Need help fixing my boot install
I need help fixing my boot sequence for my system. I have it mostly fixed thanks to this thread and specifically this solution. Problem is, the last two steps I can’t do because I’m using systemd and not grub. So I don’t know how to change the boot options for systemd so it doesn’t try to reference an invalid UUID of a device.
Do you know the wiki? https://discovery.endeavouros.com/installation/systemd-boot/2022/12/
Thanks for the link. I actually found another thread on the forum that basically says the same thing. I’m sorry for the redundant thread.
