Native Resolution on LG 29" Ultrawide Monitor
Greetings everybody! I have a freshly installed EOS Gemini system and I cannot get my system to recognize the native resolution of my 29" LG Ultrawide display, thus locking it at 1920x1080 instead of the normal resolution of 2560x1080 (native).
I’ve tried manually adding modes via xrandr to no avail, I keep getting met with an error that says randr: Configure crtc 0 failed no matter what I attempt.
The monitor is a model LG 29WN600, running newest version of EOS on KDE – I’m using an AMD graphics card (AMDGPU drivers).
Any help would be appreciated, and I can provide any output needed from terminal stuff to help diagnose the problem, it’s driving me insane.
Are you using X11 or Wayland?
In my experience X11 often has problems with high or unusual resolutions which were all solved after I switched to Wayland.
What does this command show that the monitor supports.
xrandr --verbose
i got
afbeelding
but using wayland …
xrandr if you use xorg offcourse
otherwise download wlr-randr and check with this on wayland
Does xrandr not work on Wayland?
nope , you have to use wlr-randr for terminal stuf or that display settings that works on wayland…
Is that only for making changes? On Wayland xrandr --verbose does show this.
[ricklinux@rick-ms7c37 ~]$ xrandr --verbose
Screen 0: minimum 16 x 16, current 1920 x 1080, maximum 32767 x 32767
HDMI-A-1 connected primary 1920x1080+0+0 (0x23) normal (normal left inverted right x axis y axis) 530mm x 300mm
        Identifier: 0x21
        Timestamp:  26702
        Subpixel:   unknown
        Gamma:      1.0:1.0:1.0
        Brightness: 0.0
        Clones:
        CRTC:       0
        CRTCs:      0
        Transform:  1.000000 0.000000 0.000000
                    0.000000 1.000000 0.000000
                    0.000000 0.000000 1.000000
                   filter:
        RANDR Emulation: 1
        non-desktop: 0
                supported: 0, 1
  1920x1080 (0x23) 173.000MHz -HSync +VSync *current +preferred
        h: width  1920 start 2048 end 2248 total 2576 skew    0 clock  67.16KHz
        v: height 1080 start 1083 end 1088 total 1120           clock  59.96Hz
  1440x1080 (0x24) 129.000MHz -HSync +VSync
        h: width  1440 start 1528 end 1680 total 1920 skew    0 clock  67.19KHz
        v: height 1080 start 1083 end 1087 total 1120           clock  59.99Hz
  1400x1050 (0x25) 121.750MHz -HSync +VSync
        h: width  1400 start 1488 end 1632 total 1864 skew    0 clock  65.32KHz
        v: height 1050 start 1053 end 1057 total 1089           clock  59.98Hz
  1280x1024 (0x26) 109.000MHz -HSync +VSync
        h: width  1280 start 1368 end 1496 total 1712 skew    0 clock  63.67KHz
        v: height 1024 start 1027 end 1034 total 1063           clock  59.89Hz
  1280x960 (0x27) 101.250MHz -HSync +VSync
        h: width  1280 start 1360 end 1488 total 1696 skew    0 clock  59.70KHz
        v: height  960 start  963 end  967 total  996           clock  59.94Hz
  1152x864 (0x28) 81.750MHz -HSync +VSync
        h: width  1152 start 1216 end 1336 total 1520 skew    0 clock  53.78KHz
        v: height  864 start  867 end  871 total  897           clock  59.96Hz
  1024x768 (0x29) 63.500MHz -HSync +VSync
        h: width  1024 start 1072 end 1176 total 1328 skew    0 clock  47.82KHz
        v: height  768 start  771 end  775 total  798           clock  59.92Hz
  800x600 (0x2a) 38.250MHz -HSync +VSync
        h: width   800 start  832 end  912 total 1024 skew    0 clock  37.35KHz
        v: height  600 start  603 end  607 total  624           clock  59.86Hz
  640x480 (0x2b) 23.750MHz -HSync +VSync
        h: width   640 start  664 end  720 total  800 skew    0 clock  29.69KHz
        v: height  480 start  483 end  487 total  500           clock  59.38Hz
  320x240 (0x2c)  6.000MHz -HSync +VSync
        h: width   320 start  336 end  360 total  400 skew    0 clock  15.00KHz
        v: height  240 start  243 end  247 total  252           clock  59.52Hz
  1680x1050 (0x2d) 146.250MHz -HSync +VSync
        h: width  1680 start 1784 end 1960 total 2240 skew    0 clock  65.29KHz
        v: height 1050 start 1053 end 1059 total 1089           clock  59.95Hz
  1440x900 (0x2e) 106.500MHz -HSync +VSync
        h: width  1440 start 1528 end 1672 total 1904 skew    0 clock  55.93KHz
        v: height  900 start  903 end  909 total  934           clock  59.89Hz
  1280x800 (0x2f) 83.500MHz -HSync +VSync
        h: width  1280 start 1352 end 1480 total 1680 skew    0 clock  49.70KHz
        v: height  800 start  803 end  809 total  831           clock  59.81Hz
  1152x720 (0x30) 66.750MHz -HSync +VSync
        h: width  1152 start 1208 end 1320 total 1488 skew    0 clock  44.86KHz
        v: height  720 start  723 end  729 total  748           clock  59.97Hz
  960x600 (0x31) 45.250MHz -HSync +VSync
        h: width   960 start  992 end 1088 total 1216 skew    0 clock  37.21KHz
        v: height  600 start  603 end  609 total  624           clock  59.63Hz
  928x580 (0x32) 42.750MHz -HSync +VSync
        h: width   928 start  968 end 1056 total 1184 skew    0 clock  36.11KHz
        v: height  580 start  583 end  589 total  603           clock  59.88Hz
  800x500 (0x33) 30.750MHz -HSync +VSync
        h: width   800 start  824 end  896 total  992 skew    0 clock  31.00KHz
        v: height  500 start  503 end  509 total  521           clock  59.50Hz
  768x480 (0x34) 28.750MHz -HSync +VSync
        h: width   768 start  792 end  864 total  960 skew    0 clock  29.95KHz
        v: height  480 start  483 end  489 total  500           clock  59.90Hz
  720x480 (0x35) 26.750MHz -HSync +VSync
        h: width   720 start  744 end  808 total  896 skew    0 clock  29.85KHz
        v: height  480 start  483 end  493 total  500           clock  59.71Hz
  640x400 (0x36) 20.000MHz -HSync +VSync
        h: width   640 start  664 end  720 total  800 skew    0 clock  25.00KHz
        v: height  400 start  403 end  409 total  417           clock  59.95Hz
  320x200 (0x37)  5.000MHz -HSync +VSync
        h: width   320 start  336 end  360 total  400 skew    0 clock  12.50KHz
        v: height  200 start  203 end  209 total  212           clock  58.96Hz
  1600x900 (0x38) 118.250MHz -HSync +VSync
        h: width  1600 start 1696 end 1856 total 2112 skew    0 clock  55.99KHz
        v: height  900 start  903 end  908 total  934           clock  59.95Hz
  1368x768 (0x39) 85.250MHz -HSync +VSync
        h: width  1368 start 1440 end 1576 total 1784 skew    0 clock  47.79KHz
        v: height  768 start  771 end  781 total  798           clock  59.88Hz
  1280x720 (0x3a) 74.500MHz -HSync +VSync
        h: width  1280 start 1344 end 1472 total 1664 skew    0 clock  44.77KHz
        v: height  720 start  723 end  728 total  748           clock  59.86Hz
  1024x576 (0x3b) 46.500MHz -HSync +VSync
        h: width  1024 start 1064 end 1160 total 1296 skew    0 clock  35.88KHz
        v: height  576 start  579 end  584 total  599           clock  59.90Hz
  864x486 (0x3c) 32.500MHz -HSync +VSync
        h: width   864 start  888 end  968 total 1072 skew    0 clock  30.32KHz
        v: height  486 start  489 end  494 total  506           clock  59.92Hz
  720x400 (0x3d) 22.250MHz -HSync +VSync
        h: width   720 start  744 end  808 total  896 skew    0 clock  24.83KHz
        v: height  400 start  403 end  413 total  417           clock  59.55Hz
  640x350 (0x3e) 17.500MHz -HSync +VSync
        h: width   640 start  664 end  720 total  800 skew    0 clock  21.88KHz
        v: height  350 start  353 end  363 total  366           clock  59.77Hz
ah i didnt know i also dont have xwayland installed :slight_smile:
afbeelding
