My system wants to downgrade - Not sure how I broke it
Hello all,
Recently I’ve noticed I’m not receiving many updates. I manually ran eos-update --yay and got:
$ eos-update --yay
yay update with additional and useful checks
/usr/bin/eos-update: line 77: [: too many arguments
Updating...
[sudo] password for user:
:: Synchronising package databases...
 endeavouros                                                          28.4 KiB   118 KiB/s 00:00 [--------------------------------------------------------] 100%
 core is up to date
 extra is up to date
 community is up to date
 multilib is up to date
error: failed retrieving file 'core.db' from mirror.cov.ukservers.com : SSL connection timeout
error: failed retrieving file 'extra.db' from mirror.cov.ukservers.com : SSL connection timeout
error: failed retrieving file 'community.db' from mirror.cov.ukservers.com : SSL connection timeout
warning: too many errors from mirror.cov.ukservers.com, skipping for the remainder of this transaction
error: failed retrieving file 'multilib.db' from mirror.cov.ukservers.com : SSL connection timeout
warning: archlinux-keyring-20220831-1 is up to date -- skipping
warning: endeavouros-keyring-20230523-1 is up to date -- skipping
 there is nothing to do
warning: a52dec: local (0.8.0-1) is newer than extra (0.7.4-11)
warning: aalib: local (1.4rc5-15) is newer than extra (1.4rc5-14)
warning: abseil-cpp: local (20230125.1-2) is newer than community (20220623.0-1)
warning: zxing-cpp: local (2.0.0-2) is newer than extra (1.4.0-1)
resolving dependencies...
Package (2)                  Old Version  New Version  Net Change  Download Size
endeavouros/eos-rankmirrors  2.12-1       2.14-1         0.00 MiB       0.02 MiB
endeavouros/yad              12.3-1.1     13.0-1.1       0.06 MiB       0.21 MiB
Total Download Size:   0.23 MiB
Total Installed Size:  0.68 MiB
Net Upgrade Size:      0.06 MiB
So, it looks like the mirror used was inaccessible and everything installed was “newer” than what was available in the repos. I ran eos-rank-mirrors:
$ eos-rankmirrors --verbose
==> warning: file '/etc/eos-rankmirrors.conf': EOS_RANKMIRRORS_EXIT_CODE_VERBOSITY has unsupported value '', will use 'show'.
==> Info: extracting /var/cache/pacman/pkg/endeavouros-mirrorlist-23.5-1-any.pkg.tar.zst ...
==> Info: ranking EndeavourOS mirrors, please wait ...
  https://ca.gate.endeavouros.com/endeavouros/repo/$repo/$arch
  https://de.freedif.org/EndeavourOS/repo/$repo/$arch
  https://endeavour.remi.lu/repo/$repo/$arch
  https://fastmirror.pp.ua/endeavouros/repo/$repo/$arch
  https://ftp.acc.umu.se/mirror/endeavouros/repo/$repo/$arch
  https://md.mirrors.hacktegic.com/endeavouros/repo/$repo/$arch
  https://mirror.albony.xyz/endeavouros/repo/$repo/$arch
  https://mirror.alpix.eu/endeavouros/repo/$repo/$arch
  https://mirror.archlinux.tw/EndeavourOS/repo/$repo/$arch
  https://mirror.freedif.org/EndeavourOS/repo/$repo/$arch
  https://mirror.funami.tech/endeavouros/repo/$repo/$arch
  https://mirror.jingk.ai/endeavouros/repo/$repo/$arch
  https://mirror.jordanrey.me/endeavouros/repo/$repo/$arch
==> 'https://mirror.jordanrey.me/endeavouros/repo/$repo/$arch' connection failed after 30 seconds, continuing.
  https://mirror.moson.org/endeavouros/repo/$repo/$arch
  https://mirrors.gigenet.com/endeavouros/repo/$repo/$arch
==> 'https://mirrors.gigenet.com/endeavouros/repo/$repo/$arch' connection failed after 30 seconds, continuing.
  https://mirrors.jlu.edu.cn/endeavouros/repo/$repo/$arch
  https://mirrors.tuna.tsinghua.edu.cn/endeavouros/repo/$repo/$arch
==> 'https://mirrors.tuna.tsinghua.edu.cn/endeavouros/repo/$repo/$arch' connection failed after 30 seconds, continuing.
==> Results of ranking EndeavourOS mirrors:
==> Moving old EndeavourOS mirrorlist to /etc/pacman.d/endeavouros-mirrorlist.2023.06.07-22.08.47.
==> Writing new ranked EndeavourOS mirrorlist to /etc/pacman.d/endeavouros-mirrorlist.
Root Password:
==> New mirrorlist saved.
  Deleting temporary files: /tmp/tmp.2tLX8UZSUW /tmp/tmp.dF3784sik9j /tmp/tmp.dF3784sik9j.orig
Now yay does not complain about the mirror being unreachable, but it still complains that everything is a newer version than the repos:
$ yay
 endeavouros is up to date
 core is up to date
 extra is up to date
:: Searching AUR for updates...
:: Searching databases for updates...
 -> a52dec: local (0.8.0-1) is newer than extra (0.7.4-11)
 -> aalib: local (1.4rc5-15) is newer than extra (1.4rc5-14)
 -> abseil-cpp: local (20230125.1-2) is newer than community (20220623.0-1)
 -> zxing-cpp: local (2.0.0-2) is newer than extra (1.4.0-1)
 -> Packages not in AUR: adwaita-cursors  botan2  d-spy  db5.3  default-cursors  gcr-4  geocode-glib-2  geocode-glib-common  gnome-console  grub2-theme-endeavouros  inxi  js102  libcamera  libcamera-ipa  libdex  libgirepository  libgoa  liblc3  libpanel  libpipewire  libwireplumber  openssl-1.1  pipewire-audio  python-merge3  tinycompress  vte4  webkitgtk-6.0
 -> paper-icon-theme: local (1.5.0.832.aa3e8af-1) is newer than AUR (1.5.0-3)
I’m not sure what I did to end up here. How can I force a full clean repository database download and make sure I’m on the proper “stable” channel?
try to update your arch mirrors too, you can update it also with the welcome app.
I ran “welcome” and pressed the “Update mirrors (Arch, reflector-simple)” button and got:
################# Arch Linux mirrorlist generated by Reflector #################
# With:       reflector --verbose -c GB --protocol https --sort rate --latest 10 --download-timeout 5
# When:       2023-06-07 22:08:44 UTC
# From:       https://archlinux.org/mirrors/status/json/
# Retrieved:  2023-06-07 22:08:38 UTC
# Last Check: 2023-06-07 21:12:04 UTC
## United Kingdom
Server = https://mirrors.gethosted.online/archlinux/$repo/os/$arch
## United Kingdom
Server = https://mirror.netweaver.uk/archlinux/$repo/os/$arch
## United Kingdom
Server = https://mirrors.melbourne.co.uk/archlinux/$repo/os/$arch
## United Kingdom
Server = https://mirror.bytemark.co.uk/archlinux/$repo/os/$arch
## United Kingdom
Server = https://lon.mirror.rackspace.com/archlinux/$repo/os/$arch
## United Kingdom
Server = https://repo.slithery.uk/$repo/os/$arch
## United Kingdom
Server = https://mirrors.ukfast.co.uk/sites/archlinux.org/$repo/os/$arch
## United Kingdom
Server = https://mirror.infernocomms.net/archlinux/$repo/os/$arch
## United Kingdom
Server = https://www.mirrorservice.org/sites/ftp.archlinux.org/$repo/os/$arch
I pressed the Save to /etc/pacman/mirrorlist button.
I still get the same output when running yay (nothing to do because everything installed is newer)…
Try this:
yay -S rate-mirrors
rate-mirrors arch --max-delay 7200 | sudo tee /etc/pacman.d/mirrorlist
sudo pacman -Syu
Ok, this seems to have worked. A ton of stuff is now upgrading:
Package (151)                   Old Version                   New Version                   Net Change  Download Size
extra/a52dec                    0.8.0-1                       0.8.0-2                         0.00 MiB       0.05 MiB
extra/aalib                     1.4rc5-15                     1.4rc5-16                       0.00 MiB       0.13 MiB
extra/abseil-cpp                20230125.1-2                  20230125.3-1                    0.01 MiB       1.08 MiB
extra/alsa-card-profiles        1:0.3.71-1                    1:0.3.71-2                      0.00 MiB       0.03 MiB
core/archlinux-keyring          20220831-1                    20230504-1                      0.05 MiB
extra/aribb24                                                 1.0.3-3                         0.12 MiB       0.05 MiB
core/ca-certificates-mozilla    3.89.1-1                      3.90-1                          0.00 MiB       0.35 MiB
extra/chromium                  114.0.5735.45-1               114.0.5735.106-1                0.00 MiB      90.02 MiB
extra/containerd                1.7.1-1                       1.7.2-1                         0.09 MiB      26.00 MiB
extra/cups                      1:2.4.2-7                     1:2.4.4-1                       0.01 MiB       5.18 MiB
core/curl                       8.1.1-2                       8.1.2-1                         0.00 MiB       1.16 MiB
extra/dav1d                     1.2.0-1                       1.2.1-1                         0.00 MiB       0.61 MiB
extra/dbus-python               1.2.18-5                      1.3.2-2                        -4.73 MiB       0.12 MiB
extra/discord                   0.0.27-1                      0.0.27-2                        0.00 MiB      68.10 MiB
extra/djvulibre                 3.5.28-4                      3.5.28-5                        0.14 MiB       1.02 MiB
extra/dtools                    2.103.1-1                     2.104.0-1                      -0.65 MiB       2.15 MiB
extra/electron24                                              24.4.0-1                      207.41 MiB      59.25 MiB
extra/element-desktop           1.11.31-3                     1.11.32-1                       0.05 MiB       4.03 MiB
extra/element-web               1.11.31-3                     1.11.32-1                      -0.98 MiB      16.63 MiB
extra/exempi                    2.6.3-1                       2.6.3-2                         0.04 MiB       0.54 MiB
extra/firefox                   113.0.2-1                     114.0-1                         1.24 MiB      64.94 MiB
extra/fribidi                   1.0.13-1                      1.0.13-2                        0.03 MiB       0.07 MiB
core/gc                         8.2.2-1                       8.2.4-1                         0.00 MiB       0.23 MiB
extra/git                       2.40.1-1                      2.41.0-1                        0.84 MiB       6.75 MiB
extra/gnome-connections         44.1-1                        44.1-2                          0.04 MiB       0.18 MiB
extra/gnome-shell               1:44.1-3                      1:44.2-1                        0.01 MiB       1.75 MiB
extra/gsound                    1.0.3-2                       1.0.3-3                         0.00 MiB       0.04 MiB
extra/gst-libav                 1.22.3-2                      1.22.3-4                        0.00 MiB       0.09 MiB
extra/gst-plugin-gtk            1.22.3-2                      1.22.3-4                        0.00 MiB       0.04 MiB
extra/gst-plugin-pipewire       1:0.3.71-1                    1:0.3.71-2                      0.00 MiB       0.05 MiB
extra/gst-plugins-bad           1.22.3-2                      1.22.3-4                        0.00 MiB       1.09 MiB
extra/gst-plugins-bad-libs      1.22.3-2                      1.22.3-4                        0.00 MiB       2.40 MiB
extra/gst-plugins-base          1.22.3-2                      1.22.3-4                        0.00 MiB       0.31 MiB
extra/gst-plugins-base-libs     1.22.3-2                      1.22.3-4                        0.00 MiB       2.18 MiB
extra/gst-plugins-good          1.22.3-2                      1.22.3-4                        0.00 MiB       2.18 MiB
extra/gst-plugins-ugly          1.22.3-2                      1.22.3-4                       -0.03 MiB       0.21 MiB
extra/gstreamer                 1.22.3-2                      1.22.3-4                        0.00 MiB       1.79 MiB
extra/gtk-update-icon-cache     1:4.10.3-3                    1:4.10.4-1                      0.00 MiB       0.02 MiB
extra/gtk4                      1:4.10.3-3                    1:4.10.4-1                      0.00 MiB       5.96 MiB
extra/hplip                     1:3.23.3-3                    1:3.23.5-1                      0.66 MiB      22.06 MiB
core/hwdata                     0.370-1                       0.371-1                         0.03 MiB       1.55 MiB
extra/imagemagick               7.1.1.10-1                    7.1.1.11-2                     -0.21 MiB       8.13 MiB
extra/imath                     3.1.8-1                       3.1.9-1                        -0.02 MiB       4.02 MiB
extra/lapce                     0.2.7-1                       0.2.8-1                         0.09 MiB      19.34 MiB
multilib/lib32-curl             8.1.1-1                       8.1.2-1                         0.00 MiB       0.30 MiB
multilib/lib32-libx11           1.8.4-1                       1.8.5-1                         0.00 MiB       0.62 MiB
multilib/lib32-libxcrypt        4.4.33-1                      4.4.34-1                        0.00 MiB       0.07 MiB
multilib/lib32-ncurses          6.4-1                         6.4_20230520-1                  0.02 MiB       0.23 MiB
multilib/lib32-nss              3.89.1-1                      3.90-1                          0.00 MiB       1.13 MiB
multilib/lib32-openssl          1:3.0.8-1                     1:3.0.9-1                       0.00 MiB       1.76 MiB
multilib/lib32-systemd          253.4-1                       253.5-1                         0.03 MiB       0.67 MiB
extra/libappindicator-gtk3      12.10.0.r298-1                12.10.0.r298-2                  0.00 MiB       0.05 MiB
extra/libatasmart               0.19-5                        0.19-6                          0.00 MiB       0.03 MiB
extra/libavc1394                0.5.4-5                       0.5.4-6                         0.00 MiB       0.03 MiB
extra/libblockdev               2.28-2                        2.28-4                          1.50 MiB       0.27 MiB
extra/libcaca                   0.99.beta20-1                 0.99.beta20-2                   1.31 MiB       0.41 MiB
extra/libcdio-paranoia          10.2+2.0.1-2                  10.2+2.0.1-3                   -0.01 MiB       0.06 MiB
extra/libcups                   1:2.4.2-7                     1:2.4.4-1                       0.00 MiB       0.27 MiB
extra/libdatrie                 0.2.13-2                      0.2.13-4                        0.41 MiB       0.11 MiB
extra/libdbusmenu-glib          16.04.0-5                     16.04.0.r498-1                  0.31 MiB       0.09 MiB
extra/libdbusmenu-gtk3          16.04.0-5                     16.04.0.r498-1                  0.09 MiB       0.05 MiB
extra/libdc1394                 2.2.6-2                       2.2.6-3                         1.12 MiB       0.23 MiB
extra/libdca                    0.0.7-1                       0.0.7-2                         0.01 MiB       0.10 MiB
extra/libdex                    0.2.0-1                       0.2.0-2                         0.00 MiB       0.07 MiB
extra/libdv                     1.0.0-10                      1.0.0-11                        0.00 MiB       0.08 MiB
extra/libdvdnav                 6.1.1-1                       6.1.1-2                         0.00 MiB       0.05 MiB
extra/libdvdread                6.1.3-1                       6.1.3-2                         0.00 MiB       0.10 MiB
extra/libgme                    0.6.3-2                       0.6.3-4                         0.43 MiB       0.66 MiB
extra/libgtop                   2.40.0+2+g31db82ef-2          2.41.1-1                        0.02 MiB       0.20 MiB
extra/libiptcdata               1.0.5-1                       1.0.5-2                         0.03 MiB       0.07 MiB
extra/liblouis                  3.25.0-2                      3.25.0-3                        0.05 MiB       2.37 MiB
extra/libmanette                0.2.6-4                       0.2.6-5                         0.00 MiB       0.05 MiB
core/libmicrohttpd              0.9.76-1                      0.9.77-1                        0.00 MiB       0.23 MiB
extra/libmpcdec                 1:0.1+r475-3                  1:0.1+r475-4                    0.00 MiB       0.04 MiB
extra/libmpeg2                  0.5.1-7                       0.5.1-8                         0.01 MiB       0.08 MiB
extra/libnautilus-extension     44.2-1                        44.2.1-1                        0.00 MiB       0.03 MiB
extra/libosinfo                 1.10.0-2                      1.10.0-3                       -0.02 MiB       0.27 MiB
extra/libphobos                 1:2.103.1-1                   1:2.104.0-1                    -0.19 MiB       6.15 MiB
extra/libpipewire               1:0.3.71-1                    1:0.3.71-2                      0.00 MiB       0.36 MiB
extra/libpwquality              1.4.5-2                       1.4.5-3                         0.00 MiB       0.09 MiB
extra/librsvg                   2:2.56.0-1                    2:2.56.1-1                     -4.33 MiB       2.39 MiB
extra/libsynctex                2023.66539-1                  2023.66984-6                    0.00 MiB       0.05 MiB
extra/libthai                   0.1.29-2                      0.1.29-3                        0.57 MiB       0.27 MiB
extra/libtheora                 1.1.1-5                       1.1.1-6                         0.01 MiB       0.31 MiB
extra/libva-utils               2.18.1-1                      2.18.2-1                        0.00 MiB       0.51 MiB
extra/libvirt                   1:9.3.0-1                     1:9.4.0-1                      -0.42 MiB       8.28 MiB
extra/libwbclient                                             4.18.3-1                        0.12 MiB       0.04 MiB
extra/libx11                    1.8.4-1                       1.8.5-1                        -0.15 MiB       2.04 MiB
core/libxcrypt                  4.4.33-1                      4.4.34-1                        0.00 MiB       0.08 MiB
extra/libxklavier               5.4-4                         5.4-5                           0.00 MiB       0.07 MiB
core/linux                      6.3.4.arch1-1                 6.3.6.arch1-1                   0.06 MiB     146.60 MiB
core/linux-headers              6.3.4.arch1-1                 6.3.6.arch1-1                   0.01 MiB      29.19 MiB
extra/luajit                    2.1.0.beta3.r471.g224129a8-1  2.1.0.beta3.r481.g51fb2f2c-1    0.00 MiB       0.31 MiB
extra/mailcap                   2.1.53-1                      2.1.54-1                        0.01 MiB       0.03 MiB
extra/mjpegtools                2.2.1-1                       2.2.1-2                        -0.06 MiB       0.71 MiB
core/mkinitcpio                 35.2-1                        36-1                            0.00 MiB       0.05 MiB
extra/mutter                    44.1+r2+g82bd40dcbc-1         44.2-1                          0.00 MiB       2.64 MiB
extra/nautilus                  44.2-1                        44.2.1-1                        0.00 MiB       2.26 MiB
core/ncurses                    6.4-1                         6.4_20230520-1                  0.00 MiB       1.16 MiB
extra/neovim                    0.9.0-2                       0.9.1-1                         0.03 MiB       6.11 MiB
core/nettle                     3.9-1                         3.9.1-1                         0.00 MiB       0.45 MiB
extra/networkmanager-openvpn    1.10.2-1                      1.10.2-2                       -0.02 MiB       0.29 MiB
extra/noto-fonts                20230501-1                    20230601-1                      0.00 MiB      26.94 MiB
core/nss                        3.89.1-1                      3.90-1                          0.00 MiB       1.55 MiB
extra/ntp                       4.2.8.p15-3                   4.2.8.p17-1                     0.03 MiB       1.79 MiB
extra/obsidian                  1.3.4-1                       1.3.5-1                         0.04 MiB       5.02 MiB
extra/openexr                   3.1.7-2                       3.1.8-1                         1.68 MiB       1.19 MiB
core/openssl                    3.0.8-1                       3.0.9-1                         0.01 MiB       5.11 MiB
core/openssl-1.1                1.1.1.t-1                     1.1.1.u-1                      -0.01 MiB       1.76 MiB
extra/orc                       0.4.33-1                      0.4.34-1                        0.00 MiB       0.25 MiB
extra/osinfo-db                 20230308-1                    20230518-1                      0.10 MiB       0.20 MiB
extra/pipewire                  1:0.3.71-1                    1:0.3.71-2                      0.00 MiB       0.62 MiB
extra/pipewire-alsa             1:0.3.71-1                    1:0.3.71-2                      0.00 MiB       0.00 MiB
extra/pipewire-audio            1:0.3.71-1                    1:0.3.71-2                      0.00 MiB       1.05 MiB
extra/pipewire-jack             1:0.3.71-1                    1:0.3.71-2                      0.00 MiB       0.15 MiB
extra/pipewire-pulse            1:0.3.71-1                    1:0.3.71-2                      0.00 MiB       0.16 MiB
extra/pipewire-zeroconf         1:0.3.71-1                    1:0.3.71-2                      0.00 MiB       0.05 MiB
extra/python-jaraco.functools   3.6.0-3                       3.7.0-1                         0.00 MiB       0.02 MiB
extra/python-sphinx             7.0.1-1                       7.0.1-2                         0.36 MiB       2.40 MiB
extra/python-typing_extensions  4.6.2-1                       4.6.3-1                         0.00 MiB       0.06 MiB
extra/qemu-guest-agent          8.0.0-1                       8.0.2-1                         0.00 MiB       0.30 MiB
extra/qt5-base                  5.15.9+kde+r154-1             5.15.9+kde+r155-1               0.00 MiB      13.09 MiB
extra/qt6-base                  6.5.1-1                       6.5.1-2                         0.01 MiB      13.42 MiB
extra/rust                      1:1.69.0-3                    1:1.70.0-1                      6.84 MiB      86.32 MiB
extra/rust-analyzer             20230522-1                    20230605-1                      0.15 MiB       6.54 MiB
extra/rust-src                  1:1.69.0-3                    1:1.70.0-1                      0.08 MiB       2.48 MiB
extra/signal-desktop            6.19.0-1                      6.20.1-1                        0.25 MiB     107.05 MiB
extra/simple-scan               44.0-1                        44.0-2                          0.00 MiB       1.07 MiB
extra/smbclient                 4.16.4-3                      4.18.3-1                        0.28 MiB       6.75 MiB
extra/startup-notification      0.12-7                        0.12-8                          0.00 MiB       0.02 MiB
multilib/steam                  1.0.0.76-1                    1.0.0.78-1                      0.06 MiB       3.64 MiB
extra/syncthing                 1.23.4-2                      1.23.5-1                        0.03 MiB       8.17 MiB
core/systemd                    253.4-1                       253.5-1                         0.31 MiB       7.28 MiB
core/systemd-libs               253.4-1                       253.5-1                         0.04 MiB       1.00 MiB
core/systemd-sysvcompat         253.4-1                       253.5-1                         0.00 MiB       0.01 MiB
extra/tmux                      3.3_a-3                       3.3_a-7                         0.00 MiB       0.43 MiB
extra/tracker3                  3.5.2-1                       3.5.3-1                         0.00 MiB       0.71 MiB
extra/udisks2                   2.9.4-1                       2.9.4-4                        -1.17 MiB       0.90 MiB
extra/unrar                     1:6.2.7-1                     1:6.2.8-1                       0.00 MiB       0.14 MiB
core/usbutils                   015-2                         015-3                           0.01 MiB       0.09 MiB
extra/vlc                       3.0.18-9                      3.0.18-10                       0.13 MiB      11.55 MiB
extra/vte-common                0.72.1-1                      0.72.2-1                        0.00 MiB       0.06 MiB
extra/vte3                      0.72.1-1                      0.72.2-1                        0.01 MiB       0.29 MiB
extra/vte4                      0.72.1-1                      0.72.2-1                        0.01 MiB       0.28 MiB
extra/weston                    12.0.0-1                      12.0.1-1                        0.00 MiB       1.28 MiB
extra/wildmidi                  0.4.5-1                       0.4.5-2                         0.00 MiB       0.09 MiB
extra/xdg-user-dirs-gtk         0.11-1                        0.11-2                          0.00 MiB       0.05 MiB
extra/xorg-xrdb                 1.2.1-1                       1.2.2-1                         0.00 MiB       0.02 MiB
extra/xorg-xwayland             23.1.1-1                      23.1.2-1                        0.00 MiB       0.90 MiB
extra/xterm                     381-1                         382-1                           0.00 MiB       0.43 MiB
extra/zeromq                    4.3.4-2                       4.3.4-4                        -0.25 MiB       0.55 MiB
Total Download Size:    966.27 MiB
Total Installed Size:  3507.90 MiB
Net Upgrade Size:       214.20 MiB
:: Proceed with installation? [Y/n]
Yeah, looks better now.
