Which module are you referring to blacklist?
It may be that this TP-Link T2U has a meditek chip. So i found another module in the AUR.
https://aur.archlinux.org/packages/mt7610u_wifi_sta/
Edit: Doesnât look like its been updated for a while. Iâll keep looking.
Couldnt I just type?
echo "blacklist rtl8xxxu"
In any case, doing this & reboot doesnt fix the issue....
You could also try this one. My thought is that it is a Realtek but it could also not be.
I read that and used
yay -S rtl8812au-dkms-git
Then went to https://github.com/nlkguy/archer-t2u-plus-linux/blob/main/change_interface_name.md
But when writing iwconfig, while only using TP Link it says
iwconfig
lo no wireless extensions.
When I have Internet with the other modem is
iwconfig
enp9s0 no wireless extensions.
wlan0 IEEE 802.11 ESSID:âMiFibra-A65Câ
Mode:Managed Frequency:2.412 GHz Access Point: 0C:8E:29:AE:A6:5E
Bit Rate=78 Mb/s Tx-Power=20 dBm
Retry short long limit:2 RTS thr:off Fragment thr:off
Power Management:off
Link Quality=54/70 Signal level=-56 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:44 Missed beacon:0
And I dont know how to use sudo nano.
This is an easy thing to fix. When you try it on a file, it opens up IN the terminal, and display the basic operation keys across the bottom of the screen. CTRL-X to exit and so on⌠It is included and suggested because it is simple to use, even without familiarity :grin"
You mean ^S, ^X,etc� Because I type it but nothing happens.
Nano is an editor. You just use sudo nano and path to the file. Make the change and to save is ctrl o and enter and to close is ctrl x. Or you can just use ctrl x.
example: sudo nano /etc/default/grub
This opens the default grub file used for booting parameters if you were to edit it using nano.
Hold the CTRL and tap the letter. I guess the ^x designation is a bit old school! (like me- and like nano)
What does inxi -n show? Iâm sure the TP-Link T2U Plus isnât showing.
So this is my ifconfig
enp9s0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 70:85:c2:3a:50:a5 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 2606 bytes 220852 (215.6 KiB)
TX packets 2606 bytes 220852 (215.6 KiB)
And my lsusb
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 002: ID 046a:0010 Cherry GmbH SmartBoard XX44
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 2357:0138 TP-Link 802.11ac NIC
Bus 001 Device 002: ID 18f8:0f99 [Maxxter] Optical gaming mouse
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
With these, what edits should I make, as https://github.com/nlkguy/archer-t2u-plus-linux/blob/main/change_interface_name.md says (If I ever needed)
"What does inxi -n show? Iâm sure the TP-Link T2U Plus isnât showing."
inxi -n show
Error 22: Unsupported option: show
Check -h for correct parameters.
Sorry inxi -n doesnât work?
Edit: Anyway it doesnât matter it shows the TP-Link under lsusb.
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
IF: enp9s0 state: down mac: 70:85:c2:3a:50:a5
Device-2: TP-Link 802.11ac NIC type: USB driver: usb-network
Itâs showing as usb-network for the module.
You donât need to edit anything.
Edit: Unless you are wanting to blacklist something.
I guess try this other one
yay rtl88xxau-aircrack-dkms-git
Edit: Reboot after
I FIXED MY ISSUE FINALLY
I just tried
yay -S rtl88x2bu-dkms-git
And then it started working, altought not connecting to a wifi, until I rebooted the PC, and now im posting using my TP LINK usb
Thank you for all your help!
PerfectâŚI thought it was a Realtek but didnât see these other packages. Glad itâs working now.
Edit: What does the hardware show it as now?
