Nano does now allow the user to set “modern” key bindings:
Command-line option --modernbindings (-/) makes ^Q quit, ^X cut,
^C copy, ^V paste, ^Z undo, ^Y redo, ^O open a file, ^W write a file,
^R replace, ^G find again, ^D find again backwards, ^A set the mark,
^T jump to a line, ^P show the position, and ^E execute.
You can totally customize nano’s keyboard shortcuts in its config. This is an old feature. I did so once and then got all mixed up whenever i needed to login into a remote machine that didn’t have my customizations.
In the end I decided it’s better to stick with the defaults.
This is a new option in nano. What I’m saying is: this possibility existed for years via config files. But not just a predefined “modern” keys layout. You have the option of setting any custom keybinding for nano’s actions.
Sorry, i should have written rather than just using an emote. I wasn’t sure if you’d seen that it was usable everywhere as long as you had the latest version
