I was following this guide here
and everything seemed to be okay , until I booted from a snapshot
this is journalctl output from snapshot boot.
journalctl -b | grep -i “Failed”
Jul 05 22:31:07 EndeavousOS kernel: nvidia: module verification failed: signature and/or required key missing - tainting kernel
Jul 05 22:31:09 EndeavousOS kernel: NVRM: GPU0 nvAssertOkFailedNoLog: Assertion failed: Invalid data passed [NV_ERR_INVALID_DATA] (0x00000025) returned from PlatformRequestHandler failed to get target temp from SBIOS @ platform_request_handler_ctrl.c:2174
Jul 05 22:31:09 EndeavousOS kernel: NVRM: GPU0 nvAssertOkFailedNoLog: Assertion failed: Invalid data passed [NV_ERR_INVALID_DATA] (0x00000025) returned from PlatformRequestHandler failed to get platform power mode from SBIOS @ platform_request_handler_ctrl.c:2117
Jul 05 22:31:09 EndeavousOS kernel: pci 10000:e0:06.0: bridge window [io size 0x1000]: failed to assign
Jul 05 22:31:09 EndeavousOS kernel: pci 10000:e0:1d.0: bridge window [io size 0x1000]: failed to assign
Jul 05 22:31:11 EndeavousOS systemd[1]: systemd-remount-fs.service: Failed with result ‘exit-code’.
Jul 05 22:31:11 EndeavousOS systemd[1]: Failed to start Remount Root and Kernel File Systems.
Jul 05 22:31:11 EndeavousOS systemd-remount-fs[521]: mount: /: fsconfig() failed: overlay: No changes allowed in reconfigure.
Jul 05 22:31:11 EndeavousOS systemd-remount-fs[521]: dmesg(1) may have more information after failed mount system call.
Jul 05 22:31:12 EndeavousOS (udev-worker)[583]: cfg80211: Process ‘/usr/bin/set-wireless-regdom’ failed with exit code 1.
Jul 05 22:31:12 EndeavousOS systemd-remount-fs[681]: mount: /: fsconfig() failed: overlay: No changes allowed in reconfigure.
Jul 05 22:31:12 EndeavousOS systemd-remount-fs[681]: dmesg(1) may have more information after failed mount system call.
Jul 05 22:31:12 EndeavousOS systemd[1]: systemd-remount-fs.service: Failed with result ‘exit-code’.
Jul 05 22:31:12 EndeavousOS systemd[1]: Failed to start Remount Root and Kernel File Systems.
Jul 05 22:31:13 EndeavousOS avahi-daemon[734]: Failed to parse address ‘fe80::e21c:fcff:fe63:7973%wlan0’, ignoring.
Jul 05 22:31:14 EndeavousOS dbus-broker-launch[731]: Activation request for ‘org.freedesktop.home1’ failed: The systemd unit ‘dbus-org.freedesktop.home1.service’ could not be found.
Jul 05 22:31:15 EndeavousOS wireplumber[946]: default: Failed to get percentage from UPower: org.freedesktop.DBus.Error.NameHasNoOwner
Jul 05 22:31:17 EndeavousOS dbus-broker-launch[731]: Activation request for ‘org.freedesktop.resolve1’ failed: The systemd unit ‘dbus-org.freedesktop.resolve1.service’ could not be found.
Jul 05 22:31:17 EndeavousOS NetworkManager[737]: ((../NetworkManager/src/libnm-systemd-core/src/libsystemd/sd-event/sd-event.c:4458)): assertion ‘’ failed
Jul 05 22:31:17 EndeavousOS plasma-login-greeter[942]: failed to create compose table
Jul 05 22:31:18 EndeavousOS kwin_wayland[895]: atomic commit failed: Permission denied
Jul 05 22:31:18 EndeavousOS kwin_wayland[895]: Failed to open drm node: “/dev/dri/card0”
Jul 05 22:31:21 EndeavousOS dbus-broker-launch[731]: Activation request for ‘org.freedesktop.ModemManager1’ failed: The systemd unit ‘dbus-org.freedesktop.ModemManager1.service’ could not be found.
Jul 05 22:31:21 EndeavousOS kded6[1245]: Failed enumerating MM objects: “org.freedesktop.DBus.Error.NameHasNoOwner”
“Could not activate remote peer ‘org.freedesktop.ModemManager1’: activation request failed: unknown unit”
Jul 05 22:31:21 EndeavousOS dbus-broker-launch[731]: Activation request for ‘org.bluez’ failed: The systemd unit ‘dbus-org.bluez.service’ could not be found.
Jul 05 22:31:21 EndeavousOS kded6[1245]: PendingCall Error: “Could not activate remote peer ‘org.bluez’: activation request failed: unknown unit”
Jul 05 22:31:22 EndeavousOS org_kde_powerdevil[1291]: org.kde.powerdevil.chargethresholdhelper.getthreshold failed “Charge thresholds are not supported by the kernel for this hardware”
Jul 05 22:31:22 EndeavousOS ksmserver[1243]: Failed to register with host portal QDBusError(“org.freedesktop.portal.Error.Failed”, “Could not register app ID: App info not found for ‘org.kde.ksmserver’”)
Jul 05 22:31:22 EndeavousOS xembedsniproxy[1292]: Failed to register with host portal QDBusError(“org.freedesktop.portal.Error.Failed”, “Could not register app ID: App info not found for ‘org.kde.xembedsniproxy’”)
Jul 05 22:31:22 EndeavousOS gmenudbusmenuproxy[1288]: Failed to register with host portal QDBusError(“org.freedesktop.portal.Error.Failed”, “Could not register app ID: App info not found for ‘org.kde.gmenudbusmenuproxy’”)
Jul 05 22:31:22 EndeavousOS polkit-kde-authentication-agent-1[1290]: Failed to register with host portal QDBusError(“org.freedesktop.portal.Error.Failed”, “Could not register app ID: Unable to open /proc/1290/root”)
Jul 05 22:31:22 EndeavousOS kactivitymanagerd[1281]: Failed to register with host portal QDBusError(“org.freedesktop.portal.Error.Failed”, “Could not register app ID: App info not found for ‘org.kde.ActivityManager’”)
Jul 05 22:31:22 EndeavousOS kded6[1245]: Failed to register with host portal QDBusError(“org.freedesktop.portal.Error.Failed”, “Could not register app ID: App info not found for ‘org.kde.kded6’”)
Jul 05 22:31:22 EndeavousOS org_kde_powerdevil[1291]: Failed to register with host portal QDBusError(“org.freedesktop.portal.Error.Failed”, “Could not register app ID: App info not found for ‘org.kde.org_kde_powerdevil’”)
Jul 05 22:31:22 EndeavousOS org_kde_powerdevil[1291]: Failed to register with host portal QDBusError(“org.freedesktop.portal.Error.Failed”, “Could not register app ID: Connection already associated with an application ID”)
Jul 05 22:31:22 EndeavousOS ksecretd[1067]: Failed to register with host portal QDBusError(“org.freedesktop.portal.Error.Failed”, “Could not register app ID: Connection already associated with an application ID”)
Jul 05 22:31:22 EndeavousOS kaccess[1289]: Failed to register with host portal QDBusError(“org.freedesktop.portal.Error.Failed”, “Could not register app ID: Connection already associated with an application ID”)
Jul 05 22:31:22 EndeavousOS python[1488]: Failed to register with host portal QDBusError(“org.freedesktop.portal.Error.Failed”, “Could not register app ID: App info not found for ‘’”)
Jul 05 22:31:22 EndeavousOS kdeconnectd[1437]: Failed to register with host portal QDBusError(“org.freedesktop.portal.Error.Failed”, “Could not register app ID: Connection already associated with an application ID”)
Jul 05 22:31:22 EndeavousOS xdg-desktop-portal-kde[1585]: Failed to register with host portal QDBusError(“org.freedesktop.portal.Error.Failed”, “Could not register app ID: Connection already associated with an application ID”)
Jul 05 22:31:22 EndeavousOS plasmashell[1256]: Failed to register with host portal QDBusError(“org.freedesktop.portal.Error.Failed”, “Could not register app ID: Connection already associated with an application ID”)
Jul 05 22:31:25 EndeavousOS konsole[1645]: failed to create compose table
I don’t understand these completely ,but some seem concerning to me
Kindly guide me .
What should I do?
and before anyone asks , I installed most packages from pacman ,
limine-dracut-support
limine-snapper-sync,
Only these were installed from AUR and I inspected the pkgbuild as well ( to the best of ym knowledge ofcourse)
