Need help deciphering VLC errors
thrift store DVD score of three Stones documentaries. The DVD boxes are in French and English.
My theories:
  1. are these regional errors and all is lost?
  2. one magic AUR package to make all this go away?
  3. two magic AUR packages to make all this go away?
  4. handbrake here I come?
  5. I’m out of theories.
thanks for any kick in the rear towards the right approach in order to play these dvds on my PC (so I can rip or convert to iso lager)
graci-
if you have mpv installed you can check if the disk is at least playable with this command
mpv dvd://
make sure the dvd is actually playable first. I know times handbrake doesn’t always see the disk and I have to reload it. (the disk)
came back to edit that the lo-res (pirate?) DVD does play on my DVD player/TV
For the codecs, you need to install the plugins from the repo. They just split everything to its own packages. So that is what it is.
I wasn’t going use Handbrake except maybe to take it a digital friendly format for usb. Let me try it
How about trying one magic repo package?
Assuming it’s not already installed:
sudo pacman -Syu vlc-plugins-all
This will install all plugins, so your VLC will be ready for anything you throw at it.
yeah that is correct arch split the vlc packages I remember some convo around here about that now.
got it.
I always heard it was easier to rip or create mp4 from VLC so wanted to try it.
stand by for followup
I picked a hell of a start for getting rid of my plastic DVD collection :slight_smile:
Handbrake defaults to this ( or at least it did when I installed it) I changed mine over to mkv
@Stagger_Lee’s idea of VLC plugins worked. SOLVED!
Got some Stones action now.
That was a little to easy :slight_smile: .
Thank you all
I should use MKV. good catch. my tv adores the mkvs but not all the mp4s.
