Mounted Kernel Configuration File System.
Dec 20 20:35:02 EndeavourOS systemd[1]: Mounted FUSE Control File System.
Dec 20 20:35:02 EndeavourOS systemd[1]: Starting Create Static Device Nodes in /dev gracefully...
Dec 20 20:35:02 EndeavourOS kernel: device-mapper: uevent: version 1.0.3
Dec 20 20:35:02 EndeavourOS kernel: device-mapper: ioctl: 4.50.0-ioctl (2025-04-28) initialised: dm-devel@lis>
Dec 20 20:35:02 EndeavourOS systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
Dec 20 20:35:02 EndeavourOS systemd[1]: Finished Load Kernel Module dm_mod.
Dec 20 20:35:02 EndeavourOS systemd[1]: Repartition Root Disk was skipped because no trigger condition checks>
Dec 20 20:35:02 EndeavourOS systemd[1]: Finished Generate Network Units from Kernel Command Line.
Dec 20 20:35:02 EndeavourOS systemd[1]: Finished Remount Root and Kernel File Systems.
Dec 20 20:35:02 EndeavourOS systemd-journald[540]: Collecting audit messages is enabled.
Dec 20 20:35:02 EndeavourOS systemd[1]: Rebuild Hardware Database was skipped because no trigger condition ch>
Dec 20 20:35:02 EndeavourOS systemd[1]: Platform Persistent Storage Archival was skipped because of an unmet >
Dec 20 20:35:02 EndeavourOS systemd[1]: Starting Load/Save OS Random Seed...
Dec 20 20:35:02 EndeavourOS systemd[1]: TPM SRK Setup was skipped because of an unmet condition check (Condit>
Dec 20 20:35:02 EndeavourOS systemd[1]: Finished Load udev Rules from Credentials.
Dec 20 20:35:02 EndeavourOS kernel: audit: type=1130 audit(1766280902.697:2): pid=1 uid=0 auid=4294967295 ses>
Dec 20 20:35:02 EndeavourOS systemd-journald[540]: Journal started
Dec 20 20:35:02 EndeavourOS systemd-journald[540]: Runtime Journal (/run/log/journal/ec8596f96f144915b2a8e15b>
Dec 20 20:35:02 EndeavourOS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=syst>
Dec 20 20:35:02 EndeavourOS systemd[1]: Started Journal Service.
Dec 20 20:35:02 EndeavourOS kernel: audit: type=1130 audit(1766280902.739:3): pid=1 uid=0 auid=4294967295 ses>
Dec 20 20:35:02 EndeavourOS systemd[1]: Starting Flush Journal to Persistent Storage...
Dec 20 20:35:02 EndeavourOS systemd[1]: Finished Load/Save OS Random Seed.
Dec 20 20:35:02 EndeavourOS kernel: audit: type=1130 audit(1766280902.760:4): pid=1 uid=0 auid=4294967295 ses>
Dec 20 20:35:02 EndeavourOS systemd-modules-load[543]: Inserted module 'crypto_user'
Dec 20 20:35:02 EndeavourOS systemd-journald[540]: Received client request to flush runtime journal.
Dec 20 20:35:02 EndeavourOS systemd[1]: Finished Flush Journal to Persistent Storage.
Dec 20 20:35:02 EndeavourOS kernel: audit: type=1130 audit(1766280902.857:5): pid=1 uid=0 auid=4294967295 ses>
Dec 20 20:35:02 EndeavourOS systemd[1]: Finished Coldplug All udev Devices.
Dec 20 20:35:02 EndeavourOS kernel: audit: type=1130 audit(1766280902.981:6): pid=1 uid=0 auid=4294967295 ses>
Dec 20 20:35:02 EndeavourOS systemd-modules-load[543]: Inserted module 'i2c_dev'
Dec 20 20:35:02 EndeavourOS kernel: i2c_dev: i2c /dev entries driver
Dec 20 20:35:03 EndeavourOS systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or>
Dec 20 20:35:03 EndeavourOS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2>
Dec 20 20:35:03 EndeavourOS kernel: audit: type=1130 audit(1766280903.054:7): pid=1 uid=0 auid=4294967295 ses>
Dec 20 20:35:03 EndeavourOS systemd-modules-load[543]: Inserted module 'pkcs8_key_parser'
Dec 20 20:35:03 EndeavourOS systemd[1]: Finished Load Kernel Modules.
Dec 20 20:35:03 EndeavourOS kernel: Asymmetric key parser 'pkcs8' registered
Dec 20 20:35:03 EndeavourOS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=syst>
Dec 20 20:35:03 EndeavourOS systemd[1]: Starting Apply Kernel Variables...
Dec 20 20:35:03 EndeavourOS kernel: audit: type=1130 audit(1766280903.067:8): pid=1 uid=0 auid=4294967295 ses>
Dec 20 20:35:03 EndeavourOS systemd[1]: Starting Load Kernel Module tun...
Dec 20 20:35:03 EndeavourOS audit: BPF prog-id=22 op=LOAD
Dec 20 20:35:03 EndeavourOS audit: BPF prog-id=23 op=LOAD
Dec 20 20:35:03 EndeavourOS audit: BPF prog-id=24 op=LOAD
Dec 20 20:35:03 EndeavourOS kernel: audit: type=1334 audit(1766280903.089:9): prog-id=22 op=LOAD
Dec 20 20:35:03 EndeavourOS kernel: audit: type=1334 audit(1766280903.089:10): prog-id=23 op=LOAD
Dec 20 20:35:03 EndeavourOS kernel: audit: type=1334 audit(1766280903.089:11): prog-id=24 op=LOAD
Dec 20 20:35:03 EndeavourOS systemd[1]: Starting User Database Manager...
Dec 20 20:35:03 EndeavourOS kernel: tun: Universal TUN/TAP device driver, 1.6
Dec 20 20:35:03 EndeavourOS systemd[1]: modprobe@tun.service: Deactivated successfully.
Dec 20 20:35:03 EndeavourOS systemd[1]: Finished Load Kernel Module tun.
Dec 20 20:35:03 EndeavourOS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=modp>
Dec 20 20:35:03 EndeavourOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=modpr>
Dec 20 20:35:03 EndeavourOS audit: BPF prog-id=25 op=LOAD
Dec 20 20:35:03 EndeavourOS audit: BPF prog-id=26 op=LOAD
Dec 20 20:35:03 EndeavourOS audit: BPF prog-id=27 op=LOAD
Dec 20 20:35:03 EndeavourOS systemd[1]: Starting Namespace Resource Manager...
Dec 20 20:35:03 EndeavourOS systemd[1]: Started User Database Manager.
Dec 20 20:35:03 EndeavourOS systemd[1]: Finished Apply Kernel Variables.
Dec 20 20:35:03 EndeavourOS audit: BPF prog-id=28 op=LOAD
Dec 20 20:35:03 EndeavourOS audit[580]: SYSCALL arch=c000003e syscall=321 success=yes exit=13 a0=5 a1=7ffcfb9>
Dec 20 20:35:03 EndeavourOS audit: PROCTITLE proctitle="/usr/lib/systemd/systemd-nsresourced"
Dec 20 20:35:03 EndeavourOS audit: BPF prog-id=28 op=UNLOAD
Dec 20 20:35:03 EndeavourOS audit[580]: SYSCALL arch=c000003e syscall=3 success=yes exit=0 a0=d a1=0 a2=0 a3=>
Dec 20 20:35:03 EndeavourOS audit: BPF prog-id=29 op=LOAD
Dec 20 20:35:03 EndeavourOS audit[580]: SYSCALL arch=c000003e syscall=321 success=yes exit=11 a0=5 a1=7ffcfb9>
Dec 20 20:35:03 EndeavourOS audit: BPF prog-id=29 op=UNLOAD
Dec 20 20:35:03 EndeavourOS audit[580]: SYSCALL arch=c000003e syscall=3 success=yes exit=0 a0=b a1=0 a2=0 a3=>
Dec 20 20:35:03 EndeavourOS audit: BPF prog-id=30 op=LOAD
Dec 20 20:35:03 EndeavourOS audit[580]: SYSCALL arch=c000003e syscall=321 success=yes exit=14 a0=5 a1=7ffcfb9>
Dec 20 20:35:03 EndeavourOS audit: BPF prog-id=30 op=UNLOAD
Dec 20 20:35:03 EndeavourOS audit[580]: SYSCALL arch=c000003e syscall=3 success=yes exit=0 a0=e a1=0 a2=0 a3=>
Dec 20 20:35:03 EndeavourOS audit: BPF prog-id=31 op=LOAD
Dec 20 20:35:03 EndeavourOS audit: BPF prog-id=31 op=UNLOAD
Dec 20 20:35:03 EndeavourOS audit: BPF prog-id=32 op=LOAD
Dec 20 20:35:03 EndeavourOS audit: BPF prog-id=33 op=LOAD
Dec 20 20:35:03 EndeavourOS audit[580]: SYSCALL arch=c000003e syscall=321 success=yes exit=15 a0=5 a1=7ffcfb9>
Dec 20 20:35:03 EndeavourOS audit: BPF prog-id=34 op=LOAD
Dec 20 20:35:03 EndeavourOS audit[580]: SYSCALL arch=c000003e syscall=321 success=yes exit=16 a0=5 a1=7ffcfb9>
Dec 20 20:35:03 EndeavourOS audit: BPF prog-id=35 op=LOAD
Dec 20 20:35:03 EndeavourOS audit[580]: SYSCALL arch=c000003e syscall=321 success=yes exit=17 a0=5 a1=7ffcfb9>
Dec 20 20:35:03 EndeavourOS audit: BPF prog-id=36 op=LOAD
Dec 20 20:35:03 EndeavourOS audit[580]: SYSCALL arch=c000003e syscall=321 success=yes exit=18 a0=5 a1=7ffcfb9>
Dec 20 20:35:03 EndeavourOS audit: BPF prog-id=37 op=LOAD
Dec 20 20:35:03 EndeavourOS audit[580]: SYSCALL arch=c000003e syscall=321 success=yes exit=19 a0=5 a1=7ffcfb9>
Dec 20 20:35:03 EndeavourOS systemd-nsresourced[580]: userns-restrict BPF-LSM program userns_restrict_path_ch>
Dec 20 20:35:03 EndeavourOS systemd-nsresourced[580]: userns-restrict BPF-LSM program userns_restrict_path_mk>
Dec 20 20:35:03 EndeavourOS systemd-nsresourced[580]: userns-restrict BPF-LSM program userns_restrict_path_sy>
Dec 20 20:35:03 EndeavourOS systemd-nsresourced[580]: userns-restrict BPF-LSM program userns_restrict_path_li>
Dec 20 20:35:03 EndeavourOS audit: BPF prog-id=38 op=LOAD
Dec 20 20:35:03 EndeavourOS audit[580]: SYSCALL arch=c000003e syscall=321 success=yes exit=26 a0=5 a1=7ffcfb9>
Dec 20 20:35:03 EndeavourOS audit: BPF prog-id=38 op=UNLOAD
Dec 20 20:35:03 EndeavourOS audit[580]: SYSCALL arch=c000003e syscall=3 success=yes exit=0 a0=1a a1=0 a2=0 a3>
Dec 20 20:35:03 EndeavourOS systemd-nsresourced[580]: userns-restrict BPF-LSM program userns_restrict_free_us>
Dec 20 20:35:03 EndeavourOS systemd[1]: Started Namespace Resource Manager.
Dec 20 20:35:03 EndeavourOS systemd[1]: Finished Create Static Device Nodes in /dev gracefully.
Dec 20 20:35:03 EndeavourOS systemd[1]: Starting Create System Users...
Dec 20 20:35:03 EndeavourOS systemd[1]: Finished Create System Users.
Dec 20 20:35:03 EndeavourOS audit: BPF prog-id=39 op=LOAD
Dec 20 20:35:03 EndeavourOS systemd[1]: Starting Network Name Resolution...
Dec 20 20:35:03 EndeavourOS audit: BPF prog-id=40 op=LOAD
Dec 20 20:35:03 EndeavourOS systemd[1]: Starting Network Time Synchronization...
Dec 20 20:35:03 EndeavourOS systemd[1]: Starting Create Static Device Nodes in /dev...
Dec 20 20:35:03 EndeavourOS systemd[1]: Finished Create Static Device Nodes in /dev.
Dec 20 20:35:03 EndeavourOS systemd[1]: Reached target Preparation for Local File Systems.
Dec 20 20:35:03 EndeavourOS systemd[1]: Virtual Machine and Container Storage (Compatibility) was skipped bec>
Dec 20 20:35:03 EndeavourOS systemd[1]: Reached target Local File Systems.
Dec 20 20:35:03 EndeavourOS systemd[1]: Reached target Virtual Machines and Containers.
Dec 20 20:35:03 EndeavourOS systemd[1]: Listening on Boot Entries Service Socket.
Dec 20 20:35:03 EndeavourOS systemd[1]: Listening on Disk Image Download Service Socket.
Dec 20 20:35:03 EndeavourOS systemd[1]: Listening on System Extension Image Management.
Dec 20 20:35:03 EndeavourOS systemd[1]: Started detect intel legacy gpu and install xf86-video-intel.
Dec 20 20:35:03 EndeavourOS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=inte>
Dec 20 20:35:03 EndeavourOS systemd[1]: Started Nvidia Modules installer.
Dec 20 20:35:03 EndeavourOS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=nvid>
Dec 20 20:35:03 EndeavourOS systemd[1]: Set Up Additional Binary Formats was skipped because no trigger condi>
Dec 20 20:35:03 EndeavourOS systemd[1]: Starting Update Boot Loader Random Seed...
Dec 20 20:35:03 EndeavourOS systemd[1]: Starting Automatic Boot Loader Update...
Dec 20 20:35:03 EndeavourOS systemd[1]: Merge System Configuration Images into /etc/ was skipped because no t>
Dec 20 20:35:03 EndeavourOS systemd[1]: Merge System Extension Images into /usr/ and /opt/ was skipped becaus>
Dec 20 20:35:03 EndeavourOS systemd[1]: Starting Create System Files and Directories...
Dec 20 20:35:03 EndeavourOS systemd-resolved[598]: Positive Trust Anchors:
Dec 20 20:35:03 EndeavourOS systemd-resolved[598]: . IN DS 20326 8 2 e06d44b80b8f1d39a95c0b0d7c65d08458e88040>
Dec 20 20:35:03 EndeavourOS systemd-resolved[598]: . IN DS 38696 8 2 683d2d0acb8c9b712a1948b27f741219298d0a45>
Dec 20 20:35:03 EndeavourOS systemd-resolved[598]: Negative trust anchors: home.arpa 10.in-addr.arpa 16.172.i>
Dec 20 20:35:03 EndeavourOS audit: BPF prog-id=41 op=LOAD
Dec 20 20:35:03 EndeavourOS audit: BPF prog-id=42 op=LOAD
Dec 20 20:35:03 EndeavourOS systemd[1]: Starting Rule-based Manager for Device Events and Files...
Dec 20 20:35:03 EndeavourOS systemd[1]: Starting Load JSON user/group Records from Credentials...
Dec 20 20:35:03 EndeavourOS systemd[1]: Started Network Time Synchronization.
Dec 20 20:35:03 EndeavourOS systemd[1]: Reached target System Time Set.
Dec 20 20:35:03 EndeavourOS bootctl[612]: Couldn't find EFI system partition, skipping.
Dec 20 20:35:03 EndeavourOS bootctl[611]: No ESP found, not initializing random seed.
Dec 20 20:35:03 EndeavourOS systemd[1]: Finished Update Boot Loader Random Seed.
Dec 20 20:35:03 EndeavourOS systemd[1]: Finished Automatic Boot Loader Update.
Dec 20 20:35:03 EndeavourOS systemd[1]: Finished Load JSON user/group Records from Credentials.
Dec 20 20:35:03 EndeavourOS systemd-udevd[614]: Using default interface naming scheme 'v258'.
Dec 20 20:35:03 EndeavourOS bash[609]: Bootflag nvidia=1 not set – skipping.
Dec 20 20:35:03 EndeavourOS systemd[1]: nvidia.service: Deactivated successfully.
Dec 20 20:35:03 EndeavourOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=nvidi>
Dec 20 20:35:04 EndeavourOS systemd-resolved[598]: Using system hostname 'EndeavourOS'.
Dec 20 20:35:04 EndeavourOS systemd[1]: Started Network Name Resolution.
Dec 20 20:35:04 EndeavourOS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=syst>
Dec 20 20:35:04 EndeavourOS systemd[1]: Reached target Host and Network Name Lookups.
Dec 20 20:35:04 EndeavourOS bash[608]: ==> intel-legacy-gpu-installer: No gen1..gen3 Intel graphics device wa>
Dec 20 20:35:04 EndeavourOS systemd[1]: intel.service: Main process exited, code=exited, status=1/FAILURE
Dec 20 20:35:04 EndeavourOS systemd[1]: intel.service: Failed with result 'exit-code'.
Dec 20 20:35:04 EndeavourOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=intel>
Dec 20 20:35:04 EndeavourOS systemd-resolved[598]: Switching to fallback DNS server 9.9.9.9#dns.quad9.net.
Dec 20 20:35:04 EndeavourOS systemd[1]: Started Rule-based Manager for Device Events and Files.
Dec 20 20:35:04 EndeavourOS systemd-timesyncd[599]: Network configuration changed, trying to establish connec>
Dec 20 20:35:04 EndeavourOS systemd[1]: Finished Create System Files and Directories.
Dec 20 20:35:04 EndeavourOS systemd[1]: Starting Rebuild Dynamic Linker Cache...
Dec 20 20:35:04 EndeavourOS systemd[1]: Starting First Boot Wizard...
Dec 20 20:35:04 EndeavourOS systemd[1]: Starting Rebuild Journal Catalog...
Dec 20 20:35:04 EndeavourOS systemd[1]: Starting Record System Boot/Shutdown in UTMP...
Dec 20 20:35:04 EndeavourOS audit[650]: AUDIT1127 pid=650 uid=0 auid=4294967295 ses=4294967295 msg=' comm="sy>
Dec 20 20:35:04 EndeavourOS systemd[1]: Finished Record System Boot/Shutdown in UTMP.
Dec 20 20:35:04 EndeavourOS systemd[1]: Expecting device /dev/tpm0...
Dec 20 20:35:04 EndeavourOS systemd[1]: Finished First Boot Wizard.
Dec 20 20:35:04 EndeavourOS systemd[1]: Reached target First Boot Complete.
Dec 20 20:35:04 EndeavourOS systemd[1]: Starting Save Transient machine-id to Disk...
Dec 20 20:35:04 EndeavourOS systemd[1]: Found device /dev/tpm0.
Dec 20 20:35:04 EndeavourOS systemd[1]: Reached target Trusted Platform Module.
Dec 20 20:35:05 EndeavourOS kernel: r8169 0000:03:00.0 enp3s0: renamed from eth0
Dec 20 20:35:05 EndeavourOS kernel: EDAC ie31200: No ECC support
Dec 20 20:35:05 EndeavourOS kernel: Module pcspkr is blacklisted
Dec 20 20:35:05 EndeavourOS kernel: i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
Dec 20 20:35:05 EndeavourOS kernel: i2c i2c-0: Successfully instantiated SPD at 0x51
Dec 20 20:35:05 EndeavourOS kernel: i2c i2c-0: Successfully instantiated SPD at 0x53
Dec 20 20:35:05 EndeavourOS kernel: parport_pc 00:02: reported by Plug and Play ACPI
Dec 20 20:35:05 EndeavourOS kernel: parport0: PC-style at 0x378, irq 5 [PCSPP]
Dec 20 20:35:06 EndeavourOS systemd[1]: Starting Virtual Console Setup...
Dec 20 20:35:06 EndeavourOS kernel: RAPL PMU: API unit is 2^-32 Joules, 3 fixed counters, 655360 ms ovfl timer
Dec 20 20:35:06 EndeavourOS kernel: RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
Dec 20 20:35:06 EndeavourOS kernel: RAPL PMU: hw unit of domain package 2^-14 Joules
Dec 20 20:35:06 EndeavourOS kernel: RAPL PMU: hw unit of domain dram 2^-14 Joules
Dec 20 20:35:06 EndeavourOS kernel: mei_me 0000:00:16.0: enabling device (0004 -> 0006)
Dec 20 20:35:06 EndeavourOS kernel: ee1004 0-0051: 512 byte EE1004-compliant SPD EEPROM, read-only
Dec 20 20:35:06 EndeavourOS kernel: ee1004 0-0053: 512 byte EE1004-compliant SPD EEPROM, read-only
Dec 20 20:35:06 EndeavourOS kernel: iTCO_vendor_support: vendor-support=0
Dec 20 20:35:06 EndeavourOS kernel: ppdev: user-space parallel port driver
Dec 20 20:35:06 EndeavourOS kernel: iTCO_wdt iTCO_wdt: Found a Intel PCH TCO device (Version=4, TCOBASE=0x040>
Dec 20 20:35:06 EndeavourOS kernel: iTCO_wdt iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
Dec 20 20:35:06 EndeavourOS kernel: resource: resource sanity check: requesting [mem 0x00000000fdffe800-0x000>
Dec 20 20:35:06 EndeavourOS kernel: caller get_primary_reg_base+0x4c/0xa0 [intel_pmc_core] mapping multiple B>
Dec 20 20:35:06 EndeavourOS kernel: intel_pmc_core INT33A1:00: initialized
Dec 20 20:35:06 EndeavourOS systemd[1]: etc-machine\x2did.mount: Deactivated successfully.
Dec 20 20:35:06 EndeavourOS systemd[1]: Finished Save Transient machine-id to Disk.
Dec 20 20:35:06 EndeavourOS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=syst>
Dec 20 20:35:07 EndeavourOS mtp-probe[700]: checking bus 1, device 6: "/sys/devices/pci0000:00/0000:00:14.0/u>
Dec 20 20:35:07 EndeavourOS mtp-probe[701]: checking bus 1, device 3: "/sys/devices/pci0000:00/0000:00:14.0/u>
Dec 20 20:35:07 EndeavourOS mtp-probe[703]: checking bus 1, device 2: "/sys/devices/pci0000:00/0000:00:14.0/u>
Dec 20 20:35:07 EndeavourOS mtp-probe[702]: checking bus 1, device 5: "/sys/devices/pci0000:00/0000:00:14.0/u>
Dec 20 20:35:07 EndeavourOS mtp-probe[705]: checking bus 1, device 4: "/sys/devices/pci0000:00/0000:00:14.0/u>
Dec 20 20:35:07 EndeavourOS mtp-probe[703]: bus: 1, device: 2 was not an MTP device
Dec 20 20:35:07 EndeavourOS mtp-probe[700]: bus: 1, device: 6 was not an MTP device
Dec 20 20:35:07 EndeavourOS mtp-probe[701]: bus: 1, device: 3 was not an MTP device
Dec 20 20:35:07 EndeavourOS mtp-probe[705]: bus: 1, device: 4 was not an MTP device
Dec 20 20:35:07 EndeavourOS mtp-probe[702]: bus: 1, device: 5 was not an MTP device
Dec 20 20:35:07 EndeavourOS kernel: mousedev: PS/2 mouse device common for all mice
Dec 20 20:35:07 EndeavourOS systemd[1]: Finished Rebuild Journal Catalog.
Dec 20 20:35:07 EndeavourOS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=syst>
Dec 20 20:35:07 EndeavourOS kernel: snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
Dec 20 20:35:07 EndeavourOS kernel: snd_hda_intel 0000:01:00.1: enabling device (0000 -> 0002)
Dec 20 20:35:07 EndeavourOS kernel: snd_hda_intel 0000:01:00.1: Disabling MSI
Dec 20 20:35:07 EndeavourOS kernel: snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
Dec 20 20:35:07 EndeavourOS kernel: mc: Linux media interface: v0.10
Dec 20 20:35:07 EndeavourOS kernel: snd_hda_codec_alc662 hdaudioC0D0: autoconfig for ALC892: line_outs=4 (0x1>
Dec 20 20:35:07 EndeavourOS kernel: snd_hda_codec_alc662 hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
Dec 20 20:35:07 EndeavourOS kernel: snd_hda_codec_alc662 hdaudioC0D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
Dec 20 20:35:07 EndeavourOS kernel: snd_hda_codec_alc662 hdaudioC0D0: mono: mono_out=0x0
Dec 20 20:35:07 EndeavourOS kernel: snd_hda_codec_alc662 hdaudioC0D0: inputs:
Dec 20 20:35:07 EndeavourOS kernel: snd_hda_codec_alc662 hdaudioC0D0: Rear Mic=0x18
Dec 20 20:35:07 EndeavourOS kernel: snd_hda_codec_alc662 hdaudioC0D0: Front Mic=0x19
Dec 20 20:35:07 EndeavourOS kernel: snd_hda_codec_alc662 hdaudioC0D0: Line=0x1a
Dec 20 20:35:07 EndeavourOS kernel: input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:>
Dec 20 20:35:07 EndeavourOS kernel: input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:>
Dec 20 20:35:07 EndeavourOS kernel: input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:>
Dec 20 20:35:07 EndeavourOS kernel: input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:>
Dec 20 20:35:07 EndeavourOS kernel: input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1f.3/sound/c>
Dec 20 20:35:07 EndeavourOS kernel: input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1f.3/sound/>
Dec 20 20:35:07 EndeavourOS kernel: input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1f.3/sound/card0>
Dec 20 20:35:07 EndeavourOS kernel: input: HDA Intel PCH Line Out Front as /devices/pci0000:00/0000:00:1f.3/s>
Dec 20 20:35:07 EndeavourOS kernel: input: HDA Intel PCH Line Out Surround as /devices/pci0000:00/0000:00:1f.>
Dec 20 20:35:07 EndeavourOS kernel: input: HDA Intel PCH Line Out CLFE as /devices/pci0000:00/0000:00:1f.3/so>
Dec 20 20:35:07 EndeavourOS kernel: input: HDA Intel PCH Line Out Side as /devices/pci0000:00/0000:00:1f.3/so>
Dec 20 20:35:07 EndeavourOS kernel: input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1f.3/>
Dec 20 20:35:07 EndeavourOS kernel: intel_tcc_cooling: Programmable TCC Offset detected
Dec 20 20:35:08 EndeavourOS kernel: MXM: GUID detected in BIOS
Dec 20 20:35:08 EndeavourOS kernel: nouveau 0000:01:00.0: NVIDIA GP104 (134000a1)
Dec 20 20:35:08 EndeavourOS (udev-worker)[665]: controlC1: Process '/usr/bin/alsactl restore 1' failed with e>
Dec 20 20:35:08 EndeavourOS (udev-worker)[671]: controlC0: Process '/usr/bin/alsactl restore 0' failed with e>
Dec 20 20:35:08 EndeavourOS kernel: usb 1-7: 1:1: cannot get freq at ep 0x81
Dec 20 20:35:08 EndeavourOS kernel: usb 1-7: Warning! Unlikely big volume range (=4096), cval->res is probabl>
Dec 20 20:35:08 EndeavourOS kernel: usb 1-7: [11] FU [Sidetone Playback Volume] ch = 1, val = 0/4096/1
Dec 20 20:35:08 EndeavourOS kernel: usb 1-7: 4:1: cannot get freq at ep 0x2
Dec 20 20:35:08 EndeavourOS kernel: usb 1-11: Warning! Unlikely big volume range (=496), cval->res is probabl>
Dec 20 20:35:08 EndeavourOS kernel: usb 1-11: [50] FU [Mic Capture Volume] ch = 1, val = 0/7936/16
Dec 20 20:35:08 EndeavourOS kernel: usbcore: registered new interface driver snd-usb-audio
Dec 20 20:35:08 EndeavourOS systemd[1]: Load Kernel Module dm_mod was skipped because of an unmet condition c>
Dec 20 20:35:08 EndeavourOS systemd[1]: Load Kernel Module efi_pstore was skipped because of an unmet conditi>
Dec 20 20:35:08 EndeavourOS systemd[1]: Load Kernel Module loop was skipped because of an unmet condition che>
Dec 20 20:35:08 EndeavourOS systemd[1]: Set Up Additional Binary Formats was skipped because no trigger condi>
Dec 20 20:35:08 EndeavourOS systemd[1]: Clear SysFail Entry If The Boot Is Successful was skipped because of >
Dec 20 20:35:08 EndeavourOS systemd[1]: Merge System Configuration Images into /etc/ was skipped because no t>
Dec 20 20:35:08 EndeavourOS systemd[1]: Clear Stale Hibernate Storage Info was skipped because of an unmet co>
Dec 20 20:35:08 EndeavourOS systemd[1]: Rebuild Hardware Database was skipped because no trigger condition ch>
Dec 20 20:35:08 EndeavourOS systemd[1]: TPM PCR Machine ID Measurement was skipped because of an unmet condit>
Dec 20 20:35:08 EndeavourOS systemd[1]: Platform Persistent Storage Archival was skipped because of an unmet >
Dec 20 20:35:08 EndeavourOS systemd[1]: Merge System Extension Images into /usr/ and /opt/ was skipped becaus>
Dec 20 20:35:08 EndeavourOS systemd[1]: Early TPM SRK Setup was skipped because of an unmet condition check (>
Dec 20 20:35:08 EndeavourOS systemd[1]: Repartition Root Disk was skipped because no trigger condition checks>
Dec 20 20:35:08 EndeavourOS systemd[1]: TPM SRK Setup was skipped because of an unmet condition check (Condit>
Dec 20 20:35:08 EndeavourOS kernel: nouveau 0000:01:00.0: bios: version 86.04.60.00.60
Dec 20 20:35:08 EndeavourOS (udev-worker)[670]: controlC3: Process '/usr/bin/alsactl restore 3' failed with e>
Dec 20 20:35:08 EndeavourOS (udev-worker)[660]: controlC2: Process '/usr/bin/alsactl restore 2' failed with e>
Dec 20 20:35:08 EndeavourOS kernel: intel_rapl_common: Found RAPL domain package
Dec 20 20:35:08 EndeavourOS kernel: intel_rapl_common: Found RAPL domain core
Dec 20 20:35:08 EndeavourOS kernel: intel_rapl_common: Found RAPL domain dram
Dec 20 20:35:08 EndeavourOS kernel: nouveau 0000:01:00.0: pmu: firmware unavailable
Dec 20 20:35:08 EndeavourOS systemd[1]: Finished Virtual Console Setup.
Dec 20 20:35:08 EndeavourOS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=syst>
Dec 20 20:35:08 EndeavourOS kernel: kauditd_printk_skb: 79 callbacks suppressed
Dec 20 20:35:08 EndeavourOS kernel: audit: type=1130 audit(1766280908.535:59): pid=1 uid=0 auid=4294967295 se>
Dec 20 20:35:08 EndeavourOS kernel: Console: switching to colour dummy device 80x25
Dec 20 20:35:08 EndeavourOS kernel: nouveau 0000:01:00.0: vgaarb: deactivate vga console
Dec 20 20:35:08 EndeavourOS kernel: nouveau 0000:01:00.0: fb: 8192 MiB GDDR5X
Dec 20 20:35:08 EndeavourOS kernel: nouveau 0000:01:00.0: drm: VRAM: 8192 MiB
Dec 20 20:35:08 EndeavourOS kernel: nouveau 0000:01:00.0: drm: GART: 536870912 MiB
Dec 20 20:35:08 EndeavourOS kernel: nouveau 0000:01:00.0: drm: BIT table 'A' not found
Dec 20 20:35:08 EndeavourOS kernel: nouveau 0000:01:00.0: drm: BIT table 'L' not found
Dec 20 20:35:08 EndeavourOS kernel: nouveau 0000:01:00.0: drm: TMDS table version 2.0
Dec 20 20:35:08 EndeavourOS kernel: nouveau 0000:01:00.0: drm: MM: using COPY for buffer copies
Dec 20 20:35:08 EndeavourOS kernel: snd_hda_intel 0000:01:00.1: bound 0000:01:00.0 (ops nv50_audio_component_>
Dec 20 20:35:08 EndeavourOS kernel: nouveau 0000:01:00.0: [drm] Registered 4 planes with drm panic
Dec 20 20:35:08 EndeavourOS kernel: [drm] Initialized nouveau 1.4.0 for 0000:01:00.0 on minor 0
Dec 20 20:35:08 EndeavourOS kernel: fbcon: nouveaudrmfb (fb0) is primary device
Dec 20 20:35:09 EndeavourOS systemd[1]: systemd-vconsole-setup.service: Deactivated successfully.
Dec 20 20:35:09 EndeavourOS systemd[1]: Stopped Virtual Console Setup.
Dec 20 20:35:09 EndeavourOS kernel: Console: switching to colour frame buffer device 320x67
Dec 20 20:35:09 EndeavourOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=syste>
Dec 20 20:35:09 EndeavourOS systemd[1]: Stopping Virtual Console Setup...
Dec 20 20:35:09 EndeavourOS kernel: nouveau 0000:01:00.0: [drm] fb0: nouveaudrmfb frame buffer device
Dec 20 20:35:09 EndeavourOS kernel: audit: type=1131 audit(1766280909.042:60): pid=1 uid=0 auid=4294967295 se>
Dec 20 20:35:09 EndeavourOS systemd[1]: Starting Virtual Console Setup...
Dec 20 20:35:09 EndeavourOS kernel: nouveau 0000:01:00.0: drm: Disabling PCI power management to avoid bug
Dec 20 20:35:09 EndeavourOS systemd[1]: Finished Virtual Console Setup.
Dec 20 20:35:09 EndeavourOS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=syst>
Dec 20 20:35:09 EndeavourOS kernel: audit: type=1130 audit(1766280909.080:61): pid=1 uid=0 auid=4294967295 se>
Dec 20 20:35:29 EndeavourOS systemd[1]: Finished Rebuild Dynamic Linker Cache.
Dec 20 20:35:29 EndeavourOS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=ldco>
Dec 20 20:35:29 EndeavourOS kernel: audit: type=1130 audit(1766280929.753:62): pid=1 uid=0 auid=4294967295 se>
Dec 20 20:35:29 EndeavourOS systemd[1]: Starting Update is Completed...
Dec 20 20:35:29 EndeavourOS systemd[1]: Finished Update is Completed.
Dec 20 20:35:29 EndeavourOS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=syst>
Dec 20 20:35:29 EndeavourOS kernel: audit: type=1130 audit(1766280929.788:63): pid=1 uid=0 auid=4294967295 se>
Dec 20 20:35:29 EndeavourOS systemd[1]: Reached target System Initialization.
Dec 20 20:35:29 EndeavourOS systemd[1]: Started Refresh existing PGP keys of archlinux-keyring regularly.
Dec 20 20:35:29 EndeavourOS systemd[1]: Started Daily rotation of log files.
Dec 20 20:35:29 EndeavourOS systemd[1]: Started Daily man-db regeneration.
Dec 20 20:35:29 EndeavourOS systemd[1]: Started Update the plocate database daily.
Dec 20 20:35:29 EndeavourOS systemd[1]: Started Daily verification of password and group files.
Dec 20 20:35:29 EndeavourOS systemd[1]: Started Daily Cleanup of Temporary Directories.
Dec 20 20:35:29 EndeavourOS systemd[1]: Reached target Timer Units.
Dec 20 20:35:29 EndeavourOS systemd[1]: Listening on D-Bus System Message Bus Socket.
Dec 20 20:35:29 EndeavourOS systemd[1]: Listening on GnuPG network certificate management daemon for /etc/pac>
Dec 20 20:35:29 EndeavourOS systemd[1]: Listening on GnuPG cryptographic agent and passphrase cache (access f>
Dec 20 20:35:29 EndeavourOS systemd[1]: Listening on GnuPG cryptographic agent and passphrase cache (restrict>
Dec 20 20:35:29 EndeavourOS systemd[1]: Listening on GnuPG cryptographic agent (ssh-agent emulation) for /etc>
Dec 20 20:35:29 EndeavourOS systemd[1]: Listening on GnuPG cryptographic agent and passphrase cache for /etc/>
Dec 20 20:35:29 EndeavourOS systemd[1]: Listening on GnuPG public key management service for /etc/pacman.d/gn>
Dec 20 20:35:29 EndeavourOS systemd[1]: Listening on Activation socket for spice guest agent daemon.
Dec 20 20:35:29 EndeavourOS systemd[1]: Listening on OpenSSH Server Socket (systemd-ssh-generator, AF_UNIX Lo>
Dec 20 20:35:29 EndeavourOS systemd[1]: Listening on Hostname Service Socket.
Dec 20 20:35:29 EndeavourOS systemd[1]: Listening on User Login Management Varlink Socket.
Dec 20 20:35:29 EndeavourOS systemd[1]: Listening on Virtual Machine and Container Registration Service Socke>
Dec 20 20:35:29 EndeavourOS systemd[1]: Reached target Socket Units.
Dec 20 20:35:29 EndeavourOS audit: BPF prog-id=43 op=LOAD
Dec 20 20:35:29 EndeavourOS systemd[1]: Starting D-Bus System Message Bus...
Dec 20 20:35:29 EndeavourOS kernel: audit: type=1334 audit(1766280929.807:64): prog-id=43 op=LOAD
Dec 20 20:35:29 EndeavourOS systemd[1]: TPM PCR Barrier (Initialization) was skipped because of an unmet cond>
Dec 20 20:35:29 EndeavourOS systemd[1]: Started D-Bus System Message Bus.
Dec 20 20:35:29 EndeavourOS dbus-broker-launch[778]: Ready
Dec 20 20:35:29 EndeavourOS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=dbus>
Dec 20 20:35:29 EndeavourOS systemd[1]: Reached target Basic System.
Dec 20 20:35:29 EndeavourOS kernel: audit: type=1130 audit(1766280929.924:65): pid=1 uid=0 auid=4294967295 se>
Dec 20 20:35:29 EndeavourOS systemd[1]: Starting Save/Restore Sound Card State...
Dec 20 20:35:29 EndeavourOS systemd[1]: Manage Sound Card State (restore and store) was skipped because of an>
Dec 20 20:35:29 EndeavourOS systemd[1]: Bluetooth service was skipped because of an unmet condition check (Co>
Dec 20 20:35:29 EndeavourOS systemd[1]: Starting Restore /run/initramfs on shutdown...
Dec 20 20:35:29 EndeavourOS audit: BPF prog-id=44 op=LOAD
Dec 20 20:35:29 EndeavourOS kernel: audit: type=1334 audit(1766280929.927:66): prog-id=44 op=LOAD
Dec 20 20:35:29 EndeavourOS alsactl[780]: /usr/bin/alsactl: load_state:1715: Cannot open /var/lib/alsa/asound>
Dec 20 20:35:29 EndeavourOS systemd[1]: Starting firewalld - dynamic firewall daemon...
Dec 20 20:35:29 EndeavourOS alsactl[780]: Found hardware: "HDA-Intel" "Realtek ALC892" "HDA:10ec0892,14629b48>
Dec 20 20:35:29 EndeavourOS alsactl[780]: Hardware is initialized using a generic method
Dec 20 20:35:29 EndeavourOS audit: BPF prog-id=45 op=LOAD
Dec 20 20:35:29 EndeavourOS alsactl[780]: Found hardware: "HDA-Intel" "Nvidia GPU 83 HDMI/DP" "HDA:10de0083,1>
Dec 20 20:35:29 EndeavourOS systemd[1]: Starting Home Area Manager...
Dec 20 20:35:29 EndeavourOS kernel: audit: type=1334 audit(1766280929.955:67): prog-id=45 op=LOAD
Dec 20 20:35:29 EndeavourOS alsactl[780]: Found hardware: "USB-Audio" "USB Mixer" "USB1038:12aa" "" ""
Dec 20 20:35:29 EndeavourOS alsactl[780]: Found hardware: "USB-Audio" "USB Mixer" "USB0c76:161e" "" ""
Dec 20 20:35:29 EndeavourOS audit: BPF prog-id=46 op=LOAD
Dec 20 20:35:29 EndeavourOS audit: BPF prog-id=47 op=LOAD
Dec 20 20:35:29 EndeavourOS audit: BPF prog-id=48 op=LOAD
Dec 20 20:35:29 EndeavourOS kernel: audit: type=1334 audit(1766280929.957:68): prog-id=46 op=LOAD
Dec 20 20:35:29 EndeavourOS kernel: audit: type=1334 audit(1766280929.957:69): prog-id=47 op=LOAD
Dec 20 20:35:29 EndeavourOS kernel: audit: type=1334 audit(1766280929.957:70): prog-id=48 op=LOAD
Dec 20 20:35:29 EndeavourOS systemd[1]: Starting User Login Management...
Dec 20 20:35:29 EndeavourOS systemd[1]: TPM PCR Barrier (User) was skipped because of an unmet condition chec>
Dec 20 20:35:29 EndeavourOS systemd[1]: VirtualBox Guest Service was skipped because of an unmet condition ch>
Dec 20 20:35:29 EndeavourOS systemd[1]: Open Virtual Machine Tools (VMware Tools) was skipped because of an u>
Dec 20 20:35:29 EndeavourOS systemd[1]: Open Virtual Machine Tools (vmware-vmblock-fuse) was skipped because >
Dec 20 20:35:29 EndeavourOS systemd[1]: Finished Save/Restore Sound Card State.
Dec 20 20:35:29 EndeavourOS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=alsa>
Dec 20 20:35:29 EndeavourOS systemd[1]: Reached target Sound Card.
Dec 20 20:35:29 EndeavourOS kernel: audit: type=1130 audit(1766280929.960:71): pid=1 uid=0 auid=4294967295 se>
Dec 20 20:35:29 EndeavourOS systemd[1]: Finished Restore /run/initramfs on shutdown.
Dec 20 20:35:29 EndeavourOS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=drac>
Dec 20 20:35:30 EndeavourOS systemd-homed[783]: Watching /home.
Dec 20 20:35:30 EndeavourOS systemd-logind[784]: New seat seat0.
Dec 20 20:35:30 EndeavourOS systemd-logind[784]: Watching system buttons on /dev/input/event2 (Power Button)
Dec 20 20:35:30 EndeavourOS systemd-logind[784]: Watching system buttons on /dev/input/event1 (Power Button)
Dec 20 20:35:30 EndeavourOS systemd-logind[784]: Watching system buttons on /dev/input/event0 (Sleep Button)
Dec 20 20:35:30 EndeavourOS systemd-logind[784]: Watching system buttons on /dev/input/event5 (Corsair CORSAI>
Dec 20 20:35:30 EndeavourOS systemd-logind[784]: Watching system buttons on /dev/input/event8 (Corsair CORSAI>
Dec 20 20:35:30 EndeavourOS systemd-logind[784]: Watching system buttons on /dev/input/event9 ( USB Keyboard)
Dec 20 20:35:30 EndeavourOS systemd-logind[784]: Watching system buttons on /dev/input/event10 ( USB Keyboar>
Dec 20 20:35:30 EndeavourOS systemd[1]: Started Home Area Manager.
Dec 20 20:35:30 EndeavourOS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=syst>
Dec 20 20:35:30 EndeavourOS systemd[1]: Finished Home Area Activation.
Dec 20 20:35:30 EndeavourOS systemd[1]: Started User Login Management.
Dec 20 20:35:33 EndeavourOS audit[782]: NETFILTER_CFG table=firewalld_probe:2 family=1 entries=1 op=nft_regis>
Dec 20 20:35:33 EndeavourOS audit[782]: SYSCALL arch=c000003e syscall=46 success=yes exit=88 a0=4 a1=7ffd3d09>
Dec 20 20:35:33 EndeavourOS audit: PROCTITLE proctitle=2F7573722F62696E2F707974686F6E002F7573722F62696E2F6669>
Dec 20 20:35:33 EndeavourOS audit[782]: NETFILTER_CFG table=firewalld_probe:3 family=1 entries=1 op=nft_unreg>
Dec 20 20:35:33 EndeavourOS audit[782]: SYSCALL arch=c000003e syscall=46 success=yes exit=80 a0=4 a1=7ffd3d09>
Dec 20 20:35:33 EndeavourOS audit[782]: NETFILTER_CFG table=firewalld:4 family=1 entries=1 op=nft_register_ta>
Dec 20 20:35:33 EndeavourOS audit[782]: NETFILTER_CFG table=firewalld:4 family=1 entries=2 op=nft_unregister_>
Dec 20 20:35:33 EndeavourOS audit[782]: SYSCALL arch=c000003e syscall=46 success=yes exit=164 a0=4 a1=7ffd3d0>
Dec 20 20:35:33 EndeavourOS audit[782]: NETFILTER_CFG table=firewalld:5 family=1 entries=230 op=nft_register_>
Dec 20 20:35:33 EndeavourOS audit[782]: SYSCALL arch=c000003e syscall=46 success=yes exit=26192 a0=4 a1=7ffd3>
Dec 20 20:35:34 EndeavourOS audit[782]: NETFILTER_CFG table=firewalld_policy_drop:6 family=1 entries=2 op=nft>
Dec 20 20:35:34 EndeavourOS audit[782]: SYSCALL arch=c000003e syscall=46 success=yes exit=144 a0=4 a1=7ffd3d0>
Dec 20 20:35:34 EndeavourOS audit: PROCTITLE proctitle=2F7573722F62696E2F707974686F6E002F7573722F62696E2F6669>
Dec 20 20:35:34 EndeavourOS systemd[1]: Started firewalld - dynamic firewall daemon.
Dec 20 20:35:34 EndeavourOS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=fire>
Dec 20 20:35:34 EndeavourOS systemd[1]: Reached target Preparation for Network.
Dec 20 20:35:34 EndeavourOS systemd[1]: Starting Network Manager...
Dec 20 20:35:34 EndeavourOS audit: BPF prog-id=49 op=LOAD
Dec 20 20:35:34 EndeavourOS systemd[1]: Starting Network Configuration...
Dec 20 20:35:34 EndeavourOS audit: BPF prog-id=50 op=LOAD
Dec 20 20:35:34 EndeavourOS systemd[1]: Starting Authorization Manager...
Dec 20 20:35:34 EndeavourOS polkitd[883]: Started polkitd version 126
Dec 20 20:35:34 EndeavourOS systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Dec 20 20:35:34 EndeavourOS polkitd[883]: Loading rules from directory /etc/polkit-1/rules.d
Dec 20 20:35:34 EndeavourOS polkitd[883]: Loading rules from directory /run/polkit-1/rules.d
Dec 20 20:35:34 EndeavourOS polkitd[883]: Error opening rules directory: Error opening directory “/run/polkit>
Dec 20 20:35:34 EndeavourOS polkitd[883]: Loading rules from directory /usr/local/share/polkit-1/rules.d
Dec 20 20:35:34 EndeavourOS polkitd[883]: Error opening rules directory: Error opening directory “/usr/local/>
Dec 20 20:35:34 EndeavourOS polkitd[883]: Loading rules from directory /usr/share/polkit-1/rules.d
Dec 20 20:35:34 EndeavourOS kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
Dec 20 20:35:34 EndeavourOS polkitd[883]: Finished loading, compiling and executing 3 rules
Dec 20 20:35:34 EndeavourOS systemd[1]: Started Authorization Manager.
Dec 20 20:35:34 EndeavourOS polkitd[883]: Acquired the name org.freedesktop.PolicyKit1 on the system bus
Dec 20 20:35:34 EndeavourOS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=polk>
Dec 20 20:35:34 EndeavourOS NetworkManager[881]: <info> [1766280934.4141] NetworkManager (version 1.54.2-1) >
Dec 20 20:35:34 EndeavourOS NetworkManager[881]: <info> [1766280934.4142] Read config: /etc/NetworkManager/N>
Dec 20 20:35:34 EndeavourOS kernel: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
Dec 20 20:35:34 EndeavourOS kernel: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
Dec 20 20:35:34 EndeavourOS NetworkManager[881]: <info> [1766280934.4183] manager[0x55edbfe72a30]: monitorin>
Dec 20 20:35:34 EndeavourOS audit: BPF prog-id=51 op=LOAD
Dec 20 20:35:34 EndeavourOS audit: BPF prog-id=52 op=LOAD
Dec 20 20:35:34 EndeavourOS audit: BPF prog-id=53 op=LOAD
Dec 20 20:35:34 EndeavourOS systemd[1]: Starting Hostname Service...
Dec 20 20:35:34 EndeavourOS systemd[1]: Started Hostname Service.
Dec 20 20:35:34 EndeavourOS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=syst>
Dec 20 20:35:34 EndeavourOS NetworkManager[881]: <info> [1766280934.5425] hostname: hostname: using hostnamed
Dec 20 20:35:34 EndeavourOS NetworkManager[881]: <info> [1766280934.5425] hostname: static hostname changed >
Dec 20 20:35:34 EndeavourOS NetworkManager[881]: <info> [1766280934.5427] dns-mgr: init: dns=default,systemd>
Dec 20 20:35:34 EndeavourOS NetworkManager[881]: <info> [1766280934.5428] manager[0x55edbfe72a30]: rfkill: W>
Dec 20 20:35:34 EndeavourOS NetworkManager[881]: <info> [1766280934.5429] manager[0x55edbfe72a30]: rfkill: W>
Dec 20 20:35:34 EndeavourOS (udev-worker)[888]: cfg80211: Process '/usr/bin/set-wireless-regdom' failed with >
Dec 20 20:35:34 EndeavourOS systemd-networkd[882]: lo: Link UP
Dec 20 20:35:34 EndeavourOS systemd-networkd[882]: lo: Gained carrier
Dec 20 20:35:34 EndeavourOS audit: BPF prog-id=54 op=LOAD
Dec 20 20:35:34 EndeavourOS audit[882]: SYSCALL arch=c000003e syscall=321 success=yes exit=23 a0=5 a1=7ffc8af>
Dec 20 20:35:34 EndeavourOS audit: PROCTITLE proctitle="/usr/lib/systemd/systemd-networkd"
Dec 20 20:35:34 EndeavourOS audit: BPF prog-id=54 op=UNLOAD
Dec 20 20:35:34 EndeavourOS audit[882]: SYSCALL arch=c000003e syscall=3 success=yes exit=0 a0=17 a1=0 a2=0 a3>
Dec 20 20:35:34 EndeavourOS audit: BPF prog-id=55 op=LOAD
Dec 20 20:35:34 EndeavourOS audit: BPF prog-id=55 op=UNLOAD
Dec 20 20:35:34 EndeavourOS audit: BPF prog-id=56 op=LOAD
Dec 20 20:35:34 EndeavourOS audit: BPF prog-id=56 op=UNLOAD
Dec 20 20:35:34 EndeavourOS audit: BPF prog-id=57 op=LOAD
Dec 20 20:35:34 EndeavourOS audit[882]: SYSCALL arch=c000003e syscall=321 success=yes exit=24 a0=5 a1=7ffc8af>
Dec 20 20:35:34 EndeavourOS audit: BPF prog-id=57 op=UNLOAD
Dec 20 20:35:34 EndeavourOS audit[882]: SYSCALL arch=c000003e syscall=3 success=yes exit=0 a0=18 a1=0 a2=0 a3>
Dec 20 20:35:34 EndeavourOS audit: BPF prog-id=58 op=LOAD
Dec 20 20:35:34 EndeavourOS audit[882]: SYSCALL arch=c000003e syscall=321 success=yes exit=25 a0=5 a1=7ffc8af>
Dec 20 20:35:34 EndeavourOS audit: BPF prog-id=58 op=UNLOAD
Dec 20 20:35:34 EndeavourOS audit[882]: SYSCALL arch=c000003e syscall=3 success=yes exit=0 a0=19 a1=0 a2=0 a3>
Dec 20 20:35:34 EndeavourOS NetworkManager[881]: <info> [1766280934.6097] Loaded device plugin: NMAtmManager>
Dec 20 20:35:34 EndeavourOS audit: BPF prog-id=59 op=LOAD
Dec 20 20:35:34 EndeavourOS audit: BPF prog-id=60 op=LOAD
Dec 20 20:35:34 EndeavourOS audit[882]: SYSCALL arch=c000003e syscall=321 success=yes exit=26 a0=5 a1=7ffc8af>
Dec 20 20:35:34 EndeavourOS audit: BPF prog-id=60 op=UNLOAD
Dec 20 20:35:34 EndeavourOS audit[882]: SYSCALL arch=c000003e syscall=3 success=yes exit=0 a0=1a a1=0 a2=0 a3>
Dec 20 20:35:34 EndeavourOS systemd[1]: Started Network Configuration.
Dec 20 20:35:34 EndeavourOS systemd[1]: Starting Enable Persistent Storage in systemd-networkd...
Dec 20 20:35:34 EndeavourOS NetworkManager[881]: <info> [1766280934.6273] Loaded device plugin: NMBluezManag>
Dec 20 20:35:34 EndeavourOS NetworkManager[881]: <info> [1766280934.6277] Loaded device plugin: NMOvsFactory>
Dec 20 20:35:34 EndeavourOS systemd[1]: Finished Enable Persistent Storage in systemd-networkd.
Dec 20 20:35:34 EndeavourOS NetworkManager[881]: <info> [1766280934.6897] Loaded device plugin: NMTeamFactor>
Dec 20 20:35:34 EndeavourOS NetworkManager[881]: <info> [1766280934.6900] Loaded device plugin: NMWifiFactor>
Dec 20 20:35:34 EndeavourOS NetworkManager[881]: <info> [1766280934.6903] Loaded device plugin: NMWwanFactor>
Dec 20 20:35:34 EndeavourOS NetworkManager[881]: <info> [1766280934.6905] manager: rfkill: Wi-Fi enabled by >
Dec 20 20:35:34 EndeavourOS NetworkManager[881]: <info> [1766280934.6905] manager: rfkill: WWAN enabled by r>
Dec 20 20:35:34 EndeavourOS NetworkManager[881]: <info> [1766280934.6905] manager: Networking is enabled by >
Dec 20 20:35:34 EndeavourOS NetworkManager[881]: <info> [1766280934.6906] settings: Loaded settings plugin: >
Dec 20 20:35:34 EndeavourOS dbus-broker-launch[778]: Activation request for 'org.freedesktop.nm_dispatcher' f>
Dec 20 20:35:34 EndeavourOS NetworkManager[881]: <info> [1766280934.6920] dhcp: init: Using DHCP client 'int>
Dec 20 20:35:34 EndeavourOS NetworkManager[881]: <info> [1766280934.6921] manager: (lo): new Loopback device>
Dec 20 20:35:34 EndeavourOS NetworkManager[881]: <info> [1766280934.6929] device (lo): state change: unmanag>
Dec 20 20:35:34 EndeavourOS NetworkManager[881]: <info> [1766280934.6930] device (lo): state change: unavail>
Dec 20 20:35:34 EndeavourOS NetworkManager[881]: <info> [1766280934.6933] device (lo): Activation: starting >
Dec 20 20:35:34 EndeavourOS NetworkManager[881]: <info> [1766280934.6938] manager: (enp3s0): new Ethernet de>
Dec 20 20:35:34 EndeavourOS NetworkManager[881]: <info> [1766280934.6943] settings: (enp3s0): created defaul>
Dec 20 20:35:34 EndeavourOS NetworkManager[881]: <info> [1766280934.6943] device (enp3s0): state change: unm>
Dec 20 20:35:34 EndeavourOS kernel: Generic FE-GE Realtek PHY r8169-0-300:00: attached PHY driver (mii_bus:ph>
Dec 20 20:35:34 EndeavourOS systemd-networkd[882]: enp3s0: Link UP
Dec 20 20:35:34 EndeavourOS kernel: r8169 0000:03:00.0 enp3s0: Link is Down
Dec 20 20:35:34 EndeavourOS systemd[1]: Started Network Manager.
Dec 20 20:35:34 EndeavourOS NetworkManager[881]: <info> [1766280934.9818] bus-manager: acquired D-Bus servic>
Dec 20 20:35:34 EndeavourOS NetworkManager[881]: <info> [1766280934.9824] ovsdb: disconnected from ovsdb
Dec 20 20:35:34 EndeavourOS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=Netw>
Dec 20 20:35:34 EndeavourOS NetworkManager[881]: <info> [1766280934.9825] device (lo): state change: disconn>
Dec 20 20:35:34 EndeavourOS NetworkManager[881]: <info> [1766280934.9826] device (lo): state change: prepare>
Dec 20 20:35:34 EndeavourOS NetworkManager[881]: <info> [1766280934.9827] device (lo): state change: config >
Dec 20 20:35:34 EndeavourOS systemd[1]: Reached target Network.
Dec 20 20:35:34 EndeavourOS NetworkManager[881]: <info> [1766280934.9830] device (lo): state change: ip-conf>
Dec 20 20:35:34 EndeavourOS kernel: kauditd_printk_skb: 69 callbacks suppressed
Dec 20 20:35:34 EndeavourOS kernel: audit: type=1130 audit(1766280934.980:104): pid=1 uid=0 auid=4294967295 s>
Dec 20 20:35:34 EndeavourOS systemd[1]: Starting Permit User Sessions...
Dec 20 20:35:34 EndeavourOS NetworkManager[881]: <info> [1766280934.9859] device (lo): state change: ip-chec>
Dec 20 20:35:34 EndeavourOS NetworkManager[881]: <info> [1766280934.9860] device (lo): state change: seconda>
Dec 20 20:35:34 EndeavourOS NetworkManager[881]: <info> [1766280934.9863] device (lo): Activation: successfu>
Dec 20 20:35:35 EndeavourOS systemd[1]: Finished Permit User Sessions.
Dec 20 20:35:35 EndeavourOS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=syst>
Dec 20 20:35:35 EndeavourOS kernel: audit: type=1130 audit(1766280935.017:105): pid=1 uid=0 auid=4294967295 s>
Dec 20 20:35:35 EndeavourOS systemd[1]: Started Getty on tty1.
Dec 20 20:35:35 EndeavourOS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=gett>
Dec 20 20:35:35 EndeavourOS systemd[1]: Reached target Login Prompts.
Dec 20 20:35:35 EndeavourOS kernel: audit: type=1130 audit(1766280935.019:106): pid=1 uid=0 auid=4294967295 s>
Dec 20 20:35:35 EndeavourOS systemd[1]: Reached target Multi-User System.
Dec 20 20:35:35 EndeavourOS systemd[1]: Startup finished in 16.018s (firmware) + 33.019s (loader) + 5.497s (k>
Dec 20 20:35:35 EndeavourOS audit[913]: AUDIT1101 pid=913 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:ac>
Dec 20 20:35:35 EndeavourOS kernel: audit: type=1101 audit(1766280935.267:107): pid=913 uid=0 auid=4294967295>
Dec 20 20:35:35 EndeavourOS audit[913]: AUDIT1103 pid=913 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:se>
Dec 20 20:35:35 EndeavourOS audit[913]: SYSCALL arch=c000003e syscall=1 success=yes exit=4 a0=5 a1=7fff5d24ed>
Dec 20 20:35:35 EndeavourOS audit: PROCTITLE proctitle=2F62696E2F6C6F67696E002D70002D66002D2D
Dec 20 20:35:35 EndeavourOS kernel: audit: type=1103 audit(1766280935.294:108): pid=913 uid=0 auid=4294967295>
Dec 20 20:35:35 EndeavourOS kernel: audit: type=1006 audit(1766280935.294:109): pid=913 uid=0 old-auid=429496>
Dec 20 20:35:35 EndeavourOS kernel: audit: type=1300 audit(1766280935.294:109): arch=c000003e syscall=1 succe>
Dec 20 20:35:35 EndeavourOS kernel: audit: type=1327 audit(1766280935.294:109): proctitle=2F62696E2F6C6F67696>
Dec 20 20:35:35 EndeavourOS login[913]: pam_unix(login:session): session opened for user liveuser(uid=1000) b>
Dec 20 20:35:35 EndeavourOS systemd-logind[784]: New session '1' of user 'liveuser' with class 'user' and typ>
Dec 20 20:35:35 EndeavourOS systemd[1]: Created slice User Slice of UID 1000.
Dec 20 20:35:35 EndeavourOS systemd[1]: Starting User Runtime Directory /run/user/1000...
Dec 20 20:35:35 EndeavourOS systemd-user-runtime-dir[921]: Successfully configured disk quota for UID 1000 on>
Dec 20 20:35:35 EndeavourOS systemd[1]: Finished User Runtime Directory /run/user/1000.
Dec 20 20:35:35 EndeavourOS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user>
Dec 20 20:35:35 EndeavourOS kernel: audit: type=1130 audit(1766280935.364:110): pid=1 uid=0 auid=4294967295 s>
Dec 20 20:35:35 EndeavourOS systemd[1]: Starting User Manager for UID 1000...
Dec 20 20:35:35 EndeavourOS audit[951]: AUDIT1101 pid=951 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:ac>
Dec 20 20:35:35 EndeavourOS audit[951]: AUDIT1103 pid=951 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:se>
Dec 20 20:35:35 EndeavourOS (systemd)[951]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0>
Dec 20 20:35:35 EndeavourOS audit[951]: SYSCALL arch=c000003e syscall=1 success=yes exit=4 a0=a a1=7fff713ec6>
Dec 20 20:35:35 EndeavourOS audit: PROCTITLE proctitle="(systemd)"
Dec 20 20:35:35 EndeavourOS (systemd)[951]: pam_unix(systemd-user:session): session opened for user liveuser(>
Dec 20 20:35:35 EndeavourOS kernel: audit: type=1101 audit(1766280935.389:111): pid=951 uid=0 auid=4294967295>
Dec 20 20:35:35 EndeavourOS systemd-logind[784]: New session '2' of user 'liveuser' with class 'manager' and >
Dec 20 20:35:35 EndeavourOS audit[951]: AUDIT1105 pid=951 uid=0 auid=1000 ses=2 msg='op=PAM:session_open gran>
Dec 20 20:35:35 EndeavourOS systemd-xdg-autostart-generator[957]: Configuration file /home/liveuser/.config/a>
Dec 20 20:35:35 EndeavourOS systemd[951]: Queued start job for default target Main User Target.
Dec 20 20:35:35 EndeavourOS systemd[951]: Created slice User Application Slice.
Dec 20 20:35:35 EndeavourOS systemd[951]: Reached target Paths.
Dec 20 20:35:35 EndeavourOS systemd[951]: Reached target Timers.
Dec 20 20:35:35 EndeavourOS systemd[951]: Starting D-Bus User Message Bus Socket...
Dec 20 20:35:35 EndeavourOS systemd[951]: Listening on GnuPG network certificate management daemon.
Dec 20 20:35:35 EndeavourOS systemd[951]: Listening on GnuPG cryptographic agent and passphrase cache (access>
Dec 20 20:35:35 EndeavourOS systemd[951]: Listening on GnuPG cryptographic agent and passphrase cache (restri>
Dec 20 20:35:35 EndeavourOS systemd[951]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Dec 20 20:35:35 EndeavourOS systemd[951]: Listening on GnuPG cryptographic agent and passphrase cache.
Dec 20 20:35:35 EndeavourOS systemd[951]: Listening on GnuPG public key management service.
Dec 20 20:35:35 EndeavourOS systemd[951]: Listening on p11-kit server.
Dec 20 20:35:35 EndeavourOS systemd[951]: Listening on PipeWire PulseAudio.
Dec 20 20:35:35 EndeavourOS systemd[951]: Listening on PipeWire Multimedia System Sockets.
Dec 20 20:35:35 EndeavourOS systemd[951]: Listening on Query the User Interactively for a Password.
Dec 20 20:35:35 EndeavourOS systemd[951]: Listening on D-Bus User Message Bus Socket.
Dec 20 20:35:35 EndeavourOS systemd[951]: Reached target Sockets.
Dec 20 20:35:35 EndeavourOS systemd[951]: Reached target Basic System.
Dec 20 20:35:35 EndeavourOS systemd[951]: Reached target Main User Target.
Dec 20 20:35:35 EndeavourOS systemd[951]: Startup finished in 317ms.
Dec 20 20:35:35 EndeavourOS systemd[1]: Started User Manager for UID 1000.
Dec 20 20:35:35 EndeavourOS systemd[1]: Started Session 1 of User liveuser.
Dec 20 20:35:35 EndeavourOS audit[913]: AUDIT1105 pid=913 uid=0 auid=1000 ses=1 msg='op=PAM:session_open gran>
Dec 20 20:35:35 EndeavourOS audit[913]: AUDIT1110 pid=913 uid=0 auid=1000 ses=1 msg='op=PAM:setcred grantors=>
Dec 20 20:35:35 EndeavourOS login[913]: LOGIN ON tty1 BY liveuser
Dec 20 20:35:37 EndeavourOS systemd-networkd[882]: enp3s0: Gained carrier
Dec 20 20:35:37 EndeavourOS NetworkManager[881]: <info> [1766280937.7455] device (enp3s0): carrier: link con>
Dec 20 20:35:37 EndeavourOS kernel: r8169 0000:03:00.0 enp3s0: Link is Up - 1Gbps/Full - flow control rx/tx
Dec 20 20:35:37 EndeavourOS NetworkManager[881]: <info> [1766280937.7458] device (enp3s0): state change: una>
Dec 20 20:35:37 EndeavourOS NetworkManager[881]: <info> [1766280937.7464] policy: auto-activating connection>
Dec 20 20:35:37 EndeavourOS NetworkManager[881]: <info> [1766280937.7468] device (enp3s0): Activation: start>
Dec 20 20:35:37 EndeavourOS NetworkManager[881]: <info> [1766280937.7469] device (enp3s0): state change: dis>
Dec 20 20:35:37 EndeavourOS NetworkManager[881]: <info> [1766280937.7472] manager: NetworkManager state is n>
Dec 20 20:35:37 EndeavourOS NetworkManager[881]: <info> [1766280937.7473] device (enp3s0): state change: pre>
Dec 20 20:35:37 EndeavourOS audit[782]: NETFILTER_CFG table=firewalld:7 family=1 entries=26 op=nft_register_r>
Dec 20 20:35:37 EndeavourOS audit[782]: SYSCALL arch=c000003e syscall=46 success=yes exit=6252 a0=4 a1=7ffd3d>
Dec 20 20:35:37 EndeavourOS audit: PROCTITLE proctitle=2F7573722F62696E2F707974686F6E002F7573722F62696E2F6669>
Dec 20 20:35:37 EndeavourOS NetworkManager[881]: <info> [1766280937.9026] device (enp3s0): state change: con>
Dec 20 20:35:37 EndeavourOS NetworkManager[881]: <info> [1766280937.9030] dhcp4 (enp3s0): activation: beginn>
Dec 20 20:35:38 EndeavourOS NetworkManager[881]: <info> [1766280938.2696] dhcp4 (enp3s0): state changed new >
Dec 20 20:35:38 EndeavourOS NetworkManager[881]: <info> [1766280938.3896] dhcp4 (enp3s0): state changed new >
Dec 20 20:35:38 EndeavourOS NetworkManager[881]: <info> [1766280938.3903] policy: set 'Wired connection 1' (>
Dec 20 20:35:38 EndeavourOS systemd-timesyncd[599]: Network configuration changed, trying to establish connec>
Dec 20 20:35:38 EndeavourOS systemd-resolved[598]: enp3s0: Bus client set default route setting: yes
Dec 20 20:35:38 EndeavourOS systemd-resolved[598]: enp3s0: Bus client set DNS server list to: 192.168.1.1
Dec 20 20:35:38 EndeavourOS NetworkManager[881]: <info> [1766280938.4039] device (enp3s0): state change: ip->
Dec 20 20:35:38 EndeavourOS NetworkManager[881]: <info> [1766280938.4053] device (enp3s0): state change: ip->
Dec 20 20:35:38 EndeavourOS NetworkManager[881]: <info> [1766280938.4054] device (enp3s0): state change: sec>
Dec 20 20:35:38 EndeavourOS NetworkManager[881]: <info> [1766280938.4057] manager: NetworkManager state is n>
Dec 20 20:35:38 EndeavourOS NetworkManager[881]: <info> [1766280938.4059] device (enp3s0): Activation: succe>
Dec 20 20:35:38 EndeavourOS NetworkManager[881]: <info> [1766280938.4063] manager: startup complete
Dec 20 20:35:38 EndeavourOS NetworkManager[881]: <info> [1766280938.6770] manager: NetworkManager state is n>
Dec 20 20:35:39 EndeavourOS systemd-networkd[882]: enp3s0: Gained IPv6LL
Dec 20 20:35:40 EndeavourOS systemd-timesyncd[599]: Contacted time server 209.177.158.85:123 (3.arch.pool.ntp>
Dec 20 20:35:40 EndeavourOS systemd-timesyncd[599]: Initial clock synchronization to Sun 2025-12-21 01:35:40.>
Dec 20 20:36:01 EndeavourOS systemd[951]: Created slice User Core Session Slice.
Dec 20 20:36:01 EndeavourOS systemd[951]: Starting D-Bus User Message Bus...
Dec 20 20:36:01 EndeavourOS dbus-broker-launch[1021]: Service file '/usr/share/dbus-1/services/org.kde.dolphi>
Dec 20 20:36:01 EndeavourOS dbus-broker-launch[1021]: Service file '/usr/share/dbus-1/services/org.kde.kscree>
Dec 20 20:36:01 EndeavourOS dbus-broker-launch[1021]: Service file '/usr/share/dbus-1/services/org.kde.plasma>
Dec 20 20:36:01 EndeavourOS dbus-broker-launch[1021]: Policy to allow eavesdropping in /usr/share/dbus-1/sess>
Dec 20 20:36:01 EndeavourOS systemd[951]: Started D-Bus User Message Bus.
Dec 20 20:36:01 EndeavourOS dbus-broker-launch[1021]: Ready
Dec 20 20:36:02 EndeavourOS systemd[951]: Reload requested from client PID 1017 ('startplasma-x11')...
Dec 20 20:36:02 EndeavourOS systemd[951]: Reloading...
Dec 20 20:36:02 EndeavourOS systemd-xdg-autostart-generator[1029]: Configuration file /home/liveuser/.config/>
Dec 20 20:36:02 EndeavourOS systemd[951]: Reloading finished in 151 ms.
Dec 20 20:36:02 EndeavourOS systemd[951]: Created slice Slice /app/dbus-:1.2-org.kde.KSplash.
Dec 20 20:36:02 EndeavourOS systemd[951]: Started dbus-:1.2-org.kde.KSplash@0.service.
Dec 20 20:36:02 EndeavourOS systemd[951]: /run/user/1000/systemd/generator.late/app-broadcom\x2dwl@autostart.>
Dec 20 20:36:02 EndeavourOS systemd[951]: Created slice User Background Tasks Slice.
Dec 20 20:36:02 EndeavourOS systemd[951]: Starting KDE Config Module Initialization...
Dec 20 20:36:02 EndeavourOS systemd[951]: Starting KDE Global Shortcuts Server...
Dec 20 20:36:02 EndeavourOS systemd[951]: Starting User folders update...
Dec 20 20:36:02 EndeavourOS systemd[951]: Starting Baloo File Indexer Daemon...
Dec 20 20:36:02 EndeavourOS systemd[951]: kde-baloo.service: Skipped due to 'exec-condition'.
Dec 20 20:36:02 EndeavourOS systemd[951]: Condition check resulted in Baloo File Indexer Daemon being skipped.
Dec 20 20:36:02 EndeavourOS systemd[951]: Finished User folders update.
Dec 20 20:36:02 EndeavourOS systemd[951]: Reached target Session services which should run early before the g>
Dec 20 20:36:02 EndeavourOS systemd[951]: Starting Portal service...
Dec 20 20:36:02 EndeavourOS systemd[951]: Started KDE Global Shortcuts Server.
Dec 20 20:36:02 EndeavourOS kcminit_startup[1036]: Initializing "/usr/lib/qt6/plugins/plasma/kcms/systemsett>
Dec 20 20:36:02 EndeavourOS systemd[951]: Starting sandboxed app permission store...
Dec 20 20:36:03 EndeavourOS systemd[951]: Started sandboxed app permission store.
Dec 20 20:36:03 EndeavourOS systemd[951]: Starting flatpak document portal service...
Dec 20 20:36:03 EndeavourOS systemd[951]: Started KDE Config Module Initialization.
Dec 20 20:36:03 EndeavourOS systemd[951]: Starting KDE Session Management Server...
Dec 20 20:36:03 EndeavourOS systemd[951]: Started Unlock kwallet from pam credentials.
Dec 20 20:36:03 EndeavourOS systemd[951]: Starting KDE Daemon 6...
Dec 20 20:36:03 EndeavourOS systemd[951]: Starting KDE Window Manager...
Dec 20 20:36:03 EndeavourOS systemd[951]: Started flatpak document portal service.
Dec 20 20:36:03 EndeavourOS /usr/lib/xdg-desktop-portal[1043]: Choosing gtk.portal for org.freedesktop.impl.p>
Dec 20 20:36:03 EndeavourOS systemd[951]: Started KDE Session Management Server.
Dec 20 20:36:03 EndeavourOS systemd[951]: Starting KDE Plasma Workspace...
Dec 20 20:36:03 EndeavourOS systemd[951]: Started KDE Daemon 6.
Dec 20 20:36:03 EndeavourOS systemd[951]: Starting KDE Configuration Module Initialization (Phase 1)...
Dec 20 20:36:03 EndeavourOS kcminit_startup[1036]: Initializing "/usr/lib/qt6/plugins/plasma/kcms/systemsett>
Dec 20 20:36:03 EndeavourOS systemd[951]: Started PipeWire Multimedia Service.
Dec 20 20:36:03 EndeavourOS systemd[951]: Started Multimedia Service Session Manager.
Dec 20 20:36:03 EndeavourOS systemd[951]: Started PipeWire PulseAudio.
Dec 20 20:36:03 EndeavourOS kcminit_startup[1036]: Using X11 backend
Dec 20 20:36:03 EndeavourOS systemd[951]: Finished KDE Configuration Module Initialization (Phase 1).
Dec 20 20:36:04 EndeavourOS systemd[951]: Starting KActivityManager Activity manager Service...
Dec 20 20:36:04 EndeavourOS systemd[1]: Starting RealtimeKit Scheduling Policy Service...
Dec 20 20:36:04 EndeavourOS systemd[1]: Started RealtimeKit Scheduling Policy Service.
Dec 20 20:36:04 EndeavourOS rtkit-daemon[1099]: Successfully called chroot.
Dec 20 20:36:04 EndeavourOS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=rtki>
Dec 20 20:36:04 EndeavourOS rtkit-daemon[1099]: Successfully dropped privileges.
Dec 20 20:36:04 EndeavourOS kernel: kauditd_printk_skb: 11 callbacks suppressed
Dec 20 20:36:04 EndeavourOS rtkit-daemon[1099]: Successfully limited resources.
Dec 20 20:36:04 EndeavourOS kernel: audit: type=1130 audit(1766280964.299:119): pid=1 uid=0 auid=4294967295 s>
Dec 20 20:36:04 EndeavourOS rtkit-daemon[1099]: Canary thread running.
Dec 20 20:36:04 EndeavourOS rtkit-daemon[1099]: Running.
Dec 20 20:36:04 EndeavourOS rtkit-daemon[1099]: Watchdog thread running.
Dec 20 20:36:04 EndeavourOS rtkit-daemon[1099]: Supervising 0 threads of 0 processes of 0 users.
Dec 20 20:36:04 EndeavourOS rtkit-daemon[1099]: Successfully made thread 1090 of process 1090 owned by '1000'>
Dec 20 20:36:04 EndeavourOS rtkit-daemon[1099]: Supervising 1 threads of 1 processes of 1 users.
Dec 20 20:36:04 EndeavourOS rtkit-daemon[1099]: Successfully made thread 1088 of process 1088 owned by '1000'>
Dec 20 20:36:04 EndeavourOS rtkit-daemon[1099]: Supervising 2 threads of 2 processes of 1 users.
Dec 20 20:36:04 EndeavourOS rtkit-daemon[1099]: Successfully made thread 1089 of process 1089 owned by '1000'>
Dec 20 20:36:04 EndeavourOS rtkit-daemon[1099]: Supervising 3 threads of 3 processes of 1 users.
Dec 20 20:36:04 EndeavourOS systemd[951]: Started KDE Window Manager.
Dec 20 20:36:04 EndeavourOS rtkit-daemon[1099]: Successfully made thread 1107 of process 1090 owned by '1000'>
Dec 20 20:36:04 EndeavourOS rtkit-daemon[1099]: Supervising 4 threads of 3 processes of 1 users.
Dec 20 20:36:04 EndeavourOS systemd[951]: Started KActivityManager Activity manager Service.
Dec 20 20:36:04 EndeavourOS rtkit-daemon[1099]: Successfully made thread 1117 of process 1088 owned by '1000'>
Dec 20 20:36:04 EndeavourOS rtkit-daemon[1099]: Supervising 5 threads of 3 processes of 1 users.
Dec 20 20:36:04 EndeavourOS systemd[1]: systemd-hostnamed.service: Deactivated successfully.
Dec 20 20:36:04 EndeavourOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=syste>
Dec 20 20:36:04 EndeavourOS kernel: audit: type=1131 audit(1766280964.576:120): pid=1 uid=0 auid=4294967295 s>
Dec 20 20:36:04 EndeavourOS audit: BPF prog-id=51 op=UNLOAD
Dec 20 20:36:04 EndeavourOS kernel: audit: type=1334 audit(1766280964.602:121): prog-id=51 op=UNLOAD
Dec 20 20:36:04 EndeavourOS systemd[951]: Started KDE Plasma Workspace.
Dec 20 20:36:04 EndeavourOS systemd[951]: Reached target KDE Plasma Workspace Core.
Dec 20 20:36:04 EndeavourOS systemd[951]: Started Proxies GTK DBus menus to a Plasma readable format.
Dec 20 20:36:04 EndeavourOS systemd[951]: Started KAccess.
Dec 20 20:36:04 EndeavourOS systemd[951]: Starting KDE PolicyKit Authentication Agent...
Dec 20 20:36:04 EndeavourOS systemd[951]: Starting Powerdevil...
Dec 20 20:36:04 EndeavourOS systemd[951]: Started Handle legacy xembed system tray icons.
Dec 20 20:36:05 EndeavourOS org_kde_powerdevil[1127]: Starting libddcutil. library built Not set at Not set. >
Dec 20 20:36:05 EndeavourOS kaccess[1125]: Xlib XKB extension major= 1 minor= 0
Dec 20 20:36:05 EndeavourOS systemd[951]: Started KDE PolicyKit Authentication Agent.
Dec 20 20:36:05 EndeavourOS polkit-kde-authentication-agent-1[1126]: New PolkitAgentListener 0x5614ba8befc0
Dec 20 20:36:05 EndeavourOS polkit-kde-authentication-agent-1[1126]: Adding new listener PolkitQt1::Agent::L>
Dec 20 20:36:05 EndeavourOS polkit-kde-authentication-agent-1[1126]: Listener online
Dec 20 20:36:05 EndeavourOS polkitd[883]: Registered Authentication Agent for unix-session:1 (system bus name>
Dec 20 20:36:05 EndeavourOS polkit-kde-authentication-agent-1[1126]: Authentication agent result: true
Dec 20 20:36:05 EndeavourOS audit: BPF prog-id=61 op=LOAD
Dec 20 20:36:05 EndeavourOS audit: BPF prog-id=62 op=LOAD
Dec 20 20:36:05 EndeavourOS kernel: audit: type=1334 audit(1766280965.393:122): prog-id=61 op=LOAD
Dec 20 20:36:05 EndeavourOS kernel: audit: type=1334 audit(1766280965.393:123): prog-id=62 op=LOAD
Dec 20 20:36:05 EndeavourOS systemd[1]: Starting Daemon for power management...
Dec 20 20:36:05 EndeavourOS rtkit-daemon[1099]: Successfully made thread 1163 of process 1089 owned by '1000'>
Dec 20 20:36:05 EndeavourOS rtkit-daemon[1099]: Supervising 6 threads of 3 processes of 1 users.
Dec 20 20:36:05 EndeavourOS kaccess[1125]: X server XKB extension major= 1 minor= 0
Dec 20 20:36:05 EndeavourOS systemd[951]: Starting User preferences database...
Dec 20 20:36:05 EndeavourOS systemd[951]: Started User preferences database.
Dec 20 20:36:06 EndeavourOS wireplumber[1089]: wp-event-dispatcher: wp_event_dispatcher_unregister_hook: asse>
Dec 20 20:36:06 EndeavourOS systemd[1]: Started Daemon for power management.
Dec 20 20:36:06 EndeavourOS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=upow>
Dec 20 20:36:06 EndeavourOS kernel: audit: type=1130 audit(1766280966.011:124): pid=1 uid=0 auid=4294967295 s>
Dec 20 20:36:06 EndeavourOS org_kde_powerdevil[1127]: Failed to create wl_display (No such file or directory)
Dec 20 20:36:06 EndeavourOS systemd[1]: Starting Disk Manager...
Dec 20 20:36:06 EndeavourOS org_kde_powerdevil[1127]: Initializing libddcutil. ddcutil version: 2.2.3, share>
Dec 20 20:36:06 EndeavourOS org_kde_powerdevil[1127]: library built Not set at Not >
Dec 20 20:36:06 EndeavourOS org_kde_powerdevil[1127]: [ 1127] Options passed from client:
Dec 20 20:36:06 EndeavourOS org_kde_powerdevil[1127]: [ 1127] Applying combined libddcutil options:
Dec 20 20:36:06 EndeavourOS org_kde_powerdevil[1127]: [ 1127] Device /dev/i2c-15 lacks R/W permissions
Dec 20 20:36:06 EndeavourOS org_kde_powerdevil[1127]: [ 1127] Device /dev/i2c-16 lacks R/W permissions
Dec 20 20:36:06 EndeavourOS org_kde_powerdevil[1127]: [ 1127] Device /dev/i2c-17 lacks R/W permissions
Dec 20 20:36:06 EndeavourOS kernel: nvme nvme0: using unchecked data buffer
Dec 20 20:36:06 EndeavourOS kernel: block nvme0n1: No UUID available providing old NGUID
Dec 20 20:36:06 EndeavourOS systemd[1]: Started Disk Manager.
Dec 20 20:36:06 EndeavourOS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=udis>
Dec 20 20:36:06 EndeavourOS kernel: audit: type=1130 audit(1766280966.340:125): pid=1 uid=0 auid=4294967295 s>
Dec 20 20:36:06 EndeavourOS org_kde_powerdevil[1127]: Library initialization complete.
Dec 20 20:36:06 EndeavourOS org_kde_powerdevil[1127]: Watching for DPMS state changes unimplemented
Dec 20 20:36:06 EndeavourOS org_kde_powerdevil[1127]: [ 1127] Watching for DPMS state changes unimplemented
Dec 20 20:36:06 EndeavourOS org_kde_powerdevil[1127]: [ 1127] Watching for display connection changes, resol>
Dec 20 20:36:06 EndeavourOS org_kde_powerdevil[1127]: [ 1127] extra>
Dec 20 20:36:06 EndeavourOS org_kde_powerdevil[1127]: [ 1127] libddcutil recheck thread 0x565145bfb810 start>
Dec 20 20:36:06 EndeavourOS org_kde_powerdevil[1127]: [ 1127] libddcutil watch thread 0x565145c05760 started
Dec 20 20:36:06 EndeavourOS org_kde_powerdevil[1127]: Error(s) opening ddc devices
Dec 20 20:36:06 EndeavourOS org_kde_powerdevil[1127]: Error EACCES(-13): Permission denied opening /dev/i2c-15
Dec 20 20:36:06 EndeavourOS org_kde_powerdevil[1127]: [ 1208] (dw_recheck_displays_func) Recheck interval: S>
Dec 20 20:36:06 EndeavourOS org_kde_powerdevil[1127]: Error EACCES(-13): Permission denied opening /dev/i2c-16
Dec 20 20:36:06 EndeavourOS org_kde_powerdevil[1127]: Error EACCES(-13): Permission denied opening /dev/i2c-17
Dec 20 20:36:06 EndeavourOS org_kde_powerdevil[1127]: [ 1127] Error(s) opening ddc devices
Dec 20 20:36:06 EndeavourOS org_kde_powerdevil[1127]: [ 1127] Error EACCES(-13): Permission denied opening />
Dec 20 20:36:06 EndeavourOS kded6[1060]: found no RGB LED devices
Dec 20 20:36:07 EndeavourOS kded6[1060]: Using X11 backend
Dec 20 20:36:07 EndeavourOS systemd[1]: Created slice Slice /system/dbus-:1.3-org.kde.powerdevil.discretegpuh>
Dec 20 20:36:07 EndeavourOS systemd[1]: Started dbus-:1.3-org.kde.powerdevil.discretegpuhelper@0.service.
Dec 20 20:36:07 EndeavourOS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=dbus>
Dec 20 20:36:07 EndeavourOS kernel: audit: type=1130 audit(1766280967.143:126): pid=1 uid=0 auid=4294967295 s>
Dec 20 20:36:07 EndeavourOS systemd[1]: Created slice Slice /system/dbus-:1.3-org.kde.powerdevil.chargethresh>
Dec 20 20:36:07 EndeavourOS systemd[1]: Started dbus-:1.3-org.kde.powerdevil.chargethresholdhelper@0.service.
Dec 20 20:36:07 EndeavourOS kernel: audit: type=1130 audit(1766280967.319:127): pid=1 uid=0 auid=4294967295 s>
Dec 20 20:36:07 EndeavourOS systemd[1]: Created slice Slice /system/dbus-:1.3-org.kde.powerdevil.backlighthel>
Dec 20 20:36:07 EndeavourOS systemd[1]: Started dbus-:1.3-org.kde.powerdevil.backlighthelper@0.service.
Dec 20 20:36:07 EndeavourOS kernel: audit: type=1130 audit(1766280967.659:128): pid=1 uid=0 auid=4294967295 s>
Dec 20 20:36:07 EndeavourOS systemd[951]: Starting KScreen...
Dec 20 20:36:07 EndeavourOS backlighthelper[1226]: no kernel backlight interface found
Dec 20 20:36:07 EndeavourOS org_kde_powerdevil[1127]: org.kde.powerdevil.chargethresholdhelper.getthreshold f>
Dec 20 20:36:07 EndeavourOS org_kde_powerdevil[1127]: org.kde.powerdevil.backlighthelper.brightness failed
Dec 20 20:36:07 EndeavourOS systemd[951]: Started KScreen.
Dec 20 20:36:07 EndeavourOS kscreen_backend_launcher[1227]: Connected output 69 to CRTC 62
Dec 20 20:36:07 EndeavourOS kscreen_backend_launcher[1227]: Connected output 70 to CRTC 63
Dec 20 20:36:07 EndeavourOS kscreen_backend_launcher[1227]: Detected XRandR 1.6
Dec 20 20:36:07 EndeavourOS kscreen_backend_launcher[1227]: Event Base: 89
Dec 20 20:36:07 EndeavourOS kscreen_backend_launcher[1227]: Event Error: 147
Dec 20 20:36:08 EndeavourOS audit: BPF prog-id=63 op=LOAD
Dec 20 20:36:08 EndeavourOS audit: BPF prog-id=64 op=LOAD
Dec 20 20:36:08 EndeavourOS audit: BPF prog-id=65 op=LOAD
Dec 20 20:36:08 EndeavourOS systemd[1]: Starting Power Profiles daemon...
Dec 20 20:36:08 EndeavourOS systemd[1]: Started Power Profiles daemon.
Dec 20 20:36:08 EndeavourOS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=powe>
Dec 20 20:36:08 EndeavourOS systemd[951]: Started Powerdevil.
Dec 20 20:36:08 EndeavourOS systemd[951]: Reached target KDE Plasma Workspace.
Dec 20 20:36:08 EndeavourOS systemd[951]: Reached target Current graphical user session.
Dec 20 20:36:08 EndeavourOS systemd[951]: Reached target plasma-workspace-x11.target.
Dec 20 20:36:08 EndeavourOS systemd[951]: Starting AT-SPI D-Bus Bus...
Dec 20 20:36:08 EndeavourOS systemd[951]: Starting broadcom-wl...
Dec 20 20:36:08 EndeavourOS systemd[951]: Starting Firewall Applet...
Dec 20 20:36:08 EndeavourOS systemd[951]: Starting KDE Connect...
Dec 20 20:36:08 EndeavourOS systemd[951]: Starting Plasma Session Restore...
Dec 20 20:36:08 EndeavourOS kernel: usb 1-7: 1:1: cannot get freq at ep 0x81
Dec 20 20:36:08 EndeavourOS wireplumber[1089]: spa.alsa: The decibel volume range for element 'Mic' (-3000 dB>
Dec 20 20:36:08 EndeavourOS systemd[951]: Starting vboxclient...
Dec 20 20:36:08 EndeavourOS systemd[951]: Starting VMware User Agent...
Dec 20 20:36:08 EndeavourOS systemd[951]: Starting wallpaper-once...
Dec 20 20:36:08 EndeavourOS systemd[951]: Starting Welcome...
Dec 20 20:36:08 EndeavourOS systemd[951]: Starting KDE Session Restoration...
Dec 20 20:36:08 EndeavourOS systemd[951]: Started Spice guest session agent.
Dec 20 20:36:08 EndeavourOS systemd[951]: Starting Portal service (GTK/GNOME implementation)...
Dec 20 20:36:08 EndeavourOS systemd[951]: Started wallpaper-once.
Dec 20 20:36:08 EndeavourOS systemd[951]: Finished KDE Session Restoration.
Dec 20 20:36:08 EndeavourOS org_kde_powerdevil[1127]: org.kde.powerdevil.chargethresholdhelper.getthreshold f>
Dec 20 20:36:08 EndeavourOS systemd[951]: Started Welcome.
Dec 20 20:36:08 EndeavourOS systemd[951]: Started Firewall Applet.
Dec 20 20:36:08 EndeavourOS systemd[951]: Started KDE Connect.
Dec 20 20:36:08 EndeavourOS systemd[951]: Started VMware User Agent.
Dec 20 20:36:08 EndeavourOS vmware-user-suid-wrapper[1275]: vmware-user: could not open /proc/fs/vmblock/dev
Dec 20 20:36:08 EndeavourOS systemd[951]: Started vboxclient.
Dec 20 20:36:08 EndeavourOS systemd[951]: app-at\x2dspi\x2ddbus\x2dbus@autostart.service: Skipped due to 'exe>
Dec 20 20:36:08 EndeavourOS systemd[951]: Condition check resulted in AT-SPI D-Bus Bus being skipped.
Dec 20 20:36:08 EndeavourOS systemd[951]: Started Plasma Session Restore.
Dec 20 20:36:08 EndeavourOS systemd[951]: Started broadcom-wl.
Dec 20 20:36:08 EndeavourOS systemd[951]: Reached target Startup of XDG autostart applications.
Dec 20 20:36:09 EndeavourOS spice-vdagent[1269]: vdagent virtio channel /dev/virtio-ports/com.redhat.spice.0 >
Dec 20 20:36:09 EndeavourOS systemd[951]: Starting Accessibility services bus...
Dec 20 20:36:09 EndeavourOS broadcom-wl_detect.sh[1296]: No Broadcom WLAN device found, nothing changed.
Dec 20 20:36:09 EndeavourOS broadcom-wl_detect.sh[1303]: ==== lspci -nn network devices start ====
Dec 20 20:36:09 EndeavourOS broadcom-wl_detect.sh[1312]: ==== lspci -nn network devices end ====
Dec 20 20:36:09 EndeavourOS systemd[951]: app-broadcom\x2dwl@autostart.service: Main process exited, code=exi>
Dec 20 20:36:09 EndeavourOS systemd[951]: app-broadcom\x2dwl@autostart.service: Failed with result 'exit-code>
Dec 20 20:36:09 EndeavourOS systemd[951]: Started Accessibility services bus.
Dec 20 20:36:09 EndeavourOS dbus-broker-launch[1315]: Ready
Dec 20 20:36:09 EndeavourOS systemd[951]: Created slice Slice /app/dbus-:1.36-org.a11y.atspi.Registry.
Dec 20 20:36:09 EndeavourOS systemd[951]: Started dbus-:1.36-org.a11y.atspi.Registry@0.service.
Dec 20 20:36:09 EndeavourOS systemd[951]: Started Portal service (GTK/GNOME implementation).
Dec 20 20:36:09 EndeavourOS rtkit-daemon[1099]: Supervising 6 threads of 3 processes of 1 users.
Dec 20 20:36:09 EndeavourOS at-spi2-registryd[1321]: SpiRegistry daemon is running with well-known name - org>
Dec 20 20:36:09 EndeavourOS systemd[951]: Starting Xdg Desktop Portal For KDE...
Dec 20 20:36:10 EndeavourOS systemd[951]: Started Xdg Desktop Portal For KDE.
Dec 20 20:36:10 EndeavourOS wireplumber[1089]: spa.bluez5: BlueZ system service is not available
Dec 20 20:36:10 EndeavourOS rtkit-daemon[1099]: Supervising 6 threads of 3 processes of 1 users.
Dec 20 20:36:10 EndeavourOS systemd[951]: Created slice Slice /app/dbus-:1.2-org.freedesktop.impl.portal.desk>
Dec 20 20:36:10 EndeavourOS systemd[951]: Started dbus-:1.2-org.freedesktop.impl.portal.desktop.kwallet@0.ser>
Dec 20 20:36:10 EndeavourOS wireplumber[1089]: wp-device: SPA handle 'api.libcamera.enum.manager' could not b>
Dec 20 20:36:10 EndeavourOS wireplumber[1089]: s-monitors-libcamera: PipeWire's libcamera SPA plugin is missi>
Dec 20 20:36:10 EndeavourOS systemd[951]: dbus-:1.2-org.freedesktop.impl.portal.desktop.kwallet@0.service: Ma>
Dec 20 20:36:10 EndeavourOS systemd[951]: dbus-:1.2-org.freedesktop.impl.portal.desktop.kwallet@0.service: Fa>
Dec 20 20:36:10 EndeavourOS systemd[951]: Started Portal service.
Dec 20 20:36:11 EndeavourOS plasmashell[1083]: Applet preload policy set to 1
Dec 20 20:36:11 EndeavourOS kded6[1060]: System timezone has been changed, new timezone is "UTC"
Dec 20 20:36:11 EndeavourOS kded6[1060]: QDBusObjectPath: invalid path "/modules/oom-notifier"
Dec 20 20:36:11 EndeavourOS kded6[1060]: The kded module name "oom-notifier" is invalid!
Dec 20 20:36:11 EndeavourOS kded6[1060]: QDBusObjectPath: invalid path "/modules/plasma-session-shortcuts"
Dec 20 20:36:11 EndeavourOS kded6[1060]: The kded module name "plasma-session-shortcuts" is invalid!
Dec 20 20:36:11 EndeavourOS NetworkManager[881]: <info> [1766280971.5109] agent-manager: agent[69bd610745ab5>
Dec 20 20:36:11 EndeavourOS kded6[1060]: Unable to register service to systemBus: "com.redhat.NewPrinterNotif>
Dec 20 20:36:11 EndeavourOS kded6[1060]: QDBusObjectPath: invalid path "/modules/wpad-detector"
Dec 20 20:36:11 EndeavourOS kded6[1060]: The kded module name "wpad-detector" is invalid!
Dec 20 20:36:12 EndeavourOS plasmashell[1083]: requesting unexisting screen geometry -1
Dec 20 20:36:12 EndeavourOS dbus-broker-launch[778]: Activation request for 'org.bluez' failed: The systemd u>
Dec 20 20:36:12 EndeavourOS kdeconnectd[1261]: Cannot find a compatible running Bluez. Please check the Bluez>
Dec 20 20:36:12 EndeavourOS kdeconnectd[1261]: No local bluetooth adapter found
Dec 20 20:36:12 EndeavourOS systemd[951]: Created slice Slice /app/dbus-:1.2-org.freedesktop.Notifications.
Dec 20 20:36:12 EndeavourOS systemd[951]: Started dbus-:1.2-org.freedesktop.Notifications@0.service.
Dec 20 20:36:12 EndeavourOS plasmashell[1083]: Activity added twice "cfc01e4d-21db-4f59-8a28-43c4be26ea8c"
Dec 20 20:36:13 EndeavourOS plasma6.0-remove-old-shortcuts[1525]: "Slideshow Wallpaper Next Image"
Dec 20 20:36:13 EndeavourOS plasma6.0-remove-old-shortcuts[1525]: "next activity"
Dec 20 20:36:13 EndeavourOS plasma6.0-remove-old-shortcuts[1525]: "previous activity"
Dec 20 20:36:14 EndeavourOS plasmashell[1083]: Entry is not valid "org.kde.kontact.desktop" 0x55ae9fd8c380
Dec 20 20:36:14 EndeavourOS plasmashell[1083]: Entry is not valid "org.kde.discover.desktop" 0x55ae9fdc8a30
Dec 20 20:36:14 EndeavourOS kded6[1060]: QDBusConnection: name 'org.freedesktop.UPower' had owner '' but we t>
Dec 20 20:36:14 EndeavourOS dbus-broker-launch[778]: Activation request for 'org.freedesktop.ModemManager1' f>
Dec 20 20:36:14 EndeavourOS kded6[1060]: Failed enumerating MM objects: "org.freedesktop.DBus.Error.NameHasNo>
"Could not activate remote peer 'org.freedesktop.ModemManager1': ac>
Dec 20 20:36:14 EndeavourOS kded6[1567]: xsettingsd: Loaded 16 settings from /home/liveuser/.config/xsettings>
Dec 20 20:36:14 EndeavourOS kded6[1567]: xsettingsd: Created window 0x3400001 on screen 0 with timestamp 79607
Dec 20 20:36:14 EndeavourOS kded6[1567]: xsettingsd: Selection _XSETTINGS_S0 is owned by 0x0
Dec 20 20:36:14 EndeavourOS kded6[1567]: xsettingsd: Took ownership of selection _XSETTINGS_S0
Dec 20 20:36:14 EndeavourOS systemd[1]: Created slice Slice /system/dbus-:1.3-org.kde.kded.smart.
Dec 20 20:36:14 EndeavourOS systemd[1]: Started dbus-:1.3-org.kde.kded.smart@0.service.
Dec 20 20:36:14 EndeavourOS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=dbus>
Dec 20 20:36:14 EndeavourOS kernel: kauditd_printk_skb: 4 callbacks suppressed
Dec 20 20:36:14 EndeavourOS kernel: audit: type=1130 audit(1766280974.601:133): pid=1 uid=0 auid=4294967295 s>
Dec 20 20:36:14 EndeavourOS kded6[1060]: PendingCall Error: "The name is not activatable"
Dec 20 20:36:14 EndeavourOS kded6[1060]: PendingCall Error: "Could not activate remote peer 'org.bluez': acti>
Dec 20 20:36:14 EndeavourOS audit: BPF prog-id=66 op=LOAD
Dec 20 20:36:14 EndeavourOS audit: BPF prog-id=67 op=LOAD
Dec 20 20:36:14 EndeavourOS audit: BPF prog-id=68 op=LOAD
Dec 20 20:36:14 EndeavourOS kernel: audit: type=1334 audit(1766280974.796:134): prog-id=66 op=LOAD
Dec 20 20:36:14 EndeavourOS kernel: audit: type=1334 audit(1766280974.796:135): prog-id=67 op=LOAD
Dec 20 20:36:14 EndeavourOS kernel: audit: type=1334 audit(1766280974.796:136): prog-id=68 op=LOAD
Dec 20 20:36:14 EndeavourOS systemd[1]: Starting Time & Date Service...
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: XRandR::setConfig
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: Requested screen size is QSize(6000, 1440)
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: Needed CRTCs: 2
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: Actions to perform:
Priorities: true
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: Output 69
Old: "0"
New: "2"
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: Output 70
Old: "0"
New: "1"
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: Change Screen Size: false
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: Disable outputs: false
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: Change outputs: true
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: QList(69, 70)
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: Enable outputs: false
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: RRSetCrtcConfig (change output)
Output: 69 ( "HDMI-1" )
CRTC: 62
Pos: QPoint(3440,0)
Mode: KScreen::Mode(Id: "72" , Size: QSi>
Rotation: KScreen::Output::None
Dec 20 20:36:14 EndeavourOS systemd[951]: Starting KScreen OSD service...
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: XRandRCrtc 62 m_timestamp update 0 => 79866
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: Result: 0 timestamp: 79866
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: XRandROutput 69 update
m_connected: 0
m_crtc XRandRCrtc(0x557472048220)
CRTC: 62
MODE: 72
Connection: 0
Output: 70 ( "DP-3" )
CRTC: 63
Pos: QPoint(0,0)
Mode: KScreen::Mode(Id: "196" , Size: QS>
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: XRandRCrtc 63 m_timestamp update 0 => 79897
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: Result: 0 timestamp: 79897
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: XRandROutput 70 update
m_connected: 0
m_crtc XRandRCrtc(0x5574720483e0)
CRTC: 63
MODE: 196
Connection: 0
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: RRSetOutputPrimary
New priority: 0
New priority: 0
New priority: 0
New priority: 2
New priority: 1
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: XRandR::setConfig done!
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: RRNotify_CrtcChange
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: Timestamp: 41634
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: CRTC: 62
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: Mode: 72
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: Rotation: "Rotate_0"
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: Geometry: 3440 0 2560 1080
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: RRScreenChangeNotify
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: Config_timestamp: 41634
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: Window: 39845895
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: Root: 1002
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: Size ID: 65535
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: Size: 6000 1440
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: SizeMM: 1587 381
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: RRNotify_OutputProperty (ignored)
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: Timestamp: 79897
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: Output: 69
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: Property: "_KDE_SCREEN_INDEX"
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: State (newValue, Deleted): 0
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: Timestamp: 79866
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: CRTC: 63
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: Mode: 196
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: Geometry: 0 0 3440 1440
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: Timestamp: 79930
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: Output: 70
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: RRNotify_OutputChange
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: Output: 66
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: CRTC: 0
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: Mode: 0
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: Connection: "Disconnected"
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: Subpixel Order: 0
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: Connection: "Connected"
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: XRandRCrtc 62 m_configTimestamp update 0 => 4>
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: XRandRCrtc 63 m_configTimestamp update 0 => 7>
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: XRandROutput 66 update
m_connected: 1
m_crtc QObject(0x0)
CRTC: 0
MODE: 0
Connection: 1
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: Output 66 : connected = false , enabled = false
m_connected: 0
CRTC: 63
MODE: 196
Connection: 0
Dec 20 20:36:14 EndeavourOS kscreen_backend_launcher[1227]: Output 70 : connected = true , enabled = true
m_connected: 1
m_crtc QObject(0x0)
CRTC: 0
MODE: 0
Connection: 1
m_connected: 0
CRTC: 63
MODE: 196
Connection: 0
Dec 20 20:36:14 EndeavourOS systemd[1]: Started Time & Date Service.
Dec 20 20:36:14 EndeavourOS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=syst>
Dec 20 20:36:14 EndeavourOS kernel: audit: type=1130 audit(1766280974.977:137): pid=1 uid=0 auid=4294967295 s>
Dec 20 20:36:15 EndeavourOS polkit-kde-authentication-agent-1[1126]: Listener adapter polkit_qt_listener_init>
Dec 20 20:36:15 EndeavourOS polkit-kde-authentication-agent-1[1126]: GSimpleAsyncResult: 0x5614ba8d3490
Dec 20 20:36:15 EndeavourOS polkit-kde-authentication-agent-1[1126]: polkit_qt_listener_initiate_authenticati>
Dec 20 20:36:15 EndeavourOS polkit-kde-authentication-agent-1[1126]: Initiating authentication
Dec 20 20:36:15 EndeavourOS polkit-kde-authentication-agent-1[1126]: Action description has been found
Dec 20 20:36:15 EndeavourOS org_kde_powerdevil[1127]: [ 1209] Device /dev/i2c-15 lacks R/W permissions
Dec 20 20:36:15 EndeavourOS org_kde_powerdevil[1127]: [ 1209] Device /dev/i2c-16 lacks R/W permissions
Dec 20 20:36:15 EndeavourOS org_kde_powerdevil[1127]: [ 1209] Device /dev/i2c-17 lacks R/W permissions
Dec 20 20:36:15 EndeavourOS systemd[951]: Started KScreen OSD service.
Dec 20 20:36:15 EndeavourOS kscreen_backend_launcher[1227]: Emitting configChanged()
Dec 20 20:36:15 EndeavourOS polkit-kde-authentication-agent-1[1126]: qrc:/qml/QuickAuthDialog.qml:57:5: QML S>
Dec 20 20:36:15 EndeavourOS polkit-kde-authentication-agent-1[1126]: User: "unix-user:liveuser"
Dec 20 20:36:15 EndeavourOS polkit-kde-authentication-agent-1[1126]: Trying again
Dec 20 20:36:15 EndeavourOS polkit-agent-helper-1[1652]: pam_unix(polkit-1:auth): user [liveuser] has blank p>
Dec 20 20:36:15 EndeavourOS audit[1652]: AUDIT1100 pid=1652 uid=1000 auid=1000 ses=2 msg='op=PAM:authenticati>
Dec 20 20:36:15 EndeavourOS kernel: audit: type=1100 audit(1766280975.966:138): pid=1652 uid=1000 auid=1000 s>
Dec 20 20:36:15 EndeavourOS audit[1652]: AUDIT1101 pid=1652 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting g>
Dec 20 20:36:15 EndeavourOS kernel: audit: type=1101 audit(1766280975.967:139): pid=1652 uid=1000 auid=1000 s>
Dec 20 20:36:16 EndeavourOS polkit-kde-authentication-agent-1[1126]: COMPLETED
Dec 20 20:36:16 EndeavourOS polkit-kde-authentication-agent-1[1126]: Completed: true
Dec 20 20:36:16 EndeavourOS polkit-kde-authentication-agent-1[1126]: Finishing obtaining privileges
Dec 20 20:36:16 EndeavourOS polkit-kde-authentication-agent-1[1126]: Listener adapter polkit_qt_listener_init>
Dec 20 20:36:16 EndeavourOS polkit-kde-authentication-agent-1[1126]: polkit_qt_listener_initiate_authenticati>
Dec 20 20:36:16 EndeavourOS polkit-kde-authentication-agent-1[1126]: Finish obtain authorization: true
Dec 20 20:36:16 EndeavourOS polkit-kde-authentication-agent-1[1126]: Dialog cancelled
Dec 20 20:36:16 EndeavourOS polkitd[883]: Operator of unix-session:1 successfully authenticated as unix-user:>
Dec 20 20:36:16 EndeavourOS systemd-timedated[1577]: Changed time zone to 'America/Detroit' (EDT).
Dec 20 20:36:16 EndeavourOS kded6[1060]: System timezone has been changed, new timezone is "America/Detroit"
Dec 20 20:36:16 EndeavourOS systemd[1]: dbus-:1.3-org.kde.powerdevil.discretegpuhelper@0.service: Deactivated>
Dec 20 20:36:16 EndeavourOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=dbus->
Dec 20 20:36:16 EndeavourOS kernel: audit: type=1131 audit(1766280976.992:140): pid=1 uid=0 auid=4294967295 s>
Dec 20 20:36:17 EndeavourOS kded6[1060]: Registering ":1.57/StatusNotifierItem" to system tray
Dec 20 20:36:17 EndeavourOS plasmashell[1083]: Entry is not valid "org.kde.kontact.desktop" 0x55aea09f1600
Dec 20 20:36:17 EndeavourOS plasmashell[1083]: Entry is not valid "org.kde.discover.desktop" 0x55aea0aa0030
Dec 20 20:36:17 EndeavourOS plasmashell[1083]: Entry is not valid "org.kde.kontact.desktop" 0x55ae9fd2ed70
Dec 20 20:36:17 EndeavourOS plasmashell[1083]: Entry is not valid "org.kde.discover.desktop" 0x55aea099be90
Dec 20 20:36:17 EndeavourOS systemd[1]: dbus-:1.3-org.kde.powerdevil.backlighthelper@0.service: Deactivated s>
Dec 20 20:36:17 EndeavourOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=dbus->
Dec 20 20:36:17 EndeavourOS kernel: audit: type=1131 audit(1766280977.991:141): pid=1 uid=0 auid=4294967295 s>
Dec 20 20:36:18 EndeavourOS systemd[1]: dbus-:1.3-org.kde.powerdevil.chargethresholdhelper@0.service: Deactiv>
Dec 20 20:36:18 EndeavourOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=dbus->
Dec 20 20:36:18 EndeavourOS kernel: audit: type=1131 audit(1766280978.991:142): pid=1 uid=0 auid=4294967295 s>
Dec 20 20:36:19 EndeavourOS plasmashell[1083]: qrc:/qt/qml/plasma/applet/org/kde/plasma/brightness/PopupDialo>
Dec 20 20:36:19 EndeavourOS eos-welcome[1794]: Session type: x11
Dec 20 20:36:19 EndeavourOS eos-welcome[1794]: Detected country: us
Dec 20 20:36:19 EndeavourOS eos-welcome[1794]: Setting keymap: us
Dec 20 20:36:25 EndeavourOS systemd[1]: dbus-:1.3-org.kde.kded.smart@0.service: Deactivated successfully.
Dec 20 20:36:25 EndeavourOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=dbus->
Dec 20 20:36:25 EndeavourOS kernel: audit: type=1131 audit(1766280985.004:143): pid=1 uid=0 auid=4294967295 s>
Dec 20 20:36:45 EndeavourOS systemd[951]: app-welcome@autostart.service: Consumed 5.904s CPU time, 113.2M mem>
Dec 20 20:36:46 EndeavourOS systemd[1]: systemd-timedated.service: Deactivated successfully.
Dec 20 20:36:46 EndeavourOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=syste>
Dec 20 20:36:46 EndeavourOS kernel: audit: type=1131 audit(1766281006.118:144): pid=1 uid=0 auid=4294967295 s>
Dec 20 20:36:46 EndeavourOS audit: BPF prog-id=68 op=UNLOAD
Dec 20 20:36:46 EndeavourOS audit: BPF prog-id=67 op=UNLOAD
Dec 20 20:36:46 EndeavourOS audit: BPF prog-id=66 op=UNLOAD
Dec 20 20:36:46 EndeavourOS kernel: audit: type=1334 audit(1766281006.134:145): prog-id=68 op=UNLOAD
Dec 20 20:36:46 EndeavourOS kernel: audit: type=1334 audit(1766281006.134:146): prog-id=67 op=UNLOAD
Dec 20 20:36:46 EndeavourOS kernel: audit: type=1334 audit(1766281006.134:147): prog-id=66 op=UNLOAD
Dec 20 20:36:46 EndeavourOS plasmashell[1083]: "/home/liveuser/.local/share/applications/firefox.desktop" con>
Dec 20 20:36:46 EndeavourOS systemd[951]: Started Firefox - Web Browser.
Dec 20 20:36:51 EndeavourOS audit: BPF prog-id=69 op=LOAD
Dec 20 20:36:51 EndeavourOS audit: BPF prog-id=70 op=LOAD
Dec 20 20:36:51 EndeavourOS audit: BPF prog-id=71 op=LOAD
Dec 20 20:36:51 EndeavourOS kernel: audit: type=1334 audit(1766281011.505:148): prog-id=69 op=LOAD
Dec 20 20:36:51 EndeavourOS kernel: audit: type=1334 audit(1766281011.505:149): prog-id=70 op=LOAD
Dec 20 20:36:51 EndeavourOS kernel: audit: type=1334 audit(1766281011.505:150): prog-id=71 op=LOAD
Dec 20 20:36:51 EndeavourOS systemd[1]: Starting Time & Date Service...
Dec 20 20:36:51 EndeavourOS systemd[1]: Started Time & Date Service.
Dec 20 20:36:51 EndeavourOS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=syst>
Dec 20 20:36:51 EndeavourOS kernel: audit: type=1130 audit(1766281011.548:151): pid=1 uid=0 auid=4294967295 s>
Dec 20 20:36:53 EndeavourOS rtkit-daemon[1099]: Supervising 6 threads of 3 processes of 1 users.
Dec 20 20:36:53 EndeavourOS rtkit-daemon[1099]: Successfully made thread 2503 of process 2330 owned by '1000'>
Dec 20 20:36:53 EndeavourOS rtkit-daemon[1099]: Supervising 7 threads of 4 processes of 1 users.
Dec 20 20:36:54 EndeavourOS rtkit-daemon[1099]: Supervising 7 threads of 4 processes of 1 users.
Dec 20 20:36:55 EndeavourOS rtkit-daemon[1099]: Supervising 7 threads of 4 processes of 1 users.
Dec 20 20:37:00 EndeavourOS kded6[1060]: Registering ":1.63/StatusNotifierItem" to system tray
Dec 20 20:37:02 EndeavourOS plasmashell[1083]: Exposed with no visual parent. Window positioning broken.
Dec 20 20:37:03 EndeavourOS plasma_waitforname[1030]: WaitForName: Service was not registered within timeout
Dec 20 20:37:03 EndeavourOS systemd[951]: dbus-:1.2-org.kde.KSplash@0.service: Main process exited, code=exit>
Dec 20 20:37:03 EndeavourOS systemd[951]: dbus-:1.2-org.kde.KSplash@0.service: Failed with result 'exit-code'.
Dec 20 20:37:03 EndeavourOS plasmashell[1083]: Exposed with no visual parent. Window positioning broken.
Dec 20 20:37:12 EndeavourOS rtkit-daemon[1099]: Supervising 7 threads of 4 processes of 1 users.
Dec 20 20:37:14 EndeavourOS rtkit-daemon[1099]: Supervising 7 threads of 4 processes of 1 users.
Dec 20 20:37:21 EndeavourOS systemd[1]: systemd-timedated.service: Deactivated successfully.
Dec 20 20:37:21 EndeavourOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=syste>
Dec 20 20:37:21 EndeavourOS kernel: audit: type=1131 audit(1766281041.630:152): pid=1 uid=0 auid=4294967295 s>
Dec 20 20:37:21 EndeavourOS audit: BPF prog-id=71 op=UNLOAD
Dec 20 20:37:21 EndeavourOS audit: BPF prog-id=70 op=UNLOAD
Dec 20 20:37:21 EndeavourOS audit: BPF prog-id=69 op=UNLOAD
Dec 20 20:37:21 EndeavourOS kernel: audit: type=1334 audit(1766281041.643:153): prog-id=71 op=UNLOAD
Dec 20 20:37:21 EndeavourOS kernel: audit: type=1334 audit(1766281041.643:154): prog-id=70 op=UNLOAD
Dec 20 20:37:21 EndeavourOS kernel: audit: type=1334 audit(1766281041.643:155): prog-id=69 op=UNLOAD
Dec 20 20:37:27 EndeavourOS rtkit-daemon[1099]: Supervising 7 threads of 4 processes of 1 users.
Dec 20 20:37:29 EndeavourOS rtkit-daemon[1099]: Supervising 7 threads of 4 processes of 1 users.
Dec 20 20:37:31 EndeavourOS rtkit-daemon[1099]: Supervising 7 threads of 4 processes of 1 users.
Dec 20 20:37:35 EndeavourOS rtkit-daemon[1099]: Supervising 7 threads of 4 processes of 1 users.
Dec 20 20:37:36 EndeavourOS rtkit-daemon[1099]: Supervising 7 threads of 4 processes of 1 users.
Dec 20 20:37:37 EndeavourOS rtkit-daemon[1099]: Supervising 7 threads of 4 processes of 1 users.
Dec 20 20:37:37 EndeavourOS rtkit-daemon[1099]: Successfully made thread 3771 of process 2330 owned by '1000'>
Dec 20 20:37:37 EndeavourOS rtkit-daemon[1099]: Supervising 8 threads of 4 processes of 1 users.
Dec 20 20:37:47 EndeavourOS plasmashell[1083]: Exposed with no visual parent. Window positioning broken.
Dec 20 20:37:47 EndeavourOS systemd[951]: Started Konsole - Terminal.
Dec 20 20:37:48 EndeavourOS systemd[951]: Started app-org.kde.konsole-3791.scope.
Dec 20 20:38:07 EndeavourOS rtkit-daemon[1099]: Supervising 8 threads of 4 processes of 1 users.
Dec 20 20:39:09 EndeavourOS rtkit-daemon[1099]: Supervising 8 threads of 4 processes of 1 users.
Dec 20 20:39:12 EndeavourOS rtkit-daemon[1099]: Supervising 8 threads of 4 processes of 1 users.
Dec 20 20:39:14 EndeavourOS rtkit-daemon[1099]: Supervising 8 threads of 4 processes of 1 users.
Dec 20 20:39:17 EndeavourOS rtkit-daemon[1099]: Supervising 8 threads of 4 processes of 1 users.
Dec 20 20:39:18 EndeavourOS rtkit-daemon[1099]: Supervising 8 threads of 4 processes of 1 users.
Dec 20 20:39:24 EndeavourOS rtkit-daemon[1099]: Supervising 8 threads of 4 processes of 1 users.
Dec 20 20:39:25 EndeavourOS rtkit-daemon[1099]: Supervising 8 threads of 4 processes of 1 users.
Dec 20 20:39:35 EndeavourOS rtkit-daemon[1099]: Supervising 8 threads of 4 processes of 1 users.
Dec 20 20:39:49 EndeavourOS rtkit-daemon[1099]: Supervising 8 threads of 4 processes of 1 users.
Dec 20 20:40:22 EndeavourOS audit[4761]: AUDIT1101 pid=4761 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting g>
Dec 20 20:40:22 EndeavourOS kernel: audit: type=1101 audit(1766281222.417:156): pid=4761 uid=1000 auid=1000 s>
Dec 20 20:40:22 EndeavourOS sudo[4761]: liveuser : TTY=pts/0 ; PWD=/home/liveuser ; USER=root ; COMMAND=/usr/>
Dec 20 20:40:22 EndeavourOS audit[4761]: AUDIT1110 pid=4761 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred gran>
Dec 20 20:40:22 EndeavourOS sudo[4761]: pam_unix(sudo:session): session opened for user root(uid=0) by liveus>
Dec 20 20:40:22 EndeavourOS audit[4761]: AUDIT1105 pid=4761 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open>
Dec 20 20:40:22 EndeavourOS kernel: audit: type=1110 audit(1766281222.419:157): pid=4761 uid=1000 auid=1000 s>
Dec 20 20:40:22 EndeavourOS kernel: audit: type=1105 audit(1766281222.419:158): pid=4761 uid=1000 auid=1000 s>
Dec 20 20:40:22 EndeavourOS sudo[4761]: pam_unix(sudo:session): session closed for user root
Dec 20 20:40:22 EndeavourOS audit[4761]: AUDIT1106 pid=4761 uid=1000 auid=1000 ses=2 msg='op=PAM:session_clos>
Dec 20 20:40:22 EndeavourOS audit[4761]: AUDIT1104 pid=4761 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred gran>
Dec 20 20:40:22 EndeavourOS kernel: audit: type=1106 audit(1766281222.459:159): pid=4761 uid=1000 auid=1000 s>
Dec 20 20:40:22 EndeavourOS kernel: audit: type=1104 audit(1766281222.459:160): pid=4761 uid=1000 auid=1000 s>
Dec 20 20:43:43 EndeavourOS plasmashell[1083]: Exposed with no visual parent. Window positioning broken.
Dec 20 20:43:46 EndeavourOS systemd[951]: Started Konsole - Terminal.
Dec 20 20:43:46 EndeavourOS systemd[951]: Started app-org.kde.konsole-4903.scope.
Dec 20 20:44:11 EndeavourOS systemd[951]: app-org.kde.konsole-3791.scope: Consumed 8.331s CPU time, 14.9M mem>
Dec 20 20:44:12 EndeavourOS plasmashell[1083]: Exposed with no visual parent. Window positioning broken.
Dec 20 20:44:13 EndeavourOS plasmashell[1083]: Exposed with no visual parent. Window positioning broken.
Dec 20 20:45:43 EndeavourOS audit[4950]: AUDIT1101 pid=4950 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting g>
Dec 20 20:45:43 EndeavourOS kernel: audit: type=1101 audit(1766281543.174:161): pid=4950 uid=1000 auid=1000 s>
Dec 20 20:45:43 EndeavourOS sudo[4950]: liveuser : TTY=pts/1 ; PWD=/home/liveuser ; USER=root ; COMMAND=/usr/>
Dec 20 20:45:43 EndeavourOS audit[4950]: AUDIT1110 pid=4950 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred gran>
Dec 20 20:45:43 EndeavourOS sudo[4950]: pam_unix(sudo:session): session opened for user root(uid=0) by liveus>
Dec 20 20:45:43 EndeavourOS audit[4950]: AUDIT1105 pid=4950 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open>
Dec 20 20:45:43 EndeavourOS kernel: audit: type=1110 audit(1766281543.176:162): pid=4950 uid=1000 auid=1000 s>
Dec 20 20:45:43 EndeavourOS kernel: audit: type=1105 audit(1766281543.176:163): pid=4950 uid=1000 auid=1000 s>
Dec 20 20:45:43 EndeavourOS sudo[4950]: pam_unix(sudo:session): session closed for user root
Dec 20 20:45:43 EndeavourOS audit[4950]: AUDIT1106 pid=4950 uid=1000 auid=1000 ses=2 msg='op=PAM:session_clos>
Dec 20 20:45:43 EndeavourOS audit[4950]: AUDIT1104 pid=4950 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred gran>
Dec 20 20:45:43 EndeavourOS kernel: audit: type=1106 audit(1766281543.210:164): pid=4950 uid=1000 auid=1000 s>
Dec 20 20:45:43 EndeavourOS kernel: audit: type=1104 audit(1766281543.210:165): pid=4950 uid=1000 auid=1000 s>
Dec 20 20:48:32 EndeavourOS audit[5042]: AUDIT1101 pid=5042 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting g>
Dec 20 20:48:32 EndeavourOS kernel: audit: type=1101 audit(1766281712.077:166): pid=5042 uid=1000 auid=1000 s>
Dec 20 20:48:32 EndeavourOS sudo[5042]: liveuser : TTY=pts/1 ; PWD=/home/liveuser ; USER=root ; COMMAND=/usr/>
Dec 20 20:48:32 EndeavourOS audit[5042]: AUDIT1110 pid=5042 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred gran>
Dec 20 20:48:32 EndeavourOS sudo[5042]: pam_unix(sudo:session): session opened for user root(uid=0) by liveus>
Dec 20 20:48:32 EndeavourOS audit[5042]: AUDIT1105 pid=5042 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open>
Dec 20 20:48:32 EndeavourOS kernel: audit: type=1110 audit(1766281712.079:167): pid=5042 uid=1000 auid=1000 s>
Dec 20 20:48:32 EndeavourOS kernel: audit: type=1105 audit(1766281712.079:168): pid=5042 uid=1000 auid=1000 s>
Dec 20 20:48:32 EndeavourOS sudo[5042]: pam_unix(sudo:session): session closed for user root
Dec 20 20:48:32 EndeavourOS audit[5042]: AUDIT1106 pid=5042 uid=1000 auid=1000 ses=2 msg='op=PAM:session_clos>
Dec 20 20:48:32 EndeavourOS audit[5042]: AUDIT1104 pid=5042 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred gran>
Dec 20 20:48:32 EndeavourOS kernel: audit: type=1106 audit(1766281712.081:169): pid=5042 uid=1000 auid=1000 s>
Dec 20 20:48:32 EndeavourOS kernel: audit: type=1104 audit(1766281712.081:170): pid=5042 uid=1000 auid=1000 s>
Dec 20 20:48:58 EndeavourOS audit[5048]: AUDIT1101 pid=5048 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting g>
Dec 20 20:48:58 EndeavourOS kernel: audit: type=1101 audit(1766281738.965:171): pid=5048 uid=1000 auid=1000 s>
Dec 20 20:48:58 EndeavourOS sudo[5048]: liveuser : TTY=pts/1 ; PWD=/home/liveuser ; USER=root ; COMMAND=/usr/>
Dec 20 20:48:58 EndeavourOS audit[5048]: AUDIT1110 pid=5048 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred gran>
Dec 20 20:48:58 EndeavourOS sudo[5048]: pam_unix(sudo:session): session opened for user root(uid=0) by liveus>
Dec 20 20:48:58 EndeavourOS audit[5048]: AUDIT1105 pid=5048 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open>
Dec 20 20:48:58 EndeavourOS kernel: audit: type=1110 audit(1766281738.967:172): pid=5048 uid=1000 auid=1000 s>
Dec 20 20:48:58 EndeavourOS kernel: audit: type=1105 audit(1766281738.967:173): pid=5048 uid=1000 auid=1000 s>
Dec 20 20:48:59 EndeavourOS sudo[5048]: pam_unix(sudo:session): session closed for user root
Dec 20 20:48:59 EndeavourOS audit[5048]: AUDIT1106 pid=5048 uid=1000 auid=1000 ses=2 msg='op=PAM:session_clos>
Dec 20 20:48:59 EndeavourOS audit[5048]: AUDIT1104 pid=5048 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred gran>
Dec 20 20:48:59 EndeavourOS kernel: audit: type=1106 audit(1766281739.008:174): pid=5048 uid=1000 auid=1000 s>
Dec 20 20:48:59 EndeavourOS kernel: audit: type=1104 audit(1766281739.008:175): pid=5048 uid=1000 auid=1000 s>
Dec 20 20:50:04 EndeavourOS systemd[1]: Starting Cleanup of Temporary Directories...
Dec 20 20:50:04 EndeavourOS systemd[1]: systemd-tmpfiles-clean.service: Deactivated successfully.
Dec 20 20:50:04 EndeavourOS systemd[1]: Finished Cleanup of Temporary Directories.
Dec 20 20:50:04 EndeavourOS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=syst>
Dec 20 20:50:04 EndeavourOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=syste>
Dec 20 20:50:04 EndeavourOS kernel: audit: type=1130 audit(1766281804.988:176): pid=1 uid=0 auid=4294967295 s>
Dec 20 20:50:04 EndeavourOS kernel: audit: type=1131 audit(1766281804.988:177): pid=1 uid=0 auid=4294967295 s>
Dec 20 20:50:07 EndeavourOS audit[5073]: AUDIT1101 pid=5073 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting g>
Dec 20 20:50:07 EndeavourOS kernel: audit: type=1101 audit(1766281807.701:178): pid=5073 uid=1000 auid=1000 s>
Dec 20 20:50:07 EndeavourOS sudo[5073]: liveuser : TTY=pts/1 ; PWD=/home/liveuser ; USER=root ; COMMAND=/usr/>
Dec 20 20:50:07 EndeavourOS audit[5073]: AUDIT1110 pid=5073 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred gran>
Dec 20 20:50:07 EndeavourOS sudo[5073]: pam_unix(sudo:session): session opened for user root(uid=0) by liveus>
Dec 20 20:50:07 EndeavourOS audit[5073]: AUDIT1105 pid=5073 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open>
Dec 20 20:50:07 EndeavourOS kernel: audit: type=1110 audit(1766281807.703:179): pid=5073 uid=1000 auid=1000 s>
Dec 20 20:50:07 EndeavourOS kernel: audit: type=1105 audit(1766281807.703:180): pid=5073 uid=1000 auid=1000 s>
Dec 20 20:50:07 EndeavourOS sudo[5073]: pam_unix(sudo:session): session closed for user root
Dec 20 20:50:07 EndeavourOS audit[5073]: AUDIT1106 pid=5073 uid=1000 auid=1000 ses=2 msg='op=PAM:session_clos>
Dec 20 20:50:07 EndeavourOS audit[5073]: AUDIT1104 pid=5073 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred gran>
Dec 20 20:50:07 EndeavourOS kernel: audit: type=1106 audit(1766281807.736:181): pid=5073 uid=1000 auid=1000 s>
Dec 20 20:50:07 EndeavourOS kernel: audit: type=1104 audit(1766281807.736:182): pid=5073 uid=1000 auid=1000 s>
Dec 20 20:52:15 EndeavourOS rtkit-daemon[1099]: Supervising 8 threads of 4 processes of 1 users.
Dec 20 20:52:18 EndeavourOS rtkit-daemon[1099]: Supervising 8 threads of 4 processes of 1 users.
Dec 20 20:53:45 EndeavourOS rtkit-daemon[1099]: Supervising 8 threads of 4 processes of 1 users.
Dec 20 20:53:53 EndeavourOS rtkit-daemon[1099]: Supervising 8 threads of 4 processes of 1 users.
Dec 20 20:53:54 EndeavourOS rtkit-daemon[1099]: Supervising 8 threads of 4 processes of 1 users.
Dec 20 20:56:03 EndeavourOS rtkit-daemon[1099]: Supervising 8 threads of 4 processes of 1 users.
Dec 20 20:56:47 EndeavourOS rtkit-daemon[1099]: Supervising 8 threads of 4 processes of 1 users.
Dec 20 20:57:13 EndeavourOS rtkit-daemon[1099]: Supervising 8 threads of 4 processes of 1 users.
Dec 20 20:57:14 EndeavourOS rtkit-daemon[1099]: Supervising 8 threads of 4 processes of 1 users.
Dec 20 20:58:00 EndeavourOS rtkit-daemon[1099]: Supervising 8 threads of 4 processes of 1 users.
Dec 20 21:03:55 EndeavourOS plasmashell[1083]: Exposed with no visual parent. Window positioning broken.
Dec 20 21:03:56 EndeavourOS plasmashell[1083]: Exposed with no visual parent. Window positioning broken.
Dec 20 21:03:56 EndeavourOS systemd[951]: Started Dolphin - File Manager.
Dec 20 21:03:56 EndeavourOS dolphin[5935]: Could not load default global viewproperties
Dec 20 21:03:56 EndeavourOS dolphin[5935]: Unknown class "" in session saved data!
Dec 20 21:03:57 EndeavourOS plasmashell[1083]: Exposed with no visual parent. Window positioning broken.
Dec 20 21:04:02 EndeavourOS polkit-kde-authentication-agent-1[1126]: Listener adapter polkit_qt_listener_init>
Dec 20 21:04:02 EndeavourOS polkit-kde-authentication-agent-1[1126]: GSimpleAsyncResult: 0x7fe938069c70
Dec 20 21:04:02 EndeavourOS polkit-kde-authentication-agent-1[1126]: polkit_qt_listener_initiate_authenticati>
Dec 20 21:04:02 EndeavourOS polkit-kde-authentication-agent-1[1126]: Initiating authentication
Dec 20 21:04:02 EndeavourOS polkit-kde-authentication-agent-1[1126]: Action description has been found
Dec 20 21:04:02 EndeavourOS polkit-kde-authentication-agent-1[1126]: qrc:/qml/QuickAuthDialog.qml:57:5: QML S>
Dec 20 21:04:02 EndeavourOS polkit-kde-authentication-agent-1[1126]: User: "unix-user:liveuser"
Dec 20 21:04:02 EndeavourOS polkit-kde-authentication-agent-1[1126]: Trying again
Dec 20 21:04:02 EndeavourOS polkit-agent-helper-1[5984]: pam_unix(polkit-1:auth): user [liveuser] has blank p>
Dec 20 21:04:02 EndeavourOS audit[5984]: AUDIT1100 pid=5984 uid=1000 auid=1000 ses=2 msg='op=PAM:authenticati>
Dec 20 21:04:02 EndeavourOS kernel: audit: type=1100 audit(1766282642.478:183): pid=5984 uid=1000 auid=1000 s>
Dec 20 21:04:02 EndeavourOS audit[5984]: AUDIT1101 pid=5984 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting g>
Dec 20 21:04:02 EndeavourOS kernel: audit: type=1101 audit(1766282642.479:184): pid=5984 uid=1000 auid=1000 s>
Dec 20 21:04:02 EndeavourOS polkit-kde-authentication-agent-1[1126]: COMPLETED
Dec 20 21:04:02 EndeavourOS polkit-kde-authentication-agent-1[1126]: Completed: true
Dec 20 21:04:02 EndeavourOS polkit-kde-authentication-agent-1[1126]: Finishing obtaining privileges
Dec 20 21:04:02 EndeavourOS polkit-kde-authentication-agent-1[1126]: Finish obtain authorization: true
Dec 20 21:04:02 EndeavourOS polkit-kde-authentication-agent-1[1126]: Dialog cancelled
Dec 20 21:04:02 EndeavourOS polkitd[883]: Operator of unix-session:1 successfully authenticated as unix-user:>
Dec 20 21:04:02 EndeavourOS kernel: EXT4-fs (sda2): mounted filesystem 2190f2e1-be29-4687-a507-ff295566d4b7 r>
Dec 20 21:04:02 EndeavourOS dolphin[5935]: Could not load default global viewproperties
Dec 20 21:04:08 EndeavourOS plasmashell[1083]: Connecting to deprecated signal QDBusConnectionInterface::serv>
Dec 20 21:04:08 EndeavourOS systemd[951]: Starting KRunner provider for baloo file indexer...
Dec 20 21:04:08 EndeavourOS systemd[951]: Started KRunner provider for baloo file indexer.
Dec 20 21:04:08 EndeavourOS plasmashell[1083]: Error requesting matches; calling "org.kde.runners.baloo" : ">
Dec 20 21:04:08 EndeavourOS plasmashell[1083]: currency conversion table data obtained via network
Dec 20 21:04:10 EndeavourOS systemd[951]: Started GParted - Partition Editor.
Dec 20 21:04:10 EndeavourOS baloorunner[6050]: QDBusConnection: couldn't handle call to Teardown, no slot mat>
Dec 20 21:04:10 EndeavourOS baloorunner[6050]: Could not find slot Krunner1Adaptor::Teardown
Dec 20 21:04:10 EndeavourOS kwin_x11[1061]: QDBusConnection: couldn't handle call to Teardown, no slot matched
Dec 20 21:04:10 EndeavourOS kwin_x11[1061]: Could not find slot Krunner1Adaptor::Teardown
Dec 20 21:04:10 EndeavourOS polkit-kde-authentication-agent-1[1126]: Listener adapter polkit_qt_listener_init>
Dec 20 21:04:10 EndeavourOS polkit-kde-authentication-agent-1[1126]: GSimpleAsyncResult: 0x7fe938074350
Dec 20 21:04:10 EndeavourOS polkit-kde-authentication-agent-1[1126]: polkit_qt_listener_initiate_authenticati>
Dec 20 21:04:10 EndeavourOS polkit-kde-authentication-agent-1[1126]: Initiating authentication
Dec 20 21:04:10 EndeavourOS polkit-kde-authentication-agent-1[1126]: Action description has been found
Dec 20 21:04:11 EndeavourOS polkit-kde-authentication-agent-1[1126]: qrc:/qml/QuickAuthDialog.qml:57:5: QML S>
Dec 20 21:04:11 EndeavourOS polkit-kde-authentication-agent-1[1126]: User: "unix-user:liveuser"
Dec 20 21:04:11 EndeavourOS polkit-kde-authentication-agent-1[1126]: Trying again
Dec 20 21:04:11 EndeavourOS polkit-agent-helper-1[6071]: pam_unix(polkit-1:auth): user [liveuser] has blank p>
Dec 20 21:04:11 EndeavourOS audit[6071]: AUDIT1100 pid=6071 uid=1000 auid=1000 ses=2 msg='op=PAM:authenticati>
Dec 20 21:04:11 EndeavourOS kernel: audit: type=1100 audit(1766282651.047:185): pid=6071 uid=1000 auid=1000 s>
Dec 20 21:04:11 EndeavourOS audit[6071]: AUDIT1101 pid=6071 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting g>
Dec 20 21:04:11 EndeavourOS kernel: audit: type=1101 audit(1766282651.048:186): pid=6071 uid=1000 auid=1000 s>
Dec 20 21:04:11 EndeavourOS polkit-kde-authentication-agent-1[1126]: COMPLETED
Dec 20 21:04:11 EndeavourOS polkit-kde-authentication-agent-1[1126]: Completed: true
Dec 20 21:04:11 EndeavourOS polkit-kde-authentication-agent-1[1126]: Finishing obtaining privileges
Dec 20 21:04:11 EndeavourOS polkit-kde-authentication-agent-1[1126]: Listener adapter polkit_qt_listener_init>
Dec 20 21:04:11 EndeavourOS polkit-kde-authentication-agent-1[1126]: polkit_qt_listener_initiate_authenticati>
Dec 20 21:04:11 EndeavourOS polkit-kde-authentication-agent-1[1126]: Finish obtain authorization: true
Dec 20 21:04:11 EndeavourOS polkit-kde-authentication-agent-1[1126]: Dialog cancelled
Dec 20 21:04:11 EndeavourOS polkitd[883]: Operator of unix-session:1 successfully authenticated as unix-user:>
Dec 20 21:04:11 EndeavourOS pkexec[6060]: pam_unix(polkit-1:session): session opened for user root(uid=0) by >
Dec 20 21:04:11 EndeavourOS audit[6060]: AUDIT1105 pid=6060 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open>
Dec 20 21:04:11 EndeavourOS kernel: audit: type=1105 audit(1766282651.077:187): pid=6060 uid=1000 auid=1000 s>
Dec 20 21:04:11 EndeavourOS pkexec[6060]: liveuser: Executing command [USER=root] [TTY=unknown] [CWD=/home/li>
Dec 20 21:04:11 EndeavourOS systemd[1]: Reload requested from client PID 6098 ('systemctl') (unit user@1000.s>
Dec 20 21:04:11 EndeavourOS systemd[1]: Reloading...
Dec 20 21:04:11 EndeavourOS systemd-gpt-auto-generator[6175]: EFI loader partition unknown, not processing /.
Dec 20 21:04:11 EndeavourOS systemd-gpt-auto-generator[6175]: (The boot loader did not set EFI variable Loade>
Dec 20 21:04:11 EndeavourOS systemd[1]: Reloading finished in 239 ms.
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=72 op=LOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=49 op=UNLOAD
Dec 20 21:04:11 EndeavourOS kernel: audit: type=1334 audit(1766282651.489:188): prog-id=72 op=LOAD
Dec 20 21:04:11 EndeavourOS kernel: audit: type=1334 audit(1766282651.489:189): prog-id=49 op=UNLOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=73 op=LOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=19 op=UNLOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=74 op=LOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=75 op=LOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=20 op=UNLOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=21 op=UNLOAD
Dec 20 21:04:11 EndeavourOS kernel: audit: type=1334 audit(1766282651.490:190): prog-id=73 op=LOAD
Dec 20 21:04:11 EndeavourOS kernel: audit: type=1334 audit(1766282651.490:191): prog-id=19 op=UNLOAD
Dec 20 21:04:11 EndeavourOS kernel: audit: type=1334 audit(1766282651.490:192): prog-id=74 op=LOAD
Dec 20 21:04:11 EndeavourOS kernel: audit: type=1334 audit(1766282651.490:193): prog-id=75 op=LOAD
Dec 20 21:04:11 EndeavourOS kernel: audit: type=1334 audit(1766282651.490:194): prog-id=20 op=UNLOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=76 op=LOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=40 op=UNLOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=77 op=LOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=25 op=UNLOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=78 op=LOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=79 op=LOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=26 op=UNLOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=27 op=UNLOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=80 op=LOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=81 op=LOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=61 op=UNLOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=62 op=UNLOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=82 op=LOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=43 op=UNLOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=83 op=LOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=39 op=UNLOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=84 op=LOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=63 op=UNLOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=85 op=LOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=86 op=LOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=64 op=UNLOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=65 op=UNLOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=87 op=LOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=88 op=LOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=41 op=UNLOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=42 op=UNLOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=89 op=LOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=50 op=UNLOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=90 op=LOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=44 op=UNLOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=91 op=LOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=46 op=UNLOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=92 op=LOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=93 op=LOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=47 op=UNLOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=48 op=UNLOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=94 op=LOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=22 op=UNLOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=95 op=LOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=96 op=LOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=23 op=UNLOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=24 op=UNLOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=97 op=LOAD
Dec 20 21:04:11 EndeavourOS audit: BPF prog-id=45 op=UNLOAD
Dec 20 21:04:11 EndeavourOS gparted[6198]: GParted 1.7.0
Dec 20 21:04:11 EndeavourOS gparted[6198]: configuration --enable-libparted-dmraid
Dec 20 21:04:11 EndeavourOS gparted[6198]: libparted 3.6
Dec 20 21:04:12 EndeavourOS kernel: JFS: nTxBlock = 8192, nTxLock = 65536
Dec 20 21:04:12 EndeavourOS kernel: NILFS version 2 loaded
Dec 20 21:04:12 EndeavourOS kernel: SGI XFS with ACLs, security attributes, realtime, scrub, repair, quota, n>
Dec 20 21:06:07 EndeavourOS audit[6526]: AUDIT1101 pid=6526 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting g>
Dec 20 21:06:07 EndeavourOS kernel: kauditd_printk_skb: 45 callbacks suppressed
Dec 20 21:06:07 EndeavourOS kernel: audit: type=1101 audit(1766282767.732:240): pid=6526 uid=1000 auid=1000 s>
Dec 20 21:06:07 EndeavourOS sudo[6526]: liveuser : TTY=pts/1 ; PWD=/home/liveuser ; USER=root ; COMMAND=/usr/>
Dec 20 21:06:07 EndeavourOS audit[6526]: AUDIT1110 pid=6526 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred gran>
Dec 20 21:06:07 EndeavourOS sudo[6526]: pam_unix(sudo:session): session opened for user root(uid=0) by liveus>
Dec 20 21:06:07 EndeavourOS audit[6526]: AUDIT1105 pid=6526 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open>
Dec 20 21:06:07 EndeavourOS kernel: audit: type=1110 audit(1766282767.734:241): pid=6526 uid=1000 auid=1000 s>
Dec 20 21:06:07 EndeavourOS kernel: audit: type=1105 audit(1766282767.734:242): pid=6526 uid=1000 auid=1000 s>
Dec 20 21:06:07 EndeavourOS sudo[6526]: pam_unix(sudo:session): session closed for user root
Dec 20 21:06:07 EndeavourOS audit[6526]: AUDIT1106 pid=6526 uid=1000 auid=1000 ses=2 msg='op=PAM:session_clos>
Dec 20 21:06:07 EndeavourOS audit[6526]: AUDIT1104 pid=6526 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred gran>
Dec 20 21:06:07 EndeavourOS kernel: audit: type=1106 audit(1766282767.773:243): pid=6526 uid=1000 auid=1000 s>
Dec 20 21:06:07 EndeavourOS kernel: audit: type=1104 audit(1766282767.773:244): pid=6526 uid=1000 auid=1000 s>
Dec 20 21:06:14 EndeavourOS rtkit-daemon[1099]: Supervising 8 threads of 4 processes of 1 users.
Dec 20 21:07:14 EndeavourOS rtkit-daemon[1099]: Supervising 8 threads of 4 processes of 1 users.
Dec 20 21:07:19 EndeavourOS systemd[951]: app-org.kde.konsole-4903.scope: Consumed 4.749s CPU time, 15.5M mem>
Dec 20 21:07:20 EndeavourOS plasmashell[1083]: Exposed with no visual parent. Window positioning broken.
Dec 20 21:07:21 EndeavourOS plasmashell[1083]: Exposed with no visual parent. Window positioning broken.
Dec 20 21:07:21 EndeavourOS systemd[951]: Started Konsole - Terminal.
Dec 20 21:07:21 EndeavourOS systemd[951]: Started app-org.kde.konsole-6634.scope.
Dec 20 21:07:37 EndeavourOS audit[6661]: AUDIT1101 pid=6661 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting g>
Dec 20 21:07:37 EndeavourOS kernel: audit: type=1101 audit(1766282857.037:245): pid=6661 uid=1000 auid=1000 s>
Dec 20 21:07:37 EndeavourOS sudo[6661]: liveuser : TTY=pts/0 ; PWD=/home/liveuser ; USER=root ; COMMAND=/usr/>
Dec 20 21:07:37 EndeavourOS audit[6661]: AUDIT1110 pid=6661 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred gran>
Dec 20 21:07:37 EndeavourOS sudo[6661]: pam_unix(sudo:session): session opened for user root(uid=0) by liveus>
Dec 20 21:07:37 EndeavourOS audit[6661]: AUDIT1105 pid=6661 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open>
Dec 20 21:07:37 EndeavourOS kernel: audit: type=1110 audit(1766282857.039:246): pid=6661 uid=1000 auid=1000 s>
Dec 20 21:07:37 EndeavourOS kernel: audit: type=1105 audit(1766282857.039:247): pid=6661 uid=1000 auid=1000 s>
Dec 20 21:07:37 EndeavourOS sudo[6661]: pam_unix(sudo:session): session closed for user root
Dec 20 21:07:37 EndeavourOS audit[6661]: AUDIT1106 pid=6661 uid=1000 auid=1000 ses=2 msg='op=PAM:session_clos>
Dec 20 21:07:37 EndeavourOS audit[6661]: AUDIT1104 pid=6661 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred gran>
Dec 20 21:07:37 EndeavourOS kernel: audit: type=1106 audit(1766282857.080:248): pid=6661 uid=1000 auid=1000 s>
Dec 20 21:07:37 EndeavourOS kernel: audit: type=1104 audit(1766282857.080:249): pid=6661 uid=1000 auid=1000 s>
Dec 20 21:08:10 EndeavourOS rtkit-daemon[1099]: Supervising 8 threads of 4 processes of 1 users.
Dec 20 21:09:14 EndeavourOS systemd[951]: app-org.kde.konsole-6634.scope: Consumed 4.309s CPU time, 20.2M mem>
Dec 20 21:09:15 EndeavourOS plasmashell[1083]: Exposed with no visual parent. Window positioning broken.
Dec 20 21:09:16 EndeavourOS systemd[951]: Started Konsole - Terminal.
Dec 20 21:09:16 EndeavourOS systemd[951]: Started app-org.kde.konsole-6794.scope.
Dec 20 21:09:38 EndeavourOS audit[6819]: AUDIT1101 pid=6819 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting g>
Dec 20 21:09:38 EndeavourOS sudo[6819]: liveuser : TTY=pts/0 ; PWD=/home/liveuser ; USER=root ; COMMAND=/usr/>
Dec 20 21:09:38 EndeavourOS kernel: audit: type=1101 audit(1766282978.297:250): pid=6819 uid=1000 auid=1000 s>
Dec 20 21:09:38 EndeavourOS audit[6819]: AUDIT1110 pid=6819 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred gran>
Dec 20 21:09:38 EndeavourOS audit[6819]: AUDIT1105 pid=6819 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open>
Dec 20 21:09:38 EndeavourOS sudo[6819]: pam_unix(sudo:session): session opened for user root(uid=0) by liveus>
Dec 20 21:09:38 EndeavourOS kernel: audit: type=1110 audit(1766282978.299:251): pid=6819 uid=1000 auid=1000 s>
Dec 20 21:09:38 EndeavourOS kernel: audit: type=1105 audit(1766282978.299:252): pid=6819 uid=1000 auid=1000 s>
Dec 20 21:09:38 EndeavourOS sudo[6819]: pam_unix(sudo:session): session closed for user root
Dec 20 21:09:38 EndeavourOS audit[6819]: AUDIT1106 pid=6819 uid=1000 auid=1000 ses=2 msg='op=PAM:session_clos>
Dec 20 21:09:38 EndeavourOS audit[6819]: AUDIT1104 pid=6819 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred gran>
Dec 20 21:09:38 EndeavourOS kernel: audit: type=1106 audit(1766282978.343:253): pid=6819 uid=1000 auid=1000 s>
Dec 20 21:09:38 EndeavourOS kernel: audit: type=1104 audit(1766282978.344:254): pid=6819 uid=1000 auid=1000 s>
Dec 20 21:12:23 EndeavourOS kwin_x11[1061]: XCB error: 152 (BadDamage), sequence: 25011, resource id: 1890639>
Dec 20 21:12:23 EndeavourOS kwin_x11[1061]: XCB error: 3 (BadWindow), sequence: 25012, resource id: 60818311,>
Dec 20 21:15:49 EndeavourOS systemd[951]: app-org.kde.konsole-6794.scope: Consumed 10.585s CPU time, 10.5M me>
Dec 20 21:15:50 EndeavourOS plasmashell[1083]: Exposed with no visual parent. Window positioning broken.
Dec 20 21:15:51 EndeavourOS plasmashell[1083]: Exposed with no visual parent. Window positioning broken.
Dec 20 21:15:52 EndeavourOS systemd[951]: Started Konsole - Terminal.
Dec 20 21:15:52 EndeavourOS systemd[951]: Started app-org.kde.konsole-7019.scope.
Dec 20 21:16:25 EndeavourOS audit[7060]: AUDIT1101 pid=7060 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting g>
Dec 20 21:16:25 EndeavourOS sudo[7060]: liveuser : TTY=pts/0 ; PWD=/home/liveuser ; USER=root ; COMMAND=/usr/>
Dec 20 21:16:25 EndeavourOS kernel: audit: type=1101 audit(1766283385.603:255): pid=7060 uid=1000 auid=1000 s>
Dec 20 21:16:25 EndeavourOS audit[7060]: AUDIT1110 pid=7060 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred gran>
Dec 20 21:16:25 EndeavourOS sudo[7060]: pam_unix(sudo:session): session opened for user root(uid=0) by liveus>
Dec 20 21:16:25 EndeavourOS audit[7060]: AUDIT1105 pid=7060 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open>
Dec 20 21:16:25 EndeavourOS kernel: audit: type=1110 audit(1766283385.604:256): pid=7060 uid=1000 auid=1000 s>
Dec 20 21:16:25 EndeavourOS kernel: audit: type=1105 audit(1766283385.604:257): pid=7060 uid=1000 auid=1000 s>
Dec 20 21:16:25 EndeavourOS audit[7060]: AUDIT1106 pid=7060 uid=1000 auid=1000 ses=2 msg='op=PAM:session_clos>
Dec 20 21:16:25 EndeavourOS audit[7060]: AUDIT1104 pid=7060 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred gran>
Dec 20 21:16:25 EndeavourOS sudo[7060]: pam_unix(sudo:session): session closed for user root
Dec 20 21:16:25 EndeavourOS kernel: audit: type=1106 audit(1766283385.625:258): pid=7060 uid=1000 auid=1000 s>
Dec 20 21:16:25 EndeavourOS kernel: audit: type=1104 audit(1766283385.625:259): pid=7060 uid=1000 auid=1000 s>
Dec 20 21:16:40 EndeavourOS audit[7066]: AUDIT1101 pid=7066 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting g>
Dec 20 21:16:40 EndeavourOS kernel: audit: type=1101 audit(1766283400.067:260): pid=7066 uid=1000 auid=1000 s>
Dec 20 21:16:40 EndeavourOS sudo[7066]: liveuser : TTY=pts/0 ; PWD=/home/liveuser ; USER=root ; COMMAND=/usr/>
Dec 20 21:16:40 EndeavourOS audit[7066]: AUDIT1110 pid=7066 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred gran>
Dec 20 21:16:40 EndeavourOS sudo[7066]: pam_unix(sudo:session): session opened for user root(uid=0) by liveus>
Dec 20 21:16:40 EndeavourOS audit[7066]: AUDIT1105 pid=7066 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open>
Dec 20 21:16:40 EndeavourOS kernel: audit: type=1110 audit(1766283400.069:261): pid=7066 uid=1000 auid=1000 s>
Dec 20 21:16:40 EndeavourOS kernel: audit: type=1105 audit(1766283400.069:262): pid=7066 uid=1000 auid=1000 s>
Dec 20 21:16:40 EndeavourOS udisksd[1187]: Cleaning up mount point /run/media/liveuser/endeavouros (device 8:>
Dec 20 21:16:40 EndeavourOS systemd[1]: run-media-liveuser-endeavouros.mount: Deactivated successfully.
Dec 20 21:16:40 EndeavourOS kernel: EXT4-fs (sda2): unmounting filesystem 2190f2e1-be29-4687-a507-ff295566d4b>
Dec 20 21:16:40 EndeavourOS audit[7066]: AUDIT1106 pid=7066 uid=1000 auid=1000 ses=2 msg='op=PAM:session_clos>
Dec 20 21:16:40 EndeavourOS sudo[7066]: pam_unix(sudo:session): session closed for user root
Dec 20 21:16:40 EndeavourOS audit[7066]: AUDIT1104 pid=7066 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred gran>
Dec 20 21:16:40 EndeavourOS kernel: audit: type=1106 audit(1766283400.102:263): pid=7066 uid=1000 auid=1000 s>
Dec 20 21:16:40 EndeavourOS kernel: audit: type=1104 audit(1766283400.102:264): pid=7066 uid=1000 auid=1000 s>
Dec 20 21:16:40 EndeavourOS dolphin[5935]: Could not load default global viewproperties
Dec 20 21:16:44 EndeavourOS systemd[951]: app-org.kde.dolphin@f9955a257caf4a899b88d1d2824bc27e.service: Consu>
Dec 20 21:16:47 EndeavourOS audit[7084]: AUDIT1101 pid=7084 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting g>
Dec 20 21:16:47 EndeavourOS sudo[7084]: liveuser : TTY=pts/0 ; PWD=/home/liveuser ; USER=root ; COMMAND=/usr/>
Dec 20 21:16:47 EndeavourOS kernel: audit: type=1101 audit(1766283407.506:265): pid=7084 uid=1000 auid=1000 s>
Dec 20 21:16:47 EndeavourOS audit[7084]: AUDIT1110 pid=7084 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred gran>
Dec 20 21:16:47 EndeavourOS sudo[7084]: pam_unix(sudo:session): session opened for user root(uid=0) by liveus>
Dec 20 21:16:47 EndeavourOS audit[7084]: AUDIT1105 pid=7084 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open>
Dec 20 21:16:47 EndeavourOS kernel: audit: type=1110 audit(1766283407.507:266): pid=7084 uid=1000 auid=1000 s>
Dec 20 21:16:47 EndeavourOS kernel: audit: type=1105 audit(1766283407.507:267): pid=7084 uid=1000 auid=1000 s>
Dec 20 21:16:47 EndeavourOS sudo[7084]: pam_unix(sudo:session): session closed for user root
Dec 20 21:16:47 EndeavourOS audit[7084]: AUDIT1106 pid=7084 uid=1000 auid=1000 ses=2 msg='op=PAM:session_clos>
Dec 20 21:16:47 EndeavourOS audit[7084]: AUDIT1104 pid=7084 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred gran>
Dec 20 21:16:47 EndeavourOS kernel: audit: type=1106 audit(1766283407.643:268): pid=7084 uid=1000 auid=1000 s>
Dec 20 21:16:47 EndeavourOS kernel: audit: type=1104 audit(1766283407.643:269): pid=7084 uid=1000 auid=1000 s>
Dec 20 21:17:03 EndeavourOS rtkit-daemon[1099]: Supervising 8 threads of 4 processes of 1 users.
Dec 20 21:17:33 EndeavourOS rtkit-daemon[1099]: Supervising 8 threads of 4 processes of 1 users.
Dec 20 21:17:36 EndeavourOS rtkit-daemon[1099]: Supervising 8 threads of 4 processes of 1 users.
Dec 20 21:17:37 EndeavourOS rtkit-daemon[1099]: Supervising 8 threads of 4 processes of 1 users.
Dec 20 21:18:18 EndeavourOS rtkit-daemon[1099]: Supervising 8 threads of 4 processes of 1 users.
Dec 20 21:18:29 EndeavourOS rtkit-daemon[1099]: Supervising 8 threads of 4 processes of 1 users.
Dec 20 21:18:49 EndeavourOS audit[7512]: AUDIT1101 pid=7512 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting g>
Dec 20 21:18:49 EndeavourOS sudo[7512]: liveuser : TTY=pts/0 ; PWD=/home/liveuser ; USER=root ; COMMAND=/usr/>
Dec 20 21:18:49 EndeavourOS kernel: audit: type=1101 audit(1766283529.381:270): pid=7512 uid=1000 auid=1000 s>
Dec 20 21:18:49 EndeavourOS audit[7512]: AUDIT1110 pid=7512 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred gran>
Dec 20 21:18:49 EndeavourOS sudo[7512]: pam_unix(sudo:session): session opened for user root(uid=0) by liveus>
Dec 20 21:18:49 EndeavourOS audit[7512]: AUDIT1105 pid=7512 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open>
Dec 20 21:18:49 EndeavourOS kernel: audit: type=1110 audit(1766283529.382:271): pid=7512 uid=1000 auid=1000 s>
Dec 20 21:18:49 EndeavourOS kernel: audit: type=1105 audit(1766283529.382:272): pid=7512 uid=1000 auid=1000 s>
Dec 20 21:18:49 EndeavourOS sudo[7512]: pam_unix(sudo:session): session closed for user root
Dec 20 21:18:49 EndeavourOS audit[7512]: AUDIT1106 pid=7512 uid=1000 auid=1000 ses=2 msg='op=PAM:session_clos>
Dec 20 21:18:49 EndeavourOS audit[7512]: AUDIT1104 pid=7512 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred gran>
Dec 20 21:18:49 EndeavourOS kernel: audit: type=1106 audit(1766283529.411:273): pid=7512 uid=1000 auid=1000 s>
Dec 20 21:18:49 EndeavourOS kernel: audit: type=1104 audit(1766283529.411:274): pid=7512 uid=1000 auid=1000 s>
Dec 20 21:18:59 EndeavourOS audit[7518]: AUDIT1101 pid=7518 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting g>
Dec 20 21:18:59 EndeavourOS kernel: audit: type=1101 audit(1766283539.903:275): pid=7518 uid=1000 auid=1000 s>
Dec 20 21:18:59 EndeavourOS sudo[7518]: liveuser : TTY=pts/0 ; PWD=/home/liveuser ; USER=root ; COMMAND=/usr/>
Dec 20 21:18:59 EndeavourOS audit[7518]: AUDIT1110 pid=7518 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred gran>
Dec 20 21:18:59 EndeavourOS sudo[7518]: pam_unix(sudo:session): session opened for user root(uid=0) by liveus>
Dec 20 21:18:59 EndeavourOS audit[7518]: AUDIT1105 pid=7518 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open>
Dec 20 21:18:59 EndeavourOS kernel: audit: type=1110 audit(1766283539.905:276): pid=7518 uid=1000 auid=1000 s>
Dec 20 21:18:59 EndeavourOS kernel: audit: type=1105 audit(1766283539.905:277): pid=7518 uid=1000 auid=1000 s>
Dec 20 21:18:59 EndeavourOS sudo[7518]: pam_unix(sudo:session): session closed for user root
Dec 20 21:18:59 EndeavourOS audit[7518]: AUDIT1106 pid=7518 uid=1000 auid=1000 ses=2 msg='op=PAM:session_clos>
Dec 20 21:18:59 EndeavourOS audit[7518]: AUDIT1104 pid=7518 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred gran>
Dec 20 21:18:59 EndeavourOS kernel: audit: type=1106 audit(1766283539.928:278): pid=7518 uid=1000 auid=1000 s>
Dec 20 21:18:59 EndeavourOS kernel: audit: type=1104 audit(1766283539.928:279): pid=7518 uid=1000 auid=1000 s>
Dec 20 21:19:46 EndeavourOS rtkit-daemon[1099]: Supervising 8 threads of 4 processes of 1 users.
Dec 20 21:21:55 EndeavourOS rtkit-daemon[1099]: Supervising 8 threads of 4 processes of 1 users.
Dec 20 21:21:59 EndeavourOS rtkit-daemon[1099]: Supervising 8 threads of 4 processes of 1 users.
Dec 20 21:24:09 EndeavourOS rtkit-daemon[1099]: Supervising 8 threads of 4 processes of 1 users.
Dec 20 21:24:38 EndeavourOS rtkit-daemon[1099]: Supervising 8 threads of 4 processes of 1 users.
Dec 20 21:24:59 EndeavourOS rtkit-daemon[1099]: Supervising 8 threads of 4 processes of 1 users.
Dec 20 21:26:30 EndeavourOS rtkit-daemon[1099]: Supervising 8 threads of 4 processes of 1 users.
Dec 20 21:26:49 EndeavourOS audit[9005]: AUDIT1101 pid=9005 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting g>
Dec 20 21:26:49 EndeavourOS kernel: audit: type=1101 audit(1766284009.325:280): pid=9005 uid=1000 auid=1000 s>
Dec 20 21:26:58 EndeavourOS audit[9015]: AUDIT1101 pid=9015 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting g>
Dec 20 21:26:58 EndeavourOS kernel: audit: type=1101 audit(1766284018.479:281): pid=9015 uid=1000 auid=1000 s>
Dec 20 21:27:07 EndeavourOS audit[9036]: AUDIT1101 pid=9036 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting g>
Dec 20 21:27:07 EndeavourOS kernel: audit: type=1101 audit(1766284027.412:282): pid=9036 uid=1000 auid=1000 s>
Dec 20 21:27:07 EndeavourOS sudo[9036]: liveuser : TTY=pts/0 ; PWD=/home/liveuser ; USER=root ; COMMAND=/usr/>
Dec 20 21:27:07 EndeavourOS audit[9036]: AUDIT1110 pid=9036 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred gran>
Dec 20 21:27:07 EndeavourOS kernel: audit: type=1110 audit(1766284027.413:283): pid=9036 uid=1000 auid=1000 s>
Dec 20 21:27:07 EndeavourOS sudo[9036]: pam_unix(sudo:session): session opened for user root(uid=0) by liveus>
Dec 20 21:27:07 EndeavourOS audit[9036]: AUDIT1105 pid=9036 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open>
Dec 20 21:27:07 EndeavourOS kernel: audit: type=1105 audit(1766284027.414:284): pid=9036 uid=1000 auid=1000 s>
lines 2681-2707/2707 (END)
Dunno if there’s anything relevant in there, but figured it best to include the entire 2707 lines.
Attempted to arch-chroot into my EOS installation.
EndeavorOS partition on /dev/sda2 mounts fine.
EFI partition on /dev/sda1 returns mount point does not exist.
Arch-chroot on /dev/sda2 returns Can't create chroot on non-directory /dev/sda2
dmesg output (split into 2 messages):
[liveuser@eos-2025.11.24 mnt]$ sudo dmesg
[ 0.000000] Linux version 6.17.8-arch1-1 (linux@archlinux) (gcc (GCC) 15.2.1 20251112, GNU ld (GNU Binutils) 2.45.1) #1 SMP PREEMPT_DYNAMIC Fri, 14 Nov 2025 06:54:20 +0000
[ 0.000000] Command line: initrd=\arch\boot\x86_64\initramfs-linux.img initrd=\arch\boot\intel-ucode.img initrd=\arch\boot\amd-ucode.img archisobasedir=arch archisosearchuuid=2025-11-24-21-31-18-00 cow_spacesize=10G copytoram=n module_blacklist=pcspkr nouveau.modeset=1 i915.modeset=1 radeon.modeset=1 nvme_load=yes
[ 0.000000] x86/CPU: Running old microcode
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x0000000000057fff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000000058000-0x0000000000058fff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000059000-0x000000000009dfff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009e000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000003fffffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000040000000-0x00000000403fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000040400000-0x000000007a6abfff] usable
[ 0.000000] BIOS-e820: [mem 0x000000007a6ac000-0x000000007a6acfff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000007a6ad000-0x000000007a6adfff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000007a6ae000-0x000000008d982fff] usable
[ 0.000000] BIOS-e820: [mem 0x000000008d983000-0x000000008de58fff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000008de59000-0x000000008dec8fff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x000000008dec9000-0x000000008e32dfff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000008e32e000-0x000000008f7fdfff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000008f7fe000-0x000000008f7fefff] usable
[ 0.000000] BIOS-e820: [mem 0x000000008f7ff000-0x000000008fffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000086effffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] APIC: Static calls initialized
[ 0.000000] efi: EFI v2.7 by American Megatrends
[ 0.000000] efi: TPMFinalLog=0x8e2fd000 ACPI 2.0=0x8e277000 ACPI=0x8e277000 SMBIOS=0x8f529000 MEMATTR=0x89d1f018 ESRT=0x8a973718 INITRD=0x7a7cac18 RNG=0x8dec8018 TPMEventLog=0x8dec6018
[ 0.000000] random: crng init done
[ 0.000000] efi: Remove mem51: MMIO range=[0xe0000000-0xefffffff] (256MB) from e820 map
[ 0.000000] e820: remove [mem 0xe0000000-0xefffffff] reserved
[ 0.000000] efi: Not removing mem52: MMIO range=[0xfe000000-0xfe010fff] (68KB) from e820 map
[ 0.000000] efi: Not removing mem53: MMIO range=[0xfec00000-0xfec00fff] (4KB) from e820 map
[ 0.000000] efi: Not removing mem54: MMIO range=[0xfed00000-0xfed00fff] (4KB) from e820 map
[ 0.000000] efi: Not removing mem55: MMIO range=[0xfee00000-0xfee00fff] (4KB) from e820 map
[ 0.000000] efi: Remove mem56: MMIO range=[0xff000000-0xffffffff] (16MB) from e820 map
[ 0.000000] e820: remove [mem 0xff000000-0xffffffff] reserved
[ 0.000000] SMBIOS 2.8 present.
[ 0.000000] DMI: Micro-Star International Co., Ltd. MS-7B48/Z370-A PRO (MS-7B48), BIOS 2.D0 07/06/2024
[ 0.000000] DMI: Memory slots populated: 2/4
[ 0.000000] tsc: Detected 3700.000 MHz processor
[ 0.000000] tsc: Detected 3699.850 MHz TSC
[ 0.001113] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.001115] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.001123] last_pfn = 0x86f000 max_arch_pfn = 0x400000000
[ 0.001126] MTRR map: 4 entries (3 fixed + 1 variable; max 23), built from 10 variable MTRRs
[ 0.001127] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.001457] last_pfn = 0x8f7ff max_arch_pfn = 0x400000000
[ 0.012199] esrt: Reserving ESRT space from 0x000000008a973718 to 0x000000008a973750.
[ 0.012204] e820: update [mem 0x8a973000-0x8a973fff] usable ==> reserved
[ 0.012217] Using GB pages for direct mapping
[ 0.012498] Secure boot disabled
[ 0.012498] RAMDISK: [mem 0x5c6fe000-0x6a7cdfff]
[ 0.013134] ACPI: Early table checksum verification disabled
[ 0.013136] ACPI: RSDP 0x000000008E277000 000024 (v02 ALASKA)
[ 0.013140] ACPI: XSDT 0x000000008E2770B0 0000E4 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.013144] ACPI: FACP 0x000000008E2A5AE8 000114 (v06 ALASKA A M I 01072009 AMI 00010013)
[ 0.013149] ACPI: DSDT 0x000000008E277230 02E8B8 (v02 ALASKA A M I 01072009 INTL 20160422)
[ 0.013151] ACPI: FACS 0x000000008E32DF80 000040
[ 0.013153] ACPI: APIC 0x000000008E2A5C00 0000F4 (v03 ALASKA A M I 01072009 AMI 00010013)
[ 0.013155] ACPI: FPDT 0x000000008E2A5CF8 000044 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.013158] ACPI: FIDT 0x000000008E2A5D40 00009C (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.013160] ACPI: MCFG 0x000000008E2A5DE0 00003C (v01 ALASKA A M I 01072009 MSFT 00000097)
[ 0.013162] ACPI: SSDT 0x000000008E2A5E20 0003A3 (v01 SataRe SataTabl 00001000 INTL 20160422)
[ 0.013164] ACPI: MSDM 0x000000008E2A61C8 000055 (v03 ALASKA A M I 01072009 AMI 00010013)
[ 0.013167] ACPI: SSDT 0x000000008E2A6220 003165 (v02 SaSsdt SaSsdt 00003000 INTL 20160422)
[ 0.013169] ACPI: SSDT 0x000000008E2A9388 002743 (v02 PegSsd PegSsdt 00001000 INTL 20160422)
[ 0.013171] ACPI: HPET 0x000000008E2ABAD0 000038 (v01 INTEL KBL 00000001 MSFT 0000005F)
[ 0.013173] ACPI: SSDT 0x000000008E2ABB08 0011AA (v02 INTEL Ther_Rvp 00001000 INTL 20160422)
[ 0.013176] ACPI: SSDT 0x000000008E2ACCB8 000A2C (v02 INTEL xh_rvp08 00000000 INTL 20160422)
[ 0.013178] ACPI: SSDT 0x000000008E2AD6E8 0017AE (v02 CpuRef CpuSsdt 00003000 INTL 20160422)
[ 0.013180] ACPI: LPIT 0x000000008E2AEE98 000094 (v01 INTEL KBL 00000000 MSFT 0000005F)
[ 0.013183] ACPI: SSDT 0x000000008E2AEF30 000141 (v02 INTEL HdaDsp 00000000 INTL 20160422)
[ 0.013185] ACPI: SSDT 0x000000008E2AF078 00029F (v02 INTEL sensrhub 00000000 INTL 20160422)
[ 0.013187] ACPI: SSDT 0x000000008E2AF318 003002 (v02 INTEL PtidDevc 00001000 INTL 20160422)
[ 0.013189] ACPI: SSDT 0x000000008E2B2320 000517 (v02 INTEL TbtTypeC 00000000 INTL 20160422)
[ 0.013192] ACPI: SSDT 0x000000008E2B2838 000306 (v02 INTEL Wwan 00000001 INTL 20160422)
[ 0.013194] ACPI: DBGP 0x000000008E2B2B40 000034 (v01 INTEL 00000002 MSFT 0000005F)
[ 0.013196] ACPI: DBG2 0x000000008E2B2B78 000054 (v00 INTEL 00000002 MSFT 0000005F)
[ 0.013198] ACPI: TPM2 0x000000008E2B2BD0 000034 (v04 ALASKA A M I 00000001 AMI 00000000)
[ 0.013200] ACPI: BGRT 0x000000008E2B2C08 000038 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.013203] ACPI: WSMT 0x000000008E2B2C40 000028 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.013204] ACPI: Reserving FACP table memory at [mem 0x8e2a5ae8-0x8e2a5bfb]
[ 0.013206] ACPI: Reserving DSDT table memory at [mem 0x8e277230-0x8e2a5ae7]
[ 0.013206] ACPI: Reserving FACS table memory at [mem 0x8e32df80-0x8e32dfbf]
[ 0.013207] ACPI: Reserving APIC table memory at [mem 0x8e2a5c00-0x8e2a5cf3]
[ 0.013208] ACPI: Reserving FPDT table memory at [mem 0x8e2a5cf8-0x8e2a5d3b]
[ 0.013208] ACPI: Reserving FIDT table memory at [mem 0x8e2a5d40-0x8e2a5ddb]
[ 0.013209] ACPI: Reserving MCFG table memory at [mem 0x8e2a5de0-0x8e2a5e1b]
[ 0.013209] ACPI: Reserving SSDT table memory at [mem 0x8e2a5e20-0x8e2a61c2]
[ 0.013210] ACPI: Reserving MSDM table memory at [mem 0x8e2a61c8-0x8e2a621c]
[ 0.013210] ACPI: Reserving SSDT table memory at [mem 0x8e2a6220-0x8e2a9384]
[ 0.013211] ACPI: Reserving SSDT table memory at [mem 0x8e2a9388-0x8e2abaca]
[ 0.013211] ACPI: Reserving HPET table memory at [mem 0x8e2abad0-0x8e2abb07]
[ 0.013212] ACPI: Reserving SSDT table memory at [mem 0x8e2abb08-0x8e2accb1]
[ 0.013212] ACPI: Reserving SSDT table memory at [mem 0x8e2accb8-0x8e2ad6e3]
[ 0.013213] ACPI: Reserving SSDT table memory at [mem 0x8e2ad6e8-0x8e2aee95]
[ 0.013214] ACPI: Reserving LPIT table memory at [mem 0x8e2aee98-0x8e2aef2b]
[ 0.013214] ACPI: Reserving SSDT table memory at [mem 0x8e2aef30-0x8e2af070]
[ 0.013215] ACPI: Reserving SSDT table memory at [mem 0x8e2af078-0x8e2af316]
[ 0.013215] ACPI: Reserving SSDT table memory at [mem 0x8e2af318-0x8e2b2319]
[ 0.013216] ACPI: Reserving SSDT table memory at [mem 0x8e2b2320-0x8e2b2836]
[ 0.013216] ACPI: Reserving SSDT table memory at [mem 0x8e2b2838-0x8e2b2b3d]
[ 0.013217] ACPI: Reserving DBGP table memory at [mem 0x8e2b2b40-0x8e2b2b73]
[ 0.013217] ACPI: Reserving DBG2 table memory at [mem 0x8e2b2b78-0x8e2b2bcb]
[ 0.013218] ACPI: Reserving TPM2 table memory at [mem 0x8e2b2bd0-0x8e2b2c03]
[ 0.013219] ACPI: Reserving BGRT table memory at [mem 0x8e2b2c08-0x8e2b2c3f]
[ 0.013219] ACPI: Reserving WSMT table memory at [mem 0x8e2b2c40-0x8e2b2c67]
[ 0.013312] No NUMA configuration found
[ 0.013313] Faking a node at [mem 0x0000000000000000-0x000000086effffff]
[ 0.013321] NODE_DATA(0) allocated [mem 0x86efd52c0-0x86effffff]
[ 0.013506] Zone ranges:
[ 0.013506] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.013508] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.013509] Normal [mem 0x0000000100000000-0x000000086effffff]
[ 0.013510] Device empty
[ 0.013511] Movable zone start for each node
[ 0.013512] Early memory node ranges
[ 0.013513] node 0: [mem 0x0000000000001000-0x0000000000057fff]
[ 0.013514] node 0: [mem 0x0000000000059000-0x000000000009dfff]
[ 0.013514] node 0: [mem 0x0000000000100000-0x000000003fffffff]
[ 0.013515] node 0: [mem 0x0000000040400000-0x000000007a6abfff]
[ 0.013516] node 0: [mem 0x000000007a6ae000-0x000000008d982fff]
[ 0.013517] node 0: [mem 0x000000008f7fe000-0x000000008f7fefff]
[ 0.013517] node 0: [mem 0x0000000100000000-0x000000086effffff]
[ 0.013520] Initmem setup node 0 [mem 0x0000000000001000-0x000000086effffff]
[ 0.013524] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.013525] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.013542] On node 0, zone DMA: 98 pages in unavailable ranges
[ 0.015796] On node 0, zone DMA32: 1024 pages in unavailable ranges
[ 0.016158] On node 0, zone DMA32: 2 pages in unavailable ranges
[ 0.016202] On node 0, zone DMA32: 7803 pages in unavailable ranges
[ 0.051733] On node 0, zone Normal: 2049 pages in unavailable ranges
[ 0.051757] On node 0, zone Normal: 4096 pages in unavailable ranges
[ 0.051910] ACPI: PM-Timer IO Port: 0x1808
[ 0.051917] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.051918] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[ 0.051919] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[ 0.051919] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[ 0.051920] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[ 0.051920] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[ 0.051921] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[ 0.051921] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[ 0.051922] ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
[ 0.051922] ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
[ 0.051923] ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
[ 0.051923] ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
[ 0.051949] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[ 0.051951] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.051952] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.051956] ACPI: Using ACPI (MADT) for SMP configuration information
[ 0.051957] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.051962] e820: update [mem 0x89ca6000-0x89ce7fff] usable ==> reserved
[ 0.051972] TSC deadline timer available
[ 0.051976] CPU topo: Max. logical packages: 1
[ 0.051976] CPU topo: Max. logical dies: 1
[ 0.051977] CPU topo: Max. dies per package: 1
[ 0.051980] CPU topo: Max. threads per core: 2
[ 0.051981] CPU topo: Num. cores per package: 6
[ 0.051981] CPU topo: Num. threads per package: 12
[ 0.051982] CPU topo: Allowing 12 present CPUs plus 0 hotplug CPUs
[ 0.051997] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.051999] PM: hibernation: Registered nosave memory: [mem 0x00058000-0x00058fff]
[ 0.052000] PM: hibernation: Registered nosave memory: [mem 0x0009e000-0x000fffff]
[ 0.052001] PM: hibernation: Registered nosave memory: [mem 0x40000000-0x403fffff]
[ 0.052003] PM: hibernation: Registered nosave memory: [mem 0x7a6ac000-0x7a6adfff]
[ 0.052004] PM: hibernation: Registered nosave memory: [mem 0x89ca6000-0x89ce7fff]
[ 0.052005] PM: hibernation: Registered nosave memory: [mem 0x8a973000-0x8a973fff]
[ 0.052006] PM: hibernation: Registered nosave memory: [mem 0x8d983000-0x8f7fdfff]
[ 0.052008] PM: hibernation: Registered nosave memory: [mem 0x8f7ff000-0xffffffff]
[ 0.052009] [mem 0x90000000-0xfdffffff] available for PCI devices
[ 0.052010] Booting paravirtualized kernel on bare hardware
[ 0.052011] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1910969940391419 ns
[ 0.057516] setup_percpu: NR_CPUS:8192 nr_cpumask_bits:12 nr_cpu_ids:12 nr_node_ids:1
[ 0.057943] percpu: Embedded 62 pages/cpu s217088 r8192 d28672 u262144
[ 0.057948] pcpu-alloc: s217088 r8192 d28672 u262144 alloc=1*2097152
[ 0.057950] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 -- -- -- --
[ 0.057969] Kernel command line: initrd=\arch\boot\x86_64\initramfs-linux.img initrd=\arch\boot\intel-ucode.img initrd=\arch\boot\amd-ucode.img archisobasedir=arch archisosearchuuid=2025-11-24-21-31-18-00 cow_spacesize=10G copytoram=n module_blacklist=pcspkr nouveau.modeset=1 i915.modeset=1 radeon.modeset=1 nvme_load=yes
[ 0.058112] Unknown kernel command line parameters "archisobasedir=arch archisosearchuuid=2025-11-24-21-31-18-00 cow_spacesize=10G copytoram=n nvme_load=yes", will be passed to user space.
[ 0.058132] printk: log buffer data + meta data: 131072 + 458752 = 589824 bytes
[ 0.060487] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.061674] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.061824] software IO TLB: area num 16.
[ 0.071411] Fallback order for Node 0: 0
[ 0.071413] Built 1 zonelists, mobility grouping on. Total pages: 8373534
[ 0.071415] Policy zone: Normal
[ 0.071593] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[ 0.128513] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=12, Nodes=1
[ 0.128538] Kernel/User page tables isolation: enabled
[ 0.136433] ftrace: allocating 56535 entries in 224 pages
[ 0.136434] ftrace: allocated 224 pages with 3 groups
[ 0.136503] Dynamic Preempt: full
[ 0.136552] rcu: Preemptible hierarchical RCU implementation.
[ 0.136553] rcu: RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=12.
[ 0.136553] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.136554] Trampoline variant of Tasks RCU enabled.
[ 0.136555] Rude variant of Tasks RCU enabled.
[ 0.136555] Tracing variant of Tasks RCU enabled.
[ 0.136556] rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies.
[ 0.136557] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=12
[ 0.136563] RCU Tasks: Setting shift to 4 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=12.
[ 0.136564] RCU Tasks Rude: Setting shift to 4 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=12.
[ 0.136565] RCU Tasks Trace: Setting shift to 4 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=12.
[ 0.141292] NR_IRQS: 524544, nr_irqs: 2152, preallocated irqs: 16
[ 0.141500] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.141722] kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
[ 0.141755] Console: colour dummy device 80x25
[ 0.141757] printk: legacy console [tty0] enabled
[ 0.141797] ACPI: Core revision 20250404
[ 0.142012] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635855245 ns
[ 0.142079] APIC: Switch to symmetric I/O mode setup
[ 0.143303] x2apic: IRQ remapping doesn't support X2APIC mode
[ 0.147636] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.152040] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x6aa99074b1c, max_idle_ns: 881590506587 ns
[ 0.152044] Calibrating delay loop (skipped), value calculated using timer frequency.. 7399.70 BogoMIPS (lpj=3699850)
[ 0.152062] x86/cpu: SGX disabled or unsupported by BIOS.
[ 0.152069] CPU0: Thermal monitoring enabled (TM1)
[ 0.152109] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
[ 0.152110] Last level dTLB entries: 4KB 64, 2MB 32, 4MB 32, 1GB 4
[ 0.152113] process: using mwait in idle threads
[ 0.152115] mitigations: Enabled attack vectors: user_kernel, user_user, guest_host, guest_guest, SMT mitigations: auto
[ 0.152120] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
[ 0.152121] SRBDS: Mitigation: Microcode
[ 0.152122] Spectre V2 : Mitigation: IBRS
[ 0.152122] RETBleed: Mitigation: IBRS
[ 0.152123] Spectre V2 : User space: Mitigation: STIBP via prctl
[ 0.152124] MDS: Mitigation: Clear CPU buffers
[ 0.152124] MMIO Stale Data: Mitigation: Clear CPU buffers
[ 0.152125] VMSCAPE: Mitigation: IBPB before exit to userspace
[ 0.152126] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.152127] Spectre V2 : Spectre v2 / SpectreRSB: Filling RSB on context switch and VMEXIT
[ 0.152128] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.152134] GDS: Vulnerable: No microcode
[ 0.152139] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.152140] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.152141] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.152142] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
[ 0.152143] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
[ 0.152145] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.152146] x86/fpu: xstate_offset[3]: 832, xstate_sizes[3]: 64
[ 0.152148] x86/fpu: xstate_offset[4]: 896, xstate_sizes[4]: 64
[ 0.152149] x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
[ 0.186582] Freeing SMP alternatives memory: 56K
[ 0.186585] pid_max: default: 32768 minimum: 301
[ 0.186615] LSM: initializing lsm=capability,landlock,lockdown,yama,bpf
[ 0.186675] landlock: Up and running.
[ 0.186677] Yama: becoming mindful.
[ 0.186854] LSM support for eBPF active
[ 0.186895] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.186920] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.187420] smpboot: CPU0: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz (family: 0x6, model: 0x9e, stepping: 0xa)
[ 0.187570] Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
[ 0.187590] ... version: 4
[ 0.187591] ... bit width: 48
[ 0.187591] ... generic registers: 4
[ 0.187592] ... value mask: 0000ffffffffffff
[ 0.187593] ... max period: 00007fffffffffff
[ 0.187594] ... fixed-purpose events: 3
[ 0.187595] ... event mask: 000000070000000f
[ 0.187744] signal: max sigframe size: 2032
[ 0.187757] Estimated ratio of average max frequency by base frequency (times 1024): 1217
[ 0.187793] rcu: Hierarchical SRCU implementation.
[ 0.187795] rcu: Max phase no-delay instances is 400.
[ 0.187842] Timer migration: 2 hierarchy levels; 8 children per group; 2 crossnode level
[ 0.188175] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.188260] smp: Bringing up secondary CPUs ...
[ 0.188332] smpboot: x86: Booting SMP configuration:
[ 0.188333] .... node #0, CPUs: #1 #2 #3 #4 #5 #6 #7 #8 #9 #10 #11
[ 0.191553] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[ 0.191553] MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
[ 0.191553] VMSCAPE: SMT on, STIBP is required for full protection. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/vmscape.html for more details.
[ 0.192081] smp: Brought up 1 node, 12 CPUs
[ 0.192081] smpboot: Total of 12 processors activated (88796.40 BogoMIPS)
[ 0.193121] Memory: 32542456K/33494136K available (20065K kernel code, 2946K rwdata, 16204K rodata, 4688K init, 4880K bss, 932000K reserved, 0K cma-reserved)
[ 0.193817] devtmpfs: initialized
[ 0.193817] x86/mm: Memory block size: 128MB
[ 0.196360] ACPI: PM: Registering ACPI NVS region [mem 0x7a6ac000-0x7a6acfff] (4096 bytes)
[ 0.196360] ACPI: PM: Registering ACPI NVS region [mem 0x8dec9000-0x8e32dfff] (4608000 bytes)
[ 0.196360] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.196360] posixtimers hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 0.196360] futex hash table entries: 4096 (262144 bytes on 1 NUMA nodes, total 256 KiB, linear).
[ 0.196360] pinctrl core: initialized pinctrl subsystem
[ 0.196360] PM: RTC time: 01:34:55, date: 2025-12-21
[ 0.197246] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.197606] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.197793] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.197988] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.197996] audit: initializing netlink subsys (disabled)
[ 0.198009] audit: type=2000 audit(1766280895.052:1): state=initialized audit_enabled=0 res=1
[ 0.198131] thermal_sys: Registered thermal governor 'fair_share'
[ 0.198132] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.198133] thermal_sys: Registered thermal governor 'step_wise'
[ 0.198134] thermal_sys: Registered thermal governor 'user_space'
[ 0.198135] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.198145] cpuidle: using governor ladder
[ 0.198148] cpuidle: using governor menu
[ 0.198235] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.198235] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.198235] PCI: ECAM [mem 0xe0000000-0xefffffff] (base 0xe0000000) for domain 0000 [bus 00-ff]
[ 0.198235] PCI: Using configuration type 1 for base access
[ 0.198332] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[ 0.200121] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.200121] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.200121] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.200121] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.200307] raid6: skipped pq benchmark and selected avx2x4
[ 0.200309] raid6: using avx2x2 recovery algorithm
[ 0.200362] fbcon: Taking over console
[ 0.200384] ACPI: Added _OSI(Module Device)
[ 0.200385] ACPI: Added _OSI(Processor Device)
[ 0.200386] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.239893] ACPI: 12 ACPI AML tables successfully acquired and loaded
[ 0.246750] ACPI: Dynamic OEM Table Load:
[ 0.246757] ACPI: SSDT 0xFFFF8C3D40E81800 0003FF (v02 PmRef Cpu0Cst 00003001 INTL 20160422)
[ 0.248302] ACPI: Dynamic OEM Table Load:
[ 0.248307] ACPI: SSDT 0xFFFF8C3D40E79800 00077A (v02 PmRef Cpu0Ist 00003000 INTL 20160422)
[ 0.250336] ACPI: Dynamic OEM Table Load:
[ 0.250342] ACPI: SSDT 0xFFFF8C3D40E8F000 000D14 (v02 PmRef ApIst 00003000 INTL 20160422)
[ 0.252252] ACPI: Dynamic OEM Table Load:
[ 0.252257] ACPI: SSDT 0xFFFF8C3D40E81400 000317 (v02 PmRef ApHwp 00003000 INTL 20160422)
[ 0.253490] ACPI: Dynamic OEM Table Load:
[ 0.253495] ACPI: SSDT 0xFFFF8C3D40E83800 00030A (v02 PmRef ApCst 00003000 INTL 20160422)
[ 0.261838] ACPI: Interpreter enabled
[ 0.261873] ACPI: PM: (supports S0 S3 S4 S5)
[ 0.261875] ACPI: Using IOAPIC for interrupt routing
[ 0.263369] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.263370] PCI: Ignoring E820 reservations for host bridge windows
[ 0.264475] ACPI: Enabled 8 GPEs in block 00 to 7F
[ 0.267281] ACPI: \_SB_.PCI0.PEG0.PG00: New power resource
[ 0.267630] ACPI: \_SB_.PCI0.PEG1.PG01: New power resource
[ 0.267979] ACPI: \_SB_.PCI0.PEG2.PG02: New power resource
[ 0.293630] ACPI: \_TZ_.FN00: New power resource
[ 0.293707] ACPI: \_TZ_.FN01: New power resource
[ 0.293783] ACPI: \_TZ_.FN02: New power resource
[ 0.293857] ACPI: \_TZ_.FN03: New power resource
[ 0.293935] ACPI: \_TZ_.FN04: New power resource
[ 0.295020] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
[ 0.295027] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.295131] acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug SHPCHotplug PME AER]
[ 0.295315] acpi PNP0A08:00: _OSC: OS now controls [PCIeCapability LTR DPC]
[ 0.295316] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[ 0.296169] PCI host bridge to bus 0000:00
[ 0.296173] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.296175] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.296177] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000fffff window]
[ 0.296179] pci_bus 0000:00: root bus resource [mem 0x90000000-0xdfffffff window]
[ 0.296180] pci_bus 0000:00: root bus resource [mem 0xfd000000-0xfe7fffff window]
[ 0.296182] pci_bus 0000:00: root bus resource [bus 00-fe]
[ 0.296259] pci 0000:00:00.0: [8086:3ec2] type 00 class 0x060000 conventional PCI endpoint
[ 0.296330] pci 0000:00:01.0: [8086:1901] type 01 class 0x060400 PCIe Root Port
[ 0.296340] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.296343] pci 0000:00:01.0: bridge window [io 0xe000-0xefff]
[ 0.296345] pci 0000:00:01.0: bridge window [mem 0xde000000-0xdf0fffff]
[ 0.296349] pci 0000:00:01.0: bridge window [mem 0xc0000000-0xd1ffffff 64bit pref]
[ 0.296373] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.296834] pci 0000:00:08.0: [8086:1911] type 00 class 0x088000 conventional PCI endpoint
[ 0.296848] pci 0000:00:08.0: BAR 0 [mem 0xdf32f000-0xdf32ffff 64bit]
[ 0.296941] pci 0000:00:14.0: [8086:a2af] type 00 class 0x0c0330 conventional PCI endpoint
[ 0.296973] pci 0000:00:14.0: BAR 0 [mem 0xdf310000-0xdf31ffff 64bit]
[ 0.297006] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.297730] pci 0000:00:14.2: [8086:a2b1] type 00 class 0x118000 conventional PCI endpoint
[ 0.297762] pci 0000:00:14.2: BAR 0 [mem 0xdf32e000-0xdf32efff 64bit]
[ 0.297855] pci 0000:00:16.0: [8086:a2ba] type 00 class 0x078000 conventional PCI endpoint
[ 0.297897] pci 0000:00:16.0: BAR 0 [mem 0xdf32d000-0xdf32dfff 64bit]
[ 0.297940] pci 0000:00:16.0: PME# supported from D3hot
[ 0.298466] pci 0000:00:17.0: [8086:a282] type 00 class 0x010601 conventional PCI endpoint
[ 0.298495] pci 0000:00:17.0: BAR 0 [mem 0xdf328000-0xdf329fff]
[ 0.298497] pci 0000:00:17.0: BAR 1 [mem 0xdf32c000-0xdf32c0ff]
[ 0.298499] pci 0000:00:17.0: BAR 2 [io 0xf050-0xf057]
[ 0.298501] pci 0000:00:17.0: BAR 3 [io 0xf040-0xf043]
[ 0.298503] pci 0000:00:17.0: BAR 4 [io 0xf020-0xf03f]
[ 0.298505] pci 0000:00:17.0: BAR 5 [mem 0xdf32b000-0xdf32b7ff]
[ 0.298535] pci 0000:00:17.0: PME# supported from D3hot
[ 0.298842] pci 0000:00:1c.0: [8086:a290] type 01 class 0x060400 PCIe Root Port
[ 0.298858] pci 0000:00:1c.0: PCI bridge to [bus 02]
[ 0.298904] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.299422] pci 0000:00:1c.3: [8086:a293] type 01 class 0x060400 PCIe Root Port
[ 0.299438] pci 0000:00:1c.3: PCI bridge to [bus 03]
[ 0.299441] pci 0000:00:1c.3: bridge window [io 0xd000-0xdfff]
[ 0.299443] pci 0000:00:1c.3: bridge window [mem 0xdf200000-0xdf2fffff]
[ 0.299492] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[ 0.300019] pci 0000:00:1d.0: [8086:a298] type 01 class 0x060400 PCIe Root Port
[ 0.300035] pci 0000:00:1d.0: PCI bridge to [bus 04]
[ 0.300039] pci 0000:00:1d.0: bridge window [mem 0xdf100000-0xdf1fffff]
[ 0.300089] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 0.300626] pci 0000:00:1f.0: [8086:a2c9] type 00 class 0x060100 conventional PCI endpoint
[ 0.300977] pci 0000:00:1f.2: [8086:a2a1] type 00 class 0x058000 conventional PCI endpoint
[ 0.301011] pci 0000:00:1f.2: BAR 0 [mem 0xdf324000-0xdf327fff]
[ 0.301287] pci 0000:00:1f.3: [8086:a2f0] type 00 class 0x040300 conventional PCI endpoint
[ 0.301329] pci 0000:00:1f.3: BAR 0 [mem 0xdf320000-0xdf323fff 64bit]
[ 0.301335] pci 0000:00:1f.3: BAR 4 [mem 0xdf300000-0xdf30ffff 64bit]
[ 0.301373] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[ 0.302283] pci 0000:00:1f.4: [8086:a2a3] type 00 class 0x0c0500 conventional PCI endpoint
[ 0.302413] pci 0000:00:1f.4: BAR 0 [mem 0xdf32a000-0xdf32a0ff 64bit]
[ 0.302423] pci 0000:00:1f.4: BAR 4 [io 0xf000-0xf01f]
[ 0.302737] pci 0000:01:00.0: [10de:1b80] type 00 class 0x030000 PCIe Legacy Endpoint
[ 0.302765] pci 0000:01:00.0: BAR 0 [mem 0xde000000-0xdeffffff]
[ 0.302768] pci 0000:01:00.0: BAR 1 [mem 0xc0000000-0xcfffffff 64bit pref]
[ 0.302771] pci 0000:01:00.0: BAR 3 [mem 0xd0000000-0xd1ffffff 64bit pref]
[ 0.302773] pci 0000:01:00.0: BAR 5 [io 0xe000-0xe07f]
[ 0.302775] pci 0000:01:00.0: ROM [mem 0xdf000000-0xdf07ffff pref]
[ 0.302799] pci 0000:01:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.302877] pci 0000:01:00.0: 32.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x16 link at 0000:00:01.0 (capable of 126.016 Gb/s with 8.0 GT/s PCIe x16 link)
[ 0.302949] pci 0000:01:00.1: [10de:10f0] type 00 class 0x040300 PCIe Endpoint
[ 0.302976] pci 0000:01:00.1: BAR 0 [mem 0xdf080000-0xdf083fff]
[ 0.303079] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.303169] acpiphp: Slot [1] registered
[ 0.303173] pci 0000:00:1c.0: PCI bridge to [bus 02]
[ 0.303276] pci 0000:03:00.0: [10ec:8168] type 00 class 0x020000 PCIe Endpoint
[ 0.303324] pci 0000:03:00.0: BAR 0 [io 0xd000-0xd0ff]
[ 0.303329] pci 0000:03:00.0: BAR 2 [mem 0xdf204000-0xdf204fff 64bit]
[ 0.303333] pci 0000:03:00.0: BAR 4 [mem 0xdf200000-0xdf203fff 64bit]
[ 0.303424] pci 0000:03:00.0: supports D1 D2
[ 0.303426] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.303573] pci 0000:00:1c.3: PCI bridge to [bus 03]
[ 0.303673] pci 0000:04:00.0: [15b7:5030] type 00 class 0x010802 PCIe Endpoint
[ 0.303710] pci 0000:04:00.0: BAR 0 [mem 0xdf100000-0xdf103fff 64bit]
[ 0.303856] pci 0000:04:00.0: 31.504 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x4 link at 0000:00:1d.0 (capable of 63.012 Gb/s with 16.0 GT/s PCIe x4 link)
[ 0.303923] pci 0000:00:1d.0: PCI bridge to [bus 04]
[ 0.305437] ACPI: PCI: Interrupt link LNKA configured for IRQ 11
[ 0.305492] ACPI: PCI: Interrupt link LNKB configured for IRQ 10
[ 0.305545] ACPI: PCI: Interrupt link LNKC configured for IRQ 11
[ 0.305598] ACPI: PCI: Interrupt link LNKD configured for IRQ 11
[ 0.305650] ACPI: PCI: Interrupt link LNKE configured for IRQ 11
[ 0.305702] ACPI: PCI: Interrupt link LNKF configured for IRQ 11
[ 0.305755] ACPI: PCI: Interrupt link LNKG configured for IRQ 11
[ 0.305808] ACPI: PCI: Interrupt link LNKH configured for IRQ 11
[ 0.309054] iommu: Default domain type: Translated
[ 0.309054] iommu: DMA domain TLB invalidation policy: lazy mode
[ 0.309160] SCSI subsystem initialized
[ 0.309166] libata version 3.00 loaded.
[ 0.309166] ACPI: bus type USB registered
[ 0.309166] usbcore: registered new interface driver usbfs
[ 0.309166] usbcore: registered new interface driver hub
[ 0.309166] usbcore: registered new device driver usb
[ 0.309166] EDAC MC: Ver: 3.0.0
[ 0.309309] efivars: Registered efivars operations
[ 0.309309] NetLabel: Initializing
[ 0.309309] NetLabel: domain hash size = 128
[ 0.309309] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.309309] NetLabel: unlabeled traffic allowed by default
[ 0.309309] mctp: management component transport protocol core
[ 0.309309] NET: Registered PF_MCTP protocol family
[ 0.309309] PCI: Using ACPI for IRQ routing
[ 0.337752] PCI: pci_cache_line_size set to 64 bytes
[ 0.337792] e820: reserve RAM buffer [mem 0x00058000-0x0005ffff]
[ 0.337794] e820: reserve RAM buffer [mem 0x0009e000-0x0009ffff]
[ 0.337795] e820: reserve RAM buffer [mem 0x7a6ac000-0x7bffffff]
[ 0.337796] e820: reserve RAM buffer [mem 0x89ca6000-0x8bffffff]
[ 0.337798] e820: reserve RAM buffer [mem 0x8a973000-0x8bffffff]
[ 0.337799] e820: reserve RAM buffer [mem 0x8d983000-0x8fffffff]
[ 0.337800] e820: reserve RAM buffer [mem 0x8f7ff000-0x8fffffff]
[ 0.337801] e820: reserve RAM buffer [mem 0x86f000000-0x86fffffff]
[ 0.337836] pci 0000:01:00.0: vgaarb: setting as boot VGA device
[ 0.337836] pci 0000:01:00.0: vgaarb: bridge control possible
[ 0.337836] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.337836] vgaarb: loaded
[ 0.338177] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 0.338177] hpet0: 8 comparators, 64-bit 24.000000 MHz counter
[ 0.340136] clocksource: Switched to clocksource tsc-early
[ 0.340670] VFS: Disk quotas dquot_6.6.0
[ 0.340679] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.340770] pnp: PnP ACPI init
[ 0.340831] system 00:00: [mem 0x40000000-0x403fffff] has been reserved
[ 0.341098] system 00:01: [io 0x0a00-0x0a0f] has been reserved
[ 0.341100] system 00:01: [io 0x0a10-0x0a1f] has been reserved
[ 0.341102] system 00:01: [io 0x0a20-0x0a2f] has been reserved
[ 0.341103] system 00:01: [io 0x0a30-0x0a3f] has been reserved
[ 0.341496] pnp 00:02: [dma 0 disabled]
[ 0.341946] pnp 00:04: [dma 0 disabled]
[ 0.342112] system 00:05: [io 0x0680-0x069f] has been reserved
[ 0.342114] system 00:05: [io 0xffff] has been reserved
[ 0.342116] system 00:05: [io 0xffff] has been reserved
[ 0.342117] system 00:05: [io 0xffff] has been reserved
[ 0.342119] system 00:05: [io 0x1800-0x18fe] could not be reserved
[ 0.342120] system 00:05: [io 0x164e-0x164f] has been reserved
[ 0.342205] system 00:06: [io 0x0800-0x087f] has been reserved
[ 0.342459] system 00:07: [mem 0xfed10000-0xfed17fff] has been reserved
[ 0.342461] system 00:07: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.342463] system 00:07: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.342465] system 00:07: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.342466] system 00:07: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.342468] system 00:07: [mem 0xfed90000-0xfed93fff] has been reserved
[ 0.342469] system 00:07: [mem 0xfed45000-0xfed8ffff] has been reserved
[ 0.342471] system 00:07: [mem 0xff000000-0xffffffff] has been reserved
[ 0.342472] system 00:07: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.342474] system 00:07: [mem 0xdffc0000-0xdffdffff] has been reserved
[ 0.342512] system 00:08: [mem 0xfd000000-0xfdabffff] has been reserved
[ 0.342515] system 00:08: [mem 0xfdad0000-0xfdadffff] has been reserved
[ 0.342516] system 00:08: [mem 0xfdb00000-0xfdffffff] has been reserved
[ 0.342518] system 00:08: [mem 0xfe000000-0xfe01ffff] could not be reserved
[ 0.342519] system 00:08: [mem 0xfe036000-0xfe03bfff] has been reserved
[ 0.342521] system 00:08: [mem 0xfe03d000-0xfe3fffff] has been reserved
[ 0.342808] system 00:09: [io 0xff00-0xfffe] has been reserved
[ 0.344011] system 00:0a: [mem 0xfdaf0000-0xfdafffff] has been reserved
[ 0.344014] system 00:0a: [mem 0xfdae0000-0xfdaeffff] has been reserved
[ 0.344015] system 00:0a: [mem 0xfdac0000-0xfdacffff] has been reserved
[ 0.344906] pnp: PnP ACPI: found 11 devices
[ 0.350777] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.350829] NET: Registered PF_INET protocol family
[ 0.350935] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.365319] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[ 0.365345] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.365489] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.365742] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[ 0.365924] TCP: Hash tables configured (established 262144 bind 65536)
[ 0.366009] MPTCP token hash table entries: 32768 (order: 7, 786432 bytes, linear)
[ 0.366107] UDP hash table entries: 16384 (order: 8, 1048576 bytes, linear)
[ 0.366227] UDP-Lite hash table entries: 16384 (order: 8, 1048576 bytes, linear)
[ 0.366331] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.366337] NET: Registered PF_XDP protocol family
[ 0.366349] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.366352] pci 0000:00:01.0: bridge window [io 0xe000-0xefff]
[ 0.366355] pci 0000:00:01.0: bridge window [mem 0xde000000-0xdf0fffff]
[ 0.366357] pci 0000:00:01.0: bridge window [mem 0xc0000000-0xd1ffffff 64bit pref]
[ 0.366361] pci 0000:00:1c.0: PCI bridge to [bus 02]
[ 0.366367] pci 0000:00:1c.3: PCI bridge to [bus 03]
[ 0.366369] pci 0000:00:1c.3: bridge window [io 0xd000-0xdfff]
[ 0.366372] pci 0000:00:1c.3: bridge window [mem 0xdf200000-0xdf2fffff]
[ 0.366377] pci 0000:00:1d.0: PCI bridge to [bus 04]
[ 0.366380] pci 0000:00:1d.0: bridge window [mem 0xdf100000-0xdf1fffff]
[ 0.366385] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.366386] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.366388] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000fffff window]
[ 0.366389] pci_bus 0000:00: resource 7 [mem 0x90000000-0xdfffffff window]
[ 0.366390] pci_bus 0000:00: resource 8 [mem 0xfd000000-0xfe7fffff window]
[ 0.366392] pci_bus 0000:01: resource 0 [io 0xe000-0xefff]
[ 0.366393] pci_bus 0000:01: resource 1 [mem 0xde000000-0xdf0fffff]
[ 0.366394] pci_bus 0000:01: resource 2 [mem 0xc0000000-0xd1ffffff 64bit pref]
[ 0.366396] pci_bus 0000:03: resource 0 [io 0xd000-0xdfff]
[ 0.366397] pci_bus 0000:03: resource 1 [mem 0xdf200000-0xdf2fffff]
[ 0.366398] pci_bus 0000:04: resource 1 [mem 0xdf100000-0xdf1fffff]
[ 0.366793] pci 0000:01:00.1: extending delay after power-on from D3hot to 20 msec
[ 0.366817] pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
[ 0.366854] PCI: CLS 64 bytes, default 64
[ 0.366899] pci 0000:00:1f.1: [8086:a2a0] type 00 class 0x058000 conventional PCI endpoint
[ 0.367033] pci 0000:00:1f.1: BAR 0 [mem 0xfd000000-0xfdffffff 64bit]
[ 0.367157] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.367158] software IO TLB: mapped [mem 0x0000000085ca6000-0x0000000089ca6000] (64MB)
[ 0.367227] Trying to unpack rootfs image as initramfs...
[ 0.367257] platform rtc_cmos: registered platform RTC device (no PNP device found)
[ 0.390045] Initialise system trusted keyrings
[ 0.390054] Key type blacklist registered
[ 0.390126] workingset: timestamp_bits=36 max_order=23 bucket_order=0
[ 0.390391] fuse: init (API version 7.44)
[ 0.390492] integrity: Platform Keyring initialized
[ 0.390494] integrity: Machine keyring initialized
[ 0.400724] xor: automatically using best checksumming function avx
[ 0.400727] Key type asymmetric registered
[ 0.400729] Asymmetric key parser 'x509' registered
[ 0.400753] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.400840] io scheduler mq-deadline registered
[ 0.400841] io scheduler kyber registered
[ 0.400856] io scheduler bfq registered
[ 0.401537] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.402376] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0
[ 0.402399] ACPI: button: Sleep Button [SLPB]
[ 0.402429] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 0.402445] ACPI: button: Power Button [PWRB]
[ 0.402471] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 0.403458] ACPI: button: Power Button [PWRF]
[ 0.404636] thermal LNXTHERM:00: registered as thermal_zone0
[ 0.404639] ACPI: thermal: Thermal Zone [TZ00] (28 C)
[ 0.404787] thermal LNXTHERM:01: registered as thermal_zone1
[ 0.404789] ACPI: thermal: Thermal Zone [TZ01] (30 C)
[ 0.404986] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.405336] 00:04: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[ 0.406978] serial8250: ttyS1 at I/O 0x2f8 (irq = 3, base_baud = 115200) is a 16550A
[ 0.408648] Non-volatile memory driver v1.3
[ 0.408650] Linux agpgart interface v0.103
[ 0.481924] ACPI: bus type drm_connector registered
[ 0.494947] ahci 0000:00:17.0: AHCI vers 0001.0301, 32 command slots, 6 Gbps, SATA mode
[ 0.494951] ahci 0000:00:17.0: 6/6 ports implemented (port mask 0x3f)
[ 0.494953] ahci 0000:00:17.0: flags: 64bit ncq sntf led clo only pio slum part ems deso sadm sds apst
[ 0.505009] scsi host0: ahci
[ 0.505293] scsi host1: ahci
[ 0.505524] scsi host2: ahci
[ 0.505633] scsi host3: ahci
[ 0.505706] scsi host4: ahci
[ 0.505767] scsi host5: ahci
[ 0.505794] ata1: SATA max UDMA/133 abar m2048@0xdf32b000 port 0xdf32b100 irq 124 lpm-pol 3
[ 0.505797] ata2: SATA max UDMA/133 abar m2048@0xdf32b000 port 0xdf32b180 irq 124 lpm-pol 3
[ 0.505798] ata3: SATA max UDMA/133 abar m2048@0xdf32b000 port 0xdf32b200 irq 124 lpm-pol 3
[ 0.505800] ata4: SATA max UDMA/133 abar m2048@0xdf32b000 port 0xdf32b280 irq 124 lpm-pol 3
[ 0.505802] ata5: SATA max UDMA/133 abar m2048@0xdf32b000 port 0xdf32b300 irq 124 lpm-pol 3
[ 0.505803] ata6: SATA max UDMA/133 abar m2048@0xdf32b000 port 0xdf32b380 irq 124 lpm-pol 3
[ 0.506027] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 0.506032] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[ 0.507096] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x0000000000009810
[ 0.507288] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 0.507292] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ 0.507294] xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
[ 0.507326] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.17
[ 0.507329] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.507330] usb usb1: Product: xHCI Host Controller
[ 0.507331] usb usb1: Manufacturer: Linux 6.17.8-arch1-1 xhci-hcd
[ 0.507333] usb usb1: SerialNumber: 0000:00:14.0
[ 0.507495] hub 1-0:1.0: USB hub found
[ 0.507511] hub 1-0:1.0: 16 ports detected
[ 0.509579] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.17
[ 0.509582] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.509584] usb usb2: Product: xHCI Host Controller
[ 0.509585] usb usb2: Manufacturer: Linux 6.17.8-arch1-1 xhci-hcd
[ 0.509586] usb usb2: SerialNumber: 0000:00:14.0
[ 0.509691] hub 2-0:1.0: USB hub found
[ 0.509703] hub 2-0:1.0: 10 ports detected
[ 0.511080] usbcore: registered new interface driver usbserial_generic
[ 0.511085] usbserial: USB Serial support registered for generic
[ 0.511143] i8042: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[ 0.511145] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 0.511825] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.512063] rtc_cmos rtc_cmos: RTC can wake from S4
[ 0.512755] rtc_cmos rtc_cmos: registered as rtc0
[ 0.512881] rtc_cmos rtc_cmos: setting system clock to 2025-12-21T01:34:55 UTC (1766280895)
[ 0.512901] rtc_cmos rtc_cmos: alarms up to one month, y3k, 114 bytes nvram
[ 0.513285] intel_pstate: Intel P-state driver initializing
[ 0.513737] intel_pstate: Disabling energy efficiency optimization
[ 0.513738] intel_pstate: HWP enabled
[ 0.514100] simple-framebuffer simple-framebuffer.0: [drm] Registered 1 planes with drm panic
[ 0.514102] [drm] Initialized simpledrm 1.0.0 for simple-framebuffer.0 on minor 0
[ 0.515900] Console: switching to colour frame buffer device 128x48
[ 0.517568] simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
[ 0.518560] hid: raw HID events driver (C) Jiri Kosina
[ 0.518596] usbcore: registered new interface driver usbhid
[ 0.518597] usbhid: USB HID core driver
[ 0.518672] drop_monitor: Initializing network drop monitor service
[ 0.518757] NET: Registered PF_INET6 protocol family
[ 0.519115] Segment Routing with IPv6
[ 0.519116] RPL Segment Routing with IPv6
[ 0.519122] In-situ OAM (IOAM) with IPv6
[ 0.519135] NET: Registered PF_PACKET protocol family
[ 0.519930] microcode: Current revision: 0x000000ea
[ 0.520303] IPI shorthand broadcast: enabled
[ 0.522095] sched_clock: Marking stable (518002093, 3418664)->(526141494, -4720737)
[ 0.522403] registered taskstats version 1
[ 0.523348] Loading compiled-in X.509 certificates
[ 0.532693] Freeing initrd memory: 230208K
[ 0.537292] Loaded X.509 cert 'Build time autogenerated kernel key: c03c1fe1402d6c6e461f97d145a2c0ada6431430'
[ 0.539322] zswap: loaded using pool zstd/zsmalloc
[ 0.539400] Demotion targets for Node 0: null
[ 0.539628] Key type .fscrypt registered
[ 0.539630] Key type fscrypt-provisioning registered
[ 0.540079] Btrfs loaded, zoned=yes, fsverity=yes
[ 0.540107] Key type big_key registered
[ 0.541607] PM: Magic number: 5:747:559
[ 0.541620] tty ttyS31: hash matches
[ 0.541622] port serial8250:0.30: hash matches
[ 0.542576] RAS: Correctable Errors collector initialized.
[ 0.546215] clk: Disabling unused clocks
[ 0.546216] PM: genpd: Disabling unused power domains
[ 0.744540] usb 1-3: new high-speed USB device number 2 using xhci_hcd
[ 0.814509] ata4: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 0.814541] ata2: SATA link down (SStatus 4 SControl 300)
[ 0.814575] ata5: SATA link down (SStatus 4 SControl 300)
[ 0.814608] ata1: SATA link down (SStatus 4 SControl 300)
[ 0.814644] ata6: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 0.814678] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 0.820264] ata4.00: ACPI cmd f5/00:00:00:00:00:00(SECURITY FREEZE LOCK) filtered out
[ 0.820279] ata4.00: ACPI cmd b1/c1:00:00:00:00:00(DEVICE CONFIGURATION OVERLAY) filtered out
[ 0.820296] ata3.00: ACPI cmd f5/00:00:00:00:00:00(SECURITY FREEZE LOCK) filtered out
[ 0.820310] ata3.00: ACPI cmd b1/c1:00:00:00:00:00(DEVICE CONFIGURATION OVERLAY) filtered out
[ 0.820864] ata4.00: ATA-10: WDC WD10EZEX-08WN4A0, 02.01A02, max UDMA/100
[ 0.820897] ata3.00: ATA-11: WDC WDS100T2B0A-00SM50, 415020WD, max UDMA/133
[ 0.821312] ata3.00: 1953525168 sectors, multi 1: LBA48 NCQ (depth 32), AA
[ 0.821656] ata6.00: ACPI cmd f5/00:00:00:00:00:00(SECURITY FREEZE LOCK) filtered out
[ 0.821671] ata6.00: ACPI cmd b1/c1:00:00:00:00:00(DEVICE CONFIGURATION OVERLAY) filtered out
[ 0.821935] ata4.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ 0.821958] ata4.00: Features: DIPM NCQ-prio
[ 0.824402] ata4.00: ACPI cmd f5/00:00:00:00:00:00(SECURITY FREEZE LOCK) filtered out
[ 0.824417] ata4.00: ACPI cmd b1/c1:00:00:00:00:00(DEVICE CONFIGURATION OVERLAY) filtered out
[ 0.824991] ata3.00: Features: Dev-Sleep DIPM
[ 0.827475] ata4.00: configured for UDMA/100
[ 0.827502] ata6.00: ATA-9: SanDisk SDSSDA120G, Z32070RL, max UDMA/133
[ 0.827549] ata3.00: ACPI cmd f5/00:00:00:00:00:00(SECURITY FREEZE LOCK) filtered out
[ 0.827564] ata3.00: ACPI cmd b1/c1:00:00:00:00:00(DEVICE CONFIGURATION OVERLAY) filtered out
[ 0.829889] ata6.00: 234441648 sectors, multi 1: LBA48 NCQ (depth 32), AA
[ 0.831776] ata3.00: configured for UDMA/133
[ 0.831913] ahci 0000:00:17.0: port does not support device sleep
[ 0.832316] scsi 2:0:0:0: Direct-Access ATA WDC WDS100T2B0A 20WD PQ: 0 ANSI: 5
[ 0.833197] sd 2:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 0.833238] sd 2:0:0:0: [sda] Write Protect is off
[ 0.833249] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 0.833305] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 0.833383] scsi 3:0:0:0: Direct-Access ATA WDC WD10EZEX-08W 1A02 PQ: 0 ANSI: 5
[ 0.833402] sd 2:0:0:0: [sda] Preferred minimum I/O size 512 bytes
[ 0.834327] sd 3:0:0:0: [sdb] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 0.834339] sd 3:0:0:0: [sdb] 4096-byte physical blocks
[ 0.834363] sd 3:0:0:0: [sdb] Write Protect is off
[ 0.834370] sd 3:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 0.834405] sd 3:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 0.834482] sd 3:0:0:0: [sdb] Preferred minimum I/O size 4096 bytes
[ 0.838401] ata6.00: Features: Dev-Sleep DIPM
[ 0.844643] sda: sda1 sda2
[ 0.844925] sd 2:0:0:0: [sda] Attached SCSI disk
[ 0.847099] ata6.00: ACPI cmd f5/00:00:00:00:00:00(SECURITY FREEZE LOCK) filtered out
[ 0.847113] ata6.00: ACPI cmd b1/c1:00:00:00:00:00(DEVICE CONFIGURATION OVERLAY) filtered out
[ 0.859080] sdb: sdb1
[ 0.859301] sd 3:0:0:0: [sdb] Attached SCSI disk
[ 0.863815] ata6.00: configured for UDMA/133
[ 0.866459] ahci 0000:00:17.0: port does not support device sleep
[ 0.868446] usb 1-3: New USB device found, idVendor=0781, idProduct=5575, bcdDevice= 2.01
[ 0.868461] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 0.868469] usb 1-3: Product: Cruzer Glide
[ 0.868475] usb 1-3: Manufacturer: SanDisk
[ 0.868480] usb 1-3: SerialNumber: 20042204920C67D02EA1
[ 0.869351] scsi 5:0:0:0: Direct-Access ATA SanDisk SDSSDA12 70RL PQ: 0 ANSI: 5
[ 0.870083] sd 5:0:0:0: [sdc] 234441648 512-byte logical blocks: (120 GB/112 GiB)
[ 0.870120] sd 5:0:0:0: [sdc] Write Protect is off
[ 0.870127] sd 5:0:0:0: [sdc] Mode Sense: 00 3a 00 00
[ 0.870162] sd 5:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 0.870223] sd 5:0:0:0: [sdc] Preferred minimum I/O size 512 bytes
[ 0.880319] sdc: sdc1 sdc2 sdc3 sdc4
[ 0.881112] sd 5:0:0:0: [sdc] Attached SCSI disk
[ 0.886683] Freeing unused decrypted memory: 2028K
[ 0.889219] Freeing unused kernel image (initmem) memory: 4688K
[ 0.889513] Write protecting the kernel read-only data: 36864k
[ 0.890906] Freeing unused kernel image (text/rodata gap) memory: 412K
[ 0.891399] Freeing unused kernel image (rodata/data gap) memory: 180K
[ 0.960413] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 0.960416] rodata_test: all tests were successful
[ 0.960417] x86/mm: Checking user space page tables
[ 0.982444] usb 1-7: new full-speed USB device number 3 using xhci_hcd
[ 0.992007] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 0.992011] Run /init as init process
[ 0.992012] with arguments:
[ 0.992012] /init
[ 0.992013] with environment:
[ 0.992014] HOME=/
[ 0.992015] TERM=linux
[ 0.992015] archisobasedir=arch
[ 0.992016] archisosearchuuid=2025-11-24-21-31-18-00
[ 0.992017] cow_spacesize=10G
[ 0.992017] copytoram=n
[ 0.992018] nvme_load=yes
[ 1.353762] Key type psk registered
[ 1.371331] r8169 0000:03:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 1.375775] nvme nvme0: pci function 0000:04:00.0
[ 1.376153] usb 1-7: New USB device found, idVendor=1038, idProduct=12aa, bcdDevice= 0.07
[ 1.376156] usb 1-7: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.376157] usb 1-7: Product: SteelSeries Arctis 5
[ 1.376158] usb 1-7: Manufacturer: SteelSeries
[ 1.376160] usb 1-7: SerialNumber: 00000000
[ 1.379088] r8169 0000:03:00.0 eth0: RTL8168h/8111h, 30:9c:23:9d:99:d8, XID 541, IRQ 127
[ 1.379091] r8169 0000:03:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
[ 1.392465] tsc: Refined TSC clocksource calibration: 3695.999 MHz
[ 1.392486] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x6a8d2284b57, max_idle_ns: 881590451434 ns
[ 1.392577] clocksource: Switched to clocksource tsc
[ 1.404694] nvme nvme0: 12/0/0 default/read/poll queues
[ 1.408710] nvme0n1: p1
[ 1.486768] input: SteelSeries SteelSeries Arctis 5 as /devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.5/0003:1038:12AA.0001/input/input4
[ 1.537893] hid-generic 0003:1038:12AA.0001: input,hidraw0: USB HID v1.11 Device [SteelSeries SteelSeries Arctis 5] on usb-0000:00:14.0-7/input5
[ 1.649530] usb 1-8: new full-speed USB device number 4 using xhci_hcd
[ 1.779456] usb 1-8: New USB device found, idVendor=1b1c, idProduct=1b8b, bcdDevice= 3.20
[ 1.779470] usb 1-8: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.779478] usb 1-8: Product: CORSAIR SCIMITAR RGB ELITE Gaming Mouse
[ 1.779484] usb 1-8: Manufacturer: Corsair
[ 1.779490] usb 1-8: SerialNumber: 1401F03BAF7D21015FB3CE66F5001C04
[ 1.786988] input: Corsair CORSAIR SCIMITAR RGB ELITE Gaming Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-8/1-8:1.0/0003:1B1C:1B8B.0002/input/input5
[ 1.787381] input: Corsair CORSAIR SCIMITAR RGB ELITE Gaming Mouse Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-8/1-8:1.0/0003:1B1C:1B8B.0002/input/input6
[ 1.837838] input: Corsair CORSAIR SCIMITAR RGB ELITE Gaming Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-8/1-8:1.0/0003:1B1C:1B8B.0002/input/input7
[ 1.838158] input: Corsair CORSAIR SCIMITAR RGB ELITE Gaming Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-8/1-8:1.0/0003:1B1C:1B8B.0002/input/input8
[ 1.838518] input: Corsair CORSAIR SCIMITAR RGB ELITE Gaming Mouse Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-8/1-8:1.0/0003:1B1C:1B8B.0002/input/input9
[ 1.839161] hid-generic 0003:1B1C:1B8B.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Corsair CORSAIR SCIMITAR RGB ELITE Gaming Mouse] on usb-0000:00:14.0-8/input0
